sticky: Moving to GitHub Discussions! By: Eclipse User on Fri, 31 May 2024 |
1416 |
Fri, 31 May 2024 07:39 By: Eclipse User  |
Ant "External Tool Configurations" Programatically Define Ant External Tool Configurations (Run in Same JRE) programatically from Java Code By: Eclipse User on Sat, 31 July 2021 |
5092 |
Thu, 05 September 2024 02:50 By: Eclipse User  |
Issue with protected region since Eclipse 2024-03 Duplicated protected regions are improperly reported By: Eclipse User on Thu, 25 July 2024 |
1661 |
Fri, 26 July 2024 10:12 By: Eclipse User  |
How to import java libraries to .eol files? By: Eclipse User on Thu, 06 June 2024 |
1364 |
Thu, 06 June 2024 08:28 By: Eclipse User  |
Data retrieval from models through Java and EOL By: Eclipse User on Wed, 29 May 2024 |
1774 |
Fri, 31 May 2024 08:11 By: Eclipse User  |
How to create model object diagrams By: Eclipse User on Wed, 22 May 2024 |
1882 |
Thu, 23 May 2024 07:36 By: Eclipse User  |
serialize ecl matchtrace By: Eclipse User on Wed, 30 October 2013 |
4807 |
Fri, 03 May 2024 04:57 By: Eclipse User  |
load xtext dsl during ant build By: Eclipse User on Sat, 27 April 2024 |
2805 |
Thu, 02 May 2024 04:09 By: Eclipse User  |
Using EGL to instantiate an excel file By: Eclipse User on Fri, 26 April 2024 |
2892 |
Wed, 01 May 2024 01:18 By: Eclipse User  |
Loading Excel file in Ant By: Eclipse User on Mon, 29 April 2024 |
2177 |
Tue, 30 April 2024 14:27 By: Eclipse User  |
Alternative way to create references using EOL By: Eclipse User on Thu, 25 April 2024 |
2487 |
Mon, 29 April 2024 09:35 By: Eclipse User  |
Is it possible to create enumeration ? By: Eclipse User on Fri, 19 April 2024 |
1893 |
Mon, 22 April 2024 04:06 By: Eclipse User  |
Using Xtext with Epsilon By: Eclipse User on Wed, 03 April 2024 |
4554 |
Fri, 12 April 2024 02:17 By: Eclipse User  |
Executing EGX headless without files By: Eclipse User on Sun, 03 March 2024 |
2131 |
Mon, 04 March 2024 04:48 By: Eclipse User  |
Evaluating Metamodel Quality Metrics How to calculate metamodel quality metrics using Eclipse Epsilon framework By: Eclipse User on Tue, 06 February 2024 |
1713 |
Wed, 21 February 2024 13:40 By: Eclipse User  |
How to use Epsilon (EGX, EGL, EOL, EVL) programs for Runtime Eclipse Application? By: Eclipse User on Fri, 12 January 2024 |
1430 |
Sun, 14 January 2024 06:02 By: Eclipse User  |
There are no model importers available. By: Eclipse User on Thu, 11 January 2024 |
1546 |
Fri, 12 January 2024 17:03 By: Eclipse User  |
What is the Goal of Epsilon? Call to action for Epsilon to show how it can actually help Developers By: Eclipse User on Sun, 24 December 2023 |
3491 |
Thu, 11 January 2024 13:50 By: Eclipse User  |
Why is the difference of program execution time between console time and profiling time By: Eclipse User on Thu, 21 December 2023 |
1403 |
Fri, 22 December 2023 02:59 By: Eclipse User  |
Importing/referring model of different emf metamodal in default tree base editor By: Eclipse User on Thu, 07 December 2023 |
2339 |
Sun, 10 December 2023 10:40 By: Eclipse User  |
Detect User Inactivity and Logout (Eclipse RCP) By: Eclipse User on Thu, 07 December 2023 |
1329 |
Thu, 07 December 2023 08:45 By: Eclipse User  |
