Topic |
Replies |
Views |
Last message |
Team -> show Annotations is always disabled |
2 |
8006 |
Tue, 07 May 2013 16:02 By: Stefan Lay |
How to push a tag to gitgub By: jeehaa on Fri, 23 December 2011 |
3 |
21541 |
Tue, 07 May 2013 15:54 By: Stefan Lay |
EGit could not detect where Git is installed |
8 |
19073 |
Wed, 01 May 2013 21:49 By: Candice Wooten |
How do I clone a repository in EGit? How do I clone a repository in EGit? |
1 |
3310 |
Tue, 30 April 2013 22:24 By: Steve Elsemore |
grep with jgit By: Eugene on Fri, 26 April 2013 |
1 |
4331 |
Sun, 28 April 2013 15:10 By: Robin Stocker |
Re-indexing even though "Refresh when index changes" is off |
2 |
17599 |
Tue, 16 April 2013 22:14 By: Philip Aston |
push readme. How to create and push readme to Github. |
3 |
7720 |
Thu, 11 April 2013 12:07 By: Stefan Lay |
Shortcut folder problem |
1 |
3127 |
Mon, 08 April 2013 18:38 By: Robin Rosenberg |
How do I squash commits? question |
12 |
32469 |
Sat, 06 April 2013 12:00 By: R Shapiro |
Is a relative path to git repository possible? |
5 |
10655 |
Wed, 03 April 2013 14:14 By: Stefan Lay |
Does Egit Support Mylyn Commit Changesets? By: E W on Fri, 29 March 2013 |
0 |
4275 |
Fri, 29 March 2013 05:18 By: E W |
"Replace With..." actions disabled during repository conflict state |
1 |
6345 |
Wed, 27 March 2013 11:41 By: Michele Castellucci |
after upgrade from 2.2.0 to 2.3.1: unwanted .gitignore files in SVN projects plus poor performance |
50 |
8692 |
Tue, 26 March 2013 20:47 By: Robin Rosenberg |
Synchronize View Always Show Differences |
1 |
3833 |
Sat, 23 March 2013 12:58 By: R Shapiro |
Stashing with EGIT no branch after stashing |
0 |
4308 |
Mon, 18 March 2013 17:41 By: Tommy Murnow |
Egit log encoding problem |
0 |
3440 |
Sun, 17 March 2013 07:13 By: Roman Berestnikov-Sivolov |
Updating to EGit 2.3.1 from 2.2.0 breaks CDT |
0 |
3753 |
Sat, 16 March 2013 21:31 By: Victor b |
Ignoring source columns 1-12 when comparing files? trying to customize for use in IBM i environment |
1 |
3197 |
Sat, 16 March 2013 14:37 By: Robin Rosenberg |
EGit Staging and Staging View |
0 |
4294 |
Fri, 15 March 2013 20:41 By: Vikram Jiandani |
Clone a Git Repository fails |
7 |
15357 |
Thu, 14 March 2013 21:39 By: Robert Emmons |
Not able to import a project as a general project in EGIT |
0 |
5693 |
Wed, 13 March 2013 13:25 By: martin naughton |
Manually choose git directory |
1 |
2529 |
Tue, 12 March 2013 22:40 By: Robin Rosenberg |
problems importing submodules into eclipse |
0 |
5026 |
Tue, 12 March 2013 20:38 By: Gray Mising name |
problems importing existing git repos into eclipse |
0 |
6075 |
Tue, 12 March 2013 20:35 By: Gray Mising name |
How to see current (unstaged) changes in EGit? |
1 |
14672 |
Thu, 07 March 2013 22:02 By: Abby Bader |
Upgrade Eclipse to install EGit. |
0 |
5137 |
Wed, 06 March 2013 14:04 By: p. kotzi |
How to have files on index selected on commit dialog? |
0 |
5183 |
Wed, 06 March 2013 12:27 By: Cristiano Gavião |
NPE when using MergeCommand and StrategySimpleTwoWayInCore with conflicting commits |
1 |
3663 |
Wed, 06 March 2013 05:04 By: Daniel Suskin |
Stash Apply |
4 |
10903 |
Mon, 04 March 2013 19:20 By: Robin Rosenberg |
How to list files affected in a commit ?[SOLVED] |
5 |
15549 |
Mon, 04 March 2013 16:18 By: Missing name Mising name |
