Home » Modeling » OCL » Suggestion of generalizing Ecore CollectionTypes
Suggestion of generalizing Ecore CollectionTypes [message #30810] Tue, 26 June 2007 12:27 Go to next message
Originally posted by: alu2526.etsii.ull.es
Hi Christian,
I'm here again :D.
Im working in the OMStandardLibrary at this moment, and i have realized of
some things that i wanted to commment with you.
When you specify the OCL generic metamodel with the EcoreBinding, you finish
the generalization stablishing that the type of the collection's elemente
are EClassifier. I think that you could take adventage of the use of
generics metaelements in EMF 2.3, and allow clients to specify the type of
the collection's elements.
Instead of stablishing in the OCLEcore metamodel that:
CollectionType -> EDataType, CollectionType<EClassifier, EOperation>
you could do it in this way:
CollectionType<C extends EClassifier> -> EDataType, CollectionType<C,
EOperation>
In addition of being is more flexible, this generalization is needed for me,
since im working with OCLEcore metamodel, and i have some new types (List<T>
or DictionaryType<KeyT, T>) that should extend OCLEcore CollectionType, and
it doesnt allow element type specification.
i think that this generelization would be useful for UML Metamodel Binding
too.
Adolfo.
Re: Suggestion of generalizing Ecore CollectionTypes [message #30847 is a reply to message #30810] Tue, 26 June 2007 14:30 Go to previous messageGo to next message
Hi, Adolfo,
I don't quite understand. Your specializations List<T> and
DictionaryType<KeyT, T> should be able to extend
org.eclipse.ocl.ecore.CollectionType as it is. Why would you need to
redefine its type parameter substitution? This substitution is only there
to serve the OCL parser, and shouldn't be particularly relevant to clients.
The type parameter of CollectionType<C> doesn't represent the type of the
collection's elements, as do the T and KeyT parameters in your
specializations. It ties the Ecore binding of the CollectionType to the
same <C> parameter used throughout the entire OCL API, so this would
require the entire binding of "what is the representation of OCL
Classifier" to be similarly specified as <C extends EClassifier>, but then
other complications of unsafe casting arise because the binding now is an
unknown type.
Can you elaborate some more on what you are trying to do?
Christian
Adolfo S�chez-Barbudo Herrera wrote:
> Hi Christian,
> I'm here again :D.
> finish the generalization stablishing that the type of the collection's
> elemente are EClassifier. I think that you could take adventage of the use
> of generics metaelements in EMF 2.3, and allow clients to specify the type
> of the collection's elements.
> EOperation>
> me, since im working with OCLEcore metamodel, and i have some new types
> (List<T> or DictionaryType<KeyT, T>) that should extend OCLEcore
> CollectionType, and it doesnt allow element type specification.
> too.
> Adolfo.
Re: Suggestion of generalizing Ecore CollectionTypes [message #31125 is a reply to message #30847] Thu, 28 June 2007 05:46 Go to previous messageGo to next message
Hi Christian,
Well, i have been mixing concepts and ideas around the collections (and
generics) and the type of the collection's elements.
Some more comments.
> clients.
Yes my idea was, having generic Lists and Dictionary Types metaelements. But
im thinking that i cant do it since the CollectionType is not generic.
> unknown type.
Yes you are right, and that was my confusion, and perhaps we shouldnt mix
the concept of what is representing the C in the entire OCL API with the
type of collection's elements. But indeed, C is established in
CollectionType<C, O> in order to have the type of the collection's elements
and not for another thing,
Re: Suggestion of generalizing Ecore CollectionTypes [message #31228 is a reply to message #31125] Thu, 28 June 2007 10:31 Go to previous messageGo to next message
Hi, Adolfo,
The concrete syntax of OCL collections looks generic:
let apples : Set(Apple) = ... in ...
but in the Abstract Syntax metamodel, these types are not generic. The
CollectionType metaclass has an association to Classifier, named
elementType at its end. The element type is not a template parameter.
To satisfy the need to be able to target different metamodels with different
metaclasses representing the "classifier" concept, the MDT OCL
implementation defines a generic CollectionType parameterized by the
metaclass denoting classifiers. This type parameter is used as the type of
the elementType association end. Thus, CollectionType<EClassifier>
indicates that the metatype of the element type of a collection-type
instance is EClassifier. Different instances of
CollectionType<EClassifier> have different actual element types, which are
any kind of EClassifier.
