Topic |
Replies |
Views |
Last message |
Unavailabiltiy of 3.0.0 version |
1 |
687 |
Mon, 18 September 2023 10:45 By: Thomas Landuyt |
getting error for Contextmenu option selection in a table need to select a row and perform contextmenu() and select the options from that |
1 |
795 |
Wed, 06 September 2023 15:41 By: Patrick Tasse |
ContextMenu option selection in SWTBOT unable to select option from contextmenu() inside the table |
0 |
5885 |
Mon, 04 September 2023 10:37 By: sruthi yarlagadda |
Executing a single SWTbot test from the headless runner |
1 |
1731 |
Mon, 03 April 2023 12:04 By: Gilles Iachelini |
Headless Testing on Github Failed to inject or execute JavaScript |
0 |
1669 |
Mon, 20 March 2023 09:39 By: Gilles Iachelini |
SWTBot via the Command Line |
2 |
1659 |
Tue, 03 January 2023 16:06 By: Zac Hamid |
SWTBot doesn't seem to see the "Show View" Shell Running 4.22 with SWTBot 4.1.0, the Standard Eclipse 'Show View' Shell cannot be found |
4 |
2005 |
Fri, 23 December 2022 14:24 By: Zac Hamid |
Can't access right-click menu items of project that have sub-menus |
10 |
14864 |
Mon, 26 September 2022 20:33 By: Jeff Johnston |
Triggering a mouse hover event on a toolbar item |
0 |
1972 |
Wed, 27 July 2022 19:46 By: Frederic Bard |
Migration to SLF4J logging in SWTBot 4.0 |
0 |
3331 |
Sat, 04 June 2022 15:14 By: Aparna Argade |
Test class not found when run from command line |
1 |
3534 |
Tue, 10 May 2022 16:25 By: Patrick Tasse |
SWTBot cannot be found by <my-test-plugin> in headless Running SWTBot test on existing application |
0 |
4746 |
Thu, 24 March 2022 12:27 By: Uday Kumar |
How to test the Workspace launcher dialog How to test the Workspace launcher dialog |
1 |
1106 |
Mon, 15 November 2021 15:04 By: Patrick Tasse |
Find custom View with bot |
1 |
1402 |
Mon, 04 October 2021 20:23 By: Patrick Tasse |
test rcp application Plug-in com.ide.rcp was unable to load class com.ide.rcp.Application. |
0 |
2577 |
Fri, 30 July 2021 09:28 By: sai wang |
How to click on minimize/maximize view buttons |
5 |
1578 |
Wed, 14 July 2021 15:07 By: Patrick Tasse |
Regression with SWTBot |
2 |
1441 |
Tue, 29 June 2021 22:03 By: Дарья Федорова |
Example for running SWTBot tests with Tycho for an Eclipse 4 RCP app |
1 |
2265 |
Mon, 21 June 2021 14:02 By: Lars Vogel |
Added support for Nebula CheckBoxGroup, Stepbar, RangeSlider |
0 |
2293 |
Fri, 23 April 2021 14:44 By: Aparna Argade |
How to use Katalon Studio RCP application in SWTBoT how to launch katalon studio as RCP application in SWTBot |
1 |
1058 |
Wed, 14 April 2021 06:45 By: Dieter Mai |
Accessing checkboxes from table |
0 |
2215 |
Fri, 09 April 2021 11:07 By: Alexandra Tritean |
How to open a menu? |
2 |
2637 |
Tue, 23 February 2021 13:08 By: Lutz Wrage |
SWTBot() - Could not find a display - Eclipse 2020 |
2 |
3942 |
Tue, 10 November 2020 19:26 By: Patrick Tasse |
SWTBot _Tycho SWTBot _Tycho - Skip the Test Run But Bundle it |
2 |
1513 |
Thu, 10 September 2020 04:32 By: Neju Nelson |
Problems with Keyboard when tests running headless |
1 |
3943 |
Fri, 28 August 2020 06:05 By: Felix Bruckner |
