  Announcement: Forum closed
Please visit: https://github.com/eclipse/kura
By: Eclipse User on Wed, 28 June 2023
0 3455 Wed, 28 June 2023 10:11
  Difference between "device.custom-name" & "Device Custom-Name"
By: Eclipse User on Fri, 14 April 2023
2 1311 Fri, 14 April 2023 06:49
  Eclipse Kura 5 Deploy Script (bulk deploy)
Deployment Packages installation without Web UI
By: Eclipse User on Fri, 27 January 2023
2 1616 Fri, 27 January 2023 05:31
  Cannot connect to AWS IoT
Problem with connect to AWS IoT with Kura 5.1.2
By: Eclipse User on Fri, 11 November 2022
2 2675 Wed, 23 November 2022 13:00
  Running Kura docker container
Could not initialize class org.eclipse.kura.linux.usb.LinuxUdevNative
By: Eclipse User on Tue, 16 August 2022
1 3249 Sun, 20 November 2022 12:50
  Raspberry pi kura web ui
the site can't be reached problem
By: Eclipse User on Sun, 13 November 2022
1 2360 Sun, 20 November 2022 12:49
  Help updating artifact.xml and content.xml for Kura target-definition
By: Eclipse User on Mon, 18 July 2022
1 2349 Wed, 20 July 2022 03:43
  BLE disableValueNotifications does not remove callbacks
BLE Value notification callbacks.
By: Eclipse User on Fri, 11 February 2022
0 3948 Fri, 11 February 2022 05:59
  IntelliJ IDEA support
By: Eclipse User on Sun, 09 January 2022
3 2280 Mon, 10 January 2022 10:36
  custom topic
is any easy way to set my topic template
By: Eclipse User on Mon, 28 September 2020
6 2852 Thu, 11 November 2021 11:38
  Kura on RaspberryPI4 8GB Ram on Ubuntu 18.04
By: Eclipse User on Wed, 27 October 2021
1 1593 Wed, 27 October 2021 05:19
  Kura 5 Snapshot release: Invalid keystore format
Jetty server refuses to start because of inability to read certs
By: Eclipse User on Tue, 28 September 2021
4 2595 Tue, 28 September 2021 13:27
  Starting with Kura Emulator (Simulation)
By: Eclipse User on Tue, 28 March 2017
3 8510 Wed, 11 August 2021 01:02
  OPCUA Connection Reconnect using Milo opcua code
OPCUA Connection Reconnect once get disconnected
By: Eclipse User on Tue, 10 August 2021
0 2491 Tue, 10 August 2021 05:55
  GPIO PinStatusListener
Adding PinStatusListener to a input type gpio throws unsupportedoperationexception
By: Eclipse User on Sat, 24 July 2021
1 1650 Wed, 28 July 2021 11:24
  Cloud connection-Eclipse IoT Subscriber
By: Eclipse User on Fri, 16 July 2021
2 1668 Thu, 22 July 2021 06:38
  Data export from STEP 7 (TIA V16)
PLC- data into influxdb via Kura
By: Eclipse User on Wed, 21 July 2021
0 2179 Wed, 21 July 2021 10:58
  Change log level at runtime
By: Eclipse User on Tue, 07 April 2015
7 12517 Thu, 29 April 2021 06:38
  Kura and Java 11
By: Eclipse User on Mon, 15 February 2021
4 2144 Wed, 21 April 2021 04:57
  Connect to broker on pi
connection to broker on pi fails
By: Eclipse User on Wed, 20 January 2021
3 2046 Thu, 25 March 2021 08:48
  Reusable UI with Eclipse Kura /Basys
By: Eclipse User on Fri, 19 March 2021
1 2662 Thu, 25 March 2021 08:45
  Kura show software status details in WebUI
By: Eclipse User on Fri, 12 February 2021
1 5659 Sun, 21 March 2021 16:26
  I am unable to access raspberry pi 3 using VNC after installing kura
I use my raspberry pi through VNC but after installing Kura on it my wifi has stopped working and i am unable to access it by using VNC. However i can login through SSH
By: Eclipse User on Sun, 25 March 2018
5 3364 Wed, 03 March 2021 09:04
  Publish high rate messages with DataService without H2DbService
By: Eclipse User on Thu, 25 February 2021
2 1499 Sun, 28 February 2021 15:09
  How to publish MQTT messages with a Kura component?
