  Announcement: Welcome to the Stardust Forum
Introduction to the the forum and the people behind it
By: Eclipse User on Sat, 15 October 2011
1 10782 Fri, 04 October 2013 05:25
  Announcement: This forum has been archived
By: Eclipse Webmaster on Thu, 16 November 2017
0 12574 Thu, 16 November 2017 10:06
  soap post request
By: Eclipse User on Wed, 29 March 2017
4 13802 Thu, 14 September 2017 03:05
  Build stardust
How to build stardust using source code please suggest me
By: Eclipse User on Thu, 14 September 2017
0 17248 Thu, 14 September 2017 02:59
  NPE - Java Application Initialization
Null Pointer Exception in Java Application
By: Eclipse User on Fri, 18 August 2017
2 9583 Tue, 12 September 2017 04:04
  Enabling SMTP Authentication
carnot.properties does not have mail.smtp.auth property.
By: Eclipse User on Mon, 10 April 2017
1 13580 Wed, 24 May 2017 10:52
  Using JNDI Session for Mail Application
But getting unexpected class with trailing numbers.
By: Eclipse User on Sun, 09 April 2017
1 10150 Wed, 24 May 2017 10:24
icon5.gif Stardust sub-forum is a small community?
PS: Documentation isn't really guide us to understand the work for newcomers.
By: Eclipse User on Fri, 12 May 2017
0 24371 Fri, 12 May 2017 05:10
  Multiple performer accessing same activity
By: Eclipse User on Tue, 18 April 2017
0 31369 Tue, 18 April 2017 23:55
  Stardust - Weblogic and licenses
By: Eclipse User on Tue, 28 March 2017
1 8600 Sat, 01 April 2017 09:57
  Eclipse modeler, configuration variable escaping char remains
Issue regarding the use of simple variables in Camel application
By: Eclipse User on Tue, 21 March 2017
0 7626 Tue, 21 March 2017 11:23
  Documentation: multilingual/tanslations available?
Documentation of Eclipse Process Manager (Stardust)
By: Eclipse User on Thu, 16 March 2017
0 4243 Thu, 16 March 2017 10:59
  tomcat startup exception
Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding]
By: Eclipse User on Mon, 20 March 2017
0 9119 Mon, 20 March 2017 07:16
  spi programming examples
tutorial steps either incomplete or inconsistent
By: Eclipse User on Fri, 10 March 2017
0 8826 Fri, 10 March 2017 06:08
  org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory
Jms tutorial problem
By: Eclipse User on Mon, 27 February 2017
2 7176 Tue, 28 February 2017 04:33
  cannot view pdf file
viewer hangs showing 'LOADING IMAGE...'
By: Eclipse User on Tue, 07 February 2017
0 12211 Tue, 07 February 2017 05:52
  No consumer available exception
Runtime Exception
By: Eclipse User on Fri, 27 January 2017
0 16949 Fri, 27 January 2017 13:41
  JBoss AS 7.1 preconfigured deployment configuration
repository not authorised when running maven
By: Eclipse User on Tue, 27 December 2016
2 4318 Wed, 04 January 2017 22:53
  participant manager empty tab
By: Eclipse User on Mon, 14 November 2016
10 16647 Wed, 04 January 2017 22:42
  MARS2: Unsupported database type: MSSQL
By: Eclipse User on Wed, 07 December 2016
5 9895 Fri, 23 December 2016 02:50
  Stardust portal-Participant Manager Tab empty
First time running stardust portal
By: Eclipse User on Sat, 12 November 2016
7 33944 Thu, 24 November 2016 04:21
  Nullpointerexception when deploying model
Deploy with eclipse mars2 on tomcat 7.0
By: Eclipse User on Thu, 17 November 2016
2 17558 Fri, 18 November 2016 03:30
1 7734 Thu, 17 November 2016 05:42
0 62507 Thu, 17 November 2016 05:23
0 62547 Thu, 17 November 2016 05:19
  Portal problems on Neon.1
By: Eclipse User on Wed, 19 October 2016
5 5462 Mon, 24 October 2016 00:56
  How to handle Exception in SQL invocation call application
By: Eclipse User on Mon, 16 November 2015
9 6320 Wed, 28 September 2016 00:54
  Call stored procedure using Camel End Point Application
By: Eclipse User on Mon, 18 July 2016
