Reuse channel-type By: Eclipse User on Wed, 18 March 2020 |
5612 |
Fri, 20 March 2020 03:20 By: Eclipse User  |
mvn build error Build fails at - Eclipse SmartHome Karaf Feature Verification By: Eclipse User on Thu, 29 August 2019 |
125966 |
Thu, 29 August 2019 06:45 By: Eclipse User  |
Project currently stalled - do not expect answers here! By: Eclipse User on Fri, 18 January 2019 |
4290 |
Fri, 18 January 2019 07:57 By: Eclipse User  |
Swipe functionality for Dimmer/volume controls Swipe functionality for Dimmer/volume controls By: Eclipse User on Sun, 13 January 2019 |
3603 |
Fri, 18 January 2019 04:58 By: Eclipse User  |
Flexibility of framework and supplied types By: Eclipse User on Fri, 04 January 2019 |
4047 |
Mon, 14 January 2019 05:02 By: Eclipse User  |
3633 |
Sun, 13 January 2019 17:22 By: Eclipse User  |
SOLVED: Using config to enable/disable background discovery By: Eclipse User on Sat, 22 December 2018 |
4630 |
Thu, 03 January 2019 14:02 By: Eclipse User  |
SOLVED:API Incompatibility still exist | Update of master done By: Eclipse User on Sun, 23 December 2018 |
3173 |
Sat, 29 December 2018 15:18 By: Eclipse User  |
SOLVED: Created binding but no Supported Things exist in Paper UI By: Eclipse User on Thu, 27 December 2018 |
2632 |
Fri, 28 December 2018 10:26 By: Eclipse User  |
Advice on how to handle application key By: Eclipse User on Thu, 20 December 2018 |
2864 |
Thu, 20 December 2018 15:39 By: Eclipse User  |
Testing HTTP authentication & authorization HTTP authentication & authorization By: Eclipse User on Sat, 01 December 2018 |
3115 |
Sat, 01 December 2018 02:58 By: Eclipse User  |
Upgrade from ESH-0.9.0 By: Eclipse User on Fri, 30 November 2018 |
2189 |
Fri, 30 November 2018 06:00 By: Eclipse User  |
Concepts visualisation By: Eclipse User on Thu, 15 November 2018 |
3420 |
Fri, 30 November 2018 03:52 By: Eclipse User  |
rxtx + Gnu.io problem By: Eclipse User on Fri, 23 November 2018 |
2346 |
Mon, 26 November 2018 08:55 By: Eclipse User  |
Need help on networkAddressService Integrating networkAddressService By: Eclipse User on Thu, 22 November 2018 |
2870 |
Fri, 23 November 2018 19:04 By: Eclipse User  |
SSE(Server Sent Events) not working through domain name URL ESH Server Sent Events working fine with IP address but not able to receive Events through Domain Name URL By: Eclipse User on Fri, 23 November 2018 |
2501 |
Fri, 23 November 2018 10:50 By: Eclipse User  |
Compilation failure By: Eclipse User on Tue, 20 November 2018 |
3341 |
Fri, 23 November 2018 10:44 By: Eclipse User  |
ESH + Authorisation + OPTIONS method ESH is trying to authorise requests with HTTP OPTIONS method By: Eclipse User on Thu, 06 September 2018 |
3753 |
Thu, 15 November 2018 07:34 By: Eclipse User  |
OSGi test problem: missing constraints By: Eclipse User on Fri, 09 November 2018 |
2758 |
Wed, 14 November 2018 01:16 By: Eclipse User  |
Need help understanding the rules engine implementation By: Eclipse User on Mon, 05 November 2018 |
3498 |
Wed, 14 November 2018 01:13 By: Eclipse User  |
Timer reschedule() Contributor advice needed By: Eclipse User on Tue, 06 November 2018 |
2583 |
Wed, 07 November 2018 06:55 By: Eclipse User  |
Newbee - .gitignore is broken By: Eclipse User on Mon, 29 October 2018 |
3640 |
Wed, 31 October 2018 10:21 By: Eclipse User  |
Eclipse (SimRel 2018‑09) formatter (configuration) on save broken? By: Eclipse User on Tue, 30 October 2018 |
2404 |
Tue, 30 October 2018 11:58 By: Eclipse User  |
Change buildsystem to Gradle or alternatives By: Eclipse User on Thu, 03 August 2017 |
26250 |
Mon, 29 October 2018 09:48 By: Eclipse User  |
"NoClassDefFoundError" while running "bundleContext.registerService" Light control demo just like hue example By: Eclipse User on Fri, 20 January 2017 |
5665 |
Wed, 24 October 2018 13:38 By: Eclipse User  |
How to Use the Recently Added MQTT Binding By: Eclipse User on Thu, 07 June 2018 |
6218 |
Wed, 24 October 2018 05:53 By: Eclipse User  |