By: Eclipse User on Tue, 19 January 2021
2 2059 Fri, 12 February 2021 06:47
  dpp file generated empty
By: Eclipse User on Mon, 18 January 2021
4 1716 Wed, 20 January 2021 10:38
  OSGi Deployment Package Definition support in recent Eclipse
By: Eclipse User on Fri, 15 January 2021
0 3687 Fri, 15 January 2021 17:18
  Where is the "org.eclipse.kura.core.configuration.legacyServiceTracking" Value?
By: Eclipse User on Sat, 12 December 2020
3 1457 Sun, 13 December 2020 16:23
  Kura Oomph Installation not possible: Unable to read repository
By: Eclipse User on Sun, 29 November 2020
0 2628 Sun, 29 November 2020 12:09
  Kura on Raspberry Pi 4
By: Eclipse User on Fri, 04 October 2019
4 28958 Wed, 11 November 2020 10:46
  Poll: Kura unset emulator
Kura unset emulator
By: Eclipse User on Tue, 10 November 2020
3 3466 Wed, 11 November 2020 02:56
  Kura Internationalization
Kura's plug-in configuration content is internationalized, such as Modbus plug-in configuration page?
By: Eclipse User on Wed, 21 October 2020
1 2180 Mon, 02 November 2020 07:29
  How to add new logging as a text file and not using kura.log
I wish to log my data as a text file instead of using kura.log
By: Eclipse User on Tue, 20 October 2020
2 1849 Tue, 20 October 2020 22:24
  How to get AssetName by ChannelName (ChannelRecord)
By: Eclipse User on Fri, 25 September 2020
6 1960 Fri, 02 October 2020 05:00
  WireAsset does not start reading
By: Eclipse User on Mon, 08 June 2020
10 3714 Mon, 06 July 2020 20:27
  How to reset WebConsole password
By: Eclipse User on Sun, 05 July 2020
3 2447 Mon, 06 July 2020 03:52
  kura build by using maven
By: Eclipse User on Thu, 21 December 2017
2 7625 Sat, 27 June 2020 06:03
  Kura will not create plugin jar file
By: Eclipse User on Mon, 15 June 2020
0 3056 Mon, 15 June 2020 15:02
  Running Kura on WIndows
By: Eclipse User on Wed, 03 June 2020
1 1460 Wed, 03 June 2020 10:51
  Custom appender for log4j
Need to add a bundle that contains a custom appender for log4j
By: Eclipse User on Thu, 02 August 2018
2 4610 Tue, 26 May 2020 08:26
  Integration with Hawkbit
By: Eclipse User on Wed, 26 February 2020
1 1776 Thu, 27 February 2020 09:14
  Channel subscription
By: Eclipse User on Mon, 17 February 2020
3 3179 Tue, 18 February 2020 04:30
  Kura on raspberry pi3
Installation
By: Eclipse User on Fri, 31 January 2020
3 1825 Sat, 15 February 2020 14:29
  Bundle with static website
By: Eclipse User on Wed, 05 February 2020
1 1554 Thu, 13 February 2020 03:03
  /CONF-V1/PUT/configurations/PositionService not working
Remote OSGi ConfigurationAdmin Interactions via MQTT
By: Eclipse User on Wed, 29 January 2020
2 1597 Tue, 04 February 2020 11:33
  [Beginner] getting 14,000+ errors trying to setup developer workspace
Tried both Oomph and java + workspace archive
By: Eclipse User on Sat, 18 January 2020
1 202188 Tue, 21 January 2020 08:12
  Failed to install deployment package of kura-greenhouse-demo in kura
By: Eclipse User on Tue, 07 January 2020
1 2116 Fri, 10 January 2020 04:00
  kura greenhouse download package list problem
By: Eclipse User on Sat, 13 April 2019
1 26434 Fri, 10 January 2020 03:57
  How to get advertisement data via new "BluetoothLeAdapter"
can not find any api like "startAdvertisementScan"
By: Eclipse User on Fri, 02 March 2018
7 7397 Mon, 06 January 2020 05:35
  Eclipse Kura Bundle project with Maven
By: Eclipse User on Wed, 25 November 2015
4 4003 Mon, 25 November 2019 09:27
  Kura WatchDog
By: Eclipse User on Tue, 01 October 2019
3 2341 Wed, 02 October 2019 04:16
  Wire Math Singleport Components and "Missing operand" error
By: Eclipse User on Fri, 13 September 2019
4 5108 Tue, 24 September 2019 04:47
  Edge computing: invoke python script from kura
By: Eclipse User on Mon, 09 September 2019
1 12968 Mon, 23 September 2019 11:45
  Kura Wire
How to start Kura Wire on windows?
