  'X-M2M-Origin' header in OM2M
Where can I find 'X-M2M-Origin' header in OM2M?
By: Eclipse User on Fri, 14 June 2024
1 1732 Fri, 14 June 2024 04:07
  om2m MQTT Binding Procedure
Not able to do MQTT Binding in eclipse OM2M
By: Eclipse User on Wed, 11 January 2023
1 3414 Mon, 30 January 2023 06:03
  How can I use MongoDB with OM2M
Need help in helping in understanding how to use MongoDB with OM2M as there is a lack of documentation for the same.
By: Eclipse User on Tue, 05 October 2021
1 29790 Fri, 25 March 2022 13:23
  Uncaught TypeError: net.Socket is not a constructor
By: Eclipse User on Mon, 28 February 2022
0 4068 Mon, 28 February 2022 08:44
  Semantic Descriptor
OM2M semantic
By: Eclipse User on Fri, 25 February 2022
2 1558 Fri, 25 February 2022 10:31
  fail to create "MY_SENSOR" application
fail to create "MY_SENSOR" application due to 'AE resource /in-cse not found'
By: Eclipse User on Wed, 06 October 2021
3 3004 Mon, 11 October 2021 15:05
  fetch data
By: Eclipse User on Wed, 15 September 2021
0 3215 Wed, 15 September 2021 08:03
  Build OM2M ERROR
By: Eclipse User on Thu, 26 August 2021
1 1384 Thu, 26 August 2021 11:15
  Get 501 error Not Implemented when trying access CSE with "Cae-admin"
I'm student and i'm trying to use om2m, i used to get access to CSE successfully but now i get this error, plz let me know what to do.
By: Eclipse User on Thu, 01 July 2021
1 1266 Thu, 01 July 2021 07:57
  Changing IN-CSE user and password
By: Eclipse User on Tue, 09 March 2021
4 2210 Tue, 06 April 2021 15:34
  MQTT notifications not working
NullPointerException when creating new cin that trigger MQTT notification
By: Eclipse User on Thu, 01 April 2021
0 2209 Thu, 01 April 2021 03:39
  MN-CSE and IN-CSE Authentication
By: Eclipse User on Fri, 01 January 2021
1 4421 Wed, 13 January 2021 03:51
  getting 503 error Service Unavailable
I followed the instructions for installing om2m and running it but my in-cse is not running
By: Eclipse User on Sun, 10 January 2021
1 2988 Wed, 13 January 2021 03:46
  Problem when running MyMonitor example
the same problem output when I run MyMonitor example and MyManager example
By: Eclipse User on Thu, 19 December 2019
2 7065 Wed, 25 November 2020 02:32
  containerDefinition attribute must be provided.
Flex container creation error its showing "containerDefinition attribute must be provided."
By: Eclipse User on Tue, 15 September 2020
1 2862 Wed, 25 November 2020 02:30
  Does OM2M supports mqtt notifications?
By: Eclipse User on Tue, 10 November 2020
2 1581 Wed, 25 November 2020 02:27
  Is it possible to rely on mqtt for npotifications and HTTP for all other operations?
By: Eclipse User on Mon, 09 November 2020
1 2442 Wed, 25 November 2020 02:22
  Is this a bug? Or my fault?
