Topic |
Replies |
Views |
Last message |
Use of coma in formula |
4 |
2737 |
Fri, 06 July 2018 08:54 By: Dirk Fauth |
Problem using SortColumnCommand on a table with a CompositeFreezeLayer |
2 |
2135 |
Mon, 25 June 2018 11:16 By: Tom Wheeler |
Avoid Nattable selecting the first char typed in edit mode |
4 |
2213 |
Thu, 14 June 2018 21:23 By: Santhosh Kumar |
Filtering clarifications |
8 |
51235 |
Thu, 31 May 2018 07:00 By: Dirk Fauth |
Editable GroupBy Bug, reproduced in the Examples Application |
2 |
2223 |
Mon, 28 May 2018 12:19 By: Alexander Farel |
How to detect double click on row header and do something? |
3 |
3081 |
Sat, 19 May 2018 16:50 By: Dirk Fauth |
BUG: Excel like filter with same filter value |
1 |
1647 |
Thu, 17 May 2018 15:54 By: Dirk Fauth |
How to make nattable fill window horizontally |
4 |
3012 |
Wed, 16 May 2018 05:11 By: Dirk Fauth |
NatTable data refresh issue on Horizontal and Vertical Scroll NatTable data refresh issue on Horizontal and Vertical Scroll |
10 |
6843 |
Mon, 07 May 2018 15:25 By: Santhosh Kumar |
Possible Bug in CompositeFreezeLayer There seems to be an issue with getPreferredColumnCount/getPreferredRowCount |
1 |
2452 |
Mon, 07 May 2018 12:41 By: Dirk Fauth |
Null Pointer Exception when adding new data to eventlist Getting null pointer exception when i am inserting a new data row to my eventlist |
1 |
2694 |
Thu, 03 May 2018 13:43 By: Dirk Fauth |
GAP between the custom image and base content with background image There is a gap between custom image and base content if have background image |
7 |
3917 |
Tue, 24 April 2018 02:36 By: chun liang Wen |
Custom persistence behavior and modifying the PersistenceDialog |
1 |
1714 |
Tue, 03 April 2018 16:14 By: Dirk Fauth |
Sorting not proper |
1 |
2176 |
Thu, 08 March 2018 11:26 By: Dirk Fauth |
Cell painting with Combination of images |
2 |
2710 |
Wed, 28 February 2018 17:29 By: Santhosh Kumar |
Make row index stable when Rowreorder is done |
3 |
2231 |
Tue, 27 February 2018 11:39 By: Dirk Fauth |
Way to know if Sorting/Filtering is done on NatTable |
3 |
1967 |
Tue, 27 February 2018 11:36 By: Dirk Fauth |
NatTable 1.6 release date |
1 |
2417 |
Wed, 21 February 2018 05:57 By: Dirk Fauth |
NatTable Zooming |
1 |
2161 |
Wed, 21 February 2018 05:54 By: Dirk Fauth |
Is it possible to put filter dropdown with column header ? |
2 |
12033 |
Mon, 19 February 2018 11:39 By: Gaurav Tripathi |
Paste Data |
5 |
8948 |
Thu, 15 February 2018 14:31 By: Maksim Shchekotov |
how can get the hidden cell hidden cell By: yu epng on Thu, 01 February 2018 |
1 |
1875 |
Thu, 01 February 2018 09:43 By: Dirk Fauth |
Issue with automatic cell resize with TextPainter Cell height isn't reduced to original height when horizontal space is available |
15 |
7609 |
Fri, 26 January 2018 14:30 By: Mike Rumpf |
Nattable row position after scrolling How to get the row position after scroling |
2 |
2862 |
Mon, 22 January 2018 06:21 By: Panisha RN |
Combo box drop down menu appearing outside of viewport |
2 |
2561 |
Sat, 20 January 2018 00:58 By: Louis Detweiler |
Help with overriding grid line rendering methods |
2 |
2596 |
Fri, 19 January 2018 21:38 By: Louis Detweiler |
Excel Export with .xlsx |
3 |
5630 |
Thu, 18 January 2018 13:02 By: Dirk Fauth |
Auto resize column by double clicking |
4 |
4699 |
Fri, 12 January 2018 08:39 By: Angel Fraile |
ColumnGroup collapsable even if no ColumnGroupExpandCollapseLayer registered ColumnGroup is initialized with collapsable = true always. So the expand/collapse icons are always drawn even if no ColumnGroupExpandCollapseLayer is registered. |
