icon4.gif sticky: This forum is archived
By: Eclipse User on Sat, 19 May 2012
0 19977 Sat, 19 May 2012 22:17
  Connecting RP to OM2M
By: Eclipse User on Tue, 29 September 2020
0 5736 Tue, 29 September 2020 10:48
  [QVTO] Large script - editor slow
By: Eclipse User on Thu, 03 May 2012
4 16307 Fri, 04 May 2012 09:35
  Model contains "definitions", Ecore specifies "Definition"
1 6591 Fri, 04 May 2012 06:01
  ATLLauncher and ATL Virtual Machine
Problem launching ATL transformations from Java but not from Eclipse
2 7557 Fri, 04 May 2012 05:18
  Can a QVT script transforms a Papyrus's model ?
2 7056 Thu, 03 May 2012 17:00
  M2M is moving to MMT
By: Eclipse User on Tue, 24 April 2012
1 7245 Thu, 03 May 2012 16:53
  [ATL] Using XSD as Metamodel
5 8486 Thu, 03 May 2012 12:32
  [QVTo] Access qName local part
0 14050 Thu, 03 May 2012 11:52
  ATL - Creating a PackagedElement within my XMI file
0 14577 Thu, 03 May 2012 10:00
  [ATL] No type named 'Root' in metamodel
0 15600 Thu, 03 May 2012 05:57
  [ATL] How to find the package owning a class ?
By: Eclipse User on Wed, 02 May 2012
0 14228 Wed, 02 May 2012 15:12
  [QVTO] Custom data types
1 6239 Wed, 02 May 2012 08:16
  Measure execution time
0 14315 Wed, 02 May 2012 05:57
  [ATL] Transforming one hierarchy type to another hierarchy type
By: Eclipse User on Fri, 09 December 2011
1 8234 Wed, 02 May 2012 05:51
  ATL interacting with Papyrus
By: Eclipse User on Mon, 30 April 2012
0 14624 Mon, 30 April 2012 20:03
  Official excuses
By: Eclipse User on Sun, 29 April 2012
5 8581 Mon, 30 April 2012 18:40
  Move functionality from QVTo to a library.
QVTO library question.
0 13992 Mon, 30 April 2012 17:05
  Regla que cree y retorne coleccion de objetos
0 14341 Mon, 30 April 2012 14:21
  [ATL] Feature ... is not changeable
By: Eclipse User on Thu, 02 February 2012
8 16484 Mon, 30 April 2012 10:28
  [ATL] WSDL: Access name attribute
1 5612 Mon, 30 April 2012 10:02
  [ATL] wsdl -> uml transformation
By: Eclipse User on Thu, 28 February 2008
2 11800 Sun, 29 April 2012 11:03
  Collections inside collections
By: Eclipse User on Sat, 28 April 2012
0 14035 Sat, 28 April 2012 13:14
  ATL basic configuration problem. Please help !
By: Eclipse User on Fri, 27 April 2012
0 14306 Fri, 27 April 2012 20:09
  [QVTO] Cloning intermediate class objects
1 7520 Fri, 27 April 2012 08:35
  [QVTO] Resolve on disjunctive mapping
3 8993 Thu, 26 April 2012 08:50
  [qvto]how to run qvto stand-along
By: Eclipse User on Mon, 16 April 2012
10 16395 Wed, 25 April 2012 19:56
  [QVTo] UnitResolverFactory weiredness
By: Eclipse User on Wed, 25 April 2012
3 7795 Wed, 25 April 2012 10:05
  [QVTO] advice needed for large models
7 11227 Wed, 25 April 2012 04:16
  [ATL] Copy sequences in Refining Mode
0 14509 Tue, 24 April 2012 07:51
  ATL from XMI files
loading xmi files in ATL
By: Eclipse User on Mon, 23 April 2012
0 13900 Mon, 23 April 2012 18:51
  question about "ATL/Tutorials - Create a simple ATL transformation"
By: Eclipse User on Fri, 20 April 2012
0 16287 Fri, 20 April 2012 04:49
  [Solved][ATL] Inconsistencies between normal and programmatic execution mode
By: Eclipse User on Thu, 19 April 2012
1 6723 Thu, 19 April 2012 05:45
  [ATL] and GMF
By: Eclipse User on Wed, 18 April 2012
1 7229 Thu, 19 April 2012 03:50
  QVTO Transformation in a Eclipse Plugin
By: Eclipse User on Tue, 17 April 2012
2 7491 Wed, 18 April 2012 11:52
  [Solved][ATL] Memory error
Java heap space error while trying to lauch an ATL transformation
By: Eclipse User on Thu, 05 April 2012
5 14485 Wed, 18 April 2012 03:47
  [ATL] programmatically launch of ATL transformation
By: Eclipse User on Mon, 14 November 2011
1 8011 Mon, 16 April 2012 05:13
  [qvto]can I use an ocl operation as a model attribute
By: Eclipse User on Mon, 26 March 2012
3 7381 Mon, 16 April 2012 04:33
  Transformation failure
By: Eclipse User on Fri, 13 April 2012
0 14618 Fri, 13 April 2012 06:38
  [ATL] what about two nested "distinct..foreach" ?
