    Replies Views Last message
  [Acceleo] Bad behaviour with Java classes with Acceleo runner
By: Mad Vin on Thu, 22 February 2018
8 5398 Mon, 26 February 2018 10:37
By: Laurent Goubet
  [MTL] Reading Opaque Expressions
Reading the body of an OpaqueExpression
By: Siegfried Nolte on Wed, 10 November 2010
5 5957 Fri, 23 February 2018 13:45
By: Laurent Goubet
  [Acceleo] Filename based on result of EOperation
By: Bruce Trask on Wed, 07 February 2018
1 5143 Fri, 23 February 2018 13:42
By: Laurent Goubet
  Acceleo and Xtext metamodel
Getting errors when want to use metamodel created by Xtext
By: duke vah on Wed, 11 February 2015
10 9208 Tue, 20 February 2018 20:12
By: Ed Willink
  [Acceleo] How to access elements in for loop OR use a java service for that?
I can't find a way to avoid duplicates in my selections.
By: Francesco Cagnetta on Fri, 02 February 2018
2 3416 Tue, 20 February 2018 00:35
  Traceability
Acceleo
By: Eduard C. on Wed, 13 December 2017
2 5658 Tue, 30 January 2018 13:51
By: Eduard C.
  Access to keys in EMap member of model element
By: Bruce Trask on Fri, 26 January 2018
1 2434 Fri, 26 January 2018 16:35
By: Ed Willink
  Mulitple input models to Acceleo
By: Bruce Trask on Thu, 25 January 2018
0 5101 Thu, 25 January 2018 13:51
By: Bruce Trask
0 5363 Thu, 25 January 2018 13:51
By: Bruce Trask
0 4908 Thu, 25 January 2018 13:50
By: Bruce Trask
0 4879 Thu, 25 January 2018 13:50
By: Bruce Trask
  Running template just once for an Ecore model
By: Gonzalo Sintas on Thu, 18 January 2018
5 5205 Tue, 23 January 2018 09:05
By: Ed Willink
  [Acceleo] Problem with the deleted protected zones
By: Mad Vin on Tue, 01 August 2017
5 15112 Tue, 05 December 2017 21:17
By: Damián Rotta
  Acceleo : A solution for dependencies to another project with Java launcher
By: Mad Vin on Thu, 28 September 2017
7 5757 Thu, 02 November 2017 15:21
By: Laurent Goubet
  Generate Code from Ecore metamodel
How to use an Ecore metamodel in my MTL program?
By: Ana Patricia Mascarenhas on Thu, 19 October 2017
1 2803 Fri, 20 October 2017 06:01
By: Ed Willink
  Acceleo language
By: sarah sh on Wed, 09 August 2017
2 6959 Thu, 10 August 2017 12:35
By: Laurent Goubet
  [Acceleo] Avoid the new line character when a template is called
2 10456 Fri, 04 August 2017 13:56
By: Mad Vin
  [Acceleo] Multi-model to text transformation
By: Cristina Vicente-Chicote on Mon, 19 June 2017
5 15186 Sat, 22 July 2017 08:25
By: Ed Willink
  Setting an absolute path for the File block
By: Jad El-khoury on Wed, 12 July 2017
2 13247 Mon, 17 July 2017 07:54
By: Jad El-khoury
  Acceleo run error
I new an Acceleo project and it works wrong
By: wang shiyu on Wed, 12 July 2017
2 9835 Thu, 13 July 2017 10:26
By: Laurent Goubet
  [Acceleo] Strange behavior for queries using the "iterate" method
By: Mad Vin on Tue, 11 July 2017
8 7366 Tue, 11 July 2017 17:08
By: Mad Vin
  [Acceleo] Use Ecore metamodel in the Acceleo editor without installing a plugin
By: Mad Vin on Mon, 03 July 2017
6 10099 Tue, 04 July 2017 22:13
By: Mad Vin
  [Acceleo] Getting object's textual reference
Get textual reference
By: Cesar Bernabe on Mon, 03 July 2017
4 9199 Tue, 04 July 2017 08:40
By: Laurent Goubet
1 8485 Tue, 04 July 2017 08:26
By: Laurent Goubet
  Artifact fileName
How access an artifact's fileName value
By: Geoffry Roberts on Sat, 01 July 2017
4 13786 Tue, 04 July 2017 08:21
By: Laurent Goubet
  Nothing is being generated
My first attempt is not going well.
By: Geoffry Roberts on Tue, 27 June 2017
12 19973 Mon, 03 July 2017 07:09
By: Laurent Goubet
  Stereotypes
conditional generation based on stereotype
By: Geoffry Roberts on Thu, 29 June 2017
1 3878 Thu, 29 June 2017 19:21
By: Tomasz abczy?ski
  Acceleo : How to cast in a Collection ?