By: Eclipse User on Mon, 16 September 2019
3 4192 Tue, 17 September 2019 08:25
  Connection loss after uninstalling dhcpcd5
How to maintain wifi connection even after removing dhcpcd
By: Eclipse User on Tue, 17 September 2019
0 12358 Tue, 17 September 2019 07:19
  kura and swagger codegen issues
By: Eclipse User on Wed, 28 August 2019
0 124237 Wed, 28 August 2019 06:35
  firewall warning
By: Eclipse User on Wed, 22 May 2019
57 26432 Sat, 24 August 2019 12:17
  Docker Re-Building fails due to cp: cannot stat '/context/bin/*'
By: Eclipse User on Wed, 21 August 2019
1 4365 Sat, 24 August 2019 11:47
  Problem using KURA Client to connect to AWS IoT
Unknown.Ug<IP Address of my Device>/kura line 9 > scriptElement)
By: Eclipse User on Tue, 20 August 2019
2 2754 Wed, 21 August 2019 23:36
  Auto create driver instance, assets and channels
Configure driver instance, assets and channels from code
By: Eclipse User on Mon, 12 August 2019
2 2530 Wed, 21 August 2019 08:59
  Db operation failed
java.sql.SQLException: Database instance not initialized
By: Eclipse User on Tue, 13 August 2019
1 2455 Thu, 15 August 2019 02:44
  Wire Graph thread blocked
By: Eclipse User on Tue, 06 August 2019
4 3354 Tue, 06 August 2019 04:01
  Asset configuration with table
By: Eclipse User on Fri, 02 August 2019
5 5292 Tue, 06 August 2019 03:32
  H2db-server connection problem
Not able to connect web url of h2db-server
By: Eclipse User on Tue, 02 July 2019
1 35736 Fri, 02 August 2019 05:52
  Is the kura cloud communication to kapua secured with TLS?
By: Eclipse User on Mon, 17 June 2019
16 10802 Mon, 08 July 2019 03:29
  Issue installing Kura Eclipse on raspi3
following the install instruction, can't get kura running
By: Eclipse User on Tue, 25 June 2019
1 2211 Tue, 25 June 2019 04:08
By: Eclipse User on Mon, 24 June 2019
1 1820 Mon, 24 June 2019 12:23
  [kura 4.1.0] REPLY topic problem
How to create (topic-control-prefix/account_name/requester.client.id/app_id/REPLY/request.id)
By: Eclipse User on Tue, 18 June 2019
3 2629 Wed, 19 June 2019 07:47
  Remote deployment of dp file
By: Eclipse User on Tue, 30 October 2018
12 5591 Thu, 13 June 2019 03:10
  KuraPayload body
body kura kurapayload
By: Eclipse User on Wed, 12 June 2019
1 6398 Thu, 13 June 2019 02:57
  [kura 4.1.0]Problems with CloudSubscriber
onMessageArrived method not works
By: Eclipse User on Tue, 04 June 2019
9 8352 Tue, 11 June 2019 10:17
  Send data from raspberry and read them from PC
By: Eclipse User on Thu, 06 June 2019
2 11348 Tue, 11 June 2019 09:16
  PDE Export of Kura driver: A cycle was detected when generating the classpath
By: Eclipse User on Wed, 05 June 2019
1 5536 Thu, 06 June 2019 08:38
  Orange pi zero installation
By: Eclipse User on Thu, 16 May 2019
1 20505 Mon, 20 May 2019 04:26
  kura installation issues
installation issues in Armv7hf
By: Eclipse User on Wed, 15 May 2019
1 6321 Fri, 17 May 2019 03:45
  Compile Kura on Concierge
Kura on lightweight OSGi framework
By: Eclipse User on Wed, 08 May 2019
3 2148 Wed, 08 May 2019 06:28
  mqtt message changed when routed using camel
Eclipse Kura Camel routing
By: Eclipse User on Thu, 02 May 2019
1 4407 Wed, 08 May 2019 05:27
  How to downgrade an installed library version in linux
By: Eclipse User on Mon, 29 April 2019
1 2328 Wed, 08 May 2019 04:05
  Kura Driver
By: Eclipse User on Tue, 16 April 2019
5 3488 Fri, 19 April 2019 06:20
  Unable to update kura build's minor version
Need to know the ways to update minor version of whole build.