OM2M
By: Eclipse User on Wed, 11 November 2020
0 2255 Wed, 11 November 2020 12:28
  Creating subscription on container using polling channel
OM2M polling channels
By: Eclipse User on Fri, 06 November 2020
2 1937 Fri, 06 November 2020 11:26
  Threads In OM2M
By: Eclipse User on Mon, 05 October 2020
0 1822 Mon, 05 October 2020 01:03
  OM2M - API documentation
By: Eclipse User on Sun, 12 July 2020
1 3317 Mon, 27 July 2020 03:21
  Connect OM2M with MySQL
Error SQL syntax
By: Eclipse User on Thu, 28 May 2020
0 2552 Thu, 28 May 2020 06:09
  error in running OM2M
By: Eclipse User on Wed, 20 November 2019
2 2519 Fri, 22 November 2019 03:58
  Subscription deleted
for unreachable target uri, subscription gets deleted
By: Eclipse User on Thu, 24 October 2019
2 2663 Mon, 18 November 2019 03:57
  ssl handshake exception
security on om2m
By: Eclipse User on Fri, 01 November 2019
0 4024 Fri, 01 November 2019 02:38
  print messages on console
print messages on incse console message not coming
By: Eclipse User on Wed, 30 October 2019
2 2555 Fri, 01 November 2019 01:37
  JSON content "con" attribute in ContentInstance
By: Eclipse User on Tue, 22 May 2018
5 5669 Wed, 30 October 2019 03:30
  problem to build om2m
Unable to build the om2m, following official website given steps
By: Eclipse User on Sat, 03 August 2019
1 1878 Fri, 18 October 2019 11:52
  Subscription resource is deleted
By: Eclipse User on Wed, 04 September 2019
6 2715 Fri, 06 September 2019 06:57
  Subscribe to MN-CSE CIN
By: Eclipse User on Tue, 21 May 2019
1 25724 Fri, 19 July 2019 10:12
  Forwarding Request MQTT
Using a central broker. All MN's an IN's connect through a central broker
By: Eclipse User on Fri, 19 July 2019
1 2079 Fri, 19 July 2019 10:02
  Discovery API
API Not working 6.2.8.4 API-DIS-CRB, API-DIS-CRA
By: Eclipse User on Sun, 30 June 2019
1 28388 Wed, 03 July 2019 04:18
  GROUP ACTIVITY
Documentation for GROUP Control/Read
By: Eclipse User on Mon, 24 June 2019
3 8795 Wed, 26 June 2019 01:00
  Problem building om2m following step by step cloning guide
By: Eclipse User on Wed, 13 June 2018
2 5439 Sat, 22 June 2019 05:21
  CORS issue
By: Eclipse User on Thu, 08 March 2018
1 7239 Tue, 28 May 2019 13:19
  [REQUEST] Official Release with MQTT binding feature pre-built
[Missing] MQTT binding enabled official release package in OM2M website
By: Eclipse User on Tue, 16 April 2019
0 41426 Tue, 16 April 2019 03:09
  org.eclipse.equinox.console bundle is missing
By: Eclipse User on Mon, 26 March 2018
4 3768 Tue, 16 April 2019 03:01
  MQTT: Error in creating container/content instance on MN-CSE/IN-CSE
By: Eclipse User on Fri, 16 February 2018
3 6307 Thu, 11 April 2019 09:35
  Test OM2M
The problem of how to build and test OM2M
By: Eclipse User on Thu, 26 July 2018
1 4897 Fri, 22 March 2019 05:33
  Registration between two MN
By: Eclipse User on Wed, 20 March 2019
0 18689 Wed, 20 March 2019 05:13
  Help Please! | Adding New Object to Wakaama client
Would like to create a temperature sensor for LwM2M client using wakaama implementation
By: Eclipse User on Mon, 18 February 2019
1 1969 Mon, 18 February 2019 08:24
  Multiple Content Instance Delete under Container throwing an error
I have created 10 Content Instances under a Container , while Retrieve i can able to get the Content Instances Data , but when i try to delete the Content Instances one by one i am facing an issue lik
By: Eclipse User on Wed, 06 February 2019
0 7997 Wed, 06 February 2019 01:42
  How to update content from http to mqtt?
By: Eclipse User on Sat, 19 January 2019
1 2915 Mon, 21 January 2019 20:58
  mqtt update content
How to update contnt from http to mqtt?
0 3474 Sat, 19 January 2019 06:17
  HTTPS notifications
missing https client binding
By: Eclipse User on Tue, 15 January 2019
0 3828 Tue, 15 January 2019 05:30
  Error when building om2m
I clone OM2M, but have some bug when building.