Issue with the '*]' character sequence in the generated text By: Eclipse User on Wed, 06 December 2023 |
1742 |
Thu, 07 December 2023 02:58 By: Eclipse User  |
EOL Script error in standalone execution: The feature 'x' is not a valid feature Error, EOL Standalone By: Eclipse User on Tue, 14 November 2023 |
2151 |
Tue, 05 December 2023 13:08 By: Eclipse User  |
Unable to generate .diagram folder using Eugenia By: Eclipse User on Fri, 01 December 2023 |
1350 |
Sat, 02 December 2023 06:54 By: Eclipse User  |
How to query Sequence<Any> for enum in EMF model? By: Eclipse User on Thu, 30 November 2023 |
1276 |
Fri, 01 December 2023 09:38 By: Eclipse User  |
How to get the name of the .model file and the folder it resides in? By: Eclipse User on Thu, 23 November 2023 |
1675 |
Sun, 26 November 2023 04:38 By: Eclipse User  |
Installing Epsilon with Dockerfile Advice on installing Epsilon/Emfatic into an Eclispe instance in a Docker container - dependency errors By: Eclipse User on Fri, 17 November 2023 |
1318 |
Sat, 18 November 2023 04:20 By: Eclipse User  |
Not properly disposed SWT resource By: Eclipse User on Thu, 16 November 2023 |
1204 |
Thu, 16 November 2023 11:14 By: Eclipse User  |
Could not instantiate provider org.eclipse.emf.compare.model.provider By: Eclipse User on Thu, 16 November 2023 |
927 |
Thu, 16 November 2023 11:12 By: Eclipse User  |
Flexmi and load resources By: Eclipse User on Fri, 20 October 2023 |
2164 |
Mon, 23 October 2023 09:05 By: Eclipse User  |
Java and epsilon ecl syncronizathion Issues with the value of a variable By: Eclipse User on Mon, 16 October 2023 |
18 |
3092 |
Wed, 18 October 2023 10:33 By: Eclipse User  |
Method not found for child class based on a class from another model By: Eclipse User on Fri, 06 October 2023 |
2221 |
Tue, 10 October 2023 03:30 By: Eclipse User  |
Flexmi anonymous root By: Eclipse User on Sun, 24 September 2023 |
1706 |
Tue, 26 September 2023 11:31 By: Eclipse User  |
Transforming into target structure By: Eclipse User on Tue, 05 September 2023 |
1205 |
Tue, 05 September 2023 17:06 By: Eclipse User  |
Export model as image using simulink API Export model as image using simulink API By: Eclipse User on Wed, 09 August 2023 |
1844 |
Thu, 10 August 2023 09:46 By: Eclipse User  |
EMC for INI files Component search By: Eclipse User on Tue, 08 August 2023 |
1469 |
Tue, 08 August 2023 06:53 By: Eclipse User  |
sys_paths error in epsilon simulink api Cannot use epsilon api to communicate with Simulink By: Eclipse User on Thu, 03 August 2023 |
2130 |
Fri, 04 August 2023 04:21 By: Eclipse User  |
How to query XMI file when the name of properties has colon By: Eclipse User on Thu, 27 July 2023 |
1173 |
Thu, 27 July 2023 17:43 By: Eclipse User  |
Helping a newbie creating an UML transforamtion application with EPSILON By: Eclipse User on Sun, 09 July 2023 |
2293 |
Fri, 14 July 2023 04:45 By: Eclipse User  |
Using Epsilon components in RAP Web architecture for Modelling Tools By: Eclipse User on Wed, 05 July 2023 |
2068 |
Thu, 06 July 2023 22:02 By: Eclipse User  |
Flock enumerator copy Flock enumerator copy By: Eclipse User on Tue, 30 May 2023 |
1193 |
Tue, 30 May 2023 15:36 By: Eclipse User  |
ATL to ETL transformation By: Eclipse User on Fri, 26 May 2023 |
1523 |