SWTBot on Jenkins Bitvise SSH-Server |
0 |
9605 |
Fri, 28 August 2020 05:54 By: Felix Bruckner |
SWTBotNatTable opens dialog twice |
1 |
1243 |
Fri, 29 May 2020 21:07 By: Stephan Druskat |
SWTBot with JUnit5? |
5 |
3686 |
Wed, 08 April 2020 03:38 By: Aparna Argade |
popup menu in NatTable could'nt be found |
5 |
2609 |
Wed, 04 December 2019 14:33 By: Patrick Tasse |
Open SWTBot test Recorder with RCP application SWTBot test Recorder + RCP application doesn't work |
3 |
17492 |
Fri, 22 November 2019 09:50 By: Ralf Heydenreich |
How to press shortcuts containing numpad keys? |
2 |
2813 |
Wed, 09 October 2019 09:16 By: Matthias Bank |
SWTBot with Cucumber |
3 |
6314 |
Sun, 29 September 2019 09:03 By: Heiko Köppen |
Validation of SWTBotTreeItem tooltip text |
1 |
5109 |
Mon, 23 September 2019 13:28 By: Patrick Tasse |
Test application with existing project data How can I start an application with a test project? |
2 |
3460 |
Mon, 26 August 2019 18:52 By: Ralf Heydenreich |
SWTBot test fails when creating xtext resource |
3 |
2835 |
Sat, 27 July 2019 15:45 By: Eclipse User |
SWTBot tests not running the correct application |
0 |
26435 |
Tue, 23 July 2019 00:13 By: Louis Detweiler |
SWTBot unable to access to "Table" |
2 |
2850 |
Tue, 09 July 2019 07:25 By: Thibaut marc |
Unable to create run configuration with SWTBot The goal is to create a run configuration with SWTBot. By: N M on Tue, 05 February 2019 |
3 |
5981 |
Wed, 05 June 2019 21:24 By: Patrick Tasse |
Wrong tested application is started when tests are running with Tycho |
8 |
4619 |
Sat, 20 April 2019 15:17 By: Alexey Chibisov |
Draw2D Support in GEF |
4 |
4864 |
Tue, 16 April 2019 10:01 By: Pascal Mandende |
SWTBot now supports reading of Status Line messages |
0 |
17153 |
Mon, 18 March 2019 15:35 By: Aparna Argade |
KeyStrokes don't work anymore with Mac |
5 |
3194 |
Wed, 23 January 2019 18:13 By: Patrick Tasse |
SWTBot and WebStart how to add test plugin to application SWTBot with WebStart |
2 |
2492 |
Wed, 16 January 2019 16:26 By: Alex Gor |
How to decrease warning message such as Widget is not enabled |
3 |
2282 |
Thu, 10 January 2019 20:44 By: Didier Vojtisek |
bot().textWithLabel() does not found appropriated text field |
2 |
2276 |
Thu, 10 January 2019 17:23 By: Alex Gor |
2018-12 Issues |
2 |
1819 |
Fri, 21 December 2018 15:26 By: Matt Biggs |
SWTBot test canot load class from application under testing ClassDefNotFoundError |
2 |
2040 |
Thu, 13 December 2018 18:54 By: Alex Gor |
Release planned for Eclipse 2018-12? |
4 |
2366 |
Mon, 03 December 2018 14:44 By: Patrick Tasse |
SWTBot in headless mode and java.lang.ExceptionInInitializerError headless problems |
5 |
3427 |
Thu, 08 November 2018 07:48 By: Alex Gor |
Run SWTBot test in Headless mode. RCP application is not started |
2 |
3786 |
Fri, 02 November 2018 11:43 By: Alex Gor |
Unable to read SWTBotBrowser text content < Photon |
1 |
1847 |
Mon, 01 October 2018 14:31 By: Patrick Tasse |
Improve AbstractSWTBot.dragAndDrop capability |
3 |
3852 |
Fri, 21 September 2018 21:24 By: Patrick Tasse |