2 7075 Fri, 29 July 2016 10:19
  Periodically Export Structured Data
DWH Export
By: Eclipse User on Fri, 24 June 2016
2 6121 Sat, 16 July 2016 07:54
  Issues with importing processes created in Eclipse BPMN2 Modeler Project
Require some info and help to deploy the imported BPMN2 Modeler diagrams
By: Eclipse User on Mon, 13 October 2014
3 5285 Tue, 12 July 2016 09:08
  Rest service call through camel
Http error with status 500
By: Eclipse User on Sat, 11 June 2016
1 4185 Mon, 04 July 2016 10:18
  Camel Endpoint Application - Webservice giving error 500
1 8319 Mon, 04 July 2016 10:18
  M2eclipse error 401 unauthorized
When working with remote repository that needs authentication Maven works fine from console but Eclipse is not abe to download the artifacts and throws a 401 unauthorized response
By: Eclipse User on Fri, 13 May 2016
2 10075 Tue, 21 June 2016 07:45
  Unable to compile Stardust src
DOwnloaded the source, and getting compilation errors, with Java 1.8
By: Eclipse User on Thu, 12 May 2016
1 7728 Fri, 13 May 2016 07:28
  Newbie question
Errors building the project
By: Eclipse User on Sat, 07 May 2016
2 7573 Mon, 09 May 2016 16:56
  importing in business/web modeler?
By: Eclipse User on Mon, 02 May 2016
1 3787 Tue, 03 May 2016 02:51
  Stardust Portal 4.0,0 Skin problem
By: Eclipse User on Thu, 07 April 2016
1 7722 Wed, 13 April 2016 06:50
  How to Deploy Stardust project on Tomcat without Eclipse
By: Eclipse User on Tue, 02 February 2016
3 7000 Thu, 04 February 2016 00:45
  Edit 1 element in Structured Data with a sequence
By: Eclipse User on Sat, 30 January 2016
1 5674 Tue, 02 February 2016 02:32
  Example of Process Model that iterate over structured data with maxOccurance > 1
By: Eclipse User on Thu, 28 January 2016
5 6381 Tue, 02 February 2016 02:29
  XML Document Data - Choosing the element name
When selecting the Element Name system replies: Cannot parse XSD file.: local part cannot be "null" when creating a QName
By: Eclipse User on Wed, 27 January 2016
3 5798 Fri, 29 January 2016 00:27
  Starting a process model with an XML parameter fails with exception
1 4337 Thu, 28 January 2016 02:28
  .NET Web Service example compile error
By: Eclipse User on Mon, 25 January 2016
0 6478 Mon, 25 January 2016 12:12
  Process Attachments
Process Attachments
By: Eclipse User on Fri, 25 December 2015
1 7181 Mon, 18 January 2016 06:05
  Error 404 Stardust Portal
By: Eclipse User on Thu, 14 January 2016
1 4867 Mon, 18 January 2016 06:03
  Custom ESB application type
Is it possible to create a custom ESB application type ?
By: Eclipse User on Tue, 22 January 2013
2 5823 Tue, 22 December 2015 10:19
  Copying Model
Copying Model
By: Eclipse User on Fri, 11 December 2015
1 7130 Fri, 18 December 2015 00:06
  CreateTranstion error in console log
By: Eclipse User on Wed, 11 November 2015
8 7206 Thu, 17 December 2015 23:57
  Wait notification or Loading symbol in process model
By: Eclipse User on Wed, 02 December 2015
2 7196 Tue, 15 December 2015 09:15
  How to copy and input common data to various SOAP based web-services in a Process
Copying data to WSDL based web-service data input
By: Eclipse User on Tue, 24 November 2015
3 4056 Mon, 14 December 2015 03:59
  Copy Model Not Working - Attached Models For reference
By: Eclipse User on Thu, 10 December 2015
1 3515 Fri, 11 December 2015 03:24
  Getting data sets and sql from a report
How to get the sql from a report using the java api
By: Eclipse User on Wed, 09 December 2015
2 4057 Fri, 11 December 2015 02:55
  WORK TYPE DEFINITIONS IN IPP
WORK TYPE INTEGRATION WITH OTHER SYSTEMS (may be a database)
0 6264 Thu, 10 December 2015 12:56
  Use Case Realizable with Stardust
How to realize a given use case scenario with Eclipse Stardust?