Fri, 26 May 2023 03:26 By: Eclipse User  |
Emphatic metamodel - Dynamic "attr" for "class" On-demand number of class attributes By: Eclipse User on Sat, 08 April 2023 |
2865 |
Fri, 14 April 2023 03:50 By: Eclipse User  |
Flock migration sequence By: Eclipse User on Mon, 10 April 2023 |
1008 |
Mon, 10 April 2023 15:28 By: Eclipse User  |
Model copy Model copy By: Eclipse User on Wed, 05 April 2023 |
1640 |
Mon, 10 April 2023 09:27 By: Eclipse User  |
Programmtically load genmymodel XMI export file with Epsilon Looking By: Eclipse User on Tue, 28 March 2023 |
2145 |
Thu, 06 April 2023 15:05 By: Eclipse User  |
Type 'model1!School' not found Type 'model1!School' not found at (C:\Users\LENEW\eclipse-workspace\compositionWithEML\compare.ecl@2:10-2:23) By: Eclipse User on Sat, 26 November 2022 |
2050 |
Tue, 04 April 2023 06:05 By: Eclipse User  |
Running Pinset from Ant Workflow Reflective invocation possible? By: Eclipse User on Mon, 20 March 2023 |
2151 |
Thu, 30 March 2023 08:18 By: Eclipse User  |
Collect vs Select Collect vs Select By: Eclipse User on Sun, 19 March 2023 |
1712 |
Mon, 20 March 2023 06:33 By: Eclipse User  |
Importing dynamic content from a resource By: Eclipse User on Sun, 26 February 2023 |
4067 |
Wed, 01 March 2023 09:27 By: Eclipse User  |
Best practive for prototyping tools in Eclipse Installation of tool in stand-alone mode: Possible practice? How? By: Eclipse User on Tue, 28 February 2023 |
2092 |
Wed, 01 March 2023 07:58 By: Eclipse User  |
Delegating to EOL from EMF Feature request for delegation extension points By: Eclipse User on Fri, 24 February 2023 |
2345 |
Sat, 25 February 2023 22:00 By: Eclipse User  |
Accessing Enum values compliant with iModel access via Ecore references is brittle By: Eclipse User on Tue, 14 February 2023 |
3328 |
Thu, 23 February 2023 00:08 By: Eclipse User  |
Resolve reference between models with ETL By: Eclipse User on Wed, 08 February 2023 |
2075 |
Wed, 15 February 2023 17:05 By: Eclipse User  |
Construct models programmatically but manipulate them with Epsilon By: Eclipse User on Thu, 26 January 2023 |
3351 |
Wed, 08 February 2023 16:12 By: Eclipse User  |
EPSILON INSTALLATION don't get the .diagram folder after running EuGENia By: Eclipse User on Thu, 12 January 2023 |
4732 |
Wed, 08 February 2023 00:40 By: Eclipse User  |
EGL applied to compartments standard output expressions By: Eclipse User on Sun, 29 January 2023 |
3553 |
Wed, 08 February 2023 00:36 By: Eclipse User  |
Flock Ecore Migration leaving dangling reference How to remove eSuperType pointers By: Eclipse User on Mon, 06 February 2023 |
2656 |
Mon, 06 February 2023 22:59 By: Eclipse User  |
Customizing a GMF editor generated by Eugenia By: Eclipse User on Sat, 10 December 2022 |
5338 |
Sat, 21 January 2023 05:56 By: Eclipse User  |
Including pinset dataset into markdown file using picto When using picto for markdown files it is possible to include plantuml seamlessly, however including csv pinset datasets fails By: Eclipse User on Mon, 28 November 2022 |
7883 |
Wed, 11 January 2023 03:40 By: Eclipse User  |
Bug in Flock Default Copy - Enums moved to resource Flock cannot be used to copy metamodels that contain enums By: Eclipse User on Tue, 29 November 2022 |
3238 |