SWTBotProgressBar is supported |
0 |
3289 |
Thu, 23 August 2018 08:09 By: Aparna Argade |
Getting errormarkers of xtext editor Getting error markers of xtext editor |
2 |
2418 |
Thu, 02 August 2018 10:50 By: Missing name Mising name |
Filling a tree with test data? How can I fill a tree with test items? |
3 |
2392 |
Tue, 10 July 2018 14:52 By: Christian Eugster |
How to get progress bar shell in swtbot? I am trying out to write swtbot test cases for my RCP Application. I am displaying a progress bar whenever a search is performed in the Application. To test the same using swtbot, I am using the fol By: Anup R on Mon, 09 July 2018 |
0 |
2672 |
Mon, 09 July 2018 10:10 By: Anup R |
Working with FigureCanvas |
1 |
1623 |
Wed, 09 May 2018 20:27 By: Patrick Tasse |
SWTBot Command line Framework installation Installing Headless Testing Framework |
1 |
3326 |
Wed, 09 May 2018 10:02 By: Dundappa Kamate |
How to make the Logger snippet work The Logger snippet in the documentation doesn't seem to work. How to fix it? |
1 |
4764 |
Wed, 25 April 2018 09:54 By: Aparna Argade |
SWTBot tests do not work with maven, but with Eclipse Shell does not close |
2 |
3369 |
Mon, 09 April 2018 18:23 By: Robert Hilbrich |
SWTBot and E4 RCP Applications - Status? How to combine E4 RCP Applications and SWTBot for GUI testing? |
7 |
4250 |
Thu, 05 April 2018 12:54 By: Eclipse User |
Automated test execution without showing display |
2 |
3272 |
Fri, 26 January 2018 14:38 By: Robert Schulk |
SWTBot Recorder is not absolute SWTBot Recorder generated test cases are not good enough. |
12 |
16044 |
Wed, 17 January 2018 06:00 By: Aparna Argade |
Not able to find swtbot plugin |
6 |
6071 |
Tue, 02 January 2018 06:48 By: minhang kang |
RAP Automation RAP Automation |
0 |
1514 |
Sat, 23 December 2017 15:39 By: Rajesh Gupta |
SWTBot + Selenium for SWT & browser testing? |
2 |
7976 |
Fri, 24 November 2017 23:26 By: Agustin Celentano |
SWTBot command line, my test doesn't start |
0 |
3759 |
Thu, 19 October 2017 14:00 By: Antoine Omnès |
Send a Drag and Drop between 2 node (from a Tree) Dnd, Drag and Drop, Tree, Node |
3 |
3149 |
Wed, 11 October 2017 13:54 By: Patrick Tasse |
How to modify Tree/table? |
3 |
5132 |
Tue, 10 October 2017 08:10 By: Antoine Omnès |
How to link a Part from an RCP App to SWTBot? |
3 |
6996 |
Fri, 22 September 2017 10:57 By: Antoine Omnès |
Testing FXCanvas with SWTBot |
1 |
5981 |
Thu, 14 September 2017 20:23 By: Patrick Tasse |
SWTBot and Dependency Injection |
1 |
3537 |
Tue, 12 September 2017 22:14 By: Diego Tavolaro |
More wait conditions |
0 |
10216 |
Mon, 10 July 2017 10:27 By: Aparna Argade |
StartupRecorder.openRecorder fails with NPE StartupRecorder.openRecorder fails with NPE |
5 |
10108 |
Wed, 28 June 2017 17:21 By: Patrick Tasse |
SWTBOT Spy View How to find the widget type in SWTBOT |
2 |
6618 |
Wed, 14 June 2017 18:25 By: Eclipse User |
Find Display in SWTUtils |
1 |
4898 |
Wed, 14 June 2017 17:37 By: Patrick Tasse |
SWTBot & acceptance tests tools run tests in Jenkins |
3 |
8849 |
Fri, 09 June 2017 14:08 By: Patrick Tasse |
