Stopping plug-ins when no longer used [message #307171] |
Tue, 15 August 2006 05:21  |
Originally posted by: muell.da-kulmi.de
are plug-ins stopped automatically when their classes are no longer
used? When using Eclipse-LazyStart, plug-Ins are only activated on demand.
But what happens, if the classes of a plug-in are no longer in use? Does
Eclipse stop the plug-ins automatically? Should the programmer realize
this situation and stop them him-/herself?
I am asking because I assume an activated plug-in consumes memory, and
working with an application for a longer time would cause many plug-ins
to be activated - so the application would probably need a lot of memory.
Stefan Koelmann
Re: Stopping plug-ins when no longer used [message #307189 is a reply to message #307171] |
Tue, 15 August 2006 09:11  |
Eclipse won't automatically stop a plugin ... over time, it's possible
to have more and more active.
But if a plugin is no longer used, then unless it holds resources in its
activator class I don't think it's holding more memory that it takes to
have the classes loaded.
If you know for sure it's not used, you can stop the plugin
programmatically.
Later,
PW
FUDForum. Page generated in 0.08491 seconds