Fri, 06 January 2023 20:39 By: Eclipse User  |
Using Epsilon with CDO No content reported loading from a CDO URI By: Eclipse User on Sun, 11 December 2022 |
24 |
8420 |
Mon, 19 December 2022 11:04 By: Eclipse User  |
Bug: Flock Ant Task discards ModelRepository The Flock ant task creates a new model repository By: Eclipse User on Thu, 15 December 2022 |
3021 |
Fri, 16 December 2022 06:31 By: Eclipse User  |
Generate YAML from XMI When using epsilon, it is possible to convert from a YAML (flexmi) representation to XMI. Is the opposite also possible? By: Eclipse User on Tue, 13 December 2022 |
2074 |
Wed, 14 December 2022 08:42 By: Eclipse User  |
Querying tool By: Eclipse User on Thu, 08 December 2022 |
1227 |
Thu, 08 December 2022 16:19 By: Eclipse User  |
Run EMG in workflow Can ant generate model samples By: Eclipse User on Wed, 30 November 2022 |
3400 |
Fri, 02 December 2022 06:55 By: Eclipse User  |
EMG built in operations fail Cannot use random data generation facilities. By: Eclipse User on Wed, 30 November 2022 |
1750 |
Wed, 30 November 2022 01:30 By: Eclipse User  |
Using import directive in interpreter view Testing EOL operations By: Eclipse User on Mon, 28 November 2022 |
1215 |
Mon, 28 November 2022 18:29 By: Eclipse User  |
How to run an EOL program with a resource in memory prevously loaded How to run an EOL program with a resource in memory prevously loaded By: Eclipse User on Mon, 21 November 2022 |
2286 |
Sat, 26 November 2022 14:30 By: Eclipse User  |
Extended property issues for 2.3 Extended property issues for 2.3 By: Eclipse User on Tue, 24 August 2021 |
4742 |
Wed, 16 November 2022 14:52 By: Eclipse User  |
Unregistering or locally registering a metamodel A metamodel registered in the local registry is not replaced when workflow executes By: Eclipse User on Mon, 14 November 2022 |
1126 |
Mon, 14 November 2022 18:36 By: Eclipse User  |
EGX Parallel Execution Is there a way to execute multiple different EGX rules in parallel? By: Eclipse User on Wed, 09 November 2022 |
2584 |
Fri, 11 November 2022 04:35 By: Eclipse User  |
Iteration over columns in Excel By: Eclipse User on Fri, 18 December 2020 |
3165 |
Mon, 07 November 2022 18:44 By: Eclipse User  |
Possible Major Bug: CachedResourceSet holds state over boundary of Ant run. Cannot read a model twice By: Eclipse User on Wed, 02 November 2022 |
2596 |
Fri, 04 November 2022 03:59 By: Eclipse User  |
Executing EWL How to run and interact with EWL language By: Eclipse User on Thu, 27 October 2022 |
2784 |
Mon, 31 October 2022 04:02 By: Eclipse User  |
Cast behaviour with Native types EOL language semantics By: Eclipse User on Wed, 19 October 2022 |
3691 |
Mon, 24 October 2022 06:51 By: Eclipse User  |
EGL+EGX, Type not found By: Eclipse User on Fri, 21 October 2022 |
3548 |
Sat, 22 October 2022 04:50 By: Eclipse User  |
Accessing URIConverter and using mappings Location-transparent use of EMF Resources with Epsilon By: Eclipse User on Wed, 19 October 2022 |
4170 |
Sat, 22 October 2022 04:49 By: Eclipse User  |
Unconventional naming of antlib descriptor Cannot load antlib using recommended usage pattern By: Eclipse User on Thu, 22 September 2022 |
3527 |
Thu, 06 October 2022 20:42 By: Eclipse User  |
Native usage By: Eclipse User on Mon, 03 October 2022 |
