Re: GMF errors [message #2645] |
Wed, 02 August 2006 12:42  |
The GMF update sites are listed here:
http://download.eclipse.org/modeling/gmf/update-site/release s/site.xml
If you should happen to come across a link that contains /technology/ just
replace it with /modeling until we complete our update of scripts that
generate such links, as we've recently migrated to the Modeling project.
But, if you've got the Callisto version, you've obviously found its update
site and installed it. There are no updates to the Callisto version yet;
that is, unless you want to work with 2.0 stream nightly/interim builds, or
the 1.0.1 maintenance stream builds.
Regarding the tutorial, there are both solution zip files for each step, and
the final solution in CVS. Have you compared your solution with these?
Best,
Rich
On 8/2/06 10:55 AM, in article eaqed7$b6d$1@utils.eclipse.org, "Chris Lenz"
<chris.lenz@uibk.ac.at> wrote:
> First I can't find the update site of gmf;
> I tried the example of mindmap with the calisto version of gmf, but I am
> not able to create links in the generated diagramm editor.
> I tried to use my on ecore model, and it is not possible to check links
> for the generatrion of the grapmap and toolmap. Must the links
> (aggregations) have a special style?
> Chris
Re: GMF errors [message #4085 is a reply to message #2645] |
Thu, 03 August 2006 03:06  |
I havend compared, but I have made a new version of ecore (my
organisational diagram) and it works:
Thanx
> Best,
> Rich
>> Chris
FUDForum. Page generated in 0.29699 seconds
