  RSE/TM? causes frequent hangs
By: Eclipse User on Tue, 13 April 2021
2 2987 Fri, 16 April 2021 16:00
  rse; dstore connector service; using port 0 error
By: Eclipse User on Wed, 23 April 2008
11 21823 Tue, 11 June 2019 09:27
  help on SaveAs ( ... 2 3 4 5 6)
By: Eclipse User on Mon, 23 March 2009
1050 152648 Fri, 12 May 2017 01:15
icon5.gif RSEF8067 Error
I'm receiving the error RSEF8067 when attempting to upload to the root of a remote server
By: Eclipse User on Mon, 11 April 2016
1 9550 Thu, 17 November 2016 14:39
  Active Project Handling - Howto
By: Eclipse User on Fri, 20 March 2009
20 10349 Wed, 16 November 2016 12:05
  news.eclipse.org is shutting down.
By: Eclipse Webmaster on Wed, 31 August 2016
0 2659 Wed, 31 August 2016 14:44
  Terminal Colors
Terminal colors in RSE and TM
By: Eclipse User on Wed, 20 July 2016
2 4688 Fri, 22 July 2016 13:24
  Suddenly: Daemon failed to launch server using port 0
Cannot exchange data with remote system
By: Eclipse User on Wed, 23 September 2015
0 6817 Wed, 23 September 2015 07:36
  Remote Debuging without gdbserver
By: Eclipse User on Mon, 21 February 2011
5 12210 Tue, 28 July 2015 10:42
icon5.gif Console TERM Emulation Support
Which terminal emulator is comtabilie with Target Management Terminal (RSE plugin)
By: Eclipse User on Mon, 14 November 2011
3 9542 Sun, 18 January 2015 01:31
  How to change background color of ssh terminal window?
By: Eclipse User on Fri, 11 September 2009
1 9183 Fri, 31 October 2014 16:40
  serial port problem in terminal
no such port problem
By: Eclipse User on Fri, 04 October 2013
1 7334 Thu, 20 March 2014 13:25
  FTP LIST -a command
By: Eclipse User on Wed, 02 July 2008
1 4976 Tue, 07 January 2014 15:40
  RSE set host port number programmatically
By: Eclipse User on Tue, 24 September 2013
0 4327 Tue, 24 September 2013 09:03
  How can I disable SFTP?
By: Eclipse User on Thu, 11 November 2010
3 16924 Mon, 19 August 2013 13:06
  Using RSE synchronize cache to import files
By: Eclipse User on Tue, 06 August 2013
2 6841 Sun, 11 August 2013 17:02
  create filters in modelinitializer
By: Eclipse User on Mon, 05 August 2013
0 3335 Mon, 05 August 2013 08:40
  RSE Export / Import All Connections
By: Eclipse User on Sun, 17 March 2013
0 4654 Sun, 17 March 2013 06:19
  Cannot Transfer Files
By: Eclipse User on Wed, 19 August 2009
11 10626 Mon, 11 March 2013 01:52
  Could RSE be used to mirror local project to remote system
By: Eclipse User on Fri, 11 January 2013
1 4625 Fri, 11 January 2013 03:37
  Error listing directory content
By: Eclipse User on Thu, 19 April 2012
3 9539 Wed, 08 August 2012 02:12
  RSE on imx53
By: Eclipse User on Thu, 01 March 2012
0 8859 Thu, 01 March 2012 10:16
  Target Management
Programmatically open telnet terminal
By: Eclipse User on Mon, 28 November 2011
0 10535 Mon, 28 November 2011 06:52
icon5.gif SSH Terminal Colors
How do I change the terminal colors?
By: Eclipse User on Tue, 28 September 2010
3 11732 Mon, 14 November 2011 09:30
1 10920 Tue, 04 October 2011 05:54
  getHosts() doesn't get the local host on startup/first call - should it?