2587 |
Tue, 04 October 2022 05:40 By: Eclipse User  |
JavaDoc documentation of IModel Request for description of the EMC component lifecycle By: Eclipse User on Thu, 15 September 2022 |
1906 |
Thu, 15 September 2022 03:39 By: Eclipse User  |
Buggy default method in IPropertySetter, Epsilon 2.4 By: Eclipse User on Tue, 13 September 2022 |
3022 |
Thu, 15 September 2022 00:45 By: Eclipse User  |
Bug: dependency order in installation Oomph build is buggy By: Eclipse User on Wed, 31 August 2022 |
2758 |
Tue, 06 September 2022 21:47 By: Eclipse User  |
ETL model examples' metamodels By: Eclipse User on Tue, 23 August 2022 |
2246 |
Wed, 24 August 2022 05:26 By: Eclipse User  |
ETL models Loading ETL models By: Eclipse User on Sun, 29 May 2022 |
29 |
14383 |
Sat, 20 August 2022 04:49 By: Eclipse User  |
Model generation starting from UML diagrams and c++ codes Creation of a model instance for model 2 model transformation By: Eclipse User on Mon, 18 July 2022 |
5050 |
Fri, 19 August 2022 03:05 By: Eclipse User  |
emfatic: nested double-quotes in annotations? By: Eclipse User on Mon, 25 July 2022 |
3021 |
Thu, 28 July 2022 10:01 By: Eclipse User  |
Using JDT driver in workflow Reverse engineering and architecture modernisation using DevOps By: Eclipse User on Tue, 26 July 2022 |
2288 |
Tue, 26 July 2022 23:45 By: Eclipse User  |
Models with multipe files and only file reference - preferred approach EVL By: Eclipse User on Sun, 24 July 2022 |
2376 |
Tue, 26 July 2022 08:08 By: Eclipse User  |
all() / allInstances() working - allOfType() / allOfKind() not found By: Eclipse User on Sat, 16 July 2022 |
3035 |
Sat, 23 July 2022 08:27 By: Eclipse User  |
How to run Epsilon from Java I can't run Epsilon from Java By: Eclipse User on Wed, 15 June 2022 |
2737 |
Wed, 15 June 2022 12:10 By: Eclipse User  |
How run EOL script from a Java Class How can I create a Java code that launches 2 EOL scripts to automate the process of populating models and code generation based on model data? By: Eclipse User on Mon, 13 June 2022 |
2713 |
Mon, 13 June 2022 13:45 By: Eclipse User  |
I can't get the UML representation diagram from my .ecore model I can't get the UML representation diagram from my .ecore model By: Eclipse User on Mon, 13 June 2022 |
2257 |
Mon, 13 June 2022 05:09 By: Eclipse User  |
[EVL] Validation of linked model instances By: Eclipse User on Tue, 15 March 2016 |
10629 |
Tue, 31 May 2022 04:13 By: Eclipse User  |
Inheritance in ETL How can I extend multiple target parameters of transformation rule By: Eclipse User on Mon, 16 May 2022 |
2850 |
Tue, 17 May 2022 03:25 By: Eclipse User  |
Generating xml file from xml model from java code Generating xml file from xml model from java code By: Eclipse User on Fri, 13 May 2022 |
4648 |
Mon, 16 May 2022 12:36 By: Eclipse User  |
Eugenia: problem running example filesystem By: Eclipse User on Tue, 22 February 2022 |
30 |
13731 |
Sat, 07 May 2022 16:54 By: Eclipse User  |
Problem with tree2graph transformation example Eclipse Example doesn't work with ant configuration By: Eclipse User on Sun, 24 April 2022 |
3690 |
Mon, 25 April 2022 12:22 By: Eclipse User  |
org.eclipse.epsilon.examples.egl.flowchart is missing metamodel Example fails and cannot be used By: Eclipse User on Tue, 05 April 2022 |