egit upgrade fails due to conflicting dependency |
4 |
18711 |
Thu, 28 February 2013 17:44 By: Cesc Grimalt |
Older releases of EGit. repository URL for older versions seems to no longer available |
6 |
3951 |
Thu, 28 February 2013 15:40 By: p. kotzi |
Implementation of an ActiveChangeSetManager |
0 |
4998 |
Thu, 28 February 2013 09:31 By: Joffrey Chambrin |
android adding external libraries to index android adding external libraries to index |
0 |
6922 |
Wed, 27 February 2013 18:37 By: bob wilson |
Cannot get remote repository refs By: lanz on Tue, 19 October 2010 |
6 |
49417 |
Tue, 26 February 2013 02:40 By: Jerome Song |
1 |
3418 |
Mon, 25 February 2013 07:09 By: Joffrey Chambrin |
Team menu impoverished |
3 |
6120 |
Fri, 22 February 2013 13:49 By: R Shapiro |
Extension point to perform tasks after a push |
2 |
6391 |
Wed, 20 February 2013 10:45 By: Joffrey Chambrin |
Http Push Error |
4 |
15935 |
Wed, 20 February 2013 09:10 By: Christoph Keimel |
jgit.sh clone : increase java heap space Is there a way to increase jgit.sh memory? |
1 |
6023 |
Tue, 19 February 2013 11:46 By: Christian Halstrick |
Problem opening a file for edit |
26 |
12928 |
Mon, 18 February 2013 13:47 By: Matthias Sohn |
EGit for X64 Eclipse is EGit plugin supporting X64 Eclipse environment? |
1 |
3264 |
Mon, 18 February 2013 13:37 By: Matthias Sohn |
What view is this? How do I get the views presented on the website |
1 |
2938 |
Mon, 18 February 2013 09:48 By: Pierre-Charles David |
Tracking of Audio Files eGit not recognizing .au files |
2 |
3418 |
Thu, 14 February 2013 12:08 By: Max Bedacht |
Problems Installing EGit |
4 |
7767 |
Thu, 14 February 2013 08:24 By: Matthias Sohn |
ArchiveCommand ArchiveCommand |
3 |
3445 |
Thu, 14 February 2013 08:19 By: Matthias Sohn |
Share project moves files why are sources moved after share project |
4 |
11537 |
Mon, 11 February 2013 18:18 By: Jeff Miller |
"Cherry pick failed" problem on my end, or regression? |
2 |
6872 |
Fri, 08 February 2013 14:39 By: Fabien F. |
Synchronize View |
3 |
4985 |
Tue, 05 February 2013 15:45 By: R Shapiro |
accessing Github from behind an http proxy |
3 |
15701 |
Mon, 04 February 2013 08:28 By: Michael Schmidt |
How to separate Eclipse and Git metadata |
10 |
24852 |
Mon, 04 February 2013 00:07 By: Robin Rosenberg |
"Building Workspace" slow with EGit 1.1 and Nightly |
9 |
20105 |
Wed, 30 January 2013 20:36 By: Breton Tillinghast |
Saving remote repository information Having to manually type in remote repository details on every push is tiresome |
2 |
4773 |
Tue, 29 January 2013 22:18 By: wd40bomber7 P |
quick diff with index as baseline? |
1 |
4914 |
Sun, 27 January 2013 22:52 By: Robin Rosenberg |
JGit TagCommand Having trouble making a tag via JGit |
6 |
9444 |
Sun, 27 January 2013 01:07 By: Gurce Isikyildiz |
crash during install of EGit plugin in Eclipse Indigo In attempting to install the EGit plugin I get a crash |
2 |
3175 |
Thu, 24 January 2013 22:16 By: Robin Rosenberg |
Unable to push commits with EGit Error occurred during unpacking on the remote end |
0 |
9797 |
Wed, 23 January 2013 05:29 By: Robert Jewett |
["Solved"] Commit in submodule wants to remove and re-add all files with folder appended a ["Solved"] Commit in submodule wants to remove and re-add all files with foldername appended as prefix. |