By: Eclipse User on Thu, 11 August 2011
2 13088 Wed, 24 August 2011 18:21
  Cross debugging
By: Eclipse User on Wed, 04 March 2009
3 6661 Mon, 22 August 2011 07:30
  A newcomer to RSE seeks feedback
By: Eclipse User on Tue, 05 July 2011
1 6315 Wed, 06 July 2011 04:06
  Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open
By: Eclipse User on Wed, 18 June 2008
2 7927 Tue, 14 June 2011 15:05
  Command to start a telnet terminal view on a specific machine
By: Eclipse User on Mon, 17 August 2009
3 19226 Fri, 03 June 2011 06:42
  How launch a terminal SSH in my RCP application
How using org.eclipse.tm.terminal.ssh, org.eclipse.tm.terminal.connectors
By: Eclipse User on Wed, 18 May 2011
0 9853 Wed, 18 May 2011 02:18
  SFTP sync local project with remote.
sftp by JCraft.
By: Eclipse User on Sat, 30 April 2011
0 11721 Sat, 30 April 2011 14:28
  RSE services API concurrency ?
Are all RSE service APIa thread safe or are there any potential pitfalls ?
By: Eclipse User on Wed, 23 February 2011
1 5613 Thu, 24 February 2011 09:32
  Links not refreshed properly
1 5746 Tue, 22 February 2011 09:23
  cvs on top of rse
By: Eclipse User on Tue, 11 January 2011
5 11215 Fri, 04 February 2011 05:59
  RSE server packaging
By: Eclipse User on Thu, 21 August 2008
3 6423 Thu, 03 February 2011 13:37
1 5628 Wed, 02 February 2011 10:22
  Using RSE with a public key
By: Eclipse User on Mon, 19 July 2010
6 13239 Thu, 13 January 2011 09:28
icon4.gif TM has moved to Tools, this Forum is closed!
By: Eclipse User on Wed, 12 January 2011
0 9951 Wed, 12 January 2011 19:23
  Birt Report Viewer content
1 5933 Tue, 11 January 2011 13:22
  SSH Connection Refused
By: Eclipse User on Wed, 05 January 2011
4 13929 Thu, 06 January 2011 00:28
  Connection errors using RSE
By: Eclipse User on Fri, 17 December 2010
1 8031 Sat, 18 December 2010 00:39
icon5.gif IRemoteFile.exists() returns true but can't download file with following message
RSEG9999, Missing element for : ''
By: Eclipse User on Wed, 24 November 2010
1 9628 Thu, 25 November 2010 03:49
  How to create SubSystem Programatically?
make a connection and retrieve directory and files without UI
By: Eclipse User on Wed, 17 November 2010
4 8718 Wed, 24 November 2010 21:26
  using RSE in OSGi containers (Equinox)
org.eclipse.rse.core has an unfortunatelly SWT dependency
By: Eclipse User on Fri, 19 November 2010
4 7321 Tue, 23 November 2010 06:50
  can't debug remotely
By: Eclipse User on Mon, 08 March 2010
1 5964 Tue, 16 November 2010 14:10
  Dialog to specify file
By: Eclipse User on Thu, 18 March 2010
1 6018 Tue, 16 November 2010 14:09
  Anonymous FTP access
By: Eclipse User on Tue, 23 March 2010
1 7782 Tue, 16 November 2010 14:05
  RSE - Nested Sftp / Sftp Twice / RSE behind firewall
By: Eclipse User on Tue, 30 March 2010
1 7121 Tue, 16 November 2010 14:03
  Num in SSH console
in SSH console: Num/Lock doesn't work
By: Eclipse User on Thu, 22 April 2010
1 5892 Tue, 16 November 2010 14:03
  Unable to view directory structure in FTP
By: Eclipse User on Wed, 19 May 2010
1 6401 Tue, 16 November 2010 13:59
  How to programmatically upload a file to a remote server? Updated
IFile is not uploaded
By: Eclipse User on Mon, 21 June 2010
3 7259 Tue, 16 November 2010 13:55
  Enable compression
By: Eclipse User on Mon, 14 June 2010
2 5891 Tue, 16 November 2010 13:53
  RSE connection
By: Eclipse User on Sat, 12 June 2010
1 6403 Tue, 16 November 2010 13:48
  Eclipse hang up. Suspecting RSE...