By: Eclipse User on Mon, 01 April 2019
3 3098 Thu, 04 April 2019 05:01
  Properly build .deb package
By: Eclipse User on Tue, 02 April 2019
1 3025 Tue, 02 April 2019 09:22
  Connect Wireless Devices to Kura
doing a IoT project about greenhouse
By: Eclipse User on Fri, 22 March 2019
1 11529 Fri, 29 March 2019 12:47
  Configure default instance of a service
By: Eclipse User on Mon, 28 January 2019
7 5106 Tue, 26 March 2019 08:08
  Is Raspberry Pi 3 Model B+ fully supported?
By: Eclipse User on Wed, 20 March 2019
1 3623 Thu, 21 March 2019 09:35
  java.lang.NoClassDefFoundError: javafx/collections/MapChangeListener
class not found even there is no errror in the import
By: Eclipse User on Fri, 06 April 2018
11 8347 Wed, 20 March 2019 13:26
  Run kura from command line without using UI
Kura framework
By: Eclipse User on Tue, 05 March 2019
1 1857 Thu, 14 March 2019 05:09
  Kura replace MQTT with CoAP
Use COAP for data transport rather than MQTT
1 1682 Thu, 14 March 2019 05:04
  Avoid DataService store
By: Eclipse User on Wed, 06 March 2019
3 4989 Fri, 08 March 2019 07:47
  Kura eclipse emulator and DS activation problems
By: Eclipse User on Mon, 25 February 2019
2 3261 Fri, 01 March 2019 06:13
  PTC Thingworx
Cloud Platform Thingworx integrations
By: Eclipse User on Fri, 25 January 2019
3 3486 Tue, 05 February 2019 11:30
  Using Kura (v4) in container
1 2681 Thu, 31 January 2019 02:30
  Create new database connection type
Create a SQLite database service
By: Eclipse User on Wed, 23 January 2019
2 2686 Fri, 25 January 2019 03:58
  MQTT Request/Response in camel
By: Eclipse User on Wed, 16 January 2019
6 3524 Thu, 17 January 2019 08:33
  Modbus TCP Problems with string reading
By: Eclipse User on Mon, 25 June 2018
1 4145 Wed, 16 January 2019 05:51
  How to create customized kura components and use them in Wire graph
By: Eclipse User on Mon, 14 January 2019
3 3591 Wed, 16 January 2019 05:47
  Cloud connections for industrial devices
3 1878 Mon, 14 January 2019 10:25
  Questions about application deployment on kura
By: Eclipse User on Mon, 07 January 2019
5 3211 Mon, 14 January 2019 09:25
  Connect to WiFi with hidden SSID
By: Eclipse User on Mon, 10 December 2018
5 5241 Wed, 09 January 2019 05:23
  Update to 4.0.0
3 3668 Wed, 09 January 2019 05:08
  Connect an IP Camera to Kura
By: Eclipse User on Tue, 01 January 2019
1 2214 Wed, 02 January 2019 14:32
  CamelRunner.Builder() null pointer exception
By: Eclipse User on Fri, 07 December 2018
2 2702 Mon, 17 December 2018 09:47
  Password field
Using a password field in a configurable component
2 2994 Thu, 13 December 2018 10:53
  Mqtt message capacity
KuraStoreCapacityReachedException
By: Eclipse User on Mon, 28 March 2016
10 14036 Mon, 03 December 2018 20:49
  Sensor Health Check
Checking if the sensor measuring correctly
By: Eclipse User on Thu, 29 November 2018
3 2624 Thu, 29 November 2018 10:10
  Kura 4.0 on Intel NUC