3 |
7691 |
Tue, 22 January 2013 13:44 By: Mads Baggesen |
Equivalent of `git add -A` and `git show` in jGit |
3 |
5013 |
Tue, 22 January 2013 07:40 By: Robin Rosenberg |
RefSpec question Git vs. Egit RefSpec question Git vs. Egit |
1 |
5208 |
Fri, 18 January 2013 14:03 By: R Shapiro |
How to on EGit How can I perform these commands? By: Leo B on Thu, 17 January 2013 |
1 |
2887 |
Fri, 18 January 2013 13:36 By: R Shapiro |
GitHub Mylyn Connector 2.2 |
2 |
10883 |
Mon, 14 January 2013 21:38 By: Philippe |
forced push automatically does force fetch? |
2 |
3085 |
Fri, 11 January 2013 18:29 By: Rob Cernich |
Can EGit be used to version control Linked Folder content |
10 |
11952 |
Fri, 11 January 2013 07:34 By: Mike Whittaker |
Single file is shown several times in commit dialog |
3 |
3585 |
Thu, 10 January 2013 19:58 By: Jan Poeschko |
How to clone when git-upload-pack is at custom location on the server? In command line, I would use the "-u" option, but I could not find anything similar on the EGit GUI. |
1 |
5775 |
Wed, 09 January 2013 22:27 By: Matthias Sohn |
Flash Builder 4.7, eGit and the 'Label Decorations' |
2 |
9034 |
Wed, 09 January 2013 22:04 By: Matthias Sohn |
Commit->Push->Push Upstream-> Argh!!! |
6 |
17446 |
Wed, 09 January 2013 22:02 By: Matthias Sohn |
credentials not passed with git://... no credentials are passed to FW/proxy server |
2 |
2555 |
Wed, 09 January 2013 21:33 By: Matthias Sohn |
credentials passed to proxy server which protocols pass credentials and which not? |
4 |
12011 |
Wed, 09 January 2013 21:27 By: Matthias Sohn |
Missing Feature |
7 |
6664 |
Wed, 09 January 2013 20:54 By: Matthias Sohn |
Understanding Branches |
4 |
2892 |
Wed, 09 January 2013 20:06 By: Dennis Putnam |
[RESOLVED] Cannot ignore files/directories |
6 |
15261 |
Thu, 03 January 2013 18:26 By: Philippe |
[RESOLVED] Help Setting Up Eclipse with Egit |
9 |
8557 |
Thu, 03 January 2013 13:51 By: Dennis Putnam |
Is it possible to reutilize git repository of tortoisegit within Egit |
1 |
4900 |
Fri, 28 December 2012 17:48 By: R Shapiro |
"Merge Tool" greyed out |
1 |
5945 |
Sun, 23 December 2012 22:00 By: Robin Stocker |
2.3.0 missing project-set support? |
1 |
2610 |
Sun, 23 December 2012 19:07 By: Robin Stocker |
Problem when merging |
2 |
3953 |
Sun, 23 December 2012 19:02 By: Robin Stocker |
Delete Added Line fails to delete LF at end of file |
2 |
3551 |
Sat, 22 December 2012 14:16 By: R Shapiro |
Egit well installed, but no GIT menu I can't use EGit whatever I want to do (no team, no preferences item) |
5 |
6514 |
Fri, 21 December 2012 08:28 By: GWENN BOURREE |
How to untrack already tracked files Untrack indexed files |
2 |
17305 |
Thu, 20 December 2012 16:22 By: Matthias Sohn |
Synchronize View remains empty despite lots of unstaged changes? Cannot reliably get Synchronize View to show unstaged changes |
3 |
11900 |
Thu, 20 December 2012 12:58 By: Amelie Mentor |
Egit library ( get repository name by project) |
1 |
3047 |
Tue, 18 December 2012 20:36 By: Robin Rosenberg |
How to use Egit by code |
1 |
3990 |
Tue, 18 December 2012 20:26 By: Robin Rosenberg |
JGit Logging in Eclipse More visibility into what Git is doing By: Alexi on Fri, 25 March 2011 |
5 |
11268 |
Tue, 18 December 2012 20:22 By: Robin Rosenberg |