By: Eclipse User on Thu, 22 July 2010
1 7947 Tue, 16 November 2010 13:45
  RSE installation failed
By: Eclipse User on Mon, 12 July 2010
1 6367 Tue, 16 November 2010 13:40
  SSH tunnel through a Bastion host ?
By: Eclipse User on Mon, 05 July 2010
1 10133 Tue, 16 November 2010 11:10
  RSE using Telnet instead of SSH
How to connect a Remote System over Telnet instead of SSH, preferable while still using FTP for file transfers.
1 6421 Tue, 16 November 2010 09:07
  Re: cant create a new connection
By: Eclipse User on Fri, 02 July 2010
1 4119 Tue, 16 November 2010 09:00
  CDT launch using RSE
By: Eclipse User on Fri, 13 August 2010
1 4715 Tue, 16 November 2010 08:56
  debug a local ssl site with eclipse PDT
I'm trying to debug a local https:// using Eclipse... cannot connect to the server
By: Eclipse User on Sun, 14 November 2010
1 5106 Tue, 16 November 2010 08:53
  programmatic opening of the RSE view
By: Eclipse User on Wed, 15 September 2010
2 5606 Tue, 16 November 2010 08:52
  Execute command or script after SSH connection
By: Eclipse User on Tue, 07 September 2010
1 4947 Tue, 16 November 2010 08:50
0 9663 Sun, 14 November 2010 21:31
  Ensuring RSE has initialized/loaded
By: Eclipse User on Wed, 29 September 2010
1 4479 Wed, 29 September 2010 15:30
5 3957 Fri, 17 September 2010 11:23
  Can't open RSE Perspective
By: Eclipse User on Thu, 24 June 2010
3 6045 Wed, 15 September 2010 10:23
0 8599 Tue, 07 September 2010 09:32
  Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration
By: Eclipse User on Tue, 27 July 2010
3 4217 Fri, 03 September 2010 11:35
icon5.gif How to export the RSE as an eclipse RCP production?
By: Eclipse User on Mon, 30 August 2010
5 8698 Wed, 01 September 2010 16:40
icon5.gif Get/Set Selection in RSE Explorer/TreeView ?
Is there any API for this?
By: Eclipse User on Mon, 22 February 2010
3 5435 Mon, 30 August 2010 22:58
1 4099 Mon, 30 August 2010 14:12
1 4550 Mon, 30 August 2010 14:10
How to debug a cross developed gcc application using RSE
0 8105 Fri, 13 August 2010 05:33
  Enable compression
1 4944 Mon, 09 August 2010 05:10
0 9886 Thu, 22 July 2010 04:29
0 8124 Mon, 19 July 2010 17:20
0 9527 Mon, 12 July 2010 15:43
0 9081 Mon, 12 July 2010 06:53
  Problem with indexer (RSE/CDT)
"Unresolved Inclusion" (using dstore server connection)
By: Eclipse User on Mon, 08 February 2010
5 9868 Fri, 09 July 2010 11:18
I need to remotely access a machine on a network accessable only through a bastion host.
0 9095 Mon, 05 July 2010 13:29
1 5533 Fri, 02 July 2010 11:57
0 9242 Fri, 02 July 2010 11:42
1 3836 Wed, 30 June 2010 13:38
  DSDP/TM 3.2 is released!