By: Eclipse User on Thu, 26 November 2015
1 3147 Fri, 27 November 2015 06:53
icon3.gif Stardust 3.0.1 support for BPMN 2.0
Question regarding BPMN2.0 XML support to Stardust ecosystem
By: Eclipse User on Fri, 05 June 2015
2 4653 Fri, 27 November 2015 06:37
  How to handle Exception in Rest service call application
By: Eclipse User on Thu, 12 November 2015
5 5034 Wed, 25 November 2015 04:08
  Problems deploying to Tomcat
9 12870 Mon, 23 November 2015 11:47
  View a Process Document
By: Eclipse User on Sun, 01 November 2015
5 5555 Thu, 19 November 2015 06:51
  How to delete wrong Rule Set
How to delete wrong Rule Set, not visible under "Navigation
By: Eclipse User on Mon, 09 November 2015
1 5983 Mon, 16 November 2015 00:27
  Importing decision tables
1 2663 Mon, 09 November 2015 08:10
  How to change skin of Stardust mobile UI
By: Eclipse User on Fri, 06 November 2015
1 4251 Sun, 08 November 2015 23:26
  javax.mail.Authenticator ClassNotFoundException for external smtp server
Environment is failing when trying to load javax.mail.Authenticator class for integrating with external smtp server
By: Eclipse User on Tue, 04 November 2014
3 14172 Fri, 06 November 2015 00:11
  How to show data input in manual activity in the process history
By: Eclipse User on Thu, 05 November 2015
2 2749 Thu, 05 November 2015 01:53
  Resuming execution of hibernated activity
By: Eclipse User on Tue, 03 November 2015
3 3260 Wed, 04 November 2015 04:44
  Import Type Declarations exception
By: Eclipse User on Mon, 02 November 2015
10 9244 Wed, 04 November 2015 02:14
  Showing Documents using a manual activity
By: Eclipse User on Mon, 12 October 2015
9 5386 Mon, 02 November 2015 08:01
  Problems to deploy the ACME Workflow Model from the Support Example tutorial
Is this issue caused by Apache Tomcat not running properly?
By: Eclipse User on Mon, 26 October 2015
11 10751 Thu, 29 October 2015 16:01
  Question on Stardust Modelling and interaction with DB
By: Eclipse User on Sun, 25 October 2015
2 3607 Mon, 26 October 2015 07:55
  Stardust installed, but it is not showing up?
Eclipse and Stardust installed according to directions, but the Stardust functionality is not appearing
By: Eclipse User on Thu, 22 October 2015
1 5494 Fri, 23 October 2015 04:08
  Multi Tenancy while using eclipse stardust
How can we setup eclipse stardust for a multi tenant environment
2 3051 Sat, 17 October 2015 02:51
  Calling RESTful Service Through Camel Route - a JSON POST example
By: Eclipse User on Tue, 13 October 2015
2 3578 Wed, 14 October 2015 11:39
  camel trigger as start event
By: Eclipse User on Wed, 07 October 2015
13 8192 Wed, 14 October 2015 04:23
  UI Mashup Example
By: Eclipse User on Tue, 06 October 2015
2 5397 Mon, 12 October 2015 09:46
  Angular JS based UI mashup example
1 5406 Mon, 12 October 2015 09:39
  Decision Tables / Actions
Action = get / put dateafrom / to other application
By: Eclipse User on Thu, 08 October 2015
3 3488 Mon, 12 October 2015 09:37
  JMS Trigger - Type for incoming MapMessage
Searching for the right Type to map a Incoming Mapmassige to the Datamodel in Stardust
By: Eclipse User on Fri, 09 October 2015
1 3768 Mon, 12 October 2015 09:31
  Event handler in IPP browser modeller
By: Eclipse User on Mon, 28 September 2015
5 6355 Thu, 08 October 2015 12:42
  Stardust/IPP - How to install IPP
Stardust installations in Eclipse help needed!