Effective Configuration properties display broken? Effective Configuration properties display not showing Global props |
2 |
3058 |
Sat, 15 December 2012 14:07 By: R Shapiro |
eGit Move files from GIT repo. to none GIT repo. |
1 |
2250 |
Thu, 13 December 2012 08:30 By: Matthias Sohn |
JGIT Get Path |
5 |
4913 |
Wed, 12 December 2012 04:23 By: Daniel Wurz |
Help: Unable to merge between two users |
3 |
6658 |
Mon, 10 December 2012 15:11 By: R Shapiro |
Cannot Install on CFBuilder Get a "Cannot complete the install" error |
2 |
4823 |
Mon, 10 December 2012 02:42 By: Doug Smith |
Branch with closed projects |
2 |
2992 |
Fri, 07 December 2012 13:04 By: Fabien F. |
Problem connecting Mylyn remote repo with github issues repo Problem connecting Mylyn remote repo with github issues repo |
2 |
8062 |
Wed, 05 December 2012 19:14 By: Rick Horowitz |
Existing project with multiple git repos Making egit aware of multiple repos in existing project |
5 |
7079 |
Sun, 02 December 2012 20:10 By: Armond Paiva |
Unable to use key file SSH |
2 |
18035 |
Fri, 30 November 2012 23:57 By: Tom Semple |
Build cloned files ? Build button grayed out... |
20 |
14505 |
Thu, 29 November 2012 15:32 By: Stefan Lay |
Eclipse editor features stop working eclipse editor features stop working in egit repository related project |
7 |
15004 |
Tue, 27 November 2012 20:44 By: David Mårtensson |
Wrong remotes are used in PHP Explorer View |
0 |
12126 |
Mon, 26 November 2012 11:13 By: Marc Missing name |
How to build the update site locally |
5 |
4692 |
Sun, 25 November 2012 09:14 By: François Rey |
Push and Pull errors |
2 |
6168 |
Fri, 23 November 2012 08:12 By: Stefan Lay |
Pull and MERGE_RESOLVED Questions |
4 |
33919 |
Fri, 23 November 2012 08:09 By: Stefan Lay |
Any way to launch a three-way merge with EGit? |
4 |
10844 |
Thu, 22 November 2012 09:46 By: Laurent Goubet |
Force using JSch instead of TortoisePlink on Windows ? |
2 |
5677 |
Mon, 19 November 2012 06:50 By: Matthias Sohn |
pull from another remote/branch how to pull from another remote/branch, for example when working on a forked repo. |
4 |
27618 |
Fri, 16 November 2012 09:51 By: Stefan Lay |
GIT Hooks Why don't my GIT Hooks work? |
6 |
16130 |
Fri, 16 November 2012 08:47 By: Matthias Sohn |
Reduce walk memory usage Possibilities for reducing memory usage. |
2 |
3820 |
Fri, 16 November 2012 08:37 By: Stefan Lay |
Commit/amend not possible Merge commit is not possible if nothing is changed comparing to last local commit |
1 |
6415 |
Mon, 12 November 2012 12:58 By: Eugene Kondrashev |
Move local git repository |
2 |
6664 |
Thu, 08 November 2012 19:25 By: Robin Rosenberg |
Merge tool - repository merge view shows non-conflicting files Trying to understand what the structure compare view in the merge tool is showing me. |
5 |
9058 |
Tue, 06 November 2012 23:17 By: Matthias Sohn |
EGit imported repositories are not connected to Git once added see title By: JD Wong on Tue, 06 November 2012 |
3 |
3143 |
Tue, 06 November 2012 22:55 By: Matthias Sohn |
Does Egit support shallow clone yet? |
2 |
5567 |
Fri, 02 November 2012 09:55 By: Maxmelbin Neson |
Is it possible to squash commit by rebasing? rebase |
1 |
3802 |
Thu, 01 November 2012 22:39 By: Robin Rosenberg |
JGit working in Android; Lcom/jcraft/jsch/Channel errors? By: James B on Wed, 17 October 2012 |
4 |
8143 |