By: Eclipse User on Thu, 12 April 2012
0 16141 Thu, 12 April 2012 07:36
  [ATL] Transformation failure with model references serialized with absolute paths
ATL transformation fails with model references serialized with absolute paths
By: Eclipse User on Fri, 30 March 2012
3 8280 Mon, 09 April 2012 08:13
  [QVT] not keyword recognized as a keyword
By: Eclipse User on Sun, 08 April 2012
1 5861 Mon, 09 April 2012 01:43
  Nmodels2Nmodels transformation [qvto]
in-place transformation with two input models
By: Eclipse User on Sun, 01 April 2012
12 14386 Sat, 07 April 2012 09:58
  [QVTO] Run transformation via extension point "org.eclipse.m2m.qvt.oml.runtime.qvtTransformatio
By: Eclipse User on Wed, 04 April 2012
3 7718 Sat, 07 April 2012 07:27
  [QVTO] Use metamodel mappings with nested packages
1 7627 Wed, 04 April 2012 16:41
  [QVTO] Invoke a transformation using its XMI file
Invoke in Java a QVTo transformation from its XMI file, not from the source
By: Eclipse User on Tue, 03 April 2012
1 5057 Tue, 03 April 2012 09:20
  [ATL] Problem to run ATL in JAVA
1 5987 Mon, 02 April 2012 16:27
  [ATL] Generating an EChar during transformation
3 5698 Sun, 01 April 2012 12:36
  Invoke QVT In JAVA
By: Eclipse User on Fri, 16 September 2011
17 20305 Fri, 30 March 2012 18:35
icon7.gif [Solved][ATL] problem running ATL programmatically
By: Eclipse User on Thu, 29 March 2012
3 6212 Thu, 29 March 2012 07:57
icon8.gif [Solved][ATL] string concat operation OclUndefined ???
By: Eclipse User on Tue, 27 March 2012
0 15470 Tue, 27 March 2012 10:33
  [ATL] Transform several elements into one element
0 13876 Tue, 27 March 2012 07:05
  [ATL] The generate atl plugin works differently from atl configuration
By: Eclipse User on Thu, 22 March 2012
2 5372 Mon, 26 March 2012 05:51
  [ATL] Transformation to OWL2 functional-style syntax: is owl2.ecore proper for this task?
Usage of owl2.ecore [2] for ATL transformations
By: Eclipse User on Sun, 18 March 2012
2 7244 Sun, 25 March 2012 16:39
  Henshin how to create multiple NAC
By: Eclipse User on Sat, 24 March 2012
0 13905 Sat, 24 March 2012 10:39
  [QVT] IN Model URI does not accept non XMI input
QVT runtime configuration:IN Model URI does not accept non XMI input
1 4852 Fri, 23 March 2012 08:04
  Nullpointer XMLHandler#createObjectFromFeatureType - Reference internal a second metamodel
By: Eclipse User on Wed, 21 March 2012
1 4897 Thu, 22 March 2012 02:23
  [ATL] Is it possible to two classes (input) into one class (output) in a rule
By: Eclipse User on Thu, 03 June 2010
1 8832 Mon, 19 March 2012 10:37
  Dependencies between Metamodels
By: Eclipse User on Fri, 16 March 2012
0 13782 Fri, 16 March 2012 06:54
  QVTO Execution in Plugin
By: Eclipse User on Wed, 14 March 2012
2 5040 Wed, 14 March 2012 09:30
  [ATL] AtlLuncher class
How to use AtlLuncher class
By: Eclipse User on Mon, 12 March 2012
3 5059 Tue, 13 March 2012 07:02
  Simulink M2M transformation - what is a good approach?