By: Eclipse User on Mon, 05 October 2015
1 3520 Tue, 06 October 2015 01:56
  Browser model 8.2.3 Upgrade
3 3260 Tue, 06 October 2015 01:38
  Error while setting up Stardust 3.0.1 with MySQL 5.6
By: Eclipse User on Sun, 04 October 2015
2 3316 Mon, 05 October 2015 12:04
  Unmarshalling nested or complex data elements in JAVA Web services
By: Eclipse User on Fri, 25 September 2015
2 4329 Mon, 28 September 2015 06:49
  [File missing] Camel Route to Send and Receive Email
could you please include the example file
By: Eclipse User on Tue, 21 July 2015
17 14555 Fri, 25 September 2015 08:34
  JSON string to structured data type conversion.
By: Eclipse User on Wed, 23 September 2015
4 4110 Thu, 24 September 2015 09:31
  Multi model audit trail setup
By: Eclipse User on Wed, 02 September 2015
1 2505 Wed, 02 September 2015 09:24
  Using a web application other than Stardust Portal
By: Eclipse User on Fri, 21 August 2015
3 3729 Mon, 24 August 2015 03:18
  Swift Functionality
By: Eclipse User on Sun, 16 August 2015
1 4226 Wed, 19 August 2015 12:55
  How to use user groups
By: Eclipse User on Tue, 18 August 2015
1 3095 Wed, 19 August 2015 08:16
  upgrade maven project 2 to 3
By: Eclipse User on Mon, 17 August 2015
2 3280 Tue, 18 August 2015 09:34
  How to access transitions programmatically
By: Eclipse User on Thu, 13 August 2015
3 4683 Mon, 17 August 2015 10:11
  Deployed models are cached during unit tests
By: Eclipse User on Thu, 30 July 2015
4 6357 Mon, 10 August 2015 04:21
  JBoss EAP 6.2 and UserService
By: Eclipse User on Fri, 31 July 2015
2 3883 Thu, 06 August 2015 12:31
  Issues while working with SOAP web services (HTTPS)
Problem while importing schema
By: Eclipse User on Mon, 20 July 2015
8 8847 Wed, 29 July 2015 09:07
  Porting a Stardust Application from JBOSS 5 to EAP 6.2
error msgs in server log during EAR deployment: missing/unsatisfied dependencies
By: Eclipse User on Thu, 23 July 2015
3 7193 Wed, 29 July 2015 00:03
  How to configure Mail Application using Gmail
4 7641 Tue, 28 July 2015 10:13
  First Model - Errors
Support Case : NoClassDefFoundError:
By: Eclipse User on Tue, 07 July 2015
2 3613 Sat, 25 July 2015 13:27
  Upgrade from Luna To Mars - project components are missing
By: Eclipse User on Wed, 15 July 2015
0 3809 Wed, 15 July 2015 08:32
  Activity instance not created when starting process instance programmatically
By: Eclipse User on Tue, 14 July 2015
1 2706 Tue, 14 July 2015 13:00
  Logging in and creating user programmatically
By: Eclipse User on Thu, 09 July 2015
3 3975 Fri, 10 July 2015 04:35
  Example Spring Test Project
By: Eclipse User on Mon, 29 June 2015
1 2914 Tue, 30 June 2015 03:04
  Cannot login to IPP-Portal at the first time after setup Application Server (Weblogic 12c)
By: Eclipse User on Fri, 29 May 2015
2 6737 Fri, 29 May 2015 21:01
  HOW TO RECEIVE A CARNOT.EAR FILE
By: Eclipse User on Mon, 25 May 2015
4 5023 Tue, 26 May 2015 05:55
  How to receive a carnot.ear file?