By: Eclipse User on Wed, 08 November 2017
15 10952 Sat, 29 December 2018 03:07
  ResourceType: 24 is not implemented
the problem to create flexContainer
By: Eclipse User on Sat, 24 November 2018
2 2259 Tue, 27 November 2018 03:04
  Implementation of oneM2M, Application & Service layer CSF and Security CSF
AE communication with a local CSE within an Application Service Node (ASN)
By: Eclipse User on Thu, 11 October 2018
0 3063 Thu, 11 October 2018 02:48
  coap Response byte structure
By: Eclipse User on Mon, 06 August 2018
0 3476 Mon, 06 August 2018 14:11
  Unable to receive Events(itemCommandEvent,ItemStateEvent) from ESH
1 2736 Fri, 27 July 2018 02:06
  Use TLS for IN-CSE and MN-CSE communication
By: Eclipse User on Mon, 02 July 2018
0 3788 Mon, 02 July 2018 10:12
  Unable to retrieve instance when using MongoDB
By: Eclipse User on Mon, 23 April 2018
1 7394 Wed, 13 June 2018 10:57
  OM2M MQTT-TLS
Security over MQTT
By: Eclipse User on Tue, 12 June 2018
0 4225 Tue, 12 June 2018 04:40
  Reference to request query fields
By: Eclipse User on Wed, 06 June 2018
2 2482 Wed, 06 June 2018 08:13
  A nullpointerException occur when i send CoAP message to IN-CSE
CoAP, OM2M
By: Eclipse User on Sun, 29 April 2018
2 3932 Thu, 31 May 2018 22:36
icon14.gif Using CoAP based applications (Copper vs Erbium)
By: Eclipse User on Fri, 07 November 2014
30 27783 Sun, 27 May 2018 08:38
  CoAP between App and in-cse
Problem in CoAP App
By: Eclipse User on Mon, 30 April 2018
1 4872 Wed, 16 May 2018 15:10
  monitor on python or monitor.jar source code or explanation
1 5454 Sat, 12 May 2018 11:04
  Connection between multiple servers or gateways.
By: Eclipse User on Wed, 09 May 2018
0 5416 Wed, 09 May 2018 12:26
  OM2M builds not working on RPI Board
By: Eclipse User on Tue, 10 January 2017
4 6109 Mon, 07 May 2018 11:13
  MN-CSE registered in other MN-CSE
MN-CSE_machine_3 -> MN-CSE_machine_2 -> IN-CSE_machine_1
0 6807 Mon, 23 April 2018 12:02
  Announce a resource
Question about resource announcement
By: Eclipse User on Mon, 16 April 2018
0 6204 Mon, 16 April 2018 10:39
  Hybrid addressing of a resource
By: Eclipse User on Tue, 03 April 2018
0 5772 Tue, 03 April 2018 06:30
  ACP (access control policy) fails on second update
0 6231 Tue, 03 April 2018 04:59
  Connection between two MN's and one IN
MN's interconnected and also with a IN
By: Eclipse User on Tue, 27 March 2018
0 5118 Tue, 27 March 2018 07:24
  Posting data object with MQTT
By: Eclipse User on Wed, 07 March 2018
1 5932 Thu, 22 March 2018 11:38
  OM2M MQTT Response Parameters
By: Eclipse User on Tue, 20 March 2018
2 3038 Wed, 21 March 2018 11:34
icon5.gif Connection Confusion IN-CSE and MN-CSE
The communication between IN and MN nodes are not clear, rather confusing
By: Eclipse User on Thu, 01 December 2016
3 8495 Sun, 18 March 2018 13:13
  Send data from gateway(mn) to server(in)
4 4317 Sun, 18 March 2018 11:39
  Writing IPU plugins for non ip enabled technologies (Zwave, ZigBee)
By: Eclipse User on Tue, 24 May 2016
10 10944 Wed, 14 March 2018 07:16
  Eclipse OM2M v1.3.0
6 5859 Wed, 14 March 2018 00:54
  Create AE via MQTT Binding
MQTT Binding
By: Eclipse User on Thu, 01 June 2017
25 25397 Mon, 12 March 2018 04:28
  Test MQTT blinding in OM2M
By: Eclipse User on Wed, 22 November 2017
4 9120 Tue, 06 March 2018 07:48
  NM-CSE registration error
The NM-CSE cannot registrer properly at second time
By: Eclipse User on Sat, 24 February 2018
0 5701 Sat, 24 February 2018 07:33
  connection between MN-CSE and IN-CSE
0 4545 Fri, 16 February 2018 07:36
  Configure OM2M to connect to the server
By: Eclipse User on Tue, 30 January 2018
2 3870 Sat, 03 February 2018 04:08
  Achieving authentication on a public OM2M-IN
By: Eclipse User on Mon, 22 January 2018
0 5976 Mon, 22 January 2018 07:37
  Error when sending content in http from arduino sensor node
By: Eclipse User on Wed, 10 January 2018
0 5699 Wed, 10 January 2018 23:58
  OM2M Compile Error
By: Eclipse User on Fri, 05 January 2018
1 3691 Mon, 08 January 2018 00:27
  osgi in saaj environment
how to deploy and monitor osgi bundle statuses with shell connection?