Some issues installing Kura on Intel NUC and Ubuntu
By: Eclipse User on Sat, 24 November 2018
1 3011 Thu, 29 November 2018 08:20
  Bundle start too early (before network connectivity)
A bundle does it's activate when network is not available
By: Eclipse User on Mon, 17 September 2018
4 3749 Mon, 26 November 2018 05:30
  Thingspeak connexion
By: Eclipse User on Tue, 20 November 2018
0 3325 Tue, 20 November 2018 04:36
  Kura behind Proxy
By: Eclipse User on Mon, 12 November 2018
0 4104 Mon, 12 November 2018 08:37
  Can this portable Java Device I/O library be of any assistance?
Java diozero library
By: Eclipse User on Wed, 05 July 2017
2 9486 Mon, 29 October 2018 16:15
  Creating deployment packages
By: Eclipse User on Thu, 20 September 2018
3 3404 Fri, 26 October 2018 05:11
  Generate dp file
By: Eclipse User on Wed, 24 October 2018
9 5282 Thu, 25 October 2018 02:02
  Constant growth of memory
By: Eclipse User on Thu, 11 October 2018
6 4163 Wed, 24 October 2018 06:00
  Deployment package plugins already installed
By: Eclipse User on Fri, 19 October 2018
0 3812 Fri, 19 October 2018 03:23
  Higher level APIs
APIs to decouple various implementations.
By: Eclipse User on Mon, 29 August 2016
4 4124 Thu, 18 October 2018 21:22
  adding a plugin to the target definition
eclipse workspace is the hardest part...
By: Eclipse User on Fri, 05 October 2018
2 3041 Tue, 09 October 2018 01:09
  kura wire for serial communication.
Want to access serial device using kura wires.
By: Eclipse User on Mon, 08 October 2018
1 2215 Mon, 08 October 2018 12:05
  OPC UA connection to server failed
A generic unrecoverable error happened. Please refer to the device log.
By: Eclipse User on Fri, 28 September 2018
1 2350 Tue, 02 October 2018 09:49
  How to use kura-addon repository through jfrog artifactory
0 2006 Fri, 28 September 2018 11:23
  Cannot install Kura for aarch64
By: Eclipse User on Fri, 21 September 2018
1 2525 Fri, 21 September 2018 12:05
  How to import in Eclipse com.microsoft.azure.sdk.iot.device jar
ERROR The import com.microsoft cannot be resolved
By: Eclipse User on Wed, 08 August 2018
7 8068 Thu, 13 September 2018 06:16
  Wrong Deployment Package URL sent by DeploymentAgentService
DeploymentAgent seems to post the wrong URL when launching on eclipse
By: Eclipse User on Tue, 21 August 2018
3 4311 Tue, 28 August 2018 03:32
  Kura doesn't work properly on Raspberry Pi
By: Eclipse User on Thu, 12 July 2018
2 5561 Fri, 24 August 2018 04:34
  Kura REST API URL
By: Eclipse User on Wed, 15 August 2018
1 4251 Fri, 24 August 2018 04:24
  How to connect Kura gateway to Hono
By: Eclipse User on Fri, 10 August 2018
0 3731 Fri, 10 August 2018 11:36
By: Eclipse User on Thu, 14 December 2017
4 4088 Thu, 09 August 2018 14:42
  cellular connectivity
By: Eclipse User on Mon, 06 August 2018
1 2249 Wed, 08 August 2018 04:05
  Pi4j library
How i use pi4j library in kura.