2 |
1848 |
Tue, 09 January 2018 14:53 By: Michel Pittelkow |
Intercepting row header region click actions |
1 |
1369 |
Mon, 08 January 2018 22:31 By: Louis Detweiler |
Layer type to stack type mapping Which layer is used in which type of layerstack? |
2 |
2368 |
Fri, 05 January 2018 14:04 By: Michel Pittelkow |
ColumnOverrideLabelAccumulator - addLabel for entire row to set row border |
2 |
2382 |
Fri, 05 January 2018 11:49 By: Bartosz Szczypien |
Reset to original order (PopupMenuBuilder) I want to implement a context menu item that enables the user to reset reordering made |
3 |
4482 |
Wed, 20 December 2017 13:24 By: Michel Pittelkow |
Is that possible select a cell in a FixedSummaryRowLayer and copy it? copy selected cells in FixedSummaryRowLayer |
4 |
2591 |
Wed, 20 December 2017 10:58 By: chun liang Wen |
why column header can not fully copied can not fully copy nattable's column header |
2 |
3530 |
Tue, 19 December 2017 11:03 By: chun liang Wen |
handle page up/down events in nattable |
5 |
4611 |
Tue, 19 December 2017 08:27 By: Ali Sedaghat |
define the hot key for copy // select all // paste Hot key By: yu epng on Mon, 18 December 2017 |
1 |
4020 |
Tue, 19 December 2017 06:59 By: Dirk Fauth |
EditableGridExample EditableGridExample Error Message Not Working |
1 |
2692 |
Thu, 14 December 2017 06:27 By: Dirk Fauth |
Row selection with spanning |
4 |
3029 |
Sat, 02 December 2017 07:41 By: Dirk Fauth |
Cell boundary of underlying cell showing when selecting a spanned cell |
3 |
2884 |
Wed, 29 November 2017 17:56 By: Dirk Fauth |
Row spanning in the row header region |
4 |
3478 |
Tue, 28 November 2017 18:30 By: Louis Detweiler |
Nattable does not display data when using SortHeaderLayer |
6 |
3336 |
Mon, 27 November 2017 08:06 By: Dirk Fauth |
0 |
4617 |
Sun, 26 November 2017 06:57 By: Ali Sedaghat |
Losing focus on DateCellEditor Causing a NullPointerException on Linux |
1 |
2813 |
Fri, 17 November 2017 04:35 By: Dirk Fauth |
Row header layer not converting position to index |
5 |
4274 |
Mon, 06 November 2017 20:23 By: Louis Detweiler |
Some strange behavior with multiselect checkbox combobox dropdown |
1 |
1771 |
Mon, 06 November 2017 19:41 By: Dirk Fauth |
A way to disable the default popup menu (right clicking on editable cell)? |
3 |
7077 |
Fri, 03 November 2017 04:36 By: Dirk Fauth |
Text wrapping in row header region and cells in edit mode |
5 |
3839 |
Sat, 28 October 2017 23:32 By: Louis Detweiler |
Gap between grid lines and cells in HDPI environments with CSS & swt.autoScale There might be a gap rendered between grid lines in HDPI environments with CSS & vmarg -Dswt.autoScale=quarter |
11 |
17129 |
Thu, 26 October 2017 05:51 By: Dirk Fauth |
GroupByDataLayer and TreeData |
3 |
3181 |
Tue, 24 October 2017 08:02 By: Dirk Fauth |
groupBy nattable |
1 |
1620 |
Thu, 19 October 2017 17:02 By: Dirk Fauth |
Select row instead of cell in a Tree NatTable By: Felix S on Tue, 17 October 2017 |
4 |
3618 |
Wed, 18 October 2017 10:37 By: Felix S |
Strange celleditor behavior on Mac |
2 |
3541 |
Mon, 16 October 2017 14:10 By: Bakjwis Bakjwis |
checkbox column double-click event |
1 |
2941 |
Mon, 16 October 2017 08:38 By: Dirk Fauth |
Is it possible to use the SpanningDataLayer and an ISpanningDataProvider with a GridLayer? |
1 |
1861 |
Wed, 11 October 2017 03:42 By: Dirk Fauth |
Strange column reorder behavior |