By: Eclipse User on Tue, 26 December 2017
0 12247 Tue, 26 December 2017 00:13
  add your plugin
By: Eclipse User on Thu, 03 March 2016
16 17792 Fri, 08 December 2017 21:44
  container class cast Exception (using mongodb)
when create container
By: Eclipse User on Thu, 23 November 2017
1 5968 Mon, 04 December 2017 10:29
  Device Management with LwM2M
By: Eclipse User on Wed, 28 December 2016
1 12496 Wed, 22 November 2017 04:44
  How to connect a sensor node to om2m using http?
By: Eclipse User on Tue, 14 November 2017
3 4243 Mon, 20 November 2017 05:49
  Is streaming camera video possible in OM2M?
If yes, how can this be done if the sensor node is raspberry pi?
By: Eclipse User on Sun, 19 November 2017
1 2977 Mon, 20 November 2017 02:33
  How to handle streaming data in OM2M?
By: Eclipse User on Mon, 25 April 2016
1 8689 Sun, 19 November 2017 10:07
  Child module problem when creating a new IPE plugin
By: Eclipse User on Sat, 08 October 2016
1 5078 Thu, 16 November 2017 05:17
  Issue after cloning OM2M v1.1
got errors and warnings
By: Eclipse User on Tue, 24 October 2017
5 6182 Wed, 15 November 2017 05:06
  MQTT?
is it already there?
By: Eclipse User on Wed, 11 February 2015
6 7860 Wed, 08 November 2017 04:46
  Notification over MQTT
Problem when sending a notification over MQTT
By: Eclipse User on Mon, 15 May 2017
1 16310 Wed, 08 November 2017 04:07
  communication between multiple IN-CSE
By: Eclipse User on Thu, 02 November 2017
0 4870 Thu, 02 November 2017 08:19
  MQTT Server Authorization (request/response topic)
By: Eclipse User on Wed, 21 June 2017
2 8918 Thu, 26 October 2017 21:38
  raspberry as gateway
By: Eclipse User on Sat, 15 April 2017
3 28002 Thu, 26 October 2017 13:45
  om2m and Iot
om2m and Iot
By: Eclipse User on Wed, 03 August 2016
5 9357 Tue, 24 October 2017 23:37
  Announced Resources handle in remote located IN-CSE
By: Eclipse User on Tue, 05 September 2017
2 15749 Tue, 24 October 2017 18:26
  IN-CSE is not showing Annc resources (Which are announced by MN-CSE)
0 4734 Tue, 24 October 2017 06:50
  OM2M in-cse and mn-cse connection through SSH port forwarding
By: Eclipse User on Tue, 17 October 2017
0 4462 Tue, 17 October 2017 09:47
  Question about non-server-capable application for subscription/notification scenarios
By: Eclipse User on Sun, 09 October 2016
1 6556 Mon, 18 September 2017 11:19
  New contentInstance is not created when a notification is received
why new contentInstance is not created when a notification is received
By: Eclipse User on Fri, 15 July 2016
2 8467 Wed, 13 September 2017 04:13
  Docker image for OM2M
By: Eclipse User on Fri, 11 March 2016
2 6100 Thu, 31 August 2017 06:14
  An easy way to switch DB
i'm looking for the easiest way to switch to Cassandra
By: Eclipse User on Tue, 22 August 2017
0 11082 Tue, 22 August 2017 11:09
  Location creation
LocationPolicy resource type not implemented