Impossible to cast an OclAny typed object in a Sequence
By: Mad Vin on Wed, 28 June 2017
6 11326 Thu, 29 June 2017 13:47
By: Laurent Goubet
  Vhdl code generation from UML model using acceleo
By: Raoudha Saida on Wed, 28 June 2017
1 5979 Wed, 28 June 2017 10:36
By: Ed Willink
  [Acceleo] handline of newlines in mtl templates
By: Jad El-khoury on Wed, 17 May 2017
7 17701 Tue, 20 June 2017 11:22
By: Jad El-khoury
0 9675 Mon, 19 June 2017 16:40
  [Acceleo] JMerge tags with standalone generator
By: Vincent Aranega on Mon, 22 October 2012
4 9820 Fri, 16 June 2017 13:57
By: Laurent Goubet
icon7.gif BPMN to DD-lotos using Acceleo
By: nihad rahabi on Fri, 05 May 2017
3 8140 Fri, 16 June 2017 13:41
By: Laurent Goubet
  Operator and
Operator and
By: sarah sh on Wed, 10 May 2017
2 6353 Fri, 16 June 2017 13:21
By: Laurent Goubet
  acceleo expression
acceleo expression
By: Elsa Enam on Wed, 10 May 2017
4 7612 Fri, 16 June 2017 13:18
By: Laurent Goubet
  Acceleo Documentation
Complete AQL documentation
By: Geoffry Roberts on Thu, 11 May 2017
4 10116 Fri, 16 June 2017 13:08
By: Laurent Goubet
  Cross table
Cross table cells
By: sarah sh on Thu, 11 May 2017
1 43089 Wed, 14 June 2017 15:21
By: Laurent Goubet
  Question for export a project
Sirius and Acceleo
By: nihad rahabi on Mon, 22 May 2017
2 11676 Wed, 14 June 2017 15:08
By: Laurent Goubet
  Invalid type for iteration Error
By: Nicholas Johnson on Fri, 19 May 2017
3 7695 Wed, 14 June 2017 14:53
By: Laurent Goubet
  Post trim not working
post (trim()) seems to do nothing
By: Philip Schröder on Fri, 09 June 2017
1 19222 Wed, 14 June 2017 14:39
By: Laurent Goubet
  language
language
By: Elsa Enam on Fri, 09 June 2017
1 14800 Mon, 12 June 2017 07:30
By: Laurent Goubet
icon4.gif Inquire about the topic( Acceleo and tree)
By: nihad rahabi on Mon, 08 May 2017
2 5722 Mon, 08 May 2017 07:52
By: Ed Willink
icon5.gif equivalent this code in Acceleo
4 7406 Sat, 06 May 2017 09:32
By: nihad rahabi
  how can we get DataType values in Acceleo
By: sana sana on Wed, 26 April 2017
9 14015 Thu, 04 May 2017 09:47
By: Ed Willink
  [Acceleo] How does trace block in Acceleo work
By: Anna Unikat on Thu, 21 March 2013
2 6137 Wed, 03 May 2017 09:47
By: Fy Za
icon12.gif Acceleo
Acceleo
By: Elsa Enam on Thu, 27 April 2017
3 3940 Thu, 27 April 2017 13:41
By: Ed Willink
  xpand
By: khalil on Tue, 17 May 2011
12 9062 Wed, 26 April 2017 15:16
By: gasri mohamed
icon11.gif Run different templates in Xpand project
I want to call different templates inside another template which is the root.
By: gerard TALLA on Sun, 23 April 2017
1 4296 Mon, 24 April 2017 12:54
By: Karsten Thoms
icon11.gif sirius table
sirius table
By: sarah sh on Mon, 24 April 2017
1 4739 Mon, 24 April 2017 10:17
By: Ed Willink
  IllegalArgumentException in navigateProperty
By: Nicholas Johnson on Sat, 22 April 2017
3 6631 Sat, 22 April 2017 16:54
By: Ed Willink
  add [
add [
By: sarah sh on Fri, 21 April 2017
2 4622 Fri, 21 April 2017 12:33
By: sarah sh
  [Acceleo] Type of UML attribute/property (Acceleo 4.3.0, Eclipse SR2)?