By: Eclipse User on Tue, 14 February 2012
2 7684 Mon, 12 March 2012 12:53
  Metamodel in workspace in QVTO Problem
By: Eclipse User on Sun, 15 January 2012
10 9087 Sun, 11 March 2012 01:10
  [QVTo] Standalone execution
By: Eclipse User on Mon, 27 February 2012
3 8025 Fri, 09 March 2012 15:05
  Papyrus MDT DI2ToDI
By: Eclipse User on Fri, 06 May 2011
1 5905 Wed, 07 March 2012 15:17
  WSDL to UML Transformation
By: Eclipse User on Fri, 02 March 2012
1 5111 Fri, 02 March 2012 11:50
  [ATL]syntax source model
By: Eclipse User on Mon, 26 April 2010
1 8022 Thu, 01 March 2012 02:48
icon5.gif [ATL] [Solved] Calling a rule a fixed number of times
9 7921 Tue, 28 February 2012 08:39
  [qvto]failed to create object
By: Eclipse User on Tue, 28 February 2012
1 4950 Tue, 28 February 2012 02:31
  [qvto]How to add a node in one doc to another doc
0 14057 Mon, 27 February 2012 22:08
  To be deleted
0 13442 Mon, 27 February 2012 12:44
  [ATL] Ant Task classpath problem
Plugin org.eclipse.m2m.atl.core.ant doesn't have Bundle-ClassPath set
By: Eclipse User on Sat, 25 February 2012
0 14059 Sat, 25 February 2012 21:10
  [ATL] How to know type of a model element in condition of matched rule
I need know a eCore type of an attribute of a model element
By: Eclipse User on Thu, 23 February 2012
1 4479 Thu, 23 February 2012 12:43
icon5.gif [qvto]how to transform undefined attributes
By: Eclipse User on Thu, 16 February 2012
5 6497 Thu, 23 February 2012 00:54
  [ATL] Compiling ATL files to ASM in build system
Using Tycho headless builds
By: Eclipse User on Tue, 21 February 2012
0 14277 Tue, 21 February 2012 09:16
  [ATL] Transform to unknown target element
By: Eclipse User on Mon, 13 February 2012
6 8355 Sat, 18 February 2012 02:02
  [ATL]Guard condition at target element in matched rule
By: Eclipse User on Fri, 17 February 2012
2 5345 Fri, 17 February 2012 16:59
icon9.gif ATL too slow when transforming
By: Eclipse User on Wed, 15 February 2012
3 5521 Fri, 17 February 2012 15:04
  [ATL] Global map for caching elements
0 14491 Thu, 16 February 2012 04:39
  [QVTo] Disambiguation of black-box operations
By: Eclipse User on Fri, 03 February 2012
4 8279 Tue, 14 February 2012 12:59
  [ATL] Cannot assign the same elements/reference multiple times [on progress]
By: Eclipse User on Sun, 12 February 2012
1 4343 Tue, 14 February 2012 09:58
  KM3
Validation of KM3 models
1 4075 Tue, 14 February 2012 00:42
  3rd Biannual Eclipse/OMG Workshop on March 25
By: Eclipse User on Tue, 10 January 2012
1 4591 Mon, 13 February 2012 01:46
  Bidirectional transformation
By: Eclipse User on Thu, 09 February 2012
8 7476 Sat, 11 February 2012 05:20
  [QVTo] when condition in abstract mapping
3 6227 Fri, 10 February 2012 06:42
  [QVTrelational] How to use Keys to preserve graph structure
ATL resolveTemp() ====> QVTr ............. ????
By: Eclipse User on Wed, 08 February 2012
1 4317 Wed, 08 February 2012 14:52
  [ATL] inter-model reference
By: Eclipse User on Fri, 21 October 2011
4 7114 Wed, 08 February 2012 11:35
  What is the best way to merge two metamodels?