2764 |
Fri, 08 April 2022 03:11 By: Eclipse User  |
EolDoc - Using annotations to generate documentation Base infrastructure for EOL documentation By: Eclipse User on Sun, 03 April 2022 |
2077 |
Sun, 03 April 2022 07:53 By: Eclipse User  |
Error of assignment when generating simulink model Assigning to 0 elements using a simple assignment statement is not supported. Consider using comma-separated list assignment. By: Eclipse User on Mon, 28 March 2022 |
2837 |
Tue, 29 March 2022 06:04 By: Eclipse User  |
Transforming eol file to a simulink model using fuzzy logic blocks I'm working on modelling a simulink control system that needs fuzzy logic functions, i'm still using eclipse 2020-06 , but still looking for a clear answer i thought it may be there are some updates w By: Eclipse User on Thu, 24 March 2022 |
3518 |
Mon, 28 March 2022 09:26 By: Eclipse User  |
Epsilon Core Dependencies Feature incomplete Difficult to install development target for Epsilon By: Eclipse User on Tue, 22 March 2022 |
7556 |
Fri, 25 March 2022 21:21 By: Eclipse User  |
Scripting Simulink Models Error message: Simulink block type not found By: Eclipse User on Fri, 23 July 2021 |
2377 |
Thu, 24 March 2022 10:21 By: Eclipse User  |
Epsilon Workflow Depends on Apache Ant plugin Unsafe design for Ant tasks By: Eclipse User on Thu, 17 March 2022 |
9687 |
Wed, 23 March 2022 18:23 By: Eclipse User  |
Logging from within EOL Feature request and architecture discussion By: Eclipse User on Fri, 18 March 2022 |
8850 |
Wed, 23 March 2022 05:54 By: Eclipse User  |
EVL : How to apply fixes in correct order? By: Eclipse User on Sat, 26 February 2022 |
3300 |
Wed, 23 March 2022 05:06 By: Eclipse User  |
Dynamically loading a metamodel in EOL By: Eclipse User on Mon, 21 March 2022 |
2099 |
Mon, 21 March 2022 07:43 By: Eclipse User  |
Creating a DataType Instance in ETL By: Eclipse User on Tue, 08 March 2022 |
5096 |
Mon, 14 March 2022 21:33 By: Eclipse User  |
Epsilon languages as specification language By: Eclipse User on Tue, 08 March 2022 |
3501 |
Wed, 09 March 2022 07:46 By: Eclipse User  |
EGL bulk insert EGL bulk insert By: Eclipse User on Thu, 24 February 2022 |
2335 |
Fri, 25 February 2022 04:22 By: Eclipse User  |
Issue with Epsilon on Eclipse 2021-12 Failed to create the part's controls By: Eclipse User on Mon, 21 February 2022 |
2426 |
Tue, 22 February 2022 07:22 By: Eclipse User  |
Map initialization Syntax for initializing a map with key/value pairs By: Eclipse User on Mon, 21 February 2022 |
3106 |
Mon, 21 February 2022 07:48 By: Eclipse User  |
epsilon.emf.loadRegisteredMetamodel has no effect in Antrunner By: Eclipse User on Thu, 17 February 2022 |
3145 |
Thu, 17 February 2022 19:08 By: Eclipse User  |
how to insert datetime in target file's name in EGX By: Eclipse User on Thu, 20 January 2022 |
2212 |
Thu, 20 January 2022 15:11 By: Eclipse User  |
Unexpected modification of the input model The input model is modified by a model to text transformation By: Eclipse User on Wed, 12 January 2022 |
1836 |
Wed, 12 January 2022 04:49 By: Eclipse User  |
how to declare index variables in EOL By: Eclipse User on Mon, 10 January 2022 |
2245 |
Tue, 11 January 2022 04:05 By: Eclipse User  |
