sticky: EMF-Incquery forum closure |
11110 |
Fri, 26 February 2016 16:50 By: Eclipse Webmaster |
[Release] EMF-IncQuery 1.1.0 |
5952 |
Mon, 07 December 2015 14:20 By: Abel Hegedus |
Using IncQuery to compute derived values |
2008 |
Fri, 04 December 2015 16:56 By: Zoltan Ujhelyi |
Query UML-model with UML-profile: no matches |
3259 |
Wed, 02 December 2015 17:05 By: Jens Bürger |
How to generate java files from inc query definition file (.eiq files) Generating java files from .eiq file during maven build |
4750 |
Mon, 30 November 2015 07:43 By: bisoyi J |
UML Incquery pattern : constrain to particular model name UML Incquery pattern : constrain to particular model name |
10706 |
Wed, 11 November 2015 16:37 By: Abel Hegedus |
no packages to be imported in query definition wizard? |
3079 |
Sun, 16 August 2015 19:21 By: Zoltan Ujhelyi |
Find the feature of changed elements Find the feature of changed elements |
4670 |
Fri, 31 July 2015 09:19 By: Gabor Bergmann |
Using Incquery as EVM for notifying UML papyrus changes Using Incquery as EVM for notifying UML papyrus changes |
5005 |
Sat, 25 July 2015 17:21 By: Zoltan Ujhelyi |
Query on Papyrus UML models with applied profiles Query on Papyrus UML models with applied profiles |
2962 |
Mon, 20 July 2015 14:11 By: Van Cam PHAM |
EVM: Update job - How to find the element that changed? |
6691 |
Wed, 17 June 2015 21:46 By: Zoltan Ujhelyi |
How to prevent traversal of objects (part 2) |
3331 |
Wed, 17 June 2015 08:49 By: Abel Hegedus |
How can I keep my EMF model loaded (persistent Indexes) |
3646 |
Mon, 01 June 2015 16:39 By: Istvan Rath |
Custom path for validation project |
3083 |
Thu, 28 May 2015 21:13 By: ihave question |
Passing arguments to IncQuery Patterns at Runtime Attempt to use patterns dynamically at runtime |
12631 |
Tue, 26 May 2015 11:20 By: Zoltan Ujhelyi |
Query Pattern takes up enormous amounts of memory |
2575 |
Thu, 21 May 2015 20:08 By: ihave question |
Transitive Closure for IncQuery Patterns at Runtime |
2765 |
Tue, 12 May 2015 13:47 By: Istvan Rath |
Find and count elements of certain type inside a element |
6846 |
Thu, 23 April 2015 06:56 By: Abel Hegedus |
IncQuery for RCP Applications |
8063 |
Tue, 14 April 2015 12:12 By: Zoltan Ujhelyi |
Extract transitive closure path from match |
5070 |
Mon, 09 March 2015 13:34 By: ihave question |
Migration to 0.9.0 documentation? |
5199 |
Sun, 01 March 2015 09:48 By: Jan Reimann |
Newbie questions - please help me understand |
3767 |
Mon, 23 February 2015 09:26 By: Gabor Bergmann |
Performance differences Plugin/Java API IncQuery Eclipse Plugin is much more slow than Java API |
5108 |
Tue, 20 January 2015 14:20 By: Gwendal DANIEL |
Incquery & Xtext |
5457 |
Thu, 15 January 2015 10:09 By: Zoltan Ujhelyi |
Get notified when index is ready |
4375 |
Thu, 15 January 2015 09:58 By: Ali AKAR |
Filter The result of Graph Filter The result of Graph |
3899 |
Sat, 18 October 2014 18:29 By: Zoltan Ujhelyi |
Generating and building IncQuery Project |
4588 |
Sat, 18 October 2014 18:18 By: Zoltan Ujhelyi |
correct steps to install emf incquery |
4938 |
Mon, 06 October 2014 13:34 By: Ronan B |
Duplication issue of Item and Edge in Zest graph I have duplication relations in the graph |
4066 |
Mon, 29 September 2014 04:12 By: Salwa Alzahmi |
how load xml emf resource using api |
3798 |
Mon, 15 September 2014 05:28 By: Made Leine |
call queries IncQuery API |
2330 |
Fri, 12 September 2014 14:07 By: Zoltan Ujhelyi |
IncQuery Explorer and Xtext resources |
6853 |
Thu, 11 September 2014 10:20 By: Gabor Bergmann |
Check URI of Resource |
9079 |
Thu, 28 August 2014 07:27 By: Zoltan Ujhelyi |
Aggregation of Strings of different Objects |
3062 |
Wed, 27 August 2014 22:05 By: Mario Bauer |
get Eclass of EObject |
3332 |
Fri, 22 August 2014 07:11 By: Eclipse Guest |
Simplification of Query |
3150 |
Wed, 30 July 2014 10:23 By: Mario Bauer |
Compare values |
23 |
9728 |
Sun, 06 July 2014 08:29 By: Zoltan Ujhelyi |
java.lang.Override is not on the classpath |
4093 |
Mon, 23 June 2014 14:07 By: Jan Reimann |
plugin.xml is not being generated automatically By: Emre T on Sun, 11 May 2014 |
7699 |
Mon, 02 June 2014 13:15 By: Emre T |
Use IncQueryObservables outside eclipse context (Rap) |
7931 |
Sun, 18 May 2014 21:14 By: Zoltan Ujhelyi |
Concurrency in incquery |
4245 |
Thu, 15 May 2014 07:01 By: Balázs Grill |
Another "Ambiguous variable type defintions" problem By: Emre T on Sat, 03 May 2014 |