0 3834 Mon, 25 May 2015 02:18
0 4451 Mon, 25 May 2015 02:17
  MysqlXAException: No operations allowed after connection closed
By: Eclipse User on Thu, 23 April 2015
5 7699 Thu, 21 May 2015 10:42
  Other supported Java EE server(s) for Stardust ?
By: Eclipse User on Tue, 19 May 2015
1 3266 Wed, 20 May 2015 03:46
  Deploying Workflow Model Using Console Command
By: Eclipse User on Thu, 12 March 2015
3 4158 Mon, 18 May 2015 16:17
  Deployment Problem - Urgent help!
Deployment of the Process is getting Failed. Tried a lot of things but no solutions
By: Eclipse User on Thu, 18 April 2013
14 14065 Mon, 18 May 2015 12:09
  How to capture at activity exception thrown by camel producer route
By: Eclipse User on Thu, 14 May 2015
3 5103 Mon, 18 May 2015 09:33
  Calculate Criticality based on user input
By: Eclipse User on Mon, 27 April 2015
3 4084 Mon, 04 May 2015 02:01
  Faces Context Not Found - Portal
Get a faces error after deploying a project to the server and trying to access the portal.
By: Eclipse User on Sun, 08 February 2015
5 6865 Mon, 13 April 2015 03:45
  emergency problem with WorklistQuery.findCompleteWorklist()
By: Eclipse User on Mon, 02 March 2015
1 3319 Sat, 07 March 2015 07:15
  urgent problem with state of manual activity
4 4710 Sat, 07 March 2015 07:14
icon3.gif How to add user to Runtime Participant role
By: Eclipse User on Sun, 22 February 2015
6 5090 Sun, 01 March 2015 10:51
icon4.gif unexpected work list query result
By: Eclipse User on Wed, 18 February 2015
7 5469 Mon, 23 February 2015 05:39
  Stardust_Testing_Embedded_Spring_2.1.0 extended
By: Eclipse User on Sat, 14 February 2015
9 5068 Sun, 15 February 2015 10:28
  Help for creating stardust standalone engine
By: Eclipse User on Thu, 29 January 2015
11 8594 Tue, 10 February 2015 09:37
icon3.gif urgent problem
Help with creating stardust standalone spring project
By: Eclipse User on Wed, 04 February 2015
2 4618 Sat, 07 February 2015 01:24
  Missing Daemons
Mail and Timer trigger daemons are missing from Administration perspective
By: Eclipse User on Mon, 08 December 2014
1 4917 Thu, 05 February 2015 03:36
  Structure with 1:N cardanility
By: Eclipse User on Wed, 28 January 2015
1 3527 Wed, 28 January 2015 07:48
  Professional Support
Professional Support needed
By: Eclipse User on Fri, 23 January 2015
2 3901 Tue, 27 January 2015 13:59
  Structure data type
By: Eclipse User on Tue, 27 January 2015
1 2726 Tue, 27 January 2015 03:22
  IPP Artifactory and Create Maven Project
Facing an issue when creating maven project with artifact
By: Eclipse User on Tue, 20 January 2015
7 9893 Tue, 27 January 2015 01:07
  Newbie Frustration
Troubles with getting started
By: Eclipse User on Wed, 17 December 2014
5 5120 Sun, 25 January 2015 13:11
  Using custom skin for login screen
By: Eclipse User on Fri, 16 January 2015
4 6877 Sun, 25 January 2015 13:04
  Accessing application activity information
how to retrieve the current activity instance id from a java application
2 5842 Fri, 23 January 2015 06:40
  Stardust and Subversion
By: Eclipse User on Wed, 21 January 2015
1 3203 Wed, 21 January 2015 23:50
  Stardust user guide
Stardust user guide and how to learn stardust BPM
By: Eclipse User on Fri, 14 November 2014
8 7526 Tue, 20 January 2015 07:45
  Test Data for Report testing
Is there a test data that I can use for building reports
By: Eclipse User on Tue, 02 December 2014
1 6825 Mon, 19 January 2015 03:37
  JMX MBeans creation in Stardust
How to create a JMX MBeans using spring in Stardust
By: Eclipse User on Wed, 14 January 2015
5 5375 Mon, 19 January 2015 03:20
  Assign specific account as current user
1 3939 Mon, 19 January 2015 03:12
  UI customization
By: Eclipse User on Thu, 15 January 2015
5 4789 Mon, 19 January 2015 02:54
  No source code in Stardust Web Services java client example
By: Eclipse User on Mon, 17 November 2014
5 7186 Sat, 17 January 2015 11:47
  drl file location
When I execute a rule task I get a RulesSet not found exception
By: Eclipse User on Thu, 18 December 2014
1 5776 Wed, 24 December 2014 03:40
  Mobile UI packaged as Chrome App
Is there any initiative to convert Mobile UI to a Chrome App?