By: Joost Kraaijeveld on Thu, 06 March 2014
8 8049 Wed, 22 March 2017 22:56
By: Philip Schröder
  modelToSysml
requirements Diagram
By: khalid nasr on Mon, 20 March 2017
1 2202 Mon, 20 March 2017 14:33
By: khalid nasr
  [Acceleo] NullPointerException when running standalone
By: Benno Kallweit on Thu, 02 March 2017
3 15489 Mon, 20 March 2017 11:12
By: Benno Kallweit
  [acceleo] let =null
By: louis andia. on Thu, 16 March 2017
5 5646 Fri, 17 March 2017 07:18
By: Ed Willink
  Invalid Type (OCL Collection in Acceleo)
Several Types of OCL are not found in Acceleo
By: Philip Schröder on Sun, 05 March 2017
9 8879 Wed, 08 March 2017 13:51
By: Philip Schröder
  Xpand2 IncrementalGenerationFacade deprecated
Xpand Incremental M2T transformations
By: Jimi Ogunyomi on Sun, 05 March 2017
1 2835 Sun, 05 March 2017 15:35
By: Ed Willink
  [Acceleo standalone]
By: Julien Pourille on Fri, 03 March 2017
1 3183 Fri, 03 March 2017 12:59
By: Ed Willink
  [acceleo] mtl and emtl, what is the difference?
By: Leonardo Kenji Shikida on Tue, 02 August 2011
4 9877 Thu, 23 February 2017 00:37
By: Jakub Kitaj
  [Acceleo] Unable to see IFML metamodels - how to generate code from IFML?
By: Anton Hughes on Sun, 15 March 2015
2 5175 Tue, 21 February 2017 14:27
By: Ed Willink
  [Acceleo] How to avoid generating lines with only whitespace
Acceleo
By: Elie Richa on Fri, 17 February 2017
1 9239 Sat, 18 February 2017 07:46
By: Ed Willink
  [Acceleo] pb with java services
error when i want to call java services
By: Julien Pourille on Tue, 14 February 2017
1 18104 Thu, 16 February 2017 15:40
By: Ed Willink
  Incremental for loop
By: Julien Pourille on Mon, 06 February 2017
4 3881 Tue, 14 February 2017 14:50
By: Julien Pourille
  [Acceleo] Generation in one thread
How can I controll the number of parallel generation threads?
By: Shimon Zadok on Sat, 11 February 2017
0 27721 Sat, 11 February 2017 20:21
By: Shimon Zadok
  [Acceleo] Parse multiple models of 1 metamodel
By: Julien Pourille on Fri, 10 February 2017
2 3134 Fri, 10 February 2017 09:50
By: Julien Pourille
  [Acceleo] Duplicate query/operation detection, bug?
By: Jelle Schuhmacher on Thu, 19 January 2017
1 94170 Tue, 07 February 2017 14:20
icon6.gif Operation Setereotype -> get Value
How obtain the value of a attribute of a stereotype that is associated to a operation, but...
By: walter arboleda on Sun, 22 January 2017
4 9325 Tue, 24 January 2017 16:52
By: walter arboleda
  [XPAND] I can not set breakpoints
By: David Garcia on Tue, 11 October 2016
1 6539 Thu, 19 January 2017 08:41
By: David Garcia
  Path src-gen variable
By: David Garcia on Fri, 23 December 2016
0 7267 Fri, 23 December 2016 15:37
By: David Garcia
  Best Java generation tool from UML in Eclipse
By: Víctor López on Fri, 16 December 2016
9 4915 Mon, 19 December 2016 11:52
By: Víctor López
  Cross-reference not found
Acceleo standalone cannot find the cross-referenced element
By: dat NGUYEN on Thu, 01 December 2016
1 3210 Fri, 02 December 2016 07:29
By: Ed Willink
  M2T transformation (UML2XML)
By: Raoudha Saida on Mon, 10 October 2016
9 7195 Mon, 28 November 2016 00:27
By: Henri Boucher
  [Acceleo] Problem starting Acceleo from within Magicdraw Plugin
By: Benno Kallweit on Mon, 14 November 2016
2 41411 Fri, 18 November 2016 11:31
By: Benno Kallweit
  Acceleo (Run configuration)
By: Raoudha Saida on Tue, 25 October 2016
3 3408 Wed, 02 November 2016 15:08
By: Laurent Goubet
  Workflow interrupted because of configuration errors.
By: salha salha on Wed, 05 October 2016
0 4419 Wed, 05 October 2016 10:31
By: salha salha
  Workflow configuration error - classes not found
By: Yasser Khan on Sun, 23 September 2012
3 5789 Wed, 05 October 2016 10:23
By: salha salha
  [Acceleo] Supress generation popups?
By: Patrik Nandorf on Mon, 03 October 2016
1 3093 Wed, 05 October 2016 09:41
By: Laurent Goubet
  Acceleo UI plugin doesn't generate anything
Project works on runtime, but doesn't do anything when exported.