The generic metaclass
- elementType : C
is bound to Ecore as:
- elementType : EClassifier
and has instances such as
Set(Apple)
- elementType = FruitPackage.Literals.APPLE // an EClass
Sequence(EDate)
- elementType = EcorePackage.Literals.EDATE // an EDataType
Other specific comments in-line, below.
Christian
> Hi Christian,
> Some more comments.
>> there to serve the OCL parser, and shouldn't be particularly relevant to
>> clients.
> But im thinking that i cant do it since the CollectionType is not generic.
>> then other complications of unsafe casting arise because the binding now
>> is an unknown type.
> elements and not for another thing, Am i wrong ?
Not exactly: C is established to have the *metatype* of the type of the
> When in java5 you have an EList<String> better than a EList, you are
> saying that the elements of the list are Strings better than Object.
> in EMF 2.3 you could say that CollectionType<StringLiteralExp> better than
> a CollectionType, and you would be saying that elements of the collection
> are
> StringLiteraExp (then EClass, then EClassifier) better than EClassifiers.
Generic types are good for more than just collections, though. The case of
EList<E> is a model class (M1 level) that uses a generic type parameter as
the type of its element list. CollectionType<C, O> is a metaclass (M2
level) that uses a generic type parameter as the type of its elementType
property, i.e., as the type of the type of its elements.
> So, since we dont have generic CollectionTypes, an example of a definition
> of a DictionaryType operation, such as DictionaryType<KeyT,T>::get(k:KeyT)
> : T, i would have to define it in my metamodel as a
> DictionaryType<KeyT>::get(k:KeyT): EClassifier.
No, I think you would have:
DictionaryType<KeyT, T> -> CollectionType
- get(k : KeyT) : T
Actually, more to the point, it would probably make more sense if you really
want the dictionary to fit in with other OCL collection types, to define it
as a metaclass:
DictionaryType -> SetType
- keyType : EClassifier
using a property of type EClassifier to represent the key type as
CollectionType does for the elementType. Then, a particular instance of
this might be
Dictionary(Apple, Color)
- keyType = FruitPackage.Literals.APPLE // an EClass
- elementType = FruitPackage.Literals.COLOR // an EEnum
This instance of the DictionaryType metaclass is, then, an EDataType
describing a dictionary of Fruit-Color mappings.
> Best Regards,
> Adolfo.
Re: Suggestion of generalizing Ecore CollectionTypes [message #31263 is a reply to message #31228] Thu, 28 June 2007 11:52 Go to previous messageGo to next message
Well, eventually, i think that my fault is that i m thinking in a bad
M-level. Im trying to generalize the types at M2 level when it should be
done at M1 level.
I will work more about this questions, and i'll go back again with my
doubts/conclusions ;).
Whereas, i'll set the DictionaryType as follows:
DictionaryType -> CollectionType.
keyType: EClassifier.
+ get(k:EClassifier) : EClassifier.
Thanks a lot for your replies.
Greetings,
Adolfo.
> different
> of
> - elementType : C
> Set(Apple)
> Sequence(EDate)
> Cheers,
> Christian
> Adolfo S?chez-Barbudo Herrera wrote:
>> Hi Christian,
>> Some more comments.
>>> clients.
>> generic.
>>> the
>>> is an unknown type.
>> than
>> are
>> EClassifiers.
> of
>> definition
> - get(k : KeyT) : T
> really
> it
> as a metaclass:
> this might be
>> Best Regards,
>> Adolfo.
Re: Suggestion of generalizing Ecore CollectionTypes [message #31293 is a reply to message #31263] Thu, 28 June 2007 12:18 Go to previous messageGo to next message
Hi, Adolfo,
I look forward to your conclusions! You've been very helpful on this and
other matters, finding problems (and solutions) and generally prompting me
to think. :-)
cW
> done at M1 level.
> Greetings,
> Adolfo.
<snip>
Re: Suggestion of generalizing Ecore CollectionTypes [message #31665 is a reply to message #31293] Fri, 29 June 2007 12:11 Go to previous message
Hi Christian,
Thank you very much for your words ;)
Definitely my mistake was trying to generalize the type at M2 level, because
it isn't needed (
Previous Topic:[Announce] MDT OCL 1.1.0 1.1 is available
Next Topic:About adding new predefined propertys
Current Time: Sun Jul 27 03:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.04884 seconds