Java Lifting with EMC-JDT toolchain to create Java Library API adapters By: Eclipse User on Wed, 08 December 2021 |
1882 |
Wed, 08 December 2021 15:52 By: Eclipse User  |
Loading a WSDL file with type information EOL workflow and EMF type information By: Eclipse User on Sun, 28 November 2021 |
3897 |
Mon, 29 November 2021 00:13 By: Eclipse User  |
Load HUTN as ecore model By: Eclipse User on Fri, 08 October 2021 |
63492 |
Mon, 15 November 2021 06:43 By: Eclipse User  |
EGL undesirable trim on return template operations By: Eclipse User on Mon, 01 November 2021 |
4884 |
Fri, 12 November 2021 19:41 By: Eclipse User  |
Flock reordering items when using opposite references in EMF By: Eclipse User on Wed, 03 November 2021 |
1582 |
Wed, 03 November 2021 08:48 By: Eclipse User  |
Ecore/EVL check component is instantiated By: Eclipse User on Tue, 02 November 2021 |
2265 |
Tue, 02 November 2021 12:50 By: Eclipse User  |
ETL Transformations: Types Not Found When perfoming transformations on UML Sequence Diagrams, the program does not recognize the types present in the UML metamodel By: Eclipse User on Thu, 14 October 2021 |
2572 |
Tue, 19 October 2021 12:06 By: Eclipse User  |
Xtext Graphical View By: Eclipse User on Mon, 08 April 2013 |
53 |
30779 |
Tue, 19 October 2021 10:27 By: Eclipse User  |
P2: Building on Epsilon Components Reusing the Epsilon artifacts as inclusions By: Eclipse User on Sun, 10 October 2021 |
1771 |
Mon, 11 October 2021 14:39 By: Eclipse User  |
Transform multiple elements in one By: Eclipse User on Mon, 30 August 2021 |
3287 |
Fri, 17 September 2021 10:46 By: Eclipse User  |
Mapping model for transformation with Epsilon By: Eclipse User on Wed, 08 September 2021 |
1320 |
Wed, 08 September 2021 10:46 By: Eclipse User  |
Generating plugins with dependent models using Eugenia By: Eclipse User on Mon, 06 September 2021 |
1961 |
Tue, 07 September 2021 04:59 By: Eclipse User  |
Passing ant properties to Eugenia polishing transformation Creating model instance programmatically By: Eclipse User on Sun, 05 September 2021 |
2049 |
Mon, 06 September 2021 02:04 By: Eclipse User  |
Generating Hostable Picto Views/Server Use CI/CD visualization with Epsilon By: Eclipse User on Thu, 02 September 2021 |
2174 |
Sun, 05 September 2021 21:48 By: Eclipse User  |
Loading model with multiple resources Loading model with multiple resources By: Eclipse User on Wed, 25 August 2021 |
3648 |
Wed, 01 September 2021 05:15 By: Eclipse User  |
Materialize Ecore metamodel from registry Using the model registry as a file source By: Eclipse User on Sun, 29 August 2021 |
1432 |
Sun, 29 August 2021 20:07 By: Eclipse User  |
Artficial start for workbench By: Eclipse User on Fri, 20 August 2021 |
2658 |
Wed, 25 August 2021 05:54 By: Eclipse User  |
Missing ContentTypes.dtd in maven repository Missing ContentTypes.dtd in maven repository By: Eclipse User on Mon, 23 August 2021 |
1656 |
Mon, 23 August 2021 12:34 By: Eclipse User  |
Eugenia Ant Task does not generate Model Project Ant generator task cannot be used in CI By: Eclipse User on Fri, 20 August 2021 |
1554 |
Fri, 20 August 2021 07:06 By: Eclipse User  |