I am a beginner, I need help. After clicking "Finish", there are a lot of errors By: Eclipse User on Tue, 23 October 2018 |
2438 |
Tue, 23 October 2018 10:59 By: Eclipse User  |
The issue regarding the ip obtained when I run the smarthome server By: Eclipse User on Thu, 04 October 2018 |
3066 |
Mon, 08 October 2018 08:39 By: Eclipse User  |
RULE Engine issue when installed Custome Core ID Bundle with new Custome API'S I am not able to see the RULE Engine in paperui once i install my newly created Eclipse Smarthome Core ID Bunle jar file By: Eclipse User on Thu, 20 September 2018 |
5869 |
Fri, 28 September 2018 08:45 By: Eclipse User  |
Receiving Items state Receiving Items state from binding By: Eclipse User on Mon, 26 February 2018 |
6821 |
Thu, 13 September 2018 02:38 By: Eclipse User  |
New Prometheus Metrics bundle - Need help attaching to Pax logging By: Eclipse User on Fri, 20 July 2018 |
12270 |
Mon, 27 August 2018 10:31 By: Eclipse User  |
Serialize ThingType By: Eclipse User on Sun, 29 July 2018 |
3881 |
Fri, 03 August 2018 04:19 By: Eclipse User  |
Auto created Items are not editable Items which are auto created after approve an inbox item, are not editable. By: Eclipse User on Wed, 01 August 2018 |
3165 |
Fri, 03 August 2018 00:43 By: Eclipse User  |
Unable to receive Events(itemCommandEvent,ItemStateEvent) from ESH By: Eclipse User on Fri, 27 July 2018 |
3365 |
Mon, 30 July 2018 10:12 By: Eclipse User  |
Bridge Handler adding discovered ChildThing. Need help in creating a discovered child thing. By: Eclipse User on Thu, 19 July 2018 |
2622 |
Mon, 23 July 2018 09:49 By: Eclipse User  |
Gather the data from channels By: Eclipse User on Wed, 20 June 2018 |
2911 |
Mon, 16 July 2018 18:23 By: Eclipse User  |
change states of a channel By: Eclipse User on Sat, 09 December 2017 |
10088 |
Tue, 03 July 2018 09:45 By: Eclipse User  |
ESH Google IoT core binding By: Eclipse User on Wed, 20 June 2018 |
4506 |
Tue, 03 July 2018 04:32 By: Eclipse User  |
Parameters on Channel By: Eclipse User on Wed, 27 June 2018 |
2902 |
Thu, 28 June 2018 08:25 By: Eclipse User  |
Binding with communication profile By: Eclipse User on Thu, 07 June 2018 |
4409 |
Thu, 14 June 2018 06:15 By: Eclipse User  |
ESH Development Environment Errors Following The Instructions For Setting Up ESH Development Environment By: Eclipse User on Mon, 04 June 2018 |
2824 |
Tue, 05 June 2018 04:06 By: Eclipse User  |
ESH with Google CLOUD IoT CORE By: Eclipse User on Tue, 27 March 2018 |
4733 |
Mon, 21 May 2018 01:53 By: Eclipse User  |
Process for an idea By: Eclipse User on Tue, 15 May 2018 |
2904 |
Tue, 15 May 2018 08:06 By: Eclipse User  |
using ExtendedDiscoveryService with MDNSDiscoveryParticipant By: Eclipse User on Tue, 14 November 2017 |
3759 |
Thu, 03 May 2018 04:58 By: Eclipse User  |
Update to OSGi specifications 6.0 By: Eclipse User on Mon, 30 April 2018 |
2471 |
Tue, 01 May 2018 17:32 By: Eclipse User  |
Local environment and build stability (paperui) By: Eclipse User on Sun, 22 April 2018 |
3709 |
Thu, 26 April 2018 04:57 By: Eclipse User  |
Poll: Is P2 is really necessary for Eclipse Smart Home core By: Eclipse User on Sun, 22 April 2018 |
7087 |
Mon, 23 April 2018 09:07 By: Eclipse User  |
[SOLVED] create_binding_skeleton errors Errors when trying to create a binding skeleton with the script By: Eclipse User on Sat, 11 June 2016 |
7170 |
Mon, 09 April 2018 16:56 By: Eclipse User  |
Thoughts on a new Sitemap Concept By: Eclipse User on Fri, 27 November 2015 |
18933 |
Tue, 27 March 2018 14:22 By: Eclipse User  |
Depencies in Eclipse Smart Home, howto import? Setting up Binding imports to be able compile and distribute? By: Eclipse User on Tue, 13 March 2018 |
4481 |
Fri, 16 March 2018 11:31 By: Eclipse User  |
ESH Console extensions By: Eclipse User on Sun, 11 March 2018 |
3048 |
Mon, 12 March 2018 05:31 By: Eclipse User  |
Eclipse SmartHome karaf Feature verification.......FAILURE Eclipse SmartHome karaf Feature verification.......FAILURE By: Eclipse User on Mon, 12 February 2018 |