0 4238 Mon, 06 August 2018 02:32
  update kura version
How i update kura version from 3.1.0 to 3.2.0
2 2773 Fri, 03 August 2018 08:11
  BH1705 Sensor.
Trying Read bh1705 light sensor using i2c.
By: Eclipse User on Mon, 23 July 2018
4 3504 Wed, 25 July 2018 09:17
  Sending MQTT to AWS NOT WORKING
By: Eclipse User on Fri, 15 June 2018
6 5367 Wed, 25 July 2018 04:38
  Can Kura work on x86 based linux system?
By: Eclipse User on Wed, 18 July 2018
8 3553 Thu, 19 July 2018 09:16
  I2C
Not able to access jdk.dio libaray .Event i imported jdk.dio jar from my target defination.
By: Eclipse User on Mon, 16 July 2018
2 3204 Thu, 19 July 2018 01:26
  BACnet protocol
1 1939 Wed, 18 July 2018 13:59
  Kura + External jar (ex :- Pi4j) problem
Runs only once
By: Eclipse User on Wed, 03 December 2014
11 12320 Wed, 18 July 2018 06:07
  Missing artifact org.eclipse.kura:org.eclipse.kura.api:jar:1.1.0
By: Eclipse User on Thu, 28 June 2018
1 2014 Mon, 02 July 2018 11:59
icon4.gif Something is wrong in Eclipse repository (same in Eclipse Kura repository).
By: Eclipse User on Mon, 24 April 2017
6 10444 Thu, 28 June 2018 10:29
  Need help on javax.smartcardio
Got the "java.lang.NoClassDefFoundError: javax/smartcardio/CardException" when deployed the bundle to kura
By: Eclipse User on Sat, 17 September 2016
5 7657 Tue, 26 June 2018 09:34
  Kura 3.2.0 CA-signed x.509 Azure IoT Hub
Problems with kura+IoT Hub Broker+mqtts+x.509
By: Eclipse User on Tue, 26 June 2018
0 4055 Tue, 26 June 2018 04:08
  influxdb in Eclipse Kura
how to use influxdb to save to a database in Kura
By: Eclipse User on Tue, 12 June 2018
0 2575 Tue, 12 June 2018 17:42
  Developing new kura wire components
Understanding and developing new kura wire components
By: Eclipse User on Tue, 29 May 2018
1 2789 Fri, 01 June 2018 07:49
  How to use Kura IoT with python library of sensor
By: Eclipse User on Fri, 01 June 2018
0 4639 Fri, 01 June 2018 06:58
  Difference between kura.data.DataServiceListener and kura.data.listener.DataServiceListener
By: Eclipse User on Mon, 22 May 2017
3 6211 Fri, 01 June 2018 04:03
  Kura into Virtual Machine
By: Eclipse User on Fri, 25 May 2018
0 28162 Fri, 25 May 2018 08:10
  Can not connect Krua device to kapua server exception Not authorized to connect (5)
in the past device was able to connect to kapua server but recently some of my devices are not connecting to server and gives exception.
By: Eclipse User on Thu, 24 May 2018
1 2775 Thu, 24 May 2018 08:02
  Calling the Kura API methods?
