Home » Eclipse Projects » Eclipse Platform » Common Navigator, PopUp Menu , import wizard
Common Navigator, PopUp Menu , import wizard [message #306424] Fri, 28 July 2006 12:07
Originally posted by: mgervais.signaturegenetics.com
I'm trying to use common navigator and I'd like to have some help about
wizard. I've created a wizard to import a project(from a database) in my
navigator. but when I do a right clikc in the navigator nothing is
displayed, so I don't know what is missing. I join my plugin.xml if somebody
has an idea... I cannot find the answer in examples. And My other questions
is how to implements saveables. because I've set providesSaveables to true
for the navigatorcontent but I don't know what I've to do with that, because
I'd like to save the status of my navigator in a specific file.
thanks
Mickael
<?eclipse version="3.2"?>
<plugin>
<extension point="org.eclipse.ui.newWizards">
<category id="com.seryx.eclipse.project.wizards.project"
name="Project" />
<wizard canFinishEarly="true"
category="com.seryx.eclipse.project.wizards.project"
class=" com.seryx.eclipse.folder.internal.ui.internal.wizards.NewPro jectWizard "
hasPages="true" icon="icons/full/etool16/newprj_wiz.gif"
id="com.seryx.eclipse.project.ui.internal.ProjectNewWizard"
name="New Project" project="false">
<description>Create a new Project</description>
</wizard>
</extension>
<extension point="org.eclipse.ui.views">
<view name="Project Navigator"
class=" com.seryx.eclipse.folder.internal.ui.internal.navigator.Proj ectNavigatorView "
id="com.seryx.eclipse.project.ui.internal.ProjectNavigator" >
</view>
</extension>
<extension point="org.eclipse.ui.navigator.navigatorContent">
<navigatorContent
activeByDefault="true"
contentProvider=" com.seryx.eclipse.folder.internal.ui.ProjectNavigatorContent Provider "
id="com.seryx.eclipse.project.ui.content"
labelProvider=" com.seryx.eclipse.folder.internal.ui.ProjectNavigatorLabelPr ovider "
name="Content Provider"
priority="normal"
providesSaveables="true">
<enablement>
<adapt
type="com.seryx.eclipse.folder.internal.ui.ProjectManager" />
</enablement>
<commonWizard
menuGroupId="group.port"
type="import"
wizardId="com.seryx.eclipse.project.ui.wizard.project">
<enablement>
<count value="*"/>
</enablement>
</commonWizard>
</navigatorContent>
</extension>
<extension point="org.eclipse.ui.navigator.viewer">
<viewerContentBinding
viewerId="com.seryx.eclipse.project.ui.internal.ProjectNavigator ">
<includes>
<contentExtension isRoot="true"
pattern="com.seryx.eclipse.project.ui.content" />
</includes>
</viewerContentBinding>
<viewer
<popupMenu
allowsPlatformContributions="true"
id="com.seryx.eclipse.project.ui.menu">
<insertionPoint name="group.new" separator="true" />
<insertionPoint name="group.open" separator="true" />
<insertionPoint name="group.edit" separator="true" />
<insertionPoint name="group.show" separator="true" />
<insertionPoint name="group.port" separator="false" />
<insertionPoint name="group.search" separator="true" />
<insertionPoint name="additions" separator="true" />
<insertionPoint name="group.properties"
separator="true" />
</popupMenu>
</viewer>
</extension>
<extension point="org.eclipse.ui.importWizards">
<category id="com.seryx.eclipse.project" name="Project" />
<wizard category="com.seryx.eclipse.project"
class=" com.seryx.eclipse.folder.internal.ui.internal.wizards.Import ProjectWizard "
icon="icons/full/etool16/importdir_wiz.gif"
id="com.seryx.eclipse.project.ui.wizard.project"
name="Import Project From Database" />
</extension>
</plugin>
Previous Topic:build the feature.xml
Next Topic:The URL used to update features downloaded from a site should be the URL given to download it origin
Current Time: Tue Jul 22 15:29:52 EDT 2025
Powered by FUDForum. Page generated in 0.03338 seconds