Thu, 01 November 2012 13:49 By: James B |
Rebase quirk Explicit rebase v implicit rebase via pull |
3 |
4165 |
Wed, 31 October 2012 17:03 By: R Shapiro |
Support required in Submodules in EGIT |
1 |
4651 |
Mon, 29 October 2012 09:47 By: Olivier CARRERE |
Trouble Adding Existing Local Git Repository |
3 |
6541 |
Sun, 28 October 2012 22:13 By: Matt Donnelly |
symlinks under git repository are tagged for removal at each commit symlinks |
7 |
14008 |
Sat, 27 October 2012 11:46 By: Klemens Ullmann-Marx |
Exception on first connection attempt to GitHub |
2 |
4322 |
Sat, 27 October 2012 07:28 By: Luís de Sousa |
EGit and symbolic links |
5 |
7200 |
Wed, 24 October 2012 16:19 By: Pascal Maurel |
Patches do not end with new line Patches do not end with new line - git reports them as corrupt |
1 |
15143 |
Wed, 24 October 2012 15:54 By: Mark Dexter |
Problem with exception for ls-remote My setings seem to work, but not for EGit |
3 |
15788 |
Tue, 23 October 2012 10:18 By: Alex Mising name |
Importing projects from git using new project wizard using the new project wizard files don't appear in project |
0 |
14178 |
Mon, 22 October 2012 21:33 By: Bruno Santos |
Accessing the full history of a file |
0 |
14165 |
Mon, 22 October 2012 14:00 By: Laurent Goubet |
show in repositories view, show in history broken After upgrading to 2.1 they stopped working |
2 |
2876 |
Thu, 18 October 2012 16:12 By: Jose Vidal |
Submodules do not work with staging view and project explorer |
3 |
5021 |
Tue, 16 October 2012 13:01 By: Maxmelbin Neson |
configure display of latest branch commit? |
0 |
14153 |
Mon, 15 October 2012 13:54 By: R Shapiro |
fatal: ambiguous argument 'origin/master': unknown revision or path not in the working tree. By: Eugene on Fri, 12 October 2012 |
2 |
14024 |
Fri, 12 October 2012 14:26 By: Eugene |
How to clone or checkout a specific branch ? Check out a branch |
1 |
16145 |
Fri, 12 October 2012 10:50 By: Christian Halstrick |
rebase fails: "cannot delete file" |
5 |
6234 |
Thu, 11 October 2012 17:19 By: Brian Vosburgh |
EGit does not honor ~/.hushlogin EGit does not honor ~/.hushlogin |
0 |
13637 |
Thu, 11 October 2012 17:16 By: Andrew DeFaria |
Push error: git-receive-pack not permitted Push error: git-receive-pack not permitted |
3 |
52929 |
Thu, 11 October 2012 14:38 By: Kathleen Justice |
Preparing cvs->git Migration: Developer workflow Problems finding future patch workflow for developers |
4 |
4389 |
Thu, 11 October 2012 12:46 By: R Shapiro |
EGit https clone |
7 |
14031 |
Tue, 09 October 2012 18:24 By: Sergey Kuznetsov |
Egit "clean"? |
0 |
15100 |
Sun, 07 October 2012 17:38 By: R Shapiro |
Staging and explorer view wrongly show files as changed |
1 |
3111 |
Sat, 06 October 2012 15:36 By: R Shapiro |
JGit/EGit now supports gc? |
1 |
5200 |
Fri, 05 October 2012 21:40 By: Christian Halstrick |
Data transfer without file system |
2 |
3223 |
Fri, 05 October 2012 20:56 By: R Shapiro |
How to checkout previous revision? |
8 |
19883 |
Fri, 05 October 2012 18:35 By: Luís de Sousa |
Checkout private repositories How to checkout private repositories with username and password |
2 |
3312 |
Fri, 05 October 2012 16:44 By: kaleeswaran S |
Merge disabled Merge is disabled ,grayed out |
7 |
20877 |
Thu, 04 October 2012 14:09 By: Ryan How |
EGit on Mac OS X 10.8.x |
1 |
4174 |