By: Eclipse User on Sat, 08 November 2014
3 7373 Thu, 18 December 2014 17:47
  Security Credentials is missing
I have enabled Security Propagation but it returns an empty ipp_session_credentials.
By: Eclipse User on Sun, 07 December 2014
3 5869 Thu, 11 December 2014 07:17
  Oracle "OAUTH marshalling failure" calling sysconsole command
Exception running commandline tool
By: Eclipse User on Wed, 07 November 2012
3 12867 Thu, 11 December 2014 06:32
  AtomicReference error
By: Eclipse User on Tue, 14 October 2014
4 5387 Sun, 07 December 2014 19:27
  what is the best way to log all form fields from an external mashup?
when a task is completed we want to make a log of all fields on the form
By: Eclipse User on Mon, 24 November 2014
5 8108 Thu, 04 December 2014 16:57
  Data mapping could not be resolved during model deployment
Data mappings for a rule task could not be resolved and returns an error during model deployment
4 10038 Fri, 28 November 2014 01:04
  How to use maven dependencies in eclipse stardust dynamic web project?
When I convert the dynamic web project to maven project, it fails to build
6 10043 Thu, 27 November 2014 22:36
  How to control a manual activity, rendering and input-validation
By: Eclipse User on Wed, 15 October 2014
2 7177 Thu, 27 November 2014 03:53
  Configuration Variables
By: Eclipse User on Tue, 25 November 2014
3 4516 Wed, 26 November 2014 16:12
  How to access Manual Task information from external mashup?
E.g task OID, Task name, current performer
3 6425 Mon, 24 November 2014 21:28
  Rule Task Testing
2 5837 Sun, 23 November 2014 16:26
  How to append authorization header for invoking StardustBpmServices through SOAP
Authorization Header missing error when trying to call UserService
By: Eclipse User on Thu, 20 November 2014
2 9012 Fri, 21 November 2014 04:44
icon5.gif Modelling exception flow
Attaching an exception flow to an application activity
By: Eclipse User on Tue, 21 October 2014
5 7294 Fri, 21 November 2014 03:20
  Which companies are using Stardust in Production?
Stardust production clients
By: Eclipse User on Thu, 13 November 2014
1 6030 Fri, 21 November 2014 03:17
  I can not deploy models that include a Rule Task
From Business Process Modeling Perspective I am not able to deploy the model to portal; I get an warning and if I choose to ignore the warning I get an error.