7319 |
Thu, 01 March 2018 14:23 By: Eclipse User  |
4133 |
Wed, 28 February 2018 15:59 By: Eclipse User  |
New Build on Ubuntu 16.04 - Web services not loading New Build on Ubuntu 16.04 - Web services not loading By: Eclipse User on Tue, 27 February 2018 |
3158 |
Wed, 28 February 2018 15:57 By: Eclipse User  |
Override validateConfigurationParameters in binding to check config? Question about best practice building binding By: Eclipse User on Wed, 08 November 2017 |
5080 |
Wed, 28 February 2018 14:00 By: Eclipse User  |
Data storage and visualization with SmartHome What are the capabilities of Eclipse SmartHome in terms of data storage and visualization? By: Eclipse User on Sun, 25 February 2018 |
3678 |
Tue, 27 February 2018 17:43 By: Eclipse User  |
IDE startup and HTTP 404 http://localhost:8080/ By: Eclipse User on Tue, 06 February 2018 |
4039 |
Fri, 16 February 2018 05:11 By: Eclipse User  |
HOW TO GET BACK THE STATE OF AN ITEM By: Eclipse User on Mon, 05 February 2018 |
3982 |
Thu, 08 February 2018 06:49 By: Eclipse User  |
label taken from channel-type and not from overwritten channel definition By: Eclipse User on Thu, 01 February 2018 |
3523 |
Mon, 05 February 2018 02:02 By: Eclipse User  |
Trying to add a new item to a registry through API By: Eclipse User on Fri, 02 February 2018 |
3902 |
Fri, 02 February 2018 06:01 By: Eclipse User  |
Firmware API By: Eclipse User on Wed, 03 January 2018 |
5526 |
Tue, 30 January 2018 10:33 By: Eclipse User  |
Getting error while doing maven clean install When i am doing maven clean install on windows i am getting this error By: Eclipse User on Tue, 23 January 2018 |
11457 |
Thu, 25 January 2018 01:56 By: Eclipse User  |
Recommended update strategy of channels in binding By: Eclipse User on Tue, 23 January 2018 |
3651 |
Wed, 24 January 2018 13:11 By: Eclipse User  |
When i am doing maven clean install on windows i am getting this error while i am doing maven clean install on windows i am getting this error By: Eclipse User on Tue, 23 January 2018 |
2743 |
Tue, 23 January 2018 10:44 By: Eclipse User  |
DynamicStateDescriptionProvider and sitemap By: Eclipse User on Sun, 21 January 2018 |
3348 |
Mon, 22 January 2018 12:13 By: Eclipse User  |
Maven install is getting BUILD FAILURE Maven install is getting BUILD FAILURE "Could not resolve dependencies for project " By: Eclipse User on Mon, 15 January 2018 |
12261 |
Mon, 22 January 2018 00:29 By: Eclipse User  |
Switch or Contact for channel - Best practice By: Eclipse User on Tue, 16 January 2018 |
3868 |
Wed, 17 January 2018 07:31 By: Eclipse User  |
Role based access Can we provide Role based access By: Eclipse User on Sat, 02 September 2017 |
8705 |
Tue, 16 January 2018 17:11 By: Eclipse User  |
ComboBox for selecting a channel value Channel with ComboBox By: Eclipse User on Thu, 04 January 2018 |
5413 |
Mon, 08 January 2018 14:49 By: Eclipse User  |
Eclipse Kura Need help regarding eclipse iot greenhouse project By: Eclipse User on Wed, 13 December 2017 |
3107 |
Thu, 14 December 2017 04:50 By: Eclipse User  |
Multiple AND or OR operators in rules when using rule REST API How to use multiple AND or OR operators in rule conditions when using Rule REST API By: Eclipse User on Fri, 08 December 2017 |
6565 |
Tue, 12 December 2017 02:02 By: Eclipse User  |
Eclipse SmartHome Eclipse smarthome development By: Eclipse User on Sun, 25 October 2015 |
5714 |
Sat, 09 December 2017 05:20 By: Eclipse User  |
USB and Binding By: Eclipse User on Wed, 22 November 2017 |
6950 |
Tue, 05 December 2017 09:43 By: Eclipse User  |
Default value for channels How to set the value of a channel By: Eclipse User on Sun, 26 November 2017 |
4009 |
Tue, 05 December 2017 08:12 By: Eclipse User  |
Support for Channels in DiscoveryResultBuilder and/or DiscoveryResult Is that a design choice? By: Eclipse User on Fri, 10 November 2017 |
6150 |
Tue, 21 November 2017 11:09 By: Eclipse User  |