By: Eclipse User on Mon, 14 May 2018
5 5295 Tue, 22 May 2018 06:08
  Kura 3.2.0 and Java 9
system requirement, openjre
By: Eclipse User on Fri, 18 May 2018
2 2990 Tue, 22 May 2018 05:01
  Can't unblock ports in Kura Firewall
By: Eclipse User on Mon, 21 May 2018
1 2565 Tue, 22 May 2018 04:04
  [Kura 3.2.0] Bug on Device SSL Certificate
By: Eclipse User on Thu, 17 May 2018
1 3182 Sat, 19 May 2018 03:54
  Cannot Write to OPCUA Asset
By: Eclipse User on Mon, 07 May 2018
9 6103 Tue, 15 May 2018 04:32
  Kura Debugger Access Issue
1 5495 Tue, 15 May 2018 03:47
  Driver OPC UA and arrays
By: Eclipse User on Fri, 04 May 2018
2 3846 Tue, 08 May 2018 10:59
  MQTT message not writing to asset
4 5855 Mon, 07 May 2018 05:02
  Issues with GPIO connection Kura/Eclipse
I have issues using or programming gpio connections on my raspberry pi
By: Eclipse User on Mon, 16 April 2018
10 8666 Mon, 30 April 2018 04:43
  Issue with kura installation on Raspberry Pi 2
By: Eclipse User on Sat, 21 April 2018
11 6444 Tue, 24 April 2018 08:03
  Publish PPMP Protocol
including the PPMP format to the publish method
8 4487 Tue, 24 April 2018 05:41
  Azure IoT hub Certificate Authority Connection
By: Eclipse User on Thu, 19 April 2018
6 5939 Mon, 23 April 2018 06:47
  HTTPS for Kura Web UI?
By: Eclipse User on Tue, 09 January 2018
5 5159 Mon, 16 April 2018 12:23
  GPIO access not working for me.
Having a problem understanding gpio connection in kura and how implement it.
By: Eclipse User on Sun, 15 April 2018
0 5430 Sun, 15 April 2018 17:39
  Multiple kura instances.
By: Eclipse User on Tue, 10 April 2018
2 2209 Thu, 12 April 2018 12:01
  Configuration Asset Kura 3.2.0
By: Eclipse User on Thu, 12 April 2018
2 2825 Thu, 12 April 2018 06:06
  Multiple Instance of Kura
Multiple Instance of Kura in the same system/machine
2 2514 Tue, 10 April 2018 10:21
  Creating custom API/web service?
By: Eclipse User on Thu, 15 February 2018
2 3842 Mon, 09 April 2018 13:32
  Loading Modbus assets and channels
By: Eclipse User on Wed, 21 March 2018
3 3289 Tue, 03 April 2018 04:32
  Unable to active ActiveMQ embedded broker
By: Eclipse User on Tue, 27 March 2018
1 5894 Tue, 03 April 2018 04:31
  DataPublisherService not connected
I couldn't solve the "DataPublisherService not connected"
By: Eclipse User on Thu, 15 March 2018
5 3699 Mon, 26 March 2018 09:23
  table created in the Hsql data base dropped after reboot
By: Eclipse User on Fri, 16 December 2016
6 5331 Tue, 20 March 2018 06:05
  Logfile per bundle
How to define a log file per bundle?
By: Eclipse User on Mon, 12 March 2018
4 4808 Sun, 18 March 2018 21:15
  stopping via osgi> exit causes reboot via watchdog
Stopping kura via the "exit" command in the osgi console results in the machine rebooting shortly after.
By: Eclipse User on Fri, 28 October 2016
6 8127 Sun, 18 March 2018 21:11
  Command Service
By: Eclipse User on Thu, 01 March 2018
1 5654 Mon, 12 March 2018 11:04
  The modbus library
org.eclipse.kura.protocol.modbus.ModbusProtocolDeviceService
By: Eclipse User on Mon, 05 March 2018
7 4440 Mon, 12 March 2018 10:58
  Is the Kura platform officially supported on Windows or not?
Kura Windows
By: Eclipse User on Tue, 06 March 2018
1 4434 Mon, 12 March 2018 10:56
  Problem to subscribe to a topic
I have a problem on kura to get data from kapua.
By: Eclipse User on Wed, 07 March 2018
1 3798 Mon, 12 March 2018 10:50
can not find any api like startAdvertisementScan
0 3869 Fri, 02 March 2018 02:12
  LED not blinking on RPI3
gpio library
7 3391 Thu, 01 March 2018 11:35
  how to resolve jdk.dio-CloseDeviceException
can some one please help me out with jdk.dio.CloseDeviceException ???
