Home » Eclipse Projects » Eclipse Platform » Develop multiple versions of a plugin at once
Develop multiple versions of a plugin at once [message #305944] Mon, 17 July 2006 05:30 Go to next message
Originally posted by: contact.noelios.com
I'm developing two versions of the same plugin at the same time: A1 and
A2. Also A1 depends on another plugin B1 and A2 depends on the same
plugin, but a latter version: B2.
When I have all four plugins open at the same time in Eclipse 3.2, it
seems that the classpath entries overlap and conflict. I have to close
A1 and B1 if I want to work on A2 and B2, or the other way around.
It there a solution to this problem? If not, could this be directly
supported in the future?
Jerome
Restlet, a REST framework for Java
http://www.restlet.org
Re: Develop multiple versions of a plugin at once [message #305986 is a reply to message #305944] Mon, 17 July 2006 10:44 Go to previous messageGo to next message
seems you have to change plugin id as a temp hack to make that works.
Sunny Sun
"Jerome Louvel" <contact@noelios.com>
??????:e9flav$7df$1@utils.eclipse.org...
> seems that the classpath entries overlap and conflict. I have to close A1
> Jerome
Re: Develop multiple versions of a plugin at once [message #306005 is a reply to message #305944] Mon, 17 July 2006 19:32 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Jerome Louvel" <contact@noelios.com> wrote in message
news:e9flav$7df$1@utils.eclipse.org...
Why not use multiple workspaces?
Re: Develop multiple versions of a plugin at once [message #306048 is a reply to message #305986] Wed, 19 July 2006 03:19 Go to previous messageGo to next message
Thanks Sunny, that's a good workaround. It is even used by Eclipse IDE
to deal with the two versions of JUnit (3.8 and 4.1).
Jerome
> Sunny Sun
Re: Develop multiple versions of a plugin at once [message #306049 is a reply to message #306005] Wed, 19 July 2006 03:22 Go to previous messageGo to next message
Because I really need to quickly switch from one plugin version to the
other. I have other plugins that can use any available version, A1 or A2.
Idieally, I would like Eclipse to use the dependency constraints based
on min/max versions to use the best plugin. Unfortunately, this version
resolution seems to be only supported at runtime.
Jerome
Re: Develop multiple versions of a plugin at once [message #306050 is a reply to message #305944] Wed, 19 July 2006 03:28 Go to previous message
I've just enter a related bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151044
Previous Topic:PDE extension schema editor help?
Next Topic:Specific Q about extension schema
Current Time: Sun Jul 27 03:08:15 EDT 2025
Powered by FUDForum. Page generated in 0.04790 seconds