JDBC persistence service in ESH JDBC persistence service in ESH By: Eclipse User on Thu, 16 November 2017 |
5459 |
Tue, 21 November 2017 00:10 By: Eclipse User  |
Nginx configuration to access ESH How to configure Nginx to access ESH By: Eclipse User on Fri, 27 October 2017 |
8364 |
Tue, 14 November 2017 03:49 By: Eclipse User  |
Using Threads in Profiles By: Eclipse User on Sun, 12 November 2017 |
3690 |
Mon, 13 November 2017 06:21 By: Eclipse User  |
Profiles By: Eclipse User on Wed, 25 October 2017 |
6110 |
Fri, 10 November 2017 04:04 By: Eclipse User  |
adding channels conditionally By: Eclipse User on Fri, 20 October 2017 |
5336 |
Thu, 09 November 2017 09:05 By: Eclipse User  |
Items REST API - Add formatting flag By: Eclipse User on Wed, 08 November 2017 |
3901 |
Wed, 08 November 2017 11:54 By: Eclipse User  |
Identical Things provided by different ThingProviders How to deal with this? By: Eclipse User on Wed, 01 November 2017 |
5827 |
Wed, 08 November 2017 09:17 By: Eclipse User  |
Questions about best practices implementing bindings By: Eclipse User on Fri, 27 October 2017 |
4613 |
Wed, 08 November 2017 06:29 By: Eclipse User  |
How to read / save Binding config How to read / save Binding config By: Eclipse User on Sun, 29 October 2017 |
4553 |
Mon, 06 November 2017 05:12 By: Eclipse User  |
Stuck on finalizing installation Issue with Help -> Perform Setup Tasks... -> Launch Paper UI Setup. By: Eclipse User on Sun, 29 October 2017 |
6735 |
Tue, 31 October 2017 14:22 By: Eclipse User  |
HTTP ERROR 404 By: Eclipse User on Fri, 27 October 2017 |
6360 |
Mon, 30 October 2017 07:27 By: Eclipse User  |
NextPreviousType/UpDownType By: Eclipse User on Tue, 28 February 2017 |
11470 |
Mon, 30 October 2017 04:45 By: Eclipse User  |
Install extension via /extensions/url/{url}/install REST API By: Eclipse User on Fri, 13 October 2017 |
4395 |
Thu, 19 October 2017 09:48 By: Eclipse User  |
Error executing maven build and resolving targed-platform By: Eclipse User on Mon, 16 October 2017 |
3213 |
Tue, 17 October 2017 01:49 By: Eclipse User  |
DiscoveryService registered but startScan not executed By: Eclipse User on Mon, 02 October 2017 |
9691 |
Fri, 06 October 2017 12:35 By: Eclipse User  |
Design question: searching for things (getThingByUID) By: Eclipse User on Sun, 16 July 2017 |
9215 |
Wed, 04 October 2017 16:07 By: Eclipse User  |
Changing readonly at runtime By: Eclipse User on Wed, 13 September 2017 |
12625 |
Tue, 26 September 2017 10:35 By: Eclipse User  |
o.e.s.i.t.m.MqttBrokerConnection.addconsumer() send a wrong wildcard format instead of '+' in Topic MqttBrokerConnection.addconsumer() use wrong wildcard format to MQTT Broker By: Eclipse User on Tue, 26 September 2017 |
5816 |
Tue, 26 September 2017 10:26 By: Eclipse User  |
Compilation Error Build Error By: Eclipse User on Wed, 13 September 2017 |
10776 |
Thu, 14 September 2017 20:29 By: Eclipse User  |
Help with PaperUI PaperUI problem By: Eclipse User on Wed, 13 September 2017 |
8386 |
Thu, 14 September 2017 04:33 By: Eclipse User  |
Sudden Build Problem By: Eclipse User on Sat, 09 September 2017 |
13006 |
Tue, 12 September 2017 04:38 By: Eclipse User  |
Change Channel pattern based on its configuration By: Eclipse User on Mon, 11 September 2017 |
4935 |
Mon, 11 September 2017 08:55 By: Eclipse User  |
Need help with understanding Architecture Need help with understanding Architecture By: Eclipse User on Sat, 02 September 2017 |
10977 |
Mon, 11 September 2017 00:05 By: Eclipse User  |
Event driven binding - Implementation pattern advice By: Eclipse User on Sat, 05 August 2017 |
11722 |
Sat, 09 September 2017 11:06 By: Eclipse User  |
Dynamically changing item-type category during discovery By: Eclipse User on Sat, 05 August 2017 |
10803 |
Sat, 09 September 2017 11:05 By: Eclipse User  |
Can i deploy and run ESH in any server Can i deploy and run ESH in any server By: Eclipse User on Sat, 02 September 2017 |
8623 |
Mon, 04 September 2017 02:34 By: Eclipse User  |