By: Eclipse User on Thu, 12 November 2015
4 5360 Thu, 01 March 2018 03:17
icon5.gif LED not blinking on Raspberry pi
LED not blinking on Raspberry pi using pi4j library
By: Eclipse User on Sat, 09 April 2016
3 9471 Thu, 01 March 2018 03:08
  Eclipse kura Installaton
By: Eclipse User on Mon, 26 February 2018
5 3602 Tue, 27 February 2018 15:29
  I can't import JDK.dio to my project
can't find the GPIO library
By: Eclipse User on Tue, 27 February 2018
0 4077 Tue, 27 February 2018 08:19
  ConfigurableExample service isn't showed in Kura Web UI
By: Eclipse User on Sat, 05 December 2015
16 10407 Tue, 27 February 2018 05:07
  Kura Username/Password Change
By: Eclipse User on Tue, 23 June 2015
5 5774 Wed, 21 February 2018 02:01
  OPC DEMO - write variable
cannot write
By: Eclipse User on Tue, 30 January 2018
7 5942 Mon, 19 February 2018 05:42
  Kura Emulator - missing native library for RXTX
Native library is missing for kura emulator on x86_64 when trying to run serial example demo
By: Eclipse User on Thu, 08 February 2018
0 4322 Thu, 08 February 2018 05:31
  Error write with modbus_driver
By: Eclipse User on Fri, 02 February 2018
1 5796 Thu, 08 February 2018 04:30
  How to write/add tabs in a configurable bundle
By: Eclipse User on Mon, 05 February 2018
3 3264 Tue, 06 February 2018 11:48
  Need help to connect broker to kura and receive data into h2db
Existing broker connect to RPi Gateway with Kura and receive data via MQTT into H2 built-in database
By: Eclipse User on Wed, 17 January 2018
7 6563 Tue, 06 February 2018 05:36
  Kura wires to subscribe data from extern broker
Need help to subscribe data from extern broker with Kura wires
1 2680 Tue, 06 February 2018 05:21
  how to remove configuration data when uninstall bundle
By: Eclipse User on Wed, 31 January 2018
1 2299 Wed, 31 January 2018 15:08
  Permanent deployment of plugins to kura
Unable to permanently deploy jars to kura
By: Eclipse User on Thu, 11 January 2018
3 5527 Tue, 30 January 2018 10:34
  Need Help: Error when deploy Greenhouse sample on RPi3b
By: Eclipse User on Tue, 06 September 2016
8 6662 Mon, 29 January 2018 04:03
  I2c bus
Not able to open i2c device
By: Eclipse User on Wed, 22 November 2017
1 6887 Mon, 29 January 2018 00:12
  Emulated Simple Artemis MQTT Broker localhost Configuration
Local client constantly disconnected by built-in broker
By: Eclipse User on Fri, 26 January 2018
2 4849 Sat, 27 January 2018 02:38
  REST Api
Is it possible to perform PUT and DELETE
By: Eclipse User on Tue, 23 January 2018
0 5864 Tue, 23 January 2018 04:36
  REST Service
GET AND POST ,DELETE PUT
By: Eclipse User on Thu, 18 January 2018
1 4435 Tue, 23 January 2018 02:45
  how to set a tcp server in kura?
By: Eclipse User on Mon, 22 January 2018
0 5789 Mon, 22 January 2018 02:00
  REST Services
Implementing GET, PUT, DELETE ...
1 3128 Fri, 19 January 2018 03:09
  Kura 3.1.0, Raspi3, Sensortag connectivity Problem
Error when trying to connect sensortag
6 7035 Tue, 16 January 2018 23:28
  Kura Modbus
Modbus in kura
By: Eclipse User on Fri, 22 December 2017
10 6673 Tue, 16 January 2018 04:47
  adc
Access the adc
By: Eclipse User on Wed, 10 January 2018
4 4700 Tue, 16 January 2018 03:15
  Kura built-in Simple Artemis MQTT Broker Service logs
How to get the logs from the built-in Simple Artemis MQTT Broker Service logs
By: Eclipse User on Mon, 15 January 2018
0 5694 Mon, 15 January 2018 14:28
  Why my coap server started twice?
2 4651 Fri, 12 January 2018 21:21
Current Time: Sun Aug 31 21:34:54 EDT 2025
Powered by FUDForum. Page generated in 0.04569 seconds