Wed, 03 October 2012 19:19 By: Marc Fournier |
Fetch is asking for Source? Help Me |
0 |
14636 |
Wed, 03 October 2012 17:18 By: Daniel Woodward |
Creating a new file ending in .orig. Looking for a way to create a new file called file.orig. |
2 |
3114 |
Tue, 02 October 2012 19:06 By: Phil Rau |
Unstaging changes during a merge Potential dangerous behavior |
2 |
4058 |
Tue, 02 October 2012 09:25 By: Christian Halstrick |
Bogus syntax complaint |
3 |
5109 |
Mon, 01 October 2012 17:42 By: R Shapiro |
branch deletion broken in Juno? |
9 |
5857 |
Mon, 01 October 2012 13:22 By: Manuel Doninger |
Git as a folder in an existing project egit repository under another |
4 |
3340 |
Fri, 28 September 2012 13:24 By: elric best |
Auto-share projects not working as intended? |
2 |
18796 |
Fri, 28 September 2012 08:50 By: Robert Munteanu |
History list of commits invisible |
4 |
7886 |
Thu, 27 September 2012 20:43 By: Matthias Sohn |
jGit FetchCommand By: R J on Fri, 14 September 2012 |
1 |
4304 |
Thu, 27 September 2012 15:18 By: Matthias Sohn |
Use EGit For PHP Deployment (like FTP client) |
1 |
3284 |
Thu, 27 September 2012 14:32 By: Matthias Sohn |
Location of working source? EGit doesn't seem to allow me to work the way I want to |
8 |
8705 |
Wed, 26 September 2012 08:11 By: Owen Nargodren |
Is the stash/apply running well in EGit 2.0 stash |
3 |
6622 |
Tue, 25 September 2012 12:42 By: R Shapiro |
Error when trying to use existing git repository |
7 |
31600 |
Mon, 24 September 2012 22:35 By: Robin Rosenberg |
Pull with EGit |
1 |
7770 |
Sun, 16 September 2012 21:27 By: Jeremy Krentz |
create patch and gitignore |
1 |
3359 |
Fri, 07 September 2012 10:26 By: Martin Eisengardt |
EGit and repositories with large files |
2 |
3960 |
Thu, 06 September 2012 13:00 By: Piotr Tomiak |
Weird Simply in front of project name,I can not use some egit funtion s |
3 |
6851 |
Thu, 06 September 2012 06:56 By: Stefan Lay |
EGit Annotations Across All Branches |
2 |
5249 |
Wed, 05 September 2012 18:26 By: Robin Rosenberg |
JGit Custom Command |
2 |
3917 |
Tue, 04 September 2012 02:15 By: Joseph Carroll |
Merge tool disabled on conflict mode |
1 |
7574 |
Mon, 03 September 2012 21:08 By: Matthias Sohn |
EGit and Google repo not working on Windows with Cygwin EGit (version > 1.1.0) does not work with repo managed repositories on Windows with Cygwin due to the use of symlinks. |
5 |
9347 |
Mon, 03 September 2012 09:07 By: Ken Wenzel |
Eclipse Mylyn Connector |
1 |
2313 |
Wed, 29 August 2012 21:10 By: Kevin Sawicki |
JGit Branches onto Remote master By: R J on Fri, 24 August 2012 |
2 |
3578 |
Tue, 28 August 2012 11:28 By: R J |
What are the steps to use Egit with Bitbucket I have several problems with what I follow now. I need to know the correct procedure. |
1 |
7265 |
Mon, 27 August 2012 11:58 By: Stefan Lay |
EGit variables not set on selection in Repositories view |
1 |
3392 |
Fri, 24 August 2012 16:20 By: Robin Rosenberg |
JGit Adding Files By: R J on Thu, 23 August 2012 |
2 |
3260 |
Fri, 24 August 2012 08:27 By: Christian Halstrick |
Missing "Multi-Pull" |
2 |
4269 |
Fri, 24 August 2012 05:45 By: Matthias Sohn |
Not Able to switch from one branch to another Egit Problem in branch switching |
2 |
5628 |
Fri, 24 August 2012 05:02 By: Manish Arora |