How to get Infos from Sonos-Binding for our binding By: Eclipse User on Fri, 18 August 2017 |
14316 |
Thu, 24 August 2017 03:56 By: Eclipse User  |
Binding using MqttService I am trying to develop an openhab2 binding using the MqttService By: Eclipse User on Sun, 06 August 2017 |
8474 |
Sun, 20 August 2017 12:07 By: Eclipse User  |
extending ExpiringCache with IsChanged By: Eclipse User on Sat, 12 August 2017 |
11766 |
Thu, 17 August 2017 15:56 By: Eclipse User  |
How to add things dynamically in the binding By: Eclipse User on Thu, 10 August 2017 |
11648 |
Wed, 16 August 2017 09:09 By: Eclipse User  |
Use org.openhab.persistence.mapdb binding in eclipse smart home. how to use org.openhab.persistence.mapdb By: Eclipse User on Thu, 10 August 2017 |
10096 |
Fri, 11 August 2017 03:10 By: Eclipse User  |
Build fails on Win10/x64 with Maven 3.50 By: Eclipse User on Thu, 03 August 2017 |
6104 |
Sat, 05 August 2017 10:03 By: Eclipse User  |
Build error Eclipse smarthome Build error By: Eclipse User on Wed, 02 August 2017 |
5650 |
Thu, 03 August 2017 05:47 By: Eclipse User  |
Best way to implement Discovery without known thingtype By: Eclipse User on Mon, 31 July 2017 |
8888 |
Wed, 02 August 2017 13:57 By: Eclipse User  |
lwm2m binding (Lightweight machine 2 machine protocol) Binding to support lwm2m By: Eclipse User on Mon, 31 July 2017 |
13977 |
Wed, 02 August 2017 07:24 By: Eclipse User  |
Problems in creation the development environment After the start of the smarthome-runtime, localhost:8080 returns the error 404 By: Eclipse User on Fri, 14 July 2017 |
12443 |
Wed, 19 July 2017 13:41 By: Eclipse User  |
NoClassDefFoundError when using ManagedItemProvider.add in custom binding By: Eclipse User on Thu, 13 July 2017 |
9478 |
Fri, 14 July 2017 07:50 By: Eclipse User  |
The io.transport.mqtt implementation is too restrictive The bundle does not export much useful functionality. The MqttBrokerConnection would need to be exported. Add/remove/enumerate brokers in MqttService would be helpful. By: Eclipse User on Sun, 18 June 2017 |
12386 |
Tue, 20 June 2017 08:04 By: Eclipse User  |
Eclipse Smart Home and org.slf4j build path problems By: Eclipse User on Mon, 12 June 2017 |
10254 |
Tue, 13 June 2017 05:45 By: Eclipse User  |
NPE trying to set up ESH development envirionment By: Eclipse User on Tue, 06 June 2017 |
6692 |
Tue, 06 June 2017 10:31 By: Eclipse User  |
Openhab-cloud connecter for ESH ESH need connector to connect Openhab-cloud By: Eclipse User on Fri, 12 May 2017 |
33817 |
Fri, 02 June 2017 16:37 By: Eclipse User  |
OSGI bundle Exception : Unable to resolve binding org.osgi.framework.BundleException: Unable to resolve org.openhab.binding.snavxbee2 By: Eclipse User on Fri, 02 June 2017 |
9160 |
Fri, 02 June 2017 05:52 By: Eclipse User  |
How to distribute Eclipse Smart Home Distributing Eclipse Smart Home By: Eclipse User on Wed, 31 May 2017 |
10148 |
Thu, 01 June 2017 05:32 By: Eclipse User  |
Discoverability By: Eclipse User on Thu, 04 May 2017 |
13095 |
Tue, 30 May 2017 08:34 By: Eclipse User  |
A research study on software security practice management in IoT project By: Eclipse User on Tue, 30 May 2017 |
10549 |
Tue, 30 May 2017 04:21 By: Eclipse User  |
Authentication Rest API Authentication REST API for ESH By: Eclipse User on Mon, 29 May 2017 |
5777 |
Mon, 29 May 2017 08:04 By: Eclipse User  |
[Solved]Reading the version number of the binding By: Eclipse User on Tue, 23 May 2017 |
9379 |
Wed, 24 May 2017 09:16 By: Eclipse User  |
Thing configuration does not show boolean thing parameter in paperUI boolean configure parameter not shown in paperui By: Eclipse User on Mon, 22 May 2017 |
8897 |
Tue, 23 May 2017 06:49 By: Eclipse User  |
channel: change state pattern dynamically By: Eclipse User on Tue, 31 May 2016 |
6129 |
Sun, 21 May 2017 16:40 By: Eclipse User  |
Multiple HttpClients used in Eclipse SmartHome and bindings - get rid off? By: Eclipse User on Sat, 08 August 2015 |
11100 |