By: Zuriel Morales on Thu, 30 June 2016
16 11079 Wed, 05 October 2016 09:38
By: Laurent Goubet
  [Acceleo] Maven build for Acceleo 3.3
By: Pierre Gaufillet on Thu, 29 September 2016
2 3126 Fri, 30 September 2016 07:39
  Dynamic profile not detected on second maven execution
By: pere joseph rodríguez on Thu, 08 September 2016
2 2908 Fri, 09 September 2016 14:00
By: Laurent Goubet
  Unable to generate code
By: Beat Lussi on Tue, 14 July 2015
1 3302 Thu, 08 September 2016 15:40
  [Acceleo] Dynamic Template Plugin
I want to be able to generate with a Acceleo Template in the Workspace from a Eclipse Plugin I have made.
By: Samuel Windall on Mon, 20 July 2015
1 6234 Thu, 08 September 2016 15:36
  Best method for generating code from XSD
By: Axel Biernat on Mon, 10 August 2015
3 3693 Thu, 08 September 2016 15:20
  [Acceleo] Problems generating from a referenced metamodel
By: Nikita Duemmel on Sat, 15 August 2015
1 4694 Thu, 08 September 2016 15:17
  Count attributes in a model
By: Guoming DU on Mon, 18 January 2016
1 6764 Thu, 08 September 2016 15:12
  tag []
By: meriem mhmi on Mon, 16 May 2016
1 5757 Thu, 08 September 2016 15:10
  Are there any logging facilities?
By: Shimon Zadok on Tue, 09 August 2016
2 5694 Thu, 08 September 2016 15:05
  news.eclipse.org is shutting down.
By: Eclipse Webmaster on Wed, 31 August 2016
0 2190 Wed, 31 August 2016 18:44
  Xpand and GMF
By: Wendy Wendy on Sun, 24 July 2016
18 8007 Sun, 21 August 2016 16:44
By: Wendy Wendy
  Different behaviors in Eclipse and in Maven
By: Elie Richa on Wed, 10 August 2016
1 2836 Thu, 11 August 2016 09:55
By: Elie Richa
  How Does Acceleo Know to Regenerate EMTL files?
By: Shimon Zadok on Sun, 24 July 2016
4 3922 Fri, 29 July 2016 07:28
By: Laurent Goubet
  for loop Sequence type mismatch
By: Tom Galluzzo on Thu, 21 July 2016
7 5588 Mon, 25 July 2016 08:55
By: Ed Willink
  Operation and parameters code generation queries
By: Higo Felipe on Wed, 20 July 2016
3 2639 Fri, 22 July 2016 12:49
By: Laurent Goubet
  query with multiple parameters
[Acceleo] invoking java method with multiple parameters
By: Viktoria Fink on Wed, 13 July 2016
1 1824 Wed, 13 July 2016 14:40
By: Ed Willink
  Template parameter altered by passing the result of a query
By: Elie Richa on Tue, 05 July 2016
4 3897 Thu, 07 July 2016 08:53
By: Elie Richa
  UML metamodel not found in createing Acceleo project
By: Banafsheh Azizi on Wed, 06 July 2016
1 2224 Thu, 07 July 2016 08:20
By: Laurent Goubet
  Two input models in Acceleo
generating code from two input models...
By: Naif Mokhayesh on Tue, 08 July 2014
18 10566 Wed, 06 July 2016 13:25
By: Laurent Goubet
  [Acceleo 3] Multiple metamodels
By: Supernova S. on Mon, 31 January 2011
6 13575 Tue, 05 July 2016 13:01
By: Laurent Goubet
  [Acceleo] PackageNotFoundException
I'm trying to generate code from an instance of a metamodel
By: Higo Felipe on Wed, 29 June 2016
2 3543 Sat, 02 July 2016 21:23
By: Higo Felipe
  [Acceleo] Custom Acceleo metamodel
By: Jakub Kitaj on Mon, 06 June 2016
9 12744 Mon, 27 June 2016 08:21
By: Laurent Goubet
  Using multiple input files (though one model) to generate
Generating from model that uses profile files and other imported model
By: Shimon Zadok on Fri, 03 June 2016
10 8963 Wed, 22 June 2016 08:31
By: Laurent Goubet
  Define variable in a template
By: Habtamu Tolera on Thu, 16 June 2016
1 4311 Tue, 21 June 2016 09:10
By: Laurent Goubet
  Re: Acceleo loop problem
By: Laurent Goubet on Mon, 13 June 2016
0 4657 Mon, 13 June 2016 12:22
By: Laurent Goubet
  [solved] Acceleo loop problem
elements recursion because of inheritance
By: Viktoria Fink on Tue, 31 May 2016
8 8226 Mon, 13 June 2016 12:22
By: Laurent Goubet
By: Viktoria Fink on Mon, 13 June 2016
0 4593 Mon, 13 June 2016 10:32
By: Viktoria Fink
0 4701 Mon, 13 June 2016 10:12
By: Laurent Goubet
  i an unbable to set value for type attribute in class diagram using papyrus plugin
i try to set datatype for class atributes in my class diagram but it is not showing any attributes how ican set
By: hardeep kaur on Mon, 06 June 2016
7 7201 Wed, 08 June 2016 10:42
By: hardeep kaur
  JET tag library documentation?