remote git init failed? Trying to synchronize project on remote server |
4 |
6902 |
Thu, 23 August 2012 16:43 By: Antelmo Aguilar |
JGit Committing Into a specific branch By: R J on Thu, 23 August 2012 |
3 |
3031 |
Thu, 23 August 2012 14:02 By: R J |
Remote Tracking autoupdate does'nt work - feature or bug? |
2 |
2970 |
Wed, 22 August 2012 11:37 By: Sergey Mukhin |
Support for EGit |
0 |
17388 |
Tue, 21 August 2012 05:42 By: Annamalai Mising name |
JGit diff word by word |
1 |
2971 |
Mon, 20 August 2012 22:07 By: Robin Rosenberg |
Not saving "Synchronize Git" information |
5 |
4998 |
Mon, 20 August 2012 10:31 By: Dariusz Luksza |
JGit - Override paintCommit (AbstractPlotRenderer) |
0 |
16862 |
Sun, 19 August 2012 22:17 By: Doru Chiulan |
still no decorations for local tracking? |
3 |
4200 |
Sun, 19 August 2012 13:31 By: R Shapiro |
Getting the list of modified files from a commit |
5 |
9100 |
Fri, 17 August 2012 13:11 By: Stefan Lay |
diff across a rename boundary? |
2 |
4494 |
Fri, 17 August 2012 12:33 By: Stefan Lay |
jgit diff from different revision |
1 |
3783 |
Fri, 17 August 2012 12:20 By: Stefan Lay |
Force modified eGIT version |
1 |
2929 |
Fri, 17 August 2012 11:44 By: Stefan Lay |
commit process hangs:() commit not possible |
14 |
19472 |
Wed, 15 August 2012 14:13 By: Heikki Vuolteenaho |
Working with Egit and non-Eclipse projects |
3 |
4447 |
Sat, 11 August 2012 20:54 By: Matthias Sohn |
Flash builder and Egit How to create versions |
1 |
4129 |
Sat, 11 August 2012 20:38 By: Matthias Sohn |
Remote helper integration |
2 |
4278 |
Fri, 10 August 2012 16:43 By: Andrey Pavlenko |
modify the EGit source |
2 |
3254 |
Fri, 10 August 2012 15:26 By: Matthias Sohn |
Commit causes lengthy reindexing of repository Commit causes lengthy reindexing of repository |
1 |
4238 |
Thu, 09 August 2012 01:35 By: R Shapiro |
Indexed changes in origin after push |
2 |
3738 |
Wed, 08 August 2012 14:34 By: Eugene Kondrashev |
Add Existing Local Repository programmatically |
0 |
18057 |
Mon, 30 July 2012 14:49 By: Jason Litton |
checkout with setUpstreamMode doesn't update config |
1 |
3857 |
Fri, 27 July 2012 17:52 By: Robin Rosenberg |
Push to upstream - confusing dialogue |
11 |
15672 |
Sat, 21 July 2012 11:42 By: R Shapiro |
www.eclipse.org/egit unreachable? |
2 |
3210 |
Fri, 20 July 2012 18:50 By: Kay Huber |
GitHub Gists Context menu options are not responsive |
5 |
5171 |
Thu, 19 July 2012 22:59 By: Ed Gruberman |
Line endings again |
18 |
32778 |
Thu, 19 July 2012 11:46 By: R Shapiro |
s3 git repository Can I use all git commands through jgit when hostin on s3 By: N Y on Tue, 17 July 2012 |
0 |
18222 |
Tue, 17 July 2012 22:29 By: N Y |
Update site problem |
2 |
2820 |
Tue, 17 July 2012 21:17 By: Robin Rosenberg |
Code Style @version tag for revision history. |
2 |
3727 |
Mon, 16 July 2012 22:41 By: Robin Rosenberg |
newbie import from git repository question |
5 |
132729 |
Sat, 14 July 2012 08:19 By: Alistair MacDougall |
egit cloning issue By: p b on Tue, 10 July 2012 |
1 |
4878 |
Fri, 13 July 2012 16:44 By: p b |
Maven multiple projects, some of them are not shared Try to share a Maven multiple projects, but some of them not shared |
0 |
24718 |
Fri, 13 July 2012 08:39 By: guofeng zhang |
Getting the changed text / old version of a file |
0 |
25421 |
Thu, 12 July 2012 12:43 By: John Hughes |