Fri, 19 May 2017 10:39 By: Eclipse User  |
How to packaging Eclipse smart home with karaf integration Packaging eclipse smart home with karaf By: Eclipse User on Wed, 17 May 2017 |
4879 |
Wed, 17 May 2017 10:55 By: Eclipse User  |
Difficulty creating a solution using the ESH bundles Trying to build a solution on top of Apache Karaf with no success By: Eclipse User on Tue, 10 January 2017 |
18202 |
Fri, 12 May 2017 05:45 By: Eclipse User  |
How to use smarthome-packaging-sample-karaf Best practices for creating an ESH based solution By: Eclipse User on Fri, 03 February 2017 |
29078 |
Thu, 11 May 2017 01:59 By: Eclipse User  |
[feature suggestion] Add transform on value of item to apply a bias How to deal with devices reporting values that needs a transformation By: Eclipse User on Fri, 05 May 2017 |
15708 |
Tue, 09 May 2017 08:14 By: Eclipse User  |
Rollershutter in Paper UI Does not work for me; should it? By: Eclipse User on Tue, 21 March 2017 |
9611 |
Thu, 04 May 2017 11:26 By: Eclipse User  |
Double initialize By: Eclipse User on Thu, 27 April 2017 |
11822 |
Thu, 04 May 2017 07:45 By: Eclipse User  |
New biding has errors New biding has dependencies error By: Eclipse User on Fri, 21 April 2017 |
29613 |
Tue, 02 May 2017 08:57 By: Eclipse User  |
Proper way to refer to external libraries libraries available from other repos By: Eclipse User on Sun, 30 April 2017 |
9505 |
Tue, 02 May 2017 05:43 By: Eclipse User  |
Newbie question about new biding Error in pom.xml of a new biding By: Eclipse User on Fri, 21 April 2017 |
15903 |
Mon, 24 April 2017 12:40 By: Eclipse User  |
Send Command to another Binding How to programmatically send a command inside your own binding handler to anther binding By: Eclipse User on Thu, 20 April 2017 |
11139 |
Fri, 21 April 2017 09:29 By: Eclipse User  |
Channel Configuration How to change / update it By: Eclipse User on Sat, 12 December 2015 |
17860 |
Mon, 17 April 2017 09:03 By: Eclipse User  |
How to remove a thing correctly? Link of deleted thing to an item isn't deleted. By: Eclipse User on Fri, 10 March 2017 |
10216 |
Sun, 16 April 2017 04:35 By: Eclipse User  |
Extending States - adding state attributes? By: Eclipse User on Sat, 15 April 2017 |
23702 |
Sat, 15 April 2017 11:53 By: Eclipse User  |
Asynchroneous ThingHandler initialization Is it Ok to initialize in a scheduled task ? By: Eclipse User on Mon, 10 April 2017 |
10108 |
Tue, 11 April 2017 03:20 By: Eclipse User  |
Student project about safety and security in IoT development (CoAP-Binding) Feedback for our current work and first result By: Eclipse User on Thu, 23 March 2017 |
16319 |
Mon, 10 April 2017 12:36 By: Eclipse User  |
Items, Locations and core types By: Eclipse User on Tue, 28 February 2017 |
15483 |
Mon, 10 April 2017 10:32 By: Eclipse User  |
Best update strategy for a polled device ? By: Eclipse User on Sun, 09 April 2017 |
5708 |
Mon, 10 April 2017 10:17 By: Eclipse User  |
Channels cannot be linked if dynamically created By: Eclipse User on Wed, 25 January 2017 |
30860 |
Mon, 10 April 2017 09:47 By: Eclipse User  |
Is it ok to use Thread.sleep() in binding What if the binding needs to pause while waiting for device to respond ? By: Eclipse User on Sun, 09 April 2017 |
6724 |
Mon, 10 April 2017 09:05 By: Eclipse User  |
How to use Trigger-Channels? By: Eclipse User on Sun, 02 April 2017 |
11916 |
Sat, 08 April 2017 16:17 By: Eclipse User  |
Add Options to String Channel Dynamically By: Eclipse User on Thu, 06 April 2017 |
10782 |
Sat, 08 April 2017 08:06 By: Eclipse User  |
ESH Scheduling UI By: Eclipse User on Tue, 07 March 2017 |
12347 |
Thu, 23 March 2017 19:45 By: Eclipse User  |
Are bindings cache somewhere? By: Eclipse User on Tue, 07 March 2017 |
14084 |
Mon, 20 March 2017 06:32 By: Eclipse User  |
How to update Channel's min/max By: Eclipse User on Tue, 14 March 2017 |
4257 |
Tue, 14 March 2017 11:16 By: Eclipse User  |
[solved]WhowTo make Translation files being used? Created file "BindingName_de_DE.properties" is not used! By: Eclipse User on Sat, 11 March 2017 |