By: Eclipse User on Wed, 23 June 2010
0 8607 Wed, 23 June 2010 09:30
0 8584 Wed, 23 June 2010 09:30
0 9889 Mon, 21 June 2010 04:52
  RSE connection
RSE connection doesn't work
0 8606 Sat, 12 June 2010 22:07
  can't share, import/export RSE profiles
Is there an easy way to share RSE profiles?
By: Eclipse User on Wed, 26 May 2010
3 4836 Thu, 03 June 2010 16:54
1 3562 Thu, 03 June 2010 16:31
  RSE Copy/Paste in SSL
By: Eclipse User on Thu, 06 May 2010
1 3696 Thu, 03 June 2010 15:13
1 3257 Thu, 03 June 2010 15:13
  Syntax errors in remote file not detected
2 3759 Thu, 03 June 2010 15:11
  Syntax errors in file not detected
2 5163 Thu, 03 June 2010 15:11
1 4626 Thu, 03 June 2010 15:03
  [RSE] File subsystem vs file service
By: Eclipse User on Sun, 21 February 2010
2 4850 Thu, 03 June 2010 14:57
2 3873 Thu, 03 June 2010 14:57
0 9421 Wed, 19 May 2010 12:54
  Still having problems with rseserver
By: Eclipse User on Tue, 22 July 2008
10 8918 Tue, 11 May 2010 05:23
  Num in SSH console
0 9025 Thu, 22 April 2010 11:09
1 4026 Fri, 09 April 2010 05:25
RSE on Remote Files behind a firewall, need to sftp twice
0 9595 Tue, 30 March 2010 20:12
0 8784 Tue, 23 March 2010 10:37
0 8881 Thu, 18 March 2010 13:14
0 8685 Mon, 08 March 2010 09:03
  CVS checkout to remote project folder fails
By: Eclipse User on Sat, 12 January 2008
6 12344 Thu, 25 February 2010 10:12
  [solved] FTP Connection problem
Cannot connect to my intranet
By: Eclipse User on Wed, 24 February 2010
2 4067 Thu, 25 February 2010 04:06
0 9286 Wed, 24 February 2010 18:26
  Set password for SSH connection
0 8908 Mon, 22 February 2010 04:55
0 9159 Mon, 22 February 2010 04:55
  CDT hover over capability for remote resources
By: Eclipse User on Mon, 15 February 2010
0 8712 Mon, 15 February 2010 02:26
Making hover over capabilities to work for remote resources
0 10376 Mon, 15 February 2010 02:26
  SFTP Sync
By: Eclipse User on Mon, 25 January 2010
0 8672 Mon, 25 January 2010 17:55
  SFTP Sync
Sycing local files with SFTP server
0 11806 Mon, 25 January 2010 17:55
  Remote connection using ftp fails
By: Eclipse User on Fri, 22 January 2010
0 9237 Fri, 22 January 2010 08:56
Remote connection using 'ftp only' shows empty list for remote folder.
0 10363 Fri, 22 January 2010 08:56
  PDT RSE has no code assistance
By: Eclipse User on Mon, 28 December 2009
1 3166 Tue, 29 December 2009 09:03
code assistance does not work in RSE
1 4469 Tue, 29 December 2009 09:03
  "C/C++ Remote Application" list of binaries is always empty
By: Eclipse User on Sun, 20 December 2009
0 8598 Sun, 20 December 2009 04:21
0 11745 Sun, 20 December 2009 04:21
  Permissions Lost
By: Eclipse User on Thu, 17 December 2009
2 3701 Thu, 17 December 2009 20:22
  Permissions Lost [SOLVED]
Permissions lost when transferring files over an ssh/sftp connection.
2 4128 Thu, 17 December 2009 20:22
  "Browse For Folder" Dialog does not work as expected
By: Eclipse User on Mon, 16 November 2009
12 13757 Fri, 04 December 2009 13:04
  Getting remote connection
2 3795 Tue, 24 November 2009 11:52
0 8698 Mon, 16 November 2009 07:51
0 8951 Mon, 16 November 2009 07:49
  LocatorListener.peerAdded(IPeer) is never called when Agent starts!