By: Eclipse User on Wed, 09 August 2017
0 6998 Wed, 09 August 2017 09:26
  OM2M performance for thousands of resources
By: Eclipse User on Wed, 02 August 2017
8 18504 Sun, 06 August 2017 21:27
  Usage of Postgre DB
SQL Syntax exception in Postgre
By: Eclipse User on Mon, 12 June 2017
0 13619 Mon, 12 June 2017 10:13
  om2m
By: Eclipse User on Wed, 07 June 2017
0 16386 Wed, 07 June 2017 06:46
  CoAP blockwise transfer
Californium 0.18.6 does not handle blockwise transfer correctly
By: Eclipse User on Tue, 30 May 2017
2 5314 Tue, 30 May 2017 14:44
  Query in OM2M
How to discovery a resource in OM2M
By: Eclipse User on Sat, 27 May 2017
0 12119 Sat, 27 May 2017 12:42
  RESTAPI to access the OneM2M resources
By: Eclipse User on Wed, 26 April 2017
1 23795 Sat, 27 May 2017 12:35
icon3.gif Eclipse OM2M roadmap for next releases
Discuss new features and track implementations
By: Eclipse User on Sun, 09 April 2017
12 31243 Sun, 21 May 2017 14:10
  Is Semantic Descriptor in OM2M implemented ?
By: Eclipse User on Tue, 17 January 2017
1 95656 Wed, 10 May 2017 05:52
  The difference
Difference between horizontal and vertical platform iot
By: Eclipse User on Mon, 06 February 2017
1 15400 Wed, 10 May 2017 05:46
  TImeSeries and timeSeriesInstance
By: Eclipse User on Wed, 10 May 2017
0 35396 Wed, 10 May 2017 03:41
  OneM2M Device Onboarding
How do an application onboard the devices
By: Eclipse User on Fri, 05 May 2017
1 14836 Mon, 08 May 2017 23:02
  Is there any SDK to use in the device?
hardware
0 26532 Fri, 05 May 2017 03:48
  Access control policies (oneM2M)
How to assign new ACPs to resources?
By: Eclipse User on Fri, 09 December 2016
2 11239 Thu, 04 May 2017 23:34
  Group resource-Fanout content instance
By: Eclipse User on Thu, 27 April 2017
2 8762 Fri, 28 April 2017 02:33
  Create OneM2M subscription resource with MQTT
1 9486 Fri, 28 April 2017 02:28
  CoAP tutorial
how to deal with OM2M using CoAP and legacy devices
By: Eclipse User on Wed, 10 August 2016
6 15177 Thu, 27 April 2017 00:46
icon5.gif waspmote on xbee
2 7670 Sun, 23 April 2017 11:38
  OM2M :Method Not Allowed Update on ContentInstance is not Allowed
unable to update a container instance
By: Eclipse User on Fri, 16 December 2016
8 7345 Sun, 23 April 2017 11:27
icon4.gif Problem with non blocking request (Synch)
By: Eclipse User on Sun, 19 March 2017
6 51800 Wed, 19 April 2017 15:21
  How does OM2M support the Device Management Protocol?
By: Eclipse User on Thu, 08 September 2016
4 14927 Thu, 13 April 2017 13:27
  Integrate MongoDB or any nosql databases
NoSQL databases for oneM2m
By: Eclipse User on Thu, 13 April 2017
1 6303 Thu, 13 April 2017 09:19
  Mqtt notifications regarding a oneM2M Subscription
By: Eclipse User on Mon, 10 April 2017
0 9980 Mon, 10 April 2017 08:44
  Communication between MNs (Middle nodes) without the help of IN (Infrastructure Node)
Is that possible?