3 |
2345 |
Mon, 09 October 2017 15:28 By: Dirk Fauth |
Sorting not proper for numeric values |
2 |
2750 |
Mon, 09 October 2017 09:45 By: Gaurav Tripathi |
Same column having combo-box with two different list |
2 |
3812 |
Mon, 09 October 2017 05:51 By: Gaurav Tripathi |
SizeConfig doesd not invalidate cache when DPI converter is set |
2 |
2974 |
Wed, 04 October 2017 10:46 By: Thorsten Schlathölter |
Add new row header |
7 |
6717 |
Tue, 03 October 2017 06:19 By: Dirk Fauth |
GroupBySummary Update Parent Summary value |
2 |
7211 |
Mon, 02 October 2017 06:54 By: cenk Mising name |
Scrolling row into view programmatically Problem with SelectRowsCommand |
7 |
8643 |
Fri, 22 September 2017 07:49 By: Dirk Fauth |
Possible bug in NatCombo using multiselect with easy fix |
2 |
2743 |
Mon, 18 September 2017 19:00 By: Dirk Fauth |
TableCellPainter trouble TableCellPainter configuration for specific rows-columns instead of entire column |
3 |
5259 |
Mon, 18 September 2017 17:01 By: Dirk Fauth |
Question about TableCellPainter subcell selection/editing |
2 |
3132 |
Wed, 13 September 2017 20:50 By: Louis Detweiler |
Issue with ComboBoxCellEditor position |
1 |
3179 |
Mon, 11 September 2017 18:19 By: Dirk Fauth |
cell border cell border line appearing |
6 |
7565 |
Mon, 11 September 2017 05:19 By: Dirk Fauth |
Custom ComboBoxCellEditor |
6 |
6334 |
Fri, 08 September 2017 23:38 By: Louis Detweiler |
Removing a row affects another row |
4 |
6955 |
Fri, 08 September 2017 19:16 By: Ralf Heydenreich |
NatTable: Remove Gridline from cell Paint Cell Borders Grid line with CustomLineBorderDecorator By: PC PC on Thu, 07 September 2017 |
1 |
3663 |
Fri, 08 September 2017 13:14 By: Dirk Fauth |
Help with validation error handlers |
1 |
5331 |
Fri, 01 September 2017 03:52 By: Dirk Fauth |
How to make row header cells editable? |
1 |
1762 |
Tue, 29 August 2017 23:06 By: Louis Detweiler |
Deselecting the cell after selection does not edit the cell |
2 |
16555 |
Sat, 26 August 2017 11:30 By: Dirk Fauth |
Combo box Editor is not hiding/closing sometimes |
12 |
11870 |
Fri, 25 August 2017 16:32 By: Dirk Fauth |
Background color in a cell |
3 |
7153 |
Fri, 25 August 2017 12:35 By: Dirk Fauth |
Potential bug in SelectionModel.java |
3 |
7717 |
Fri, 25 August 2017 11:33 By: Dirk Fauth |
Best Practice about uncommon table layout How to add an area between header and body |
12 |
22239 |
Fri, 25 August 2017 06:05 By: Chris Lewold |
Is it possible to use RowSelectionModel in combination with GroupByLayer ? There seem to be problems when Group-By is active with casts from GroupByObject to "MyRowBean" |
6 |
19423 |
Fri, 25 August 2017 05:59 By: Dirk Fauth |
How to use static filters how to reapply a static filter in case data change |
2 |
6943 |
Fri, 25 August 2017 05:56 By: Chris Lewold |
Is it possible to implement something similar to merged cells in Excel? |
3 |
11380 |
Thu, 24 August 2017 03:50 By: Dirk Fauth |
Can't get TableCellPainter's dynamically calculated sub cell heights to work |
2 |
6988 |
Wed, 23 August 2017 17:55 By: Louis Detweiler |
NatTable Books |
2 |
4393 |
Tue, 22 August 2017 07:05 By: Lalit Solanki |
Import Excel to nabula nattable |
7 |
7459 |
Tue, 22 August 2017 07:02 By: Lalit Solanki |
0 |
12338 |
Fri, 18 August 2017 01:35 By: Louis Detweiler |
Register a normal click in a table with CellEditors Select a cell with a normal click, CellEditor with the second click |
1 |
6337 |
Thu, 17 August 2017 09:10 By: Angel Fraile |