By: James Clark on Tue, 07 June 2016
1 2627 Tue, 07 June 2016 14:30
By: Ed Willink
  Acceleo : How do I compare the value of the current and the previous iteration in a for loop
Acceleo
By: Hassen Bazar on Thu, 02 June 2016
1 2553 Thu, 02 June 2016 16:11
By: Ed Willink
  Is there a better [let] construct for multiple variable context
By: Shimon Zadok on Fri, 27 May 2016
1 4130 Tue, 31 May 2016 13:58
By: Laurent Goubet
  [solved] Where to find [macro] usage (and an example)?
By: Shimon Zadok on Sat, 28 May 2016
1 4322 Tue, 31 May 2016 12:47
By: Laurent Goubet
  [Solved] Navigating to the Class type with a Realization dependency
By: Shimon Zadok on Sat, 21 May 2016
9 5090 Fri, 27 May 2016 13:46
By: Shimon Zadok
  tag []
display the tag []
2 4448 Fri, 20 May 2016 08:17
By: meriem mhmi
  Loop in Acceleo
break a loop
By: walter arboleda on Thu, 05 May 2016
2 5626 Wed, 18 May 2016 11:36
By: Laurent Goubet
  Acceleo does not regenerate
By: Mr Cur on Sat, 30 April 2016
4 4099 Wed, 18 May 2016 11:31
By: Laurent Goubet
  Cannot Access Stereotypes
By: Daniel Clarke on Fri, 22 April 2016
10 9889 Thu, 28 April 2016 12:33
By: Ed Willink
  acceleo launching
By: nes ab on Sun, 17 April 2016
2 4269 Mon, 18 April 2016 08:55
By: Laurent Goubet
  luna launching acceleo
acceleo couldnt load class main
By: nes ab on Tue, 05 April 2016
2 5967 Mon, 18 April 2016 08:22
By: nes ab
  Code synchronization with UML model
By: Nelson Pestana on Thu, 07 April 2016
2 3664 Fri, 15 April 2016 16:34
By: Nelson Pestana
  Pair up data
By: Nattapon Thathong on Tue, 12 April 2016
1 4184 Wed, 13 April 2016 08:18
By: Laurent Goubet
  [error launching acceleo]
Due to changes in the Eclipse platform in Luna, the Acceleo Plug-in Application strategy may not work.
By: nes ab on Sun, 03 April 2016
1 4452 Mon, 04 April 2016 06:21
By: Ed Willink
  acceleo
[mars] Launching acceleo problem
By: nes ab on Fri, 01 April 2016
0 5426 Fri, 01 April 2016 10:14
By: nes ab
  I have the editor and the template. Now what?
By: Zuriel Morales on Sun, 13 March 2016
1 6112 Mon, 28 March 2016 10:10
By: Annamalai Mising name
  Use of workspace-external template for EGL run Config
Usage of template file (EGL) not in workspace
By: HanK CP on Tue, 16 February 2016
1 6956 Wed, 24 February 2016 20:47
By: Dimitris Kolovos
  Cannot Access SysML Sterotypes and their properties
I am unable to retrieve SysML sterotypes such as FlowPort and its direction property
By: Yasir Hussain on Fri, 29 January 2016
1 3006 Sat, 30 January 2016 09:49
By: Ed Willink
  metamodel that reference other metamodels
By: dorraaaa Z on Mon, 04 January 2016
0 5530 Mon, 04 January 2016 10:04
By: dorraaaa Z
  How the use 2 input Models in Acceleo
0 5874 Mon, 04 January 2016 09:17
By: dorraaaa Z
  [Acceleo] template/generation error listening
other than watching STDOUT
By: Joel Gluth on Thu, 20 September 2012
8 8104 Mon, 30 November 2015 22:13
By: Ed Willink
icon5.gif [Acceleo] How to register other metamodels?