By: Eclipse User on Tue, 07 February 2012
0 14222 Tue, 07 February 2012 11:52
  [ATL] Roadmap
By: Eclipse User on Fri, 23 September 2011
1 6615 Tue, 07 February 2012 09:40
  [QVTo] composing transformations
2 5111 Mon, 06 February 2012 03:08
  [ATL] trace model problem with source element
1 4076 Fri, 03 February 2012 04:29
  [ATL] Logging to file
0 13976 Thu, 02 February 2012 14:17
  [QVTo] Support for advanced mathematical operations on numerical data types, e.g. exp() and log()
By: Eclipse User on Wed, 01 February 2012
4 6730 Wed, 01 February 2012 13:45
  [ATL] Refining Mode: refine more than one element
0 14720 Wed, 01 February 2012 05:11
  [QVTo] Project status and plan
By: Eclipse User on Thu, 26 January 2012
1 4206 Thu, 26 January 2012 13:08
  Bidirectional M2M Transformations using Eclipse EMF
By: Eclipse User on Wed, 25 January 2012
1 4340 Wed, 25 January 2012 12:54
  [ATL] __xmiID__ values on output elements change after executing the transformation
Problem saving ids of output elements in other output model
By: Eclipse User on Mon, 23 January 2012
1 4677 Tue, 24 January 2012 04:52
  Invalid results while using minus operator in ATL
By: Eclipse User on Thu, 19 January 2012
0 14358 Thu, 19 January 2012 15:06
  MicrosoftExcelInjector example error
0 14309 Thu, 19 January 2012 13:50
  [ATL] ATL plugin : path problem (Resolved)
Problem to configure the path of ecore file
By: Eclipse User on Wed, 22 June 2011
3 6970 Wed, 18 January 2012 08:13
  [ATL] Transformation execution time
My transformation seems to run endlessly
By: Eclipse User on Tue, 17 January 2012
1 4189 Tue, 17 January 2012 09:19
  Qvto Trace file through Java
By: Eclipse User on Wed, 11 January 2012
1 4283 Tue, 17 January 2012 04:18
  [ATL] Error loading file: ... The feature 'DFSResource' is not a valid feature
By: Eclipse User on Fri, 26 August 2011
2 5606 Mon, 16 January 2012 06:41
  Inject multiple XML records
By: Eclipse User on Mon, 09 January 2012
4 6698 Thu, 12 January 2012 00:21
icon5.gif Migration of new profile definition does not work
1 5041 Tue, 10 January 2012 06:03
  Namespace Problems
0 15063 Tue, 10 January 2012 05:24
  Plugin For Qvto Transformation
By: Eclipse User on Tue, 03 January 2012
1 4130 Tue, 10 January 2012 05:07
  Output based on current and previous input values
By: Eclipse User on Sun, 08 January 2012
1 3973 Sun, 08 January 2012 11:43
  [QVTo] Unit not found while executing qvto in own application
By: Eclipse User on Wed, 21 December 2011
4 8845 Thu, 05 January 2012 07:23
  incomplete output because containment reference
By: Eclipse User on Wed, 30 November 2011
3 5491 Thu, 05 January 2012 05:24
  [ATL] ATL life console
By: Eclipse User on Thu, 05 January 2012
0 14896 Thu, 05 January 2012 05:12
  [ATL] ATL vs XSLT
0 14764 Tue, 03 January 2012 14:37
  [ATL] Sequence problem
By: Eclipse User on Wed, 28 December 2011
1 4750 Mon, 02 January 2012 03:27
  [ATL] ATL transformation in a plugin involving profiles
different behaviour of ATL transformations involving profiles [plugin/run configuration]
By: Eclipse User on Thu, 29 December 2011
2 5528 Fri, 30 December 2011 09:41
  Graphical ATL transformation tool
By: Eclipse User on Sat, 24 December 2011
1 4608 Sat, 24 December 2011 11:25
icon8.gif Check duplicates
Creating target model without any duplicates
By: Eclipse User on Thu, 22 December 2011
0 14730 Thu, 22 December 2011 20:17
  [ATL] Reading XML Value
How can I reference a xml element value with the ATL
By: Eclipse User on Wed, 14 December 2011
5 5710 Thu, 15 December 2011 15:25
icon5.gif [ATL] The purpose of Injector and Extractor?