Eclipse SWTBot generator with Nattable |
1 |
3872 |
Mon, 08 May 2017 14:35 By: Patrick Tasse |
Finding item in swtbottable fails if item not present in first column. Item present in table in other than first column is not found and returned false if SWTBotTable.containsItem(final String item) is used. |
0 |
35721 |
Mon, 08 May 2017 10:03 By: kunal tayal |
SWTBot support for Nebula TableCombo? Support by SWTBot for the Nebula TableCombo Widget |
1 |
3399 |
Tue, 04 April 2017 19:41 By: Patrick Tasse |
How to click on toolbar dropdown menu item using SWTBOT |
4 |
11824 |
Mon, 03 April 2017 12:37 By: Gunnar Wagenknecht |
Execute SWTBot in running IDE |
5 |
6260 |
Thu, 23 March 2017 23:30 By: Lutz Wrage |
Test failing with _cairo_format_from_content: Assertion `!"reached"' fail |
2 |
4810 |
Wed, 15 March 2017 17:17 By: Julien HENRY |
SWTBotTreeItem.getTooltipText SWTBotTreeItem.getTooltipText() returns "" |
4 |
6136 |
Mon, 13 March 2017 10:45 By: Aparna Argade |
Reference a target file as platform configuration |
1 |
3595 |
Thu, 09 March 2017 09:04 By: Malte Brunnlieb |
How to enable checkbox? bot.checkBox().click(); fails because checkBox is not enabled |
8 |
17840 |
Thu, 23 February 2017 15:39 By: Patrick Tasse |
Can't add Required plug-ins to MANIFEST.MF SWTBot on Mac |
2 |
3721 |
Thu, 02 February 2017 21:43 By: Martin Paquin |
Sometimes SWTBotTable.select sends event.item=Null in SelectionEvent |
2 |
5032 |
Mon, 05 December 2016 17:26 By: Aparna Argade |
Not able to access table view Not able to access table view |
1 |
2405 |
Mon, 14 November 2016 15:47 By: Patrick Tasse |
Bot Unable to find Comboviwer.. Hi, I am trying to test an eclipse RCP application. I want SWTBot to click on an item of a combo box (drop down box), I tried bot.combo,bot.ccombo, bot.comboboxwithId but I get a WidgetNotFoundExc |
1 |
4462 |
Mon, 14 November 2016 14:33 By: Patrick Tasse |
GEF / Draw2D unit tests |
2 |
3078 |
Thu, 03 November 2016 08:13 By: Sebastien Pennec |
[solved] Eclipse-Plugin-Test: Log4J Error by using SWTBot WidgetNotFoundException caused by Initialize Error in Log4J |
0 |
5673 |
Thu, 22 September 2016 05:42 By: Corrado Parisi |
Flaky Tests How to handle Flaky Tests with SWTBot |
2 |
3462 |
Fri, 09 September 2016 02:29 By: Vivek Veera |
news.eclipse.org is shutting down. |
0 |
2581 |
Wed, 31 August 2016 18:44 By: Eclipse Webmaster |
Timeout Issues in SWTBot Tests How to handle Timeout Issues in SWTBot Tests |
4 |
6339 |
Wed, 24 August 2016 06:19 By: Vivek Veera |
Headless Test with Maven/Tycho Headless Test with Maven/Tycho |
4 |
5454 |
Mon, 01 August 2016 17:04 By: Vivek Veera |
Combination of Parameterized and SWTBotJunit4 runners |
2 |
3032 |
Wed, 27 July 2016 04:22 By: Aparna Argade |
How to launch my SWTbot tests from console? |
23 |
33346 |
Fri, 22 July 2016 12:54 By: Lakshman an M |
Unable to access Toolbar View Menu Unable to access Toolbar View Menu |
2 |
2423 |
Wed, 20 July 2016 17:24 By: Vivek Veera |
Nebula Grid and SWTBot Support for Nebula Grid in SWTBot |
1 |
2545 |
Mon, 11 July 2016 21:07 By: Patrick Tasse |