Enable cell decoration outside of editing mode I'd like to show a cell decoration for invalid values even if the cell is not edited |
1 |
1516 |
Thu, 03 August 2017 23:41 By: Stephan Druskat |
Body and row headers not displaying for Big Data |
4 |
4418 |
Wed, 02 August 2017 16:58 By: Wallace Lake |
Dynamically create new row on commit last row's last cell's CellEditor When I manually add to the data model in commit, two new rows are created |
2 |
5317 |
Tue, 01 August 2017 23:04 By: Stephan Druskat |
Not able to select Row Header when only one column is present |
4 |
9843 |
Mon, 31 July 2017 06:24 By: Gaurav Tripathi |
How to set native SWT images in CheckBoxPainter? |
1 |
4553 |
Tue, 25 July 2017 10:48 By: Dirk Fauth |
Simple filter without row |
2 |
4827 |
Mon, 24 July 2017 11:35 By: Jean-Marc LARRE |
Selective edit of rows in Nattable Selective edit of rows in Nattable |
1 |
8443 |
Mon, 24 July 2017 05:32 By: Dirk Fauth |
How to register Jface Dialog to NatTable Cells ? |
1 |
9117 |
Thu, 20 July 2017 05:34 By: Dirk Fauth |
NatTable does not render cells after moving from 1.4 to 1.5 |
4 |
5495 |
Tue, 18 July 2017 10:43 By: Arjan Kok |
Make column unmovable while scrolling horizontally |
1 |
4369 |
Wed, 12 July 2017 12:04 By: Gaurav Tripathi |
How to show a tooltip over a sorting triangle image at a column header? |
5 |
19972 |
Wed, 12 July 2017 05:59 By: Dirk Fauth |
How check a cell which only display part of content? |
5 |
10402 |
Sat, 08 July 2017 09:54 By: Bel Razom |
Row Reorder issue |
1 |
6553 |
Thu, 06 July 2017 10:33 By: Dirk Fauth |
Dynamic preferred min column width in composite layer |
2 |
6806 |
Thu, 29 June 2017 06:31 By: Dirk Fauth |
Static Filter for tree structure in NatTable |
1 |
10570 |
Wed, 21 June 2017 06:59 By: Dirk Fauth |
Remove row numbers in Nattable Nattable |
1 |
3241 |
Sat, 17 June 2017 19:17 By: Dirk Fauth |
Create nattable with two column ,the second column has multiple dynamic rows inside. Creating a customise nattable |
15 |
22197 |
Tue, 13 June 2017 06:49 By: Andreea Sonda |
"Interrupted Selection" creates Multiselection effect |
13 |
12956 |
Thu, 08 June 2017 12:29 By: Ludwig Moser |
Nattable Export Excel Report contains filter string also Nattable Export Excel Report contains filter string also |
6 |
16220 |
Thu, 08 June 2017 09:10 By: Christian Mohr |
Text Filter column doesn't work |
7 |
7149 |
Fri, 02 June 2017 15:27 By: Mohamed SADI |
setDataValue of ColumnPropertyAccessor not called when using TableCellEditor setDataValue of ColumnPropertyAccessor not called when using TableCellEditor |
4 |
8931 |
Fri, 02 June 2017 12:38 By: Mathias Jankow |
Unavailable dependencies in the Getting Started Tutorial Missing Neon Release modules used in the tutorial |
2 |
3895 |
Wed, 31 May 2017 16:01 By: Bel Razom |
A view Issue at NatTable Examples Application on Windows7 Empty view at the right part of the window |
5 |
16322 |
Wed, 31 May 2017 03:26 By: Bel Razom |
Multiple Selection in NatTable Is it possible to Select multiple NatTable value? |
1 |
3840 |
Tue, 30 May 2017 16:01 By: Dirk Fauth |
Cell DisplayMode Changed Event |
5 |
2927 |
Fri, 12 May 2017 12:17 By: Dirk Fauth |
Loading Nattable state takes a lot of time. |
17 |
23579 |
Wed, 03 May 2017 11:30 By: Dirk Fauth |
IColumnAccessor.setDataValue is called twice |
3 |
6728 |
Fri, 28 April 2017 06:33 By: Dirk Fauth |
RichTextPainter and Alignment question |
3 |
3152 |
Wed, 26 April 2017 14:59 By: Mike Rumpf |
Suggestion related to ComboboxFilter |