By: Eclipse User on Thu, 15 December 2011
0 14937 Thu, 15 December 2011 03:28
  [ATL] calling a lazy rule with arguments
1 6230 Wed, 14 December 2011 11:20
  Select a Component from bag
4 5373 Wed, 14 December 2011 10:49
icon5.gif [ATL] - Create Integer set and add a new integer.
By: Eclipse User on Thu, 08 December 2011
9 9954 Wed, 14 December 2011 03:43
  Re: [M2M] model2xhtml QVT problem
By: Eclipse User on Mon, 12 December 2011
1 4275 Mon, 12 December 2011 09:56
  how select elements in a specific element
By: Eclipse User on Wed, 07 December 2011
3 5434 Sat, 10 December 2011 09:53
  ATL transformation programmatically inter model reference
0 15217 Fri, 09 December 2011 05:41
  [ATL] Invoking an ATL transformation on a part of a model, not on a whole model
0 15068 Wed, 07 December 2011 08:14
  [ATL] remove elements
By: Eclipse User on Thu, 24 November 2011
2 5315 Thu, 24 November 2011 10:22
  [ATL] Referenced part does not exist yet: org.eclipse.jdt.ui.PackageExplorer.
Invoking the ATL Perspective and open an *.atl file -> errorlog + cpu increase
1 7220 Thu, 24 November 2011 04:00
  [ATL] Running ATL programmatically
By: Eclipse User on Thu, 19 August 2010
2 6591 Wed, 23 November 2011 07:15
  [ATL] Use more than one instance
By: Eclipse User on Mon, 21 November 2011
2 5673 Wed, 23 November 2011 04:24
  [ATL] Copy entire Model without refining mode
By: Eclipse User on Wed, 02 November 2011
3 6201 Tue, 22 November 2011 09:05
  [ATL] "Continue" Java statement
Is there an ATL statement that is similar to the "continue" Java one ?
By: Eclipse User on Wed, 19 October 2011
1 4610 Tue, 22 November 2011 08:54
  [ATL] problem with a query on EMF-specific VM
1 4621 Tue, 22 November 2011 08:47
  [ATL] Unicode string literals in transformation
By: Eclipse User on Fri, 18 November 2011
2 6071 Mon, 21 November 2011 17:22
  Incorrect output HOT
By: Eclipse User on Sun, 20 November 2011
2 4923 Mon, 21 November 2011 10:06
  [ATL] Problems with EMF-Specific VM and Regular VM
By: Eclipse User on Sat, 12 December 2009
5 8895 Mon, 21 November 2011 03:25
icon9.gif [ATL] Launch UML2OWL on Helios
By: Eclipse User on Sun, 13 March 2011
1 7229 Tue, 15 November 2011 12:25
  [QVTo] Cast EObject to Meta-Model Type
By: Eclipse User on Sat, 12 November 2011
4 6309 Sat, 12 November 2011 09:19
  [ATL] Same emf resource as input & output
By: Eclipse User on Thu, 10 November 2011
0 15398 Thu, 10 November 2011 13:55
icon5.gif Partial parsing to an EObject which contains a cross reference across grammars
Partial parsing of a text to an EObject which contains a cross reference to another EObject which is defined in another grammar (cross-referencing across grammars).
By: Eclipse User on Wed, 09 November 2011
0 15938 Wed, 09 November 2011 01:05
  [ATL] Atl plugin problem ecore with referenced ecore
By: Eclipse User on Sun, 06 November 2011
7 9509 Tue, 08 November 2011 10:37
  [ATL] EMFInjector and Resource
By: Eclipse User on Tue, 08 November 2011
0 15742 Tue, 08 November 2011 06:07
  [ATL] Inter model references
2 5214 Thu, 03 November 2011 07:57
  [ATL] recover the value of a "multivalued" property in a stereotype
By: Eclipse User on Tue, 01 November 2011
0 7987 Tue, 01 November 2011 08:26
  Transforming to and from nested objects
By: Eclipse User on Wed, 26 October 2011
1 3996 Mon, 31 October 2011 13:47
  [QVTr] Is it impossible to create a profileApplication in QVT Relation Language?