Open SWTBot test Recorder with custom RCP application |
1 |
7523 |
Tue, 14 June 2016 19:29 By: Patrick Tasse |
Recorder/Generator for non RCP app |
3 |
4357 |
Fri, 27 May 2016 11:44 By: Daniel Wendelken |
Replacement for deprecated SWTBotView.menus method? deprecated SWTBotViewMenu |
2 |
4022 |
Thu, 05 May 2016 19:54 By: Aparna Argade |
How to click on Message dilogue "OK" Button At the Time of Saving content Message Dilogue appears with OK and Cancel,I want to click on OK button.please reply |
4 |
7218 |
Thu, 28 April 2016 16:48 By: Patrick Tasse |
Nebula NatTable is now supported SWTBotNatTable |
0 |
6095 |
Thu, 28 April 2016 07:03 By: Aparna Argade |
using @Category annotation with SWTBot is it possible to use @Category annotation in SWTBot tests |
2 |
7233 |
Mon, 11 April 2016 11:35 By: Ess Kay |
How to Set or type text in TextField of Table..? I have Tree which is Table/Cell Format. After clicking a particular Cell aTextField appears. I want to Type or Set Text in that table cell. |
3 |
6740 |
Thu, 07 April 2016 13:29 By: Sumit Ganjale |
How to select an Item in ComboBox of a Tree.. |
5 |
11229 |
Tue, 05 April 2016 05:42 By: Sumit Ganjale |
Does SWTBot supports JavaFx Does SWTBot supports JavaFx |
1 |
5062 |
Wed, 23 March 2016 10:29 By: Mickael Istria |
run tests with maven/tycho headless |
6 |
14867 |
Wed, 09 March 2016 06:01 By: Lorenzo Bettini |
Testing External Application with SWBot |
4 |
7532 |
Tue, 08 March 2016 07:45 By: Vlad Ilie |
Edit NatTable cell Using SWTBOT Edit NatTable cell Using SWTBOT |
1 |
9353 |
Tue, 23 February 2016 09:12 By: Aparna Argade |
SWTBot tests inconsistent for Kepler in Windows Virtualized Environment Latest SWTBot release breaks with Kepler - Is there any solution ? - Can I get the "old" content of the update site ? |
3 |
4381 |
Mon, 22 February 2016 21:04 By: Carlos Humberto Oropeza Ramirez |
Test used to work. Failing now. |
0 |
8062 |
Mon, 22 February 2016 18:05 By: Carlos Humberto Oropeza Ramirez |
SWTBot Video Tutorials |
2 |
5554 |
Thu, 18 February 2016 17:26 By: Farris Bar |
[Problem]No context available outside of the request service lifecycle |
1 |
3852 |
Fri, 12 February 2016 13:06 By: Andre Lopes |
drag and drop from FigureCanvas Is there a way to drag and drop elements from FigureCanvas |
1 |
6815 |
Sun, 31 January 2016 21:50 By: Mickael Istria |
Testing a dialog with Browse button > DirectoryDialog |
1 |
6897 |
Sun, 31 January 2016 21:46 By: Mickael Istria |
Not able to detect Combo box with org.eclipse.jface.fieldassist.SimpleContentProposalProvider |
1 |
6657 |
Mon, 14 December 2015 06:46 By: Pawan Relan |
How to Access a Tree inside a CTab? How to Access a Tree inside a CTab? |
3 |
4182 |
Fri, 11 December 2015 23:48 By: Shabari shetty |
Injecting an object in a Context in SWTBot test |
0 |
5519 |
Fri, 04 December 2015 10:46 By: Kasper M. |
Testing Nebula's Nat Table functionality through SWTBot. Testing Nebula's Nat Table functionality through SWTBot (Robot Framework Eclipse Library -> Interface between Robot Framework and SWTBot) |
0 |
5099 |
