Home » Eclipse Projects » Eclipse Platform » Error on displaying Problem Marker in Problem View in Eclipse 3.2
Error on displaying Problem Marker in Problem View in Eclipse 3.2 [message #306405] |
Thu, 27 July 2006 22:49  |
Originally posted by: zzhang.numericatech.com
I put Problem Markers in my editor, and when I try to open the "Problem
View", an error dialog will pop up
showing
"An error has occured. See error log for more details."
And in the problem view, I can see the error message, but the node category
"error" has not text or icon.
the problem entry does have an icon (red square) though (insteadof a red
circle with white cross in Eclipse 3.1)
And this has been tested working for me in Eclipse 3.1.
The log file shows the stacktrace of
!ENTRY org.eclipse.jface 4 2 2006-07-27 15:26:03.859
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:150)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:126)
org.eclipse.jface.resource.ResourceManager.createImage(Resou rceManager.java:93)
org.eclipse.ui.views.markers.internal.FieldSeverityAndMessag e.getImage(FieldSeverityAndMessage.java:65)
org.eclipse.ui.views.markers.internal.TableViewLabelProvider .getColumnImage(TableViewLabelProvider.java:49)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:310)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:95)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:840)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:465)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1955)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:744)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:2427)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1640)
org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(T reeViewer.java:955)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1616)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1571)
org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:1415)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1323)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1413)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1370)
org.eclipse.ui.views.markers.internal.MarkerView$UpdateJob.r unInUIThread(MarkerView.java:222)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at com.rcp.Application.run(Application.java:1
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:7
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:6
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
I also found a similar report from EclipsePluginCentral
http://www.eclipseplugincentral.com/PNphpBB2-printview-t-354 2-start-0.html
Is this a bug for Eclipse 3.2?
Any help is appreciated!!
Thanks.
Sincerely,
Stan
Re: Error on displaying Problem Marker in Problem View in Eclipse 3.2 [message #306440 is a reply to message #306438] |
Fri, 28 July 2006 15:39   |
Dear Walter,
Yes, you're right. I use debug, it seems the Eclipse failed to get
ImageDescriptor for this string
IDEInternalWorkbenchImages.IMG_ETOOL_PROBLEM_CATEGORY
while calling in FieldSeverityAndMessage.getImage
return
JFaceResources.getResources().createImage(IDEInternalWorkben chImages.getImageDescriptor(
IDEInternalWorkbenchImages.IMG_ETOOL_PROBLEM_CATEGORY)
Below is the code I created Marker (again, it has no problem under Eclipse
3.1. It seems the introduction of the category caused the error).
Map<String, Object> map = new HashMap<String, Object>();
MarkerUtilities.setLineNumber(map, lineNumber);
MarkerUtilities.setMessage(map, e.getMessage());
map.put(IMarker.LOCATION, file.getFullPath().toString());
Integer charStart = new Integer(document.getLineOffset(lineNumber-1));
if (charStart != null)
map.put(IMarker.CHAR_START, charStart);
Integer charEnd = charStart;
charEnd = new Integer(document.getLineOffset(lineNumber)-2);
if (charEnd != null)
map.put(IMarker.CHAR_END, charEnd);
map.put(IMarker.SEVERITY, new Integer(IMarker.SEVERITY_ERROR));
map.put(IMarker.TRANSIENT, true);
MarkerUtilities.createMarker(file, map, IMarker.PROBLEM);
Thanks again.
Sincerely,
Stan
"Walter Harley" <wharley@bea.com> wrote in message
news:eadlft$bjm$1@utils.eclipse.org...
> "zzhang" <zzhang@numericatech.com> wrote in message
> news:eabtvg$30f$1@utils.eclipse.org...
>> showing
>> category "error" has not text or icon.
>> !STACK 0
>> at
>> at
>> at
> Sounds like it is trying to get an icon to attach to the marker, and
> failing to find it. Can you post a short excerpt of the code that you are
> using to create the marker?
Re: Error on displaying Problem Marker in Problem View in Eclipse 3.2 [message #306633 is a reply to message #306440] |
Thu, 03 August 2006 03:53  |
zzhang wrote:
>Dear Walter,
>return
Well, you're doomed to fail: when using internal code you must expect to
be broken at any time.
Dani
>Thanks again.
>Sincerely,
>Stan
>>>Hi,
>>>showing
>>>!STACK 0
>>>at
>>>at
>>>at
Current Time: Sat Jul 19 01:22:52 EDT 2025
Powered by FUDForum. Page generated in 0.03652 seconds