1 |
3881 |
Fri, 21 April 2017 13:00 By: Dirk Fauth |
Icons will not be displayes when column is frozen Issue when first table column is frozen, no icons will be displayed |
2 |
5803 |
Tue, 18 April 2017 10:54 By: Mike Rumpf |
How to remove configuration from Nattable? Dynamic column number - user can select more or less columns to display |
3 |
6402 |
Fri, 31 March 2017 06:31 By: Dirk Fauth |
NatTable 1.5.0 released |
0 |
60318 |
Mon, 20 March 2017 06:54 By: Dirk Fauth |
Combo Box editor clears value on keyboard input |
1 |
3417 |
Wed, 15 March 2017 22:03 By: Dirk Fauth |
Custom filter for not displayed values in table |
3 |
4999 |
Wed, 08 March 2017 12:59 By: Dirk Fauth |
Multiline text cell editor |
1 |
3026 |
Mon, 06 March 2017 20:22 By: Dirk Fauth |
Using Filtering and Sorting with TreeList.Format ( Tree ) |
1 |
2617 |
Mon, 06 March 2017 12:14 By: Dirk Fauth |
How to use a filter on a NatTable without headers (neither column nor row) |
6 |
6110 |
Thu, 02 March 2017 16:56 By: ADeveloper Repoleved |
Row height based on position, Instead of Index |
1 |
5914 |
Tue, 28 February 2017 07:51 By: Dirk Fauth |
How to not render grid lines around between cells via CSS How to not render grid lines around between cells via CSS |
3 |
4615 |
Mon, 20 February 2017 15:26 By: Dirk Fauth |
nebula nattable vs swt table deferences |
4 |
4038 |
Mon, 13 February 2017 08:53 By: Lalit Solanki |
ComboBoxCellEditor can't save custom input value |
3 |
3171 |
Wed, 08 February 2017 07:33 By: Dirk Fauth |
Focus is not coming out of custom cell editor. |
5 |
4777 |
Thu, 26 January 2017 07:35 By: Dirk Fauth |
TreeLayer: Retrieve items lazily does not work properly By: Marc M on Tue, 24 January 2017 |
3 |
3030 |
Wed, 25 January 2017 08:02 By: Dirk Fauth |
Search not working |
4 |
3154 |
Fri, 20 January 2017 12:57 By: Ludwig Moser |
Editor position mismatches in Groupby Nattable. |
4 |
4369 |
Fri, 20 January 2017 08:48 By: Naveen Sabapathy |
Displaying different objects in Nat Table |
3 |
3114 |
Thu, 19 January 2017 10:54 By: Dirk Fauth |
Key navigation not "active" when programmatically focusing NatTable Control |
2 |
4688 |
Wed, 18 January 2017 16:17 By: Stephan Druskat |
StyledText in TextPainter |
6 |
3497 |
Thu, 12 January 2017 18:26 By: Joachim Fox |
Get index of currently selected column from within custom selection binding |
1 |
2555 |
Fri, 06 January 2017 17:22 By: Dirk Fauth |
NatTable a suitable widget for my application? I'm trying to assess whether I should dive into an implementation based on NatTable |
6 |
5224 |
Thu, 05 January 2017 08:27 By: Stephan Druskat |
Flip row and column |
6 |
4802 |
Thu, 05 January 2017 08:11 By: Stephan Druskat |
[NatTable]how to add icon in each column header? |
1 |
1880 |
Tue, 20 December 2016 15:23 By: Dirk Fauth |
programmatically calling keyEvents or other way for opening build in Dialogs |
2 |
1559 |
Wed, 14 December 2016 08:54 By: Ludwig Moser |
Mass update of Groupby table with Regular Expession is not working. |
2 |
4075 |
Tue, 06 December 2016 17:34 By: Naveen Sabapathy |
DragSupport and reorderDragMode Doesn't works together |
3 |
2125 |
Mon, 28 November 2016 16:29 By: Mickael ADAM |
Problem with greyed out columns when table is resized |
19 |
33025 |
Tue, 22 November 2016 15:34 By: Mike Rumpf |
Groupby display name shows original name Groupby columns shows original column name, not the renamed column name |
1 |
2277 |
Fri, 11 November 2016 10:24 By: Dirk Fauth |