4 7751 Fri, 21 November 2014 03:01
  Stardust with rule engine (Drools)
By: Eclipse User on Tue, 16 July 2013
4 7830 Thu, 20 November 2014 23:42
  Not able to access the Infinity artifactory to download archetype
1 3570 Tue, 18 November 2014 09:41
  Audit Trail Database Schema in Production
Mysql Database schema for Stardust in Production
6 6753 Sun, 16 November 2014 23:17
  Stardust 1.0 to 2.0.1 upgrade
Upgrade Steps
By: Eclipse User on Tue, 11 November 2014
2 3263 Wed, 12 November 2014 08:38
  How does Stardust scale in Production
Stardust setup in Production and its scale
By: Eclipse User on Sun, 02 November 2014
2 4420 Mon, 10 November 2014 05:43
  Adding Custom Activities to Stardust Modeler
By: Eclipse User on Mon, 27 October 2014
1 4310 Fri, 07 November 2014 01:42
icon5.gif Debug fails to start
By: Eclipse User on Mon, 20 October 2014
6 5939 Wed, 22 October 2014 04:20
  Stardust offline donwload links no longer working
3 3437 Thu, 16 October 2014 06:05
  Business Process Modeling Error
I can not implement the model as per "Creating Models" training video
By: Eclipse User on Thu, 25 September 2014
4 4329 Thu, 25 September 2014 05:54
  Audit Trail support for MySql current version
Is it planned to support MySql current version?
By: Eclipse User on Wed, 10 September 2014
4 6943 Thu, 25 September 2014 02:48
  Logging.Directory property does not appear to work
carnot.log is not created in expected folder
By: Eclipse User on Tue, 23 September 2014
2 3964 Tue, 23 September 2014 20:10
  Reporting documentation bugs/issues
What is the preferred way to report documentation bugs?
By: Eclipse User on Mon, 08 September 2014
1 3599 Tue, 09 September 2014 01:55
icon5.gif Camel Trigger, email and headers
By: Eclipse User on Sat, 02 August 2014
6 7363 Thu, 21 August 2014 03:08
  Broken Link for self-learning training "Department Concept"
By: Eclipse User on Wed, 02 July 2014
3 4893 Thu, 21 August 2014 01:51
  missing training videos
training videos are missing for End User Portal and TIFF Viewer sections
By: Eclipse User on Wed, 20 August 2014
1 3346 Thu, 21 August 2014 01:48
  java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/resource/Resource$Internal
By: Eclipse User on Tue, 08 July 2014
1 5758 Tue, 15 July 2014 20:27
  eclipse-collector: Unable to find artifact p2.osgi.bundle:org.eclipse.osgi:jar:3.10.0.v20140513-1456
Dependency problems when building stardust 2.0.0 with maven
By: Eclipse User on Thu, 26 June 2014
5 13055 Fri, 04 July 2014 07:40
  Eclipse does not start due to not finding the JRE and javaw.exe
Unable to start the Eclipse IDE on Windows7 64-bit
By: Eclipse User on Thu, 01 March 2012
7 35952 Sat, 14 June 2014 05:23
  1.1.2 build issue - needs missing product.home var ?
By: Eclipse User on Thu, 15 May 2014
1 16746 Thu, 22 May 2014 07:01
icon7.gif Using Audit Trail Database
By: Eclipse User on Mon, 07 April 2014
5 5945 Thu, 24 April 2014 18:38
  Failed when call SOAP web services to save OUT data values
By: Eclipse User on Mon, 21 April 2014
1 8263 Tue, 22 April 2014 02:56
  Stardust API's Deployment - Poll Data via Query API
Technique to use the Stardust API's to get activity and Process data from Stardust
By: Eclipse User on Fri, 21 March 2014
8 6139 Thu, 27 March 2014 04:23
  Integrate XML File
By: Eclipse User on Mon, 03 March 2014
5 4664 Thu, 06 March 2014 13:34
  Load Testing of Business Process
Technique & Tools
By: Eclipse User on Tue, 18 February 2014
5 21498 Thu, 27 February 2014 04:54
  Stardust 1.1 logon error
HTTP Status 404 ...shell/desktop-index.html is not available
1 18019 Thu, 20 February 2014 20:30
  Building Stardust
By: Eclipse User on Wed, 27 February 2013
32 32719 Fri, 07 February 2014 07:46
  Monitoring of Roles, Worklists & Participants
Fetching the monitoring data from the Audit Trail DB for participants users.