Fri, 27 November 2015 05:20 By: Ganesh Kumbhar |
Code coverage showing partial coverage Code coverage showing partial coverage in eclipse luna using eclemma |
1 |
5697 |
Mon, 09 November 2015 12:40 By: Lorenzo Bettini |
auto compile plugin |
0 |
5928 |
Wed, 09 September 2015 13:40 By: edy franta |
Integrate SWTBOT test cases with Jenkins |
3 |
4037 |
Sat, 22 August 2015 12:24 By: Lorenzo Bettini |
NPE in HandledContributionItem when testing application on eclipse 4.5 |
3 |
10364 |
Wed, 19 August 2015 08:17 By: Arne Deutsch |
SWTBot executed in parallel? |
0 |
4380 |
Thu, 13 August 2015 19:00 By: Andrea Richiardi |
Using SWTBot for Jface tableViewer |
0 |
4541 |
Wed, 12 August 2015 12:35 By: Apurva Mundhada |
TreeView to GEF editor drag n drop |
0 |
4540 |
Tue, 28 July 2015 15:37 By: ModelGeek Mising name |
swtbot command line plugins |
1 |
2967 |
Mon, 27 July 2015 11:47 By: edy franta |
Headless SWTBot tests fail on Windows |
3 |
5594 |
Wed, 22 July 2015 09:03 By: Lorenzo Bettini |
Still cannot get Mars working with Kali Linux Mars dosent like Kali |
0 |
5832 |
Tue, 21 July 2015 13:15 By: Lamar Daughma |
SWTBot Test throws WidgetNotFoundException only when run with Maven |
1 |
4093 |
Wed, 15 July 2015 06:43 By: Lorenzo Bettini |
SWTBot for Indigo |
2 |
4008 |
Mon, 13 July 2015 12:33 By: Lorenzo Bettini |
Problem with Mars on Kali Kali Instalation of eclipse fails to launch |
2 |
2716 |
Wed, 08 July 2015 21:06 By: Lamar Daughma |
How to test context or popup Menus for a Composite. |
0 |
4689 |
Mon, 06 July 2015 17:28 By: Jordan Deyton |
RCP Testing -- Contribution Identities |
3 |
3313 |
Thu, 25 June 2015 18:34 By: Eclipse User |
Selecting a Part from a Part Stack |
2 |
4035 |
Mon, 22 June 2015 15:38 By: Patrik Suzzi |
swtbot-how to change the facet version in Project Facets wizard modifying project facets version |
3 |
4790 |
Thu, 04 June 2015 11:15 By: Peter Kazakov |
org.eclipse.swt.SWTError: No more handles getting "No more handles" error with no resource leak |
3 |
8291 |
Wed, 20 May 2015 15:23 By: Franck Malartic |
SWTBot tests for an SWTBrowser component SWTBot tests for an SWTBrowser component |
1 |
2223 |
Wed, 20 May 2015 12:35 By: Erdal Karaca |
SWTBot run application in another mode then exported apllication Correct run configuration for SWTBot |
1 |
3161 |
Sun, 10 May 2015 15:52 By: Lorenzo Bettini |
What SWTBOT tests exist for Eclipse? Existing SWTBOT tests |
1 |
3969 |
Wed, 29 April 2015 07:33 By: Lorenzo Bettini |
Unable to access context menus in sub classes of an Xviewer tree |
2 |
4787 |
Thu, 23 April 2015 18:28 By: Saar Sagir |
Using SWTBot with an existing RCP application |
2 |
3668 |
Wed, 22 April 2015 11:56 By: Romain Vianef |
problems with viewByTitle in Mars |
4 |
4685 |
Tue, 21 April 2015 11:18 By: Lorenzo Bettini |
Assert the text inside the MessageDialog How to assert the text inside the MessageDialog box in #SWTBot? |
2 |
3920 |
Tue, 07 April 2015 08:41 By: Abhirami Kumaraguruparan |
Unable to instantiate SWTWorkbenchBot in Eclipse E4 |
3 |
4513 |
Wed, 01 April 2015 12:55 By: Loic Faure |