8738 |
Wed, 07 May 2014 09:07 By: Emre T |
A logger directly in *.eiq possible? By: Emre T on Sat, 26 April 2014 |
3087 |
Sun, 27 April 2014 07:53 By: Abel Hegedus |
Inherited derived references By: Emre T on Mon, 17 March 2014 |
8976 |
Fri, 04 April 2014 11:34 By: Emre T |
A pattern definition regarding Inheritance By: Emre T on Fri, 14 March 2014 |
4793 |
Tue, 18 March 2014 12:55 By: Abel Hegedus |
Statements and Operations in Query Definitions By: Emre T on Mon, 24 February 2014 |
5126 |
Fri, 14 March 2014 12:08 By: Emre T |
Accessing the values of attributes/references in pattern bodies By: Emre T on Tue, 11 March 2014 |
2327 |
Tue, 11 March 2014 17:13 By: Zoltan Ujhelyi |
Variable has a type which has multiple definitions By: Emre T on Tue, 11 February 2014 |
8999 |
Mon, 24 February 2014 08:38 By: Zoltan Ujhelyi |
Unique names of derived features? By: Emre T on Wed, 19 February 2014 |
5824 |
Mon, 24 February 2014 00:47 By: Abel Hegedus |
Queries for derived features with constrains By: Emre T on Mon, 10 February 2014 |
5909 |
Wed, 19 February 2014 09:52 By: Zoltan Ujhelyi |
Not representable well-behaving feature By: Emre T on Tue, 11 February 2014 |
8273 |
Thu, 13 February 2014 13:38 By: Abel Hegedus |
Is it possible to use incquery in Standalone EMF? |
6426 |
Tue, 11 February 2014 19:46 By: Zoltan Ujhelyi |
Reflective IncQueryEngine |
25 |
17697 |
Tue, 11 February 2014 16:45 By: Zoltan Ujhelyi |
setSelectionToViewer NoSuchMethod exception |
6612 |
Tue, 11 February 2014 15:57 By: Zoltan Ujhelyi |
Distinct Query |
3792 |
Tue, 11 February 2014 11:53 By: Gabor Bergmann |
IncQuery support for XText 2.5 |
6640 |
Mon, 10 February 2014 16:17 By: Emre T |
How to prevent traversal of objects |
3488 |
Tue, 04 February 2014 14:20 By: Istvan Rath |
Querying Derived Features |
6914 |
Wed, 09 October 2013 08:45 By: Zoltan Ujhelyi |
Parameterized queries |
4765 |
Tue, 08 October 2013 20:42 By: Zoltan Ujhelyi |
Simple expression syntax |
3991 |
Thu, 05 September 2013 18:57 By: Zoltan Ujhelyi |
[Solved] [How to] : Expressing constraints on type or class |
7432 |
Mon, 12 August 2013 22:02 By: Didier Garcin |
[Solved] [EMF-IncQuery Project Builder] : Errors running builder 'EMF-IncQuery Project Builder' |
6994 |
Sat, 10 August 2013 11:43 By: Didier Garcin |
Different Results when usin API in runtime Eclipse and in JUnit Plugin Test |
21 |
14747 |
Thu, 08 August 2013 10:27 By: Jan Reimann |
Error executing EValidator |
8820 |
Wed, 10 July 2013 13:05 By: Jan Reimann |
After each workspace build every pattern has the same error |
4922 |
Mon, 08 July 2013 09:57 By: Abel Hegedus |
Package declaration "does not match the container package" |
5243 |
Sat, 29 June 2013 17:04 By: Remy Honig |
Support for Xtext 2.4? By: Emre T on Tue, 25 June 2013 |
4448 |
Tue, 25 June 2013 11:35 By: Istvan Rath |
Non-persisted resources for AdvancedAPI By: Emre T on Mon, 03 June 2013 |
7883 |
Tue, 04 June 2013 10:26 By: Gabor Bergmann |
Running IncQuery transformation inside an Eclipse WorkspaceJob |
6574 |
Tue, 21 May 2013 07:29 By: Joost van Pinxten |
Generating *.eiq code from IncQuery metamodel instances By: Emre T on Sun, 21 April 2013 |
5363 |
Thu, 25 April 2013 22:37 By: Emre T |
Special syntax for pattern activation on nullable features? |
4060 |
Thu, 18 April 2013 13:37 By: Abel Hegedus |
Substring search in atributes By: Emre T on Tue, 16 April 2013 |
9056 |
Tue, 16 April 2013 21:15 By: Istvan Rath |
Substring search in Atributes [Double-post] By: Emre T on Mon, 15 April 2013 |
2900 |
Mon, 15 April 2013 23:43 By: Emre T |
Model transformation: how to force the order of output elements based on the order of input elements |
6325 |
Thu, 28 March 2013 18:30 By: Istvan Rath |
Invoke IncQuery in JUnit test cases |
54 |
6876 |
Wed, 27 March 2013 11:08 By: Eclipse User |
EMF-IncQuery Eclipse.org migration is complete |
4947 |
Mon, 04 March 2013 09:02 By: Istvan Rath |
Warning about cartesian product seems unnecessary in some cases |
10063 |
Tue, 12 February 2013 10:03 By: Gabor Bergmann |
Finding all elements of an association in a subtree Can you tell me how to do this? |
4585 |
Mon, 11 February 2013 07:43 By: Abel Hegedus |
Unable to install EMF IncQuery Unable to install EMF IncQuery from the update site. |
5836 |
Tue, 22 January 2013 14:14 By: Istvan Rath |
Welcome to eclipse.incquery |
2474 |
Fri, 19 October 2012 15:55 By: Eclipse Webmaster |