By: Eclipse User on Sat, 11 March 2017
3 9065 Thu, 23 March 2017 10:30
  sending CoAP Get request to OM2M one by using Copper
By: Eclipse User on Thu, 23 March 2017
2 4702 Thu, 23 March 2017 10:27
  Regarding Subscription(onem2m)
how to get notification of the sensor data in my application?
By: Eclipse User on Wed, 22 March 2017
0 9408 Wed, 22 March 2017 06:56
icon5.gif Cannot access mn-cse resource from in-cse web interface
with the LAMP sample
By: Eclipse User on Thu, 16 March 2017
1 3151 Thu, 16 March 2017 18:29
  OM2M Subscription, H2 and MongoDB
By: Eclipse User on Tue, 29 November 2016
4 10621 Tue, 14 March 2017 07:57
  Dynamically discovering and connecting remote CSEs and AEs.
By: Eclipse User on Wed, 18 January 2017
1 100939 Mon, 30 January 2017 07:10
icon5.gif Problem in Custom Access Control Policy Creation
Create Custom Access Control Policy, creation request originate from MN-AE
By: Eclipse User on Thu, 19 January 2017
0 97974 Thu, 19 January 2017 06:28
  Supports for mgmtCmd
By: Eclipse User on Thu, 12 January 2017
0 27123 Thu, 12 January 2017 04:42
  CoAP request Option ONEM2M_FRis not working
CoAP request with Option Option(256, "admin:admin") is not working
By: Eclipse User on Mon, 09 January 2017
1 5199 Wed, 11 January 2017 08:41
  CoAP Authentication in Request Option Bug
By: Eclipse User on Wed, 11 January 2017
1 3124 Wed, 11 January 2017 08:39
  (XML or JSON) Serialization of the request and response primitives in MQTT protocol
By: Eclipse User on Sun, 01 May 2016
9 9641 Wed, 11 January 2017 05:24
  MN-CSE Container Capacity
By: Eclipse User on Mon, 26 December 2016
2 13349 Sat, 07 January 2017 00:10
  What is the purpose of configuring RequestIdentifier?
By: Eclipse User on Thu, 05 January 2017
1 3328 Fri, 06 January 2017 05:28
  OM2M - Missing data in NSCL
By: Eclipse User on Sat, 10 December 2016
10 7535 Thu, 05 January 2017 11:41
icon9.gif Develop Applications
idea
By: Eclipse User on Tue, 27 December 2016
2 12872 Wed, 04 January 2017 06:12
  OMA DM support for Eclipse OM2M
Is OMADM_mapping plugin supported?
By: Eclipse User on Thu, 29 December 2016
0 16547 Thu, 29 December 2016 13:20
  Develop oneM2M Applications
applications
0 11509 Tue, 27 December 2016 05:17
  MN-CSE dynamic IP
0 11347 Mon, 26 December 2016 21:08
  Router Internal Error when running tutorial application
By: Eclipse User on Thu, 15 December 2016
7 9471 Fri, 23 December 2016 09:53
  Security in OM2M release1
By: Eclipse User on Mon, 25 July 2016
3 6147 Fri, 23 December 2016 03:32
  reel sensor discovery on the beagleboard/raspberry pi
How to push the date from the sensor to the gateway
By: Eclipse User on Sat, 03 December 2016
5 11544 Mon, 19 December 2016 04:29
  how to run OM2M Application from tutorial & what is the difference between application and plugi
2 7431 Thu, 15 December 2016 13:27
  OM2M - Max throughput
By: Eclipse User on Wed, 07 December 2016
1 2335 Wed, 07 December 2016 18:28
  new clone OM2M version (clone on 3.12.2016) not working?