By: Eclipse User on Tue, 07 June 2011
3 7523 Fri, 28 October 2011 04:19
  [ATL] Query a model element using XPATH expression
By: Eclipse User on Thu, 27 October 2011
0 7071 Thu, 27 October 2011 20:24
  [QVTO] Executing OCL queries
By: Eclipse User on Tue, 01 September 2009
5 7444 Thu, 27 October 2011 12:21
  Profile with ATL
By: Eclipse User on Sun, 23 October 2011
5 5992 Wed, 26 October 2011 16:44
  [ATL] iterate() operation
1 3894 Wed, 26 October 2011 09:37
  Error InterfaceRealization and values upper- lower
By: Eclipse User on Tue, 25 October 2011
0 7025 Tue, 25 October 2011 07:09
  Error Profile ATL transformation
1 4412 Mon, 24 October 2011 03:55
  [ATL] how can I get an XML schema equivalent to the metamodel
0 6588 Sun, 23 October 2011 20:57
  [ATL] Deleting elements in refing mode
By: Eclipse User on Thu, 18 August 2011
1 6296 Sun, 23 October 2011 15:22
  [ATL] Start Genmodel transformation via ant
0 7030 Fri, 21 October 2011 07:28
  [ATL] How to use EMF-Specific VM with ANT task
1 3563 Fri, 21 October 2011 07:23
  AML(AtlanMod Matching Language )
I am a student and I did a search on AML(AtlanMod Matching Language )
By: Eclipse User on Sat, 23 April 2011
2 16398 Fri, 21 October 2011 05:43
  Match with abstract Classes
By: Eclipse User on Thu, 20 October 2011
0 7113 Thu, 20 October 2011 18:48
  [QVTo] Generate XMI with multiple namespaces
By: Eclipse User on Mon, 17 October 2011
3 6326 Thu, 20 October 2011 11:59
  [ATL]: a target model inconsistant with it's metamodel
0 6853 Thu, 20 October 2011 11:39
  [ATL] Many imperative instructions inside a helper
0 7848 Mon, 17 October 2011 04:24
  labrary of rules in ATL
By: Eclipse User on Wed, 05 October 2011
3 5853 Mon, 17 October 2011 04:08
  [QVTO] Any way to speed up transformation?
Transformation takes too much time, unacceptable for user experience
By: Eclipse User on Fri, 14 October 2011
9 8023 Sat, 15 October 2011 08:39
  how generate string from a Sequence of Tuple
By: Eclipse User on Mon, 10 October 2011
4 7707 Thu, 13 October 2011 11:49
  [ATL] Complete Documentation for the ATL Metamodel
By: Eclipse User on Wed, 14 September 2011
1 4886 Mon, 10 October 2011 12:45
  Transforming Use Case Maps (jUCMNav) to Activity Diagrams (UML 2.0) using M2M
By: Eclipse User on Fri, 07 October 2011
1 5645 Sat, 08 October 2011 01:18
  Transformation Lists
0 7292 Fri, 07 October 2011 21:33
  index from sequence
By: Eclipse User on Thu, 06 October 2011
7 6460 Fri, 07 October 2011 12:43
  How to call a called rule.[ATL]
2 5666 Wed, 05 October 2011 08:37
  [ATL] Iterating over collections
By: Eclipse User on Wed, 28 September 2011
3 5497 Wed, 28 September 2011 15:05
  [ATL] MWE2 component
By: Eclipse User on Sat, 24 September 2011
2 4756 Sat, 24 September 2011 08:51
  [QVTO] Accessing Java class members from transformations
By: Eclipse User on Wed, 21 September 2011
6 6858 Fri, 23 September 2011 05:33
  [QVT] result of allSubobjects on sets
8 7868 Thu, 22 September 2011 02:28
  [QVTo] Metamodels list "reloading" in QVTo plugin
How to reload a list of metamodels seen by QVTo plugin ?