By: Eclipse User on Mon, 09 November 2009
0 8703 Mon, 09 November 2009 04:40
0 9909 Mon, 09 November 2009 04:40
  proxy error: forbidden
By: Eclipse User on Fri, 23 October 2009
0 6303 Fri, 23 October 2009 04:09
0 14598 Fri, 23 October 2009 04:09
  TCF Visual Studio build problems, cause: DIA SDK
By: Eclipse User on Fri, 18 September 2009
6 9208 Mon, 12 October 2009 03:12
  problem building the RSE feature, dstore.core not found
By: Eclipse User on Fri, 09 October 2009
0 4876 Fri, 09 October 2009 03:52
problem building org.eclipse.rse feature
0 6473 Fri, 09 October 2009 03:52
  Diagnosing RSEG1066
6 18314 Wed, 07 October 2009 08:42
  TM 3.1.1 has been released with Galileo SR1
By: Eclipse User on Mon, 28 September 2009
2 4428 Thu, 01 October 2009 21:30
0 4608 Mon, 28 September 2009 06:36
  Export to remote file system doesn't work
By: Eclipse User on Sun, 27 September 2009
1 3447 Sun, 27 September 2009 18:15
1 3483 Sun, 27 September 2009 18:15
0 4401 Fri, 18 September 2009 03:33
  Diagnosing RSEG1066
0 4746 Fri, 11 September 2009 11:03
  programmatically select a file in the "Remote Systems" view
By: Eclipse User on Thu, 10 September 2009
0 4393 Thu, 10 September 2009 11:24
0 5145 Thu, 10 September 2009 11:24
  persistence of IHost custom properties
By: Eclipse User on Wed, 02 September 2009
4 4698 Wed, 09 September 2009 15:01
  isLink not returning correct value for IRemoteFile
By: Eclipse User on Tue, 08 September 2009
0 5253 Tue, 08 September 2009 11:26
0 3787 Tue, 08 September 2009 11:26
  TM3.1 Problem with "Export to Remote File System"
By: Eclipse User on Mon, 24 August 2009
6 6298 Fri, 04 September 2009 07:07
0 4134 Wed, 02 September 2009 18:47
  Problem using SystemRemoteFolderDialog
By: Eclipse User on Tue, 25 August 2009
4 4643 Wed, 26 August 2009 18:39
0 4271 Tue, 25 August 2009 08:44
0 3882 Mon, 24 August 2009 13:07
  Adding a new connector (TerminalConnectorImpl)
0 3857 Mon, 24 August 2009 12:02
0 5709 Mon, 24 August 2009 12:02
0 4351 Wed, 19 August 2009 15:05
0 4708 Mon, 17 August 2009 15:01
  RSE Components Will Not Install
By: Eclipse User on Mon, 03 August 2009
0 6690 Mon, 03 August 2009 22:45
0 4722 Mon, 03 August 2009 22:45
  Empty List when using FTP
By: Eclipse User on Mon, 03 November 2008
12 17209 Mon, 03 August 2009 12:37
  RSE daemon.pl on AIX throws MalformedInputException
By: Eclipse User on Wed, 15 July 2009
4 9292 Fri, 17 July 2009 03:33
  The RSE org.eclipse.rse.importexport plugin execution environments level?
By: Eclipse User on Wed, 08 July 2009
6 11226 Thu, 16 July 2009 16:55
0 4346 Wed, 15 July 2009 07:48
  Re: SSH via RSE
0 5757 Wed, 08 July 2009 18:34
  Re: SSH via RSE
0 3657 Wed, 08 July 2009 18:34
  RSE:What is the use of RemoteSystemsTempFiles in workspace?
By: Eclipse User on Tue, 23 June 2009
14 15909 Wed, 08 July 2009 13:46
  RSE:How to set timeout to stop the connecting state?