By: Eclipse User on Fri, 02 December 2016
2 4748 Fri, 02 December 2016 20:53
  IPU Monitor
IPU Monitor
By: Eclipse User on Mon, 28 November 2016
3 3756 Thu, 01 December 2016 11:40
  How to use the DiscoveryController
By: Eclipse User on Sun, 27 November 2016
0 6620 Sun, 27 November 2016 14:44
  Missing start level 3 for in-cse product
By: Eclipse User on Tue, 22 November 2016
2 3879 Tue, 22 November 2016 05:20
  How to perform the Discovery request in OM2M
By: Eclipse User on Fri, 11 November 2016
0 42413 Fri, 11 November 2016 07:27
  cannot open Eclipse on mac
By: Eclipse User on Tue, 25 October 2016
1 3636 Tue, 25 October 2016 09:28
  Add new MN-CSE or ASN-CSE
how to add new MN-CSE or ASN-CSE
By: Eclipse User on Sun, 23 October 2016
3 3233 Sun, 23 October 2016 13:32
  CoAPExchange Response Code
CoAP,OM2M
By: Eclipse User on Mon, 17 October 2016
0 15415 Mon, 17 October 2016 04:12
icon8.gif where is the OM2M-libs.rar
OM2M
2 4315 Wed, 12 October 2016 12:00
  MN-CSE levels
Is it possible to configure an MN-CSE behind another MN-CSE ( cascading 2 levels of MN-CSE)?
By: Eclipse User on Fri, 30 September 2016
4 6794 Tue, 04 October 2016 16:11
  "Error 5000 java.lang.ClassCastException" when creating a subscription from an IN to ASN
By: Eclipse User on Tue, 04 October 2016
0 5006 Tue, 04 October 2016 09:50
  asking about receiving notification in OM2M
0 4161 Tue, 04 October 2016 04:14
icon12.gif Some question regardings the topic "Standard-Compliant Application"
By: Eclipse User on Mon, 26 September 2016
0 6595 Mon, 26 September 2016 09:48
  asking about OM2M component
By: Eclipse User on Wed, 21 September 2016
4 3915 Fri, 23 September 2016 09:27
  send SIP message to PhonerLite from IN-CSE
By: Eclipse User on Wed, 14 September 2016
1 2645 Wed, 14 September 2016 07:55
0 4619 Wed, 14 September 2016 06:19
  How to start the plugin which not located in CSE
By: Eclipse User on Tue, 13 September 2016
0 4544 Tue, 13 September 2016 05:02
  Is the CoAP binding protocol not fully supported in OM2M?
CoAP Rest Client can not be found in mn-cse
By: Eclipse User on Mon, 29 August 2016
6 13231 Mon, 12 September 2016 05:28
  Does end-user applications can interact directly with MN-CSE ?
By: Eclipse User on Tue, 06 September 2016
8 6499 Fri, 09 September 2016 10:07
  What is ASN-CSE and ADN-CSE?
2 9785 Fri, 09 September 2016 06:10
where is the OM2M-libs.rar link?
0 4742 Thu, 08 September 2016 20:00
  How to add a string to the body of contentInstance?
By: Eclipse User on Thu, 01 September 2016
3 34134 Thu, 08 September 2016 05:18
  How to start the plugin automatically?
By: Eclipse User on Mon, 05 September 2016
2 2970 Tue, 06 September 2016 04:55
  Problems when Running CoAP monitor within a plug-in application
1 31773 Mon, 05 September 2016 04:43
  How to connect in-cse and mn-cse which located in different network
By: Eclipse User on Mon, 08 August 2016
3 3854 Thu, 01 September 2016 08:45
  Error code 4103 and 5000 when receiving notification response
By: Eclipse User on Fri, 26 August 2016
2 5450 Tue, 30 August 2016 10:57
  Error in OSGi console
OM2M, OSGi, Linux Debian
By: Eclipse User on Tue, 23 August 2016
2 5696 Tue, 30 August 2016 10:49
  Router internal error when running in-cse
When I run the in-cse, the in-cse waiting for new cse connecting! but the error happen!