Facing issue while rename column header in Nattable RenameColumnHeaderCommand doesn't work properly for the columns which are not visible. |
3 |
3002 |
Wed, 09 November 2016 15:51 By: Naveen Sabapathy |
Observation: Alternate row color changes in custom style |
1 |
2682 |
Wed, 02 November 2016 15:44 By: Dirk Fauth |
second lvl RowGroup Example |
1 |
1764 |
Fri, 21 October 2016 10:37 By: Dirk Fauth |
Display column header diagonally |
2 |
2228 |
Thu, 20 October 2016 09:36 By: Vincent Lorenzo |
Traversal and MultiLineTextCellEditor |
5 |
3641 |
Thu, 20 October 2016 03:52 By: Dirk Fauth |
TreeGridWithCheckBoxFieldsExample Sortation Problem TreeGridWithCheckBoxFieldsExample Sortation Problem when data of root set null |
2 |
3337 |
Sat, 22 October 2016 19:42 By: Dirk Fauth |
[Help] Freeze Rows/Colums freezes all indexes down to 0 |
1 |
1586 |
Thu, 06 October 2016 14:13 By: Dirk Fauth |
RowReorderCommand works only in one direction |
2 |
1964 |
Wed, 05 October 2016 19:01 By: Ralf Heydenreich |
GroupBy - how to refresh groups after data changed? |
4 |
2633 |
Fri, 30 September 2016 19:14 By: Joachim Fox |
CalculatedValueCache Deadlock |
5 |
2529 |
Thu, 29 September 2016 18:47 By: Dirk Fauth |
NatTable Drawing FPS / Performance vs SWT table |
4 |
4537 |
Fri, 23 September 2016 11:36 By: Bernhard Buss |
Row-height defined via CSS not being applied to data added at runtime Row-height defined via CSS not being applied to data added at runtime |
4 |
3710 |
Fri, 16 September 2016 16:52 By: Lothar L. |
Export NatTable to Pdf Export NatTable to Pdf |
1 |
1717 |
Fri, 09 September 2016 20:03 By: Dirk Fauth |
ShowCellInViewportCommand on _513_FreezeExample |
12 |
6544 |
Thu, 08 September 2016 10:40 By: Dirk Fauth |
Excel Like coloring facility Providing color to Nattable, Something simillar to excel. |
4 |
3221 |
Fri, 16 September 2016 09:43 By: Naveen Sabapathy |
How to resize the nattable row header column width |
2 |
2685 |
Thu, 25 August 2016 14:35 By: Ramakrishnan PK |
Cell editor based on the canonical "ROW" data |
1 |
1757 |
Thu, 25 August 2016 08:47 By: Dirk Fauth |
Editor registered for a Spanned cell should invoke original column editor Editor registered for a Spanned cell should invoke original column editor |
1 |
1619 |
Thu, 25 August 2016 08:38 By: Dirk Fauth |
Conditional CellEditor activation based on EditAction |
3 |
2598 |
Fri, 26 August 2016 05:48 By: Tobias Mehre |
Find Text while setting the Scope to Selection, Removing Application Modal After setting the Scope to selection, Its getting only the First value. |
8 |
4328 |
Tue, 27 September 2016 20:44 By: Dirk Fauth |
Word wrapping problem in RichTextCellPainter |
3 |
3052 |
Tue, 23 August 2016 05:37 By: Volker Bier |
Using a SelectionLayer and buttons together in a table Using a SelectionLayer and buttons together in a table |
4 |
4392 |
Fri, 19 August 2016 16:13 By: Lothar L. |
Vertical scrollbars broken on Mac OS (10.11) Vertical scrollbars rendering issue |
8 |
4169 |
Wed, 17 August 2016 14:46 By: Thomas Zahn |
Cell Edit Event Configuration |
1 |
4038 |
Sun, 14 August 2016 08:07 By: Dirk Fauth |
Condition based styling for cells Set different styles to cells based on value |
1 |
2141 |
Thu, 11 August 2016 10:39 By: Arye Shemesh |
Remove selection anchor |
6 |
3590 |
Wed, 10 August 2016 05:41 By: Dirk Fauth |
Hided dynamic column whose header is persisted leads to refresh issues Persisted state of header columns |
2 |
1721 |
Fri, 05 August 2016 08:41 By: Dirk Fauth |
ZoomLayer |
2 |