By: Anderson Ledo on Sun, 17 January 2010
8 7698 Sat, 21 November 2015 19:27
By: Guillermo Serratto
  Uml to Java issue
By: Eclipse User on Fri, 06 November 2015
1 5468 Thu, 19 November 2015 13:18
By: Akira Tanaka
  [ACCELEO] Add model preprocessing before text generation
By: Pierre Gaufillet on Mon, 12 October 2015
5 5022 Tue, 10 November 2015 13:00
By: Ed Willink
  What happend to
UML2MetaModel and ProfileMetaModel
By: Missing name Mising name on Fri, 16 October 2015
1 7269 Wed, 28 October 2015 14:33
  [Acceleo] Generate package with same order as the UML editor
By: Johan Hardy on Tue, 06 October 2015
1 1969 Tue, 06 October 2015 15:04
By: Johan Hardy
  [ACCELEO] call Query interpreter programmatically
By: Vincent De Bry on Thu, 01 October 2015
2 2791 Mon, 05 October 2015 15:44
By: Vincent De Bry
  [ACCELEO] Maven generate Standalone not able to access applied profile
By: Horst Leitenmueller on Wed, 23 September 2015
1 3947 Mon, 28 September 2015 07:44
  [Solved][XPand+MWE] Execute MWE(v1.2.1) programmatically
By: Zheng Cheng on Mon, 07 September 2015
4 3866 Fri, 25 September 2015 15:39
By: Zheng Cheng
  Xtend files compile in plugin environment
By: Babu M on Tue, 22 September 2015
1 2666 Thu, 24 September 2015 09:52
By: Babu M
  [Acceleo] Cannot access EClass objects declared in a referenced .ecore file
from a Java Service
By: Francois Cabrol on Thu, 11 June 2015
2 3621 Wed, 02 September 2015 15:14
By: Francois Cabrol
  [Acceleo] Logging / Debugging
By: Harri T. on Tue, 01 September 2015
1 1709 Tue, 01 September 2015 14:45
By: Harri T.
  [JET] Error "resources.jar is read-only" at JETEditor
By: Jose Ventura Roda on Fri, 21 August 2015
0 9421 Fri, 21 August 2015 12:05
  html Export
Export diagrams and links into html file
By: David Niehaus on Wed, 19 August 2015
0 8837 Wed, 19 August 2015 10:12
By: David Niehaus
  generate code out of metamodel(.ecore file ) using xpandfacade
By: Adnan AL-SOSWA on Mon, 23 December 2013
3 4100 Mon, 17 August 2015 16:45
By: ngoc tho huynh
  [Xtext] updating/writing resource descriptions chunk x of xxx
By: Ali AKAR on Thu, 26 February 2015
2 4616 Thu, 13 August 2015 06:34
By: Christian Dietrich
  [MWE2] check error handling and editor problems
Don't see error message from check input file; editor shows spurious errors
By: Peter Keller on Fri, 31 July 2015
1 3284 Tue, 11 August 2015 14:19
By: Peter Keller
  how to delete a file using a template
By: Stever Simpson on Mon, 10 August 2015
0 3654 Mon, 10 August 2015 22:29
By: Stever Simpson
  [XPAND2] Learning basic
need helps on a simple question
By: Valentin Edai on Fri, 31 July 2015
1 2779 Mon, 03 August 2015 08:38
By: Karsten Thoms
  [Acceleo] Undefined "Let" expression
Acceleo Evaluation Exception: Undefined "Let" expression at line .. in Module ... for block ...
By: Samuel Windall on Wed, 22 July 2015
1 2670 Wed, 22 July 2015 01:47
By: Samuel Windall
  [Acceleo] Random Plugin Errors
Acceleo is throwing random erros about "The feature 'iff' is not a valid feature"
By: Samuel Windall on Tue, 21 July 2015
2 2502 Tue, 21 July 2015 21:33
By: Samuel Windall
  [Acceleo] Run my generator code from CLI
How can i run my generator code from command line interface ,inside shell script
By: bilel feddaoui on Fri, 10 July 2015
1 3299 Tue, 21 July 2015 09:41
By: Wilbert Alberts
  [Acceleo] Running stand alone
Some quirks
By: Wilbert Alberts on Tue, 21 July 2015
0 5591 Tue, 21 July 2015 09:39
By: Wilbert Alberts
icon1.gif Dynamic Acceleo Project Plugin
I want to run an Acceleo Project from an Installed Plugin dynamically, where users can modify the templates without needing to deploy anything.