Robotframework tool using SWTBot |
1 |
11249 |
Fri, 27 March 2015 06:23 By: Ganesh Kumbhar |
SWTBot on RCP Trying to use SWTBot test on my RCP application |
0 |
3181 |
Tue, 03 March 2015 09:42 By: Harshini Garikiparthi |
An error occurred while automatically activating bundle uitest Error when doing SWTBot or even simple Junit test |
0 |
3140 |
Wed, 18 February 2015 12:27 By: Jeevan Rex |
running swtbot on linux luna |
2 |
3203 |
Mon, 16 February 2015 09:38 By: chenna e |
view not really closing |
1 |
3049 |
Thu, 12 February 2015 11:24 By: Lorenzo Bettini |
SWTBot Figurecanvas use Selecting node of a mapping using SWTBot |
0 |
3199 |
Tue, 27 January 2015 06:49 By: Vishnu VK |
Cannot launch RCP app second time with Webstart Webstart RCP application launches successfully then attempts to run the downloaded JNLP fail |
3 |
17171 |
Wed, 21 January 2015 23:29 By: vivek kar |
Problems Description too short Compiler |
0 |
3137 |
Tue, 13 January 2015 07:57 By: zhijie lu |
How to work on TableViewer in Swtbot |
3 |
4600 |
Mon, 12 January 2015 10:03 By: Shweta Dhumal |
select 2 nodes of tree SWTbot select 2 nodes of tree SWTbot |
1 |
2336 |
Thu, 08 January 2015 17:46 By: Eric Rizzo |
Clicking on menu Eclipse in Mac OSX |
2 |
4928 |
Wed, 31 December 2014 14:52 By: Benoit Ries |
Seletion on Nebula gridview Select combobox element from nebula gridview. |
0 |
2677 |
Thu, 04 December 2014 13:43 By: Aparajita K |
Changing font and background color of only header in SWT table Changing font and background color of only header in SWT table |
1 |
6197 |
Fri, 28 November 2014 08:28 By: Mickael Istria |
@RunWith(SWTBotJunit4ClassRunner.class) won't catch screenshots on failure |
8 |
10706 |
Mon, 24 November 2014 12:16 By: Jeff MAURY |
SWTBotTreeItem's context menu click gives TimeoutException SWTBotTreeItem's context menu click gives TimeoutException |
8 |
7615 |
Thu, 13 November 2014 10:06 By: Aparna Argade |
Anyone knows a way to click on submenus of a view menu? |
1 |
2989 |
Wed, 12 November 2014 07:41 By: Mickael Istria |
waituntil some condition waituntil is not working everywhere |
1 |
3823 |
Mon, 10 November 2014 14:14 By: Mickael Istria |
wait for the project complete |
2 |
3580 |
Thu, 06 November 2014 08:58 By: Aparajita K |
Display not found in framework |
4 |
5821 |
Tue, 04 November 2014 09:45 By: Shweta Dhumal |
Context Menu on CDT expressions view ( Luna and SWTBot2.2.1) Attempt to access expressions view context menu through SWTBotleads to exception |
3 |
5765 |
Wed, 22 October 2014 20:54 By: Lisa Jett |
SWTBot in Mars |
1 |
3340 |
Mon, 20 October 2014 19:54 By: Mickael Istria |
How to get the menu which is poped up by right click natTable? By: ju lei on Thu, 09 October 2014 |
0 |
2870 |
Thu, 09 October 2014 08:12 By: ju lei |
Switch workspace problem |
2 |
5325 |
Thu, 09 October 2014 06:16 By: premjit Mohanty |
Eclipse Newsletter Article about SWTBot published |
3 |
4542 |
Thu, 02 October 2014 12:14 By: Aurélien Pupier |
How to test RCP application with login screen? |
2 |
5392 |
Wed, 01 October 2014 12:30 By: M Jääskeläinen |