By: Eclipse User on Mon, 12 September 2011
3 5282 Fri, 16 September 2011 15:52
  ATL launch error
By: Eclipse User on Wed, 17 March 2010
7 9950 Fri, 16 September 2011 09:34
  [QVTO] Calling transformation programmatically
By: Eclipse User on Thu, 12 March 2009
12 11832 Fri, 16 September 2011 09:20
  ATL Development Tools
By: Eclipse User on Thu, 15 September 2011
0 7374 Thu, 15 September 2011 18:48
  [ATL] Assigning attributes to target class using HOT
By: Eclipse User on Tue, 13 September 2011
2 4368 Wed, 14 September 2011 15:39
  [ATL] EMF VM testing
0 7699 Wed, 14 September 2011 10:44
  [QVT] undeterministic behaviour - sometimes classifiers disappear
1 5856 Wed, 14 September 2011 01:06
  [QVT] Adding element to feature
By: Eclipse User on Fri, 09 September 2011
1 5076 Wed, 14 September 2011 00:56
  How to handle references?
0 7714 Mon, 12 September 2011 09:30
  Arguments with called rules
By: Eclipse User on Sun, 11 September 2011
2 4949 Mon, 12 September 2011 04:01
  [QVTo] factoryEntries in class EclipseRegistry/ interface UnitResolverFactory are empty
Could not find unit ; getExtensionPoint("org.eclipse.m2m.qvt.oml.unitResolverFactory").getExtension() = null
By: Eclipse User on Wed, 07 September 2011
1 5735 Sat, 10 September 2011 09:53
  [QVTo] How to extend a model
By: Eclipse User on Fri, 15 July 2011
3 8144 Sat, 10 September 2011 07:22
  [QVTo] UML Stereotypes application not set when launching transformation from Java
1 4350 Thu, 08 September 2011 12:33
  ATL : Reference to a target class using a different rule
13 8943 Thu, 08 September 2011 07:35
  [QVT] Replacing entities in a transformation
By: Eclipse User on Thu, 08 September 2011
0 7538 Thu, 08 September 2011 06:54
  [QVTo] Standalone transformation
By: Eclipse User on Thu, 01 April 2010
4 7443 Wed, 07 September 2011 08:14
  [ATL]: how do you debug you transformations
By: Eclipse User on Tue, 06 September 2011
1 3703 Tue, 06 September 2011 11:19
  [QVTo] Exporting a plugin
By: Eclipse User on Mon, 25 April 2011
2 5539 Tue, 06 September 2011 03:40
  About ATL transformations and classes in the target model
By: Eclipse User on Sun, 04 September 2011
1 4466 Sun, 04 September 2011 15:58
  [QVTo] How models from QVT conforms to models from EMF ?
By: Eclipse User on Fri, 02 September 2011
1 11472 Sun, 04 September 2011 05:37
  [ATL] Check for duplicate target objects.
Making sure that target metamodel (HOT) has unique classes.
By: Eclipse User on Wed, 31 August 2011
3 6858 Thu, 01 September 2011 03:56
  java.lang.IllegalArgumentException: The feature 'lass' is not a valid feature
By: Eclipse User on Thu, 17 May 2007
9 11675 Tue, 30 August 2011 12:42
  How to give reference of Metamodel in workspace in QVT
By: Eclipse User on Mon, 29 August 2011
3 5540 Mon, 29 August 2011 16:06
  [QVTo] - Relationships (ATL2QVTo) - The type {2} does not conform to the type {1} of the property{0}
QVTo, Relationships, ATL, SemanticUtil_8, Error
6 18924 Sun, 28 August 2011 14:30
  org.eclipse.m2m.internal.qvt.oml.emf.util.EmfException
Error is occuring when i hit the run button. "org.eclipse.m2m.internal.qvt.oml.emf.util.EmfException" can anyone help me out. How to resolve this exception.
By: Eclipse User on Sun, 28 August 2011
6 5896 Sun, 28 August 2011 13:53
  BPMN DIAGRAM ECORE METAMODEL
Does anybody have the metamodel?
By: Eclipse User on Tue, 28 June 2011
10 13865 Thu, 25 August 2011 19:11
  How to solve ATL references?
ATL References
By: Eclipse User on Fri, 17 September 2010
2 5150 Thu, 25 August 2011 18:55
  [QVTo] Blackbox library support in standalone mode
By: Eclipse User on Mon, 11 July 2011
3 5454 Wed, 24 August 2011 17:03
Current Time: Thu Nov 20 23:13:51 EST 2025
Powered by FUDForum. Page generated in 0.07401 seconds