5472 |
Sun, 12 March 2017 12:44 By: Eclipse User  |
Thing Added/Removed notification By: Eclipse User on Thu, 02 March 2017 |
4821 |
Fri, 03 March 2017 14:27 By: Eclipse User  |
How to Pre-populate "Location Field" for Thing in Paper UI's autodiscover Inbox By: Eclipse User on Sun, 05 February 2017 |
7684 |
Fri, 03 March 2017 12:01 By: Eclipse User  |
Persistent data for a binding By: Eclipse User on Mon, 13 February 2017 |
8386 |
Fri, 03 March 2017 02:59 By: Eclipse User  |
Build failed Eclipse SmartHome Model Items By: Eclipse User on Mon, 21 March 2016 |
10570 |
Wed, 22 February 2017 23:22 By: Eclipse User  |
Write only channel By: Eclipse User on Thu, 16 February 2017 |
17081 |
Mon, 20 February 2017 13:25 By: Eclipse User  |
ESH TP Version By: Eclipse User on Thu, 09 February 2017 |
12485 |
Tue, 14 February 2017 11:31 By: Eclipse User  |
Changing of channels state and options on build, how? By: Eclipse User on Wed, 25 January 2017 |
27786 |
Tue, 14 February 2017 10:56 By: Eclipse User  |
Dynamic Channel Groups? By: Eclipse User on Tue, 07 February 2017 |
11903 |
Mon, 13 February 2017 13:52 By: Eclipse User  |
Depolyable ESH Deployable ESH as Openhab By: Eclipse User on Thu, 09 February 2017 |
6037 |
Sun, 12 February 2017 23:56 By: Eclipse User  |
Auto Install ESH Bundles After Fresh installation/update Autostart non-default bundles/features By: Eclipse User on Fri, 02 December 2016 |
11469 |
Mon, 06 February 2017 03:36 By: Eclipse User  |
Loggers: static or non-static? By: Eclipse User on Fri, 30 December 2016 |
4705 |
Sat, 04 February 2017 04:52 By: Eclipse User  |
Change thing parameters from a rule E.g., change network thing parameters By: Eclipse User on Thu, 26 January 2017 |
22077 |
Thu, 26 January 2017 10:06 By: Eclipse User  |
Get A lot of ERROR while setup my ESH environment (T_T) By: Eclipse User on Tue, 17 January 2017 |
5921 |
Tue, 24 January 2017 06:01 By: Eclipse User  |
Getting channel's current/latest state By: Eclipse User on Sun, 08 January 2017 |
5662 |
Mon, 16 January 2017 06:30 By: Eclipse User  |
How To Query Items Things and Bindings A few questions about getting global information. By: Eclipse User on Fri, 06 January 2017 |
10433 |
Mon, 16 January 2017 05:44 By: Eclipse User  |
How to get binding configuration properties in an AbstractDiscoveryService? By: Eclipse User on Thu, 12 January 2017 |
12465 |
Mon, 16 January 2017 05:17 By: Eclipse User  |
Yahoo Weather Binding Crash By: Eclipse User on Thu, 12 January 2017 |
3443 |
Thu, 12 January 2017 16:06 By: Eclipse User  |
How can I run ESH outside of eclipse? ESH is composed of a lot of bundles, which come in a preconfigured eclipse workspace. How can I export them outside of eclipse and run them as an independent OSGi service? By: Eclipse User on Fri, 16 December 2016 |
3038 |
Sun, 18 December 2016 05:22 By: Eclipse User  |
Launch configuration for Smarthome Designer for Windows missing By: Eclipse User on Sat, 25 June 2016 |
9169 |
Sat, 10 December 2016 11:57 By: Eclipse User  |
Developing binding: how to get all item values? When user changes a single item value, I command the device with all item values. How do I determine what all the values are? By: Eclipse User on Tue, 06 December 2016 |
6802 |
Thu, 08 December 2016 08:45 By: Eclipse User  |
Interface problem Creating file By: Eclipse User on Tue, 29 November 2016 |
5501 |
Fri, 02 December 2016 02:08 By: Eclipse User  |
Static Code Analysis Checks Add Static Code Analysis Checks to the ESH build By: Eclipse User on Tue, 29 November 2016 |
6654 |
Tue, 29 November 2016 05:58 By: Eclipse User  |
MQTT binding for ESH Creation of a ESH binding similar to the MQTT binding for OH1. By: Eclipse User on Tue, 13 January 2015 |
21962 |
Sun, 27 November 2016 05:36 By: Eclipse User  |
MQTT not getting configuration Configure MQTT By: Eclipse User on Tue, 22 November 2016 |
21090 |
Tue, 22 November 2016 08:37 By: Eclipse User  |