By: Eclipse User on Mon, 22 August 2016
1 5319 Tue, 30 August 2016 10:40
  Use REST client to change the attribute of Container
2 4611 Tue, 30 August 2016 10:06
  responseStatusCode=5204, error when create subscription of IN data to MN(solved)
By: Eclipse User on Tue, 30 August 2016
0 32995 Tue, 30 August 2016 05:20
  OM2M semanticDescriptor resource
1 2884 Fri, 26 August 2016 05:05
  Connect devices to your gateway
Two mechanisms showing how to connect devices to the gateway.
By: Eclipse User on Sat, 28 February 2015
1 6588 Wed, 24 August 2016 09:40
icon12.gif Is the redirect request between CSE always HTTP Protocol?
Is the redirect request between CSE always HTTP Protocol? CoAP request can not be sent using port 5684
0 7203 Tue, 23 August 2016 16:50
  Router internal error when running in-cse in MAC OS
I run in-cse in MAC OS but it occurs a problem with the notice like Router internal error! Please help me to solve this problem! Thank you so much!
0 4957 Tue, 23 August 2016 01:33
  oneM2M and CoAP
Tutorial required
By: Eclipse User on Mon, 07 March 2016
4 5842 Mon, 22 August 2016 07:14
  Add a new plugin in OM2M (without Eclipse)
By: Eclipse User on Wed, 22 June 2016
3 5244 Tue, 16 August 2016 09:43
  OM2M using COAP Protocol
How to configure COAP binding in to eclipse IN-CSE and MN-CSE stack
1 4849 Tue, 16 August 2016 08:17
  Does OM2M support oneM2M Release 2 (i.e. Semantics)?
0 5629 Wed, 10 August 2016 23:07
  Is it possible that the mn-cse running alone without registering to in-cse?
By: Eclipse User on Tue, 02 August 2016
1 3605 Thu, 04 August 2016 06:01
  responseStatusCode=4103 (Unknown or unauthorized originator) when notify to AE resource
By: Eclipse User on Tue, 26 July 2016
35 23141 Sat, 30 July 2016 19:15
  how to set the POA address for AE correctly?
By: Eclipse User on Sat, 30 July 2016
1 4142 Sat, 30 July 2016 11:19
  why do we need mn cse and in cse?
why do we need mn cse and in cse in om2m and what are their differences?
6 4554 Thu, 28 July 2016 04:40
  Source code for OM2M v0.8
By: Eclipse User on Wed, 27 July 2016
2 2614 Wed, 27 July 2016 08:30
  OM2M on Android
By: Eclipse User on Tue, 19 July 2016
3 4009 Sun, 24 July 2016 13:41
  Subscriptions
How To Subscribe to GSCL resources
By: Eclipse User on Fri, 04 July 2014
18 18726 Fri, 15 July 2016 10:13
  Two general questions: Managing library dependencies and referencing local directories
By: Eclipse User on Wed, 13 July 2016
0 4546 Wed, 13 July 2016 14:35
  Ask a question about subscribe a lamp event
How to get DAO value?
By: Eclipse User on Sat, 18 June 2016
4 5245 Tue, 12 July 2016 20:13
  Communication between two plugins
By: Eclipse User on Tue, 15 December 2015
11 9792 Fri, 08 July 2016 04:28
  Trouble with dependencies
By: Eclipse User on Fri, 01 July 2016
3 4415 Wed, 06 July 2016 11:49
  Running mn-cse in virtual machine.
By: Eclipse User on Thu, 30 June 2016
8 5716 Wed, 06 July 2016 11:46
  Create your own Plugin
Error in given code
By: Eclipse User on Thu, 16 June 2016
2 6523 Wed, 06 July 2016 08:58
  How to send sensor value to actuator plug-in
By: Eclipse User on Tue, 05 July 2016
6 5406 Wed, 06 July 2016 08:53
  HTTP Error 404 when running om2m on Ubuntu 12.04
By: Eclipse User on Tue, 12 April 2016
5 12924 Wed, 06 July 2016 08:41
Current Time: Fri Jul 25 21:56:26 EDT 2025
Powered by FUDForum. Page generated in 1.03971 seconds