By: Eclipse User on Wed, 15 January 2014
4 12992 Wed, 05 February 2014 08:07
  Unable to send email
By: Eclipse User on Tue, 04 February 2014
1 6258 Tue, 04 February 2014 16:30
  How to test forceCompletion(from IAdministrationService) API in SOAP UI test tool
How to test forceCompletion API from IAdministrationService
By: Eclipse User on Mon, 21 October 2013
2 6082 Tue, 04 February 2014 11:22
  Issues while using Web Service Application in Stardust1.1.0
Issues migrating to Stardust 1.1.0
By: Eclipse User on Mon, 20 January 2014
3 8173 Tue, 28 January 2014 11:09
  Active Process and Timer
By: Eclipse User on Mon, 27 January 2014
2 6072 Tue, 28 January 2014 10:48
  Invoking process using REST
By: Eclipse User on Thu, 23 January 2014
1 3706 Thu, 23 January 2014 12:16
  Using Rest Web Services in Stardust
How to use rest services in Stardust
By: Eclipse User on Wed, 18 December 2013
6 12404 Thu, 09 January 2014 07:38
  Proxy setting for using external Web Services
Problems while using WSDL of external 3rd party online hosted web services under company proxy
By: Eclipse User on Mon, 16 December 2013
4 12503 Wed, 08 January 2014 10:52
  How to suspend process at any time for incoming message?
By: Eclipse User on Thu, 21 November 2013
1 4706 Wed, 08 January 2014 00:23
  Problems with the source code - need help!
By: Eclipse User on Thu, 26 December 2013
2 4426 Wed, 01 January 2014 21:21
  Stardust 1.1
By: Eclipse User on Tue, 03 December 2013
4 6069 Tue, 17 December 2013 08:20
  How to delegate the Activity to UserGroup
How to delegateTheActivity to the UserGroup
By: Eclipse User on Thu, 28 November 2013
2 11924 Mon, 09 December 2013 02:11
  Data Entity Beans can't resolve
4 5338 Wed, 04 December 2013 15:57
  Maven repository links are broken
2 4396 Wed, 04 December 2013 03:47
  Mail / SMTP / Authentication
Set SMTP AuthenticationCredentials
By: Eclipse User on Wed, 30 October 2013
3 10324 Tue, 03 December 2013 04:45
  How to deploy stardust WAR to Tomcat
By: Eclipse User on Mon, 02 December 2013
2 6194 Tue, 03 December 2013 00:39
  How can I suspend or abort process using "Spring Bean Applicationa"
By: Eclipse User on Fri, 29 November 2013
2 6119 Mon, 02 December 2013 15:22
  Unable to deploy stardust in Jboss 5.1
1 8162 Mon, 02 December 2013 05:38
  findUsers - Webservice API
findUsers - needs only the valid users
By: Eclipse User on Tue, 22 October 2013
2 5069 Thu, 28 November 2013 08:02
  Web project doesn't run on Eclipse's Tomcat
Eclipse and Tomcat
By: Eclipse User on Tue, 26 November 2013
3 21690 Thu, 28 November 2013 07:47
  Getting ClassCastException while deploying a model
By: Eclipse User on Fri, 22 November 2013
1 4817 Tue, 26 November 2013 00:26
  Cannot find Audit Trail Datasource on Tomcat settings
2 5682 Fri, 22 November 2013 04:30
  Stardust with JBoss deployment
How to deploy the stardust in JBoss server
By: Eclipse User on Mon, 18 November 2013
0 5195 Mon, 18 November 2013 07:33
icon3.gif BPMS SPI Monitoring - IActivityInstanceMonitor
Discussion on SPI Monitoring using IActivityInstanceMonitor
By: Eclipse User on Fri, 18 October 2013
4 6261 Wed, 23 October 2013 09:37
  BPMS SPI Monitoring - IProcessExecutionMonitor
Some query on using the SPI monitoring technique
By: Eclipse User on Tue, 15 October 2013
4 6143 Wed, 16 October 2013 12:10
  Getting error while deploying processes in updated version of Startdust
Getting error while working with the updated version.
By: Eclipse User on Wed, 09 October 2013
3 8006 Wed, 16 October 2013 09:36
Current Time: Sat Jul 26 09:50:16 EDT 2025
Powered by FUDForum. Page generated in 0.09966 seconds