Bridge/Thing lifecycle question By: Eclipse User on Tue, 15 November 2016 |
29298 |
Mon, 21 November 2016 10:18 By: Eclipse User  |
Contribute CM11A binding for X10 devices Discussion of creating a CM11A binding By: Eclipse User on Tue, 15 November 2016 |
34702 |
Fri, 18 November 2016 10:06 By: Eclipse User  |
Installing ESH on MAC Sierra (10.12.1) By: Eclipse User on Tue, 15 November 2016 |
10636 |
Wed, 16 November 2016 10:59 By: Eclipse User  |
newbie needs help starting binding What do I do after installing ESH development environment? By: Eclipse User on Mon, 31 October 2016 |
9407 |
Tue, 08 November 2016 20:54 By: Eclipse User  |
list of channels Determine if any item is interested in an event By: Eclipse User on Fri, 04 November 2016 |
4774 |
Tue, 08 November 2016 04:00 By: Eclipse User  |
REST : ItemResource : only PUT to update state? By: Eclipse User on Sat, 29 October 2016 |
2851 |
Sun, 30 October 2016 18:23 By: Eclipse User  |
LOG & EVENTS Is needed a REST API to get access to log & events By: Eclipse User on Sat, 03 September 2016 |
4626 |
Sat, 22 October 2016 03:44 By: Eclipse User  |
Dynamic Creation and Disposal of Channels Suggestions on efficient methods to dynamically create, remove and dispose channels By: Eclipse User on Thu, 22 September 2016 |
6748 |
Wed, 19 October 2016 06:21 By: Eclipse User  |
Extra information in config XML files By: Eclipse User on Fri, 07 October 2016 |
5265 |
Tue, 11 October 2016 06:53 By: Eclipse User  |
ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge By: Eclipse User on Mon, 03 October 2016 |
4352 |
Fri, 07 October 2016 10:56 By: Eclipse User  |
Duplicate channels on Thing By: Eclipse User on Tue, 04 October 2016 |
3077 |
Wed, 05 October 2016 10:10 By: Eclipse User  |
Upnp Discovery issue usage of the UpnpDiscoveryParticipant By: Eclipse User on Tue, 27 September 2016 |
5600 |
Wed, 05 October 2016 06:50 By: Eclipse User  |
Limit to single instance of a Thing in binding By: Eclipse User on Wed, 28 September 2016 |
3946 |
Fri, 30 September 2016 13:05 By: Eclipse User  |
Binding Transformation Transformation where the source is a binding By: Eclipse User on Mon, 12 September 2016 |
5451 |
Fri, 23 September 2016 01:17 By: Eclipse User  |
Single binding for handling multiple things simultaneously By: Eclipse User on Thu, 08 September 2016 |
7474 |
Fri, 16 September 2016 04:54 By: Eclipse User  |
0.9.0 release plan By: Eclipse User on Tue, 06 September 2016 |
5111 |
Wed, 14 September 2016 12:10 By: Eclipse User  |
Image from Item state (rather from URL) By: Eclipse User on Fri, 09 September 2016 |
4585 |
Wed, 14 September 2016 08:14 By: Eclipse User  |
Combination of Eclipse Kura & Smarthome By: Eclipse User on Wed, 16 March 2016 |
11619 |
Thu, 08 September 2016 17:53 By: Eclipse User  |
LightweightM2M / Leshan / IPSO Implement LwM2m binding By: Eclipse User on Fri, 30 October 2015 |
12597 |
Fri, 26 August 2016 05:01 By: Eclipse User  |
Device configuration system By: Eclipse User on Fri, 15 July 2016 |
10254 |
Tue, 09 August 2016 07:24 By: Eclipse User  |
Running ESH on Knoplerfish framework By: Eclipse User on Thu, 04 August 2016 |
3413 |
Fri, 05 August 2016 11:08 By: Eclipse User  |
New (static) channels are not shown/added for things already existing By: Eclipse User on Sat, 18 June 2016 |
6917 |
Tue, 02 August 2016 10:55 By: Eclipse User  |
EnOcean Binding By: Eclipse User on Mon, 03 August 2015 |
8940 |
Fri, 29 July 2016 07:29 By: Eclipse User  |
Fuzzy logic rule engine By: Eclipse User on Thu, 21 July 2016 |
5492 |
Mon, 25 July 2016 03:19 By: Eclipse User  |
Rule conflict detection Are there any plans to support the Rule conflict detection? By: Eclipse User on Thu, 21 July 2016 |
3463 |
Fri, 22 July 2016 01:32 By: Eclipse User  |
The maximum number of concurrent running devices A question for the maximum number of concurrent execution devices By: Eclipse User on Wed, 20 July 2016 |
2622 |
Wed, 20 July 2016 03:12 By: Eclipse User  |