0 5043 Mon, 20 July 2015 06:04
By: Samuel Windall
  Android Code Generation
By: Mohammed Fouad on Tue, 30 June 2015
1 2723 Tue, 14 July 2015 23:09
By: André Ribeiro
  [Acceleo] PDE and EMTL
EMTL files are not generated during pde build
By: Brice Pajot on Tue, 28 June 2011
3 4419 Mon, 13 July 2015 09:18
By: Fabian Meyer
  [Acceleo] Out of memory
By: Wilbert Alberts on Thu, 02 July 2015
5 2908 Thu, 02 July 2015 11:55
By: Wilbert Alberts
  MoDisco Model to Java Source Code
By: Keith Ó Dúlaigh on Fri, 26 June 2015
0 1940 Fri, 26 June 2015 10:46
By: Keith Ó Dúlaigh
  Launching Acceleo as plug-in
By: Eclipse User on Tue, 03 March 2015
3 3710 Thu, 25 June 2015 08:11
By: Eclipse User
  [Accelleo] Access EEnumLiteral's EAnnotation
By: Le Chau Nguyen on Wed, 24 June 2015
2 2589 Thu, 25 June 2015 01:38
By: Le Chau Nguyen
  Trouble in loading model from Action Handler
By: Babu M on Wed, 24 June 2015
2 2409 Wed, 24 June 2015 06:58
  [XTEND] can i call a xtend template from java
By: lucky star on Wed, 17 June 2015
3 2337 Tue, 23 June 2015 20:00
  Querys in templates without empty line?
Include querys in templates without printing an empty line in the output?
By: Martin Gruber on Tue, 23 June 2015
1 1612 Tue, 23 June 2015 05:39
By: Ed Willink
  Method to save and edit values in ACCELEO templates
I wan't to generate some embedded code with ACCELEO templates. I need a way to save and edit values
By: Martin Gruber on Sun, 21 June 2015
3 2653 Mon, 22 June 2015 10:26
By: Martin Gruber
  ACCELEO EDITOR is not working correctly
Error correction etc. is not working correctly
By: Martin Gruber on Mon, 25 May 2015
4 4287 Sat, 20 June 2015 14:36
By: Martin Gruber
icon9.gif [Acceleo - Papyrus] Package with uri '--- ActionLanguage-Profile' not found.
By: Etienne SF on Wed, 03 December 2014
2 4680 Thu, 18 June 2015 13:49
By: Stephane Begaudeau
  [Acceleo] Where to get it from?
By: Anton Hughes on Thu, 12 March 2015
1 3725 Mon, 15 June 2015 09:07
  [UML Generators] Where to get user guide?
1 3511 Mon, 15 June 2015 08:58
  [acceleo] and [cdo] How does I open my model
Is it possible to use a model stored in a cdo repository. If the response is yes, how I do it?
By: Martin Paquin on Mon, 27 April 2015
1 4043 Mon, 15 June 2015 08:55
  Generation process M2T
By: Rafael Dantas on Sat, 16 May 2015
1 3931 Mon, 15 June 2015 08:52
  ACCELEO Extensibility
By: DJAMEL KHEBAB on Mon, 18 May 2015
2 2220 Mon, 15 June 2015 08:49
  problem when launching acceleo application
By: arbia karoui on Thu, 28 May 2015
2 2224 Mon, 15 June 2015 08:24
  Acceleo - search for class
By: Dennis Mueller on Fri, 29 May 2015
1 3225 Mon, 15 June 2015 08:20
  Could not initialize class org.artop.aal.autosar40.validation.listeners.ProblemMarkerIntegrity40List
By: Babu M on Thu, 04 June 2015
0 3007 Thu, 04 June 2015 10:52
By: Babu M
  Xtend2 type-system wrappers
By: Babu M on Mon, 25 May 2015
1 2007 Mon, 25 May 2015 14:08
  [acceleo] Unable to generate code
AcceleoEvaluationException: The type of the first parameter of the main template named 'generateElement' is a proxy.