How to Click on a link under a CTabFolder? How to Click on a link under a TabFolder? or right click on the empty space or link to get context menu? |
4 |
6236 |
Tue, 30 September 2014 21:39 By: Minnie P |
"WorkbenchTestable - No Classloader found for plug-in |
2 |
3902 |
Tue, 30 September 2014 20:54 By: Minnie P |
Cannot use ClickContextMenu on a extended SWTBot widget By: ju lei on Mon, 29 September 2014 |
0 |
4763 |
Mon, 29 September 2014 12:50 By: ju lei |
testing content assist on a text field |
4 |
5719 |
Mon, 29 September 2014 08:45 By: Lorenzo Bettini |
0 |
4843 |
Mon, 29 September 2014 07:20 By: ju lei |
How to Click on a Label using swtbot ?? |
4 |
7240 |
Mon, 29 September 2014 07:12 By: Mickael Istria |
SWTBotRadio method click() doesn't work properly SWTBotRadio method click() doesn't work properly |
0 |
5446 |
Tue, 16 September 2014 12:56 By: pascale prost |
Unable to click a label in DatePicker |
0 |
5642 |
Tue, 16 September 2014 07:53 By: Pawan Relan |
Any Plans for Support in Eclipse LUNA ?? |
1 |
4019 |
Fri, 12 September 2014 09:32 By: Mickael Istria |
How to select a TREE item in a TABLE? |
3 |
4064 |
Thu, 11 September 2014 18:18 By: Minnie P |
How to handle unpredictable shells |
2 |
5333 |
Thu, 11 September 2014 10:43 By: pawan garia |
Unable to identify/Click On Shell |
4 |
6675 |
Thu, 11 September 2014 10:28 By: pawan garia |
How to wait until context menu is visible |
2 |
4302 |
Thu, 11 September 2014 10:24 By: pawan garia |
How to wait until next label is visible |
4 |
6764 |
Thu, 11 September 2014 10:21 By: pawan garia |
Context menu in project explorer view. How to get right click menu option in project explorer view. |
1 |
5639 |
Thu, 11 September 2014 10:16 By: pawan garia |
How to get failed test cases in the middle. |
5 |
5565 |
Thu, 11 September 2014 10:10 By: pawan garia |
How to click a button under a CTabFolder? |
2 |
4023 |
Wed, 10 September 2014 23:22 By: Minnie P |
[Maven/Tycho] First editor activation event not delivered? |
1 |
3718 |
Thu, 04 September 2014 15:39 By: Mickael Istria |
java.lang.NoClassDefFoundError when using bot.waitUntil(ICondition) |
1 |
11390 |
Thu, 04 September 2014 04:46 By: Shwetali Dhumal |
wait until some condition Wait until the shell disappears. |
3 |
4876 |
Mon, 01 September 2014 16:18 By: Mickael Istria |
How to test NatTable using swtbot? How to test natTable automatically |
1 |
3567 |
Mon, 25 August 2014 10:01 By: Mickael Istria |
metacity sometimes makes SWTBot tests fail in Jenkins |
2 |
5246 |
Fri, 22 August 2014 12:51 By: Lorenzo Bettini |
Difference of click() in the test thread vs. wrapping its execution in syncExec()? |
2 |
3428 |
Thu, 21 August 2014 08:49 By: Erdal Karaca |
Execute async() followed by sync() |
0 |
8068 |
Thu, 21 August 2014 06:58 By: Erdal Karaca |
JRuby Support |
12 |
9192 |
Wed, 20 August 2014 11:48 By: Shwetali Dhumal |
Force flushing of pending UI events |
1 |
4239 |
Mon, 18 August 2014 12:56 By: Mickael Istria |
editor's cursor disappear the cursor disappear after press F5 |
0 |
4662 |
Fri, 08 August 2014 06:30 By: ren chunfei |