8 10456 Wed, 08 July 2009 13:31
0 4526 Wed, 08 July 2009 07:09
  Cygwin Support?
By: Eclipse User on Fri, 03 July 2009
2 4189 Tue, 07 July 2009 14:32
  TM 3.1 is released with Galileo
By: Eclipse User on Fri, 26 June 2009
2 4565 Tue, 07 July 2009 04:39
  Folder/File rights (chwon/chmod)
By: Eclipse User on Wed, 24 June 2009
8 7424 Fri, 03 July 2009 12:46
  Cygwin Support?
0 3731 Fri, 03 July 2009 08:13
  Using privileged ports for RSE
By: Eclipse User on Wed, 01 July 2009
6 5475 Thu, 02 July 2009 14:23
  RSE: Impossible to connect from a Windows PC to a Sun Workstation via FTP
By: Eclipse User on Mon, 18 May 2009
14 16089 Thu, 02 July 2009 00:30
0 5819 Wed, 01 July 2009 07:47
  hidden files do not show on remote server
By: Eclipse User on Sun, 28 June 2009
4 8031 Mon, 29 June 2009 22:55
0 4050 Sun, 28 June 2009 22:38
  GDB Warnings (Wrong Library or Version Mismatch?)
0 5217 Fri, 26 June 2009 18:16
0 9498 Fri, 26 June 2009 18:16
  No TM monthly meeting on 1-Jul
0 4152 Fri, 26 June 2009 14:25
0 5627 Fri, 26 June 2009 14:25
0 3967 Fri, 26 June 2009 14:25
  Trying to do remote debuging on a AIX host from a Windows client
By: Eclipse User on Mon, 19 May 2008
16 16331 Thu, 25 June 2009 19:15
0 4169 Wed, 24 June 2009 06:02
0 4043 Tue, 23 June 2009 20:58
0 4276 Tue, 23 June 2009 02:20
  RSE: Erreur when using Remote Systems view
By: Eclipse User on Tue, 19 May 2009
8 41373 Mon, 22 June 2009 08:38
  openSolaris ? What is the story ?
By: Eclipse User on Fri, 19 June 2009
2 4725 Mon, 22 June 2009 08:36
  RSE can't open files in some directory, which give the RSEG1067 error
By: Eclipse User on Mon, 22 June 2009
2 4756 Mon, 22 June 2009 08:20
  "C/C++ Remote Application" not available in run configurations
By: Eclipse User on Wed, 17 June 2009
2 8900 Mon, 22 June 2009 08:13
  Navigator -> New -> File -> Addvanced -> Link -> RSE = no files, but folders
By: Eclipse User on Tue, 09 June 2009
6 6408 Mon, 22 June 2009 08:11
0 4198 Mon, 22 June 2009 00:56
0 5419 Fri, 19 June 2009 19:58
0 4021 Wed, 17 June 2009 14:34
0 3919 Tue, 09 June 2009 03:58
  RSEC1002
By: Eclipse User on Wed, 03 June 2009
2 8629 Thu, 04 June 2009 14:59
  RSEC1002
0 4960 Wed, 03 June 2009 15:22
  RSE flat single level view, no directories
By: Eclipse User on Mon, 13 April 2009
20 8960 Fri, 29 May 2009 16:27
  DStore Deamon - binary version for embedded devices
By: Eclipse User on Fri, 15 May 2009
4 4904 Thu, 28 May 2009 14:24
0 4767 Tue, 19 May 2009 05:18
0 4259 Mon, 18 May 2009 08:00
0 3541 Fri, 15 May 2009 11:17
  RSE terminals and windows tiling
By: Eclipse User on Wed, 06 May 2009
2 4676 Tue, 12 May 2009 13:39
Current Time: Sun Jul 27 07:03:35 EDT 2025
Powered by FUDForum. Page generated in 0.09534 seconds