By: Martin Paquin on Thu, 07 May 2015
4 2885 Thu, 21 May 2015 20:28
By: Martin Paquin
  [acceleo] add Acceleo plugin in a RAP application workbench
By: Enrique LG on Mon, 18 May 2015
0 3490 Mon, 18 May 2015 08:00
By: Enrique LG
  UML2C where to start
By: Jonathan Marino on Wed, 13 May 2015
3 2125 Wed, 13 May 2015 17:35
  xpand to xtend2 type system migration
By: Babu M on Tue, 12 May 2015
11 4249 Wed, 13 May 2015 13:21
  [Acceleo] Difficulties with variables
By: Simone Franzini on Tue, 19 October 2010
8 9143 Mon, 11 May 2015 20:34
By: Ed Willink
  [XPAND]Unkown type while accessing multiple models
By: lucky star on Tue, 28 April 2015
20 8195 Thu, 07 May 2015 13:28
  OCL Constraint to java code
OCL Constraint
By: ilan rosenfeld on Tue, 05 May 2015
1 1636 Tue, 05 May 2015 14:24
By: Ed Willink
  Problems with flow port stereotype with Luna and Acceleo
How to know if a port has the flow port stereotype and which direction it has
By: Thomas Bardot on Wed, 18 March 2015
3 6779 Tue, 28 April 2015 09:01
  [XPAND] java.net.MalformedURLException: unknown protocol: ar
[XPAND]java.net.MalformedURLException: unknown protocol: ar
By: lucky star on Wed, 15 April 2015
65 26938 Tue, 28 April 2015 04:48
  [Xtend] provide interface for generation
By: Bastian Mohrmann on Wed, 22 April 2015
2 2080 Mon, 27 April 2015 15:23
  XTend + artop combined sdk
Information required on xtend + artop combi
By: Babu M on Mon, 27 April 2015
3 3213 Mon, 27 April 2015 08:57
By: Babu M
  [Acceleo] Generating code from multiple metamodels
By: Tobias R on Tue, 23 March 2010
14 8066 Mon, 27 April 2015 07:45
  Where to find resources on JET...
By: Stever Simpson on Sun, 19 April 2015
1 1351 Mon, 20 April 2015 14:42
By: Ed Willink
  [Acceleo] Easiest way to deploy a generator
By: Wilbert Alberts on Tue, 14 April 2015
3 2459 Tue, 14 April 2015 11:29
By: Ed Willink
  [Acceleo] How to log or monitor inoperable plug-in?
By: Luís de Sousa on Thu, 19 February 2015
4 2574 Sun, 29 March 2015 14:30
By: Luís de Sousa
  [Acceleo] Error creating plugin: failed to create task or type apitooling.apigeneration
By: Luís de Sousa on Sun, 16 February 2014
1 30543 Sat, 28 March 2015 12:13
By: Luís de Sousa
icon5.gif [Acceleo] Netlist Generation (nested loops+ variables?)
By: Frank W. on Wed, 25 March 2015
1 1728 Wed, 25 March 2015 16:58
By: Frank W.
icon7.gif [ACCELEO] Generate Declarations
Tweak and change to Code
By: Frank W. on Tue, 17 March 2015
2 2144 Thu, 19 March 2015 16:16
By: Frank W.
  Acceleo Debugger doesn't work
By: Wolfgang Grossinger on Wed, 18 March 2015
0 2540 Wed, 18 March 2015 09:46
icon7.gif Declaration Generation
Tweak some Code
0 2676 Tue, 17 March 2015 13:57
By: Frank W.
  [Acceleo] StandAlone generation
By: Thibaut on Fri, 17 June 2011
16 18999 Fri, 13 March 2015 18:39
By: Khdev Khdev
  Flatten Sequence(String) to String
By: Robbie Simpson on Tue, 10 March 2015
2 1890 Wed, 11 March 2015 14:04
By: Robbie Simpson
  using a hashmap in Acceleo
By: Rafael Merino Garcia on Tue, 10 March 2015
1 1644 Tue, 10 March 2015 15:12
By: Ed Willink
  SysML activity diagram output pins.
By: Stephen Blackwell on Fri, 27 February 2015
1 1886 Fri, 27 February 2015 19:51
  Acceleo Builder error encountered during build: java.util.ConcurrentModificationException
By: Jose Angelo Suarez on Wed, 21 January 2015
2 2204 Fri, 20 February 2015 19:27
By: Eduardo Jr. Sapugay
  [Acceleo] Removing duplicate in collection
How to remove duplicate descriptions of collections
By: Wagner de Andrade Perin on Tue, 24 July 2012
3 4681 Fri, 20 February 2015 04:27
By: Gangyada Krishna
  How to Remove Duplicates Using Advance Filter?
By: Gangyada Krishna on Fri, 20 February 2015
0 2780 Fri, 20 February 2015 04:26
  Acceleo online: edit templates in the browser
Your feedback about the Acceleo online editor made by GenMyModel
By: tom legrand on Mon, 16 February 2015
2 2518 Thu, 19 February 2015 11:22
By: tom legrand
Legend New Messages New Messages   No New messages No New messages   Locked (w/ unread messages) Locked (w/ unread messages)   Locked Locked   Moved to another forum Moved to another forum
Current Time: Sun Apr 28 20:42:42 GMT 2024
Powered by FUDForum. Page generated in 0.04172 seconds