1723 |
Wed, 03 August 2016 08:15 By: Nico Linder |
Tree full CSS styling of tree status column Trying to apply CSS styling to the very left column of a tree |
11 |
5430 |
Thu, 04 August 2016 16:25 By: Dirk Fauth |
Localization Additional languages |
3 |
2928 |
Thu, 11 August 2016 07:45 By: Dirk Fauth |
How to config NatTable to select entire row not single? |
1 |
1418 |
Wed, 27 July 2016 14:54 By: Dirk Fauth |
Wrapping of text in Column Header |
3 |
2309 |
Mon, 25 July 2016 12:13 By: Dirk Fauth |
NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility with eclipse 4 and jdk 1.8 |
2 |
1558 |
Tue, 12 July 2016 15:15 By: Deepshikha Tripathi |
NatTable Merge of cell |
2 |
2039 |
Thu, 21 July 2016 05:04 By: Lalit Solanki |
Getting and setting manage |
6 |
2758 |
Wed, 06 July 2016 11:11 By: Dirk Fauth |
Hiding a Column Using NAT TABLE API Hiding a Column Using NAT TABLE API |
3 |
3778 |
Fri, 01 July 2016 14:33 By: Dirk Fauth |
Select a row after including a new one |
2 |
2353 |
Tue, 28 June 2016 12:35 By: Nico Linder |
Column Group Header Rename |
2 |
2094 |
Mon, 27 June 2016 12:14 By: Bhagwan Moondra |
Change localization of search mask |
2 |
1709 |
Mon, 27 June 2016 12:24 By: Nico Linder |
In NatTable hide horizontal scrollbar with out disturbing vertical scrolling In NatTable how to hide horizontal scrollbar with out disturbing vertical scrolling |
1 |
1953 |
Mon, 27 June 2016 12:20 By: Dirk Fauth |
Nattable with "horizontal tree" structure |
3 |
2425 |
Fri, 24 June 2016 08:38 By: Thorsten Schlathölter |
column with by percent and group column header |
8 |
2496 |
Fri, 17 June 2016 12:42 By: Martin Jacob |
Copy/paste from external source How to copy and paste into NatTable from an external source |
1 |
1853 |
Mon, 06 June 2016 18:43 By: Dirk Fauth |
Advanced filters with expressions |
9 |
5864 |
Mon, 06 June 2016 14:50 By: Dirk Fauth |
NatTable 1.4.0 released |
0 |
4162 |
Wed, 01 June 2016 20:56 By: Dirk Fauth |
How to split single cell into multiple rows |
2 |
1804 |
Tue, 24 May 2016 14:21 By: Alin Vulparu |
fresh installed, did nothing, immediately this Bug? |
1 |
1315 |
Tue, 24 May 2016 13:28 By: Dirk Fauth |
Save with F10 |
1 |
2092 |
Wed, 18 May 2016 10:28 By: Rashmi Tr |
Color of the text in the cell changes while scrolling the table Cell text color |
1 |
2714 |
Thu, 12 May 2016 11:35 By: Dirk Fauth |
240 dpi not supported? and possibly others dpi |
7 |
6405 |
Tue, 17 May 2016 14:50 By: Dirk Fauth |
IStructureSelection Facing issue to get group data inside IStructureSelection object. Not the group name, complete groupobject with set of row objects. |
5 |
5669 |
Tue, 17 May 2016 12:18 By: Dirk Fauth |
Multiple Rows deletion in NatTable Multiple Rows deletion in NatTable |
6 |
3582 |
Wed, 04 May 2016 11:52 By: Dirk Fauth |
NatTable 1.3.0 DPI calculation issues when resizing columns Rounding problems when up-/downscaling DPI-pixel values while resizing columns |
6 |
6684 |
Fri, 13 May 2016 08:38 By: Markus Barbey |
NatTable Tree Grid Filtering |
1 |
4633 |
Thu, 28 April 2016 07:41 By: Dirk Fauth |
How to change Time in DateCellEditor Cell |
4 |
6173 |
Mon, 09 May 2016 09:50 By: Rashmi Tr |
how to get the row position of an item? when grouping is enabled |
7 |
7467 |
Sun, 24 April 2016 07:37 By: Ludwig Moser |
How to make Case-Sensitive Filter |
4 |
5633 |
Wed, 13 April 2016 08:35 By: Dirk Fauth |
How to find filter applied columns Find filter applied column |
3 |
6720 |
Thu, 14 April 2016 07:19 By: Dirk Fauth |