Cannot set the JDK compliance level in polishing transformation Eugenia task polishing step cannot access literals via String lookup By: Eclipse User on Fri, 20 August 2021 |
1511 |
Fri, 20 August 2021 01:44 By: Eclipse User  |
Using external querying language Using external querying language By: Eclipse User on Thu, 19 August 2021 |
1409 |
Thu, 19 August 2021 13:41 By: Eclipse User  |
Implicit edges in Control Flow Graph M2M transformation - Create nodes and edges from CFG By: Eclipse User on Fri, 13 August 2021 |
2401 |
Wed, 18 August 2021 09:55 By: Eclipse User  |
[EGL/EGX + Maven] By: Eclipse User on Mon, 16 August 2021 |
1823 |
Tue, 17 August 2021 02:50 By: Eclipse User  |
EOL Formatter Quality of Merges of EOL language artifacts By: Eclipse User on Mon, 16 August 2021 |
1588 |
Tue, 17 August 2021 01:49 By: Eclipse User  |
How to compare two models to find the difference between them?? By: Eclipse User on Thu, 12 August 2021 |
2453 |
Sat, 14 August 2021 14:00 By: Eclipse User  |
How to keep the EUnit test running to find all failures at on time and show what are those failures? By: Eclipse User on Mon, 26 July 2021 |
4404 |
Sat, 14 August 2021 13:59 By: Eclipse User  |
Microsoft Excel sheets in Epsilon Microsoft Excel sheets doesnt show up under Models for running EOL queries By: Eclipse User on Mon, 04 January 2021 |
4395 |
Wed, 04 August 2021 09:02 By: Eclipse User  |
How to configure the project when I try to run the EUnit test by JAVA on linux command line? By: Eclipse User on Wed, 04 August 2021 |
1646 |
Wed, 04 August 2021 03:08 By: Eclipse User  |
Load second UML model with ANT By: Eclipse User on Tue, 01 March 2016 |
5519 |
Mon, 02 August 2021 05:31 By: Eclipse User  |
Model Validation from Java Code Unexpected errors when running validations (EVL) from Java Code instead of Ant (build.xml) By: Eclipse User on Fri, 30 July 2021 |
2068 |
Mon, 02 August 2021 05:26 By: Eclipse User  |
Adapting IModel to reveal EMF Reusing the Epsilon repository with EMF By: Eclipse User on Fri, 23 July 2021 |
2041 |
Sat, 24 July 2021 03:49 By: Eclipse User  |
Compatibility issue between Epsilon and RoboTool By: Eclipse User on Fri, 23 July 2021 |
1960 |
Sat, 24 July 2021 03:48 By: Eclipse User  |
Classloading in Workflow Ant Tasks Workflow tasks possibly cannot be used with classes on plugin class loader By: Eclipse User on Fri, 23 July 2021 |
1647 |
Fri, 23 July 2021 05:00 By: Eclipse User  |
How to get the information of all failures when running the EUnit test? By: Eclipse User on Wed, 21 July 2021 |
2296 |
Fri, 23 July 2021 02:06 By: Eclipse User  |
How to run eunit for etl on linux By: Eclipse User on Fri, 16 July 2021 |
2218 |
Wed, 21 July 2021 08:16 By: Eclipse User  |
Is it possible to generate a set of files using EGL/EGX? By: Eclipse User on Wed, 21 July 2021 |
2381 |
Wed, 21 July 2021 05:59 By: Eclipse User  |
[ETL] Accessing specific output of a transformation rule Is it possible to use .equivalent() in a similar kind of way as ATL's resolveTemp() By: Eclipse User on Mon, 12 July 2021 |
2973 |
Thu, 15 July 2021 04:17 By: Eclipse User  |
Element shown twice in target metamodel By: Eclipse User on Fri, 02 July 2021 |
2262 |
Fri, 09 July 2021 00:33 By: Eclipse User  |
How to validate only part of model How to validate only part of model By: Eclipse User on Wed, 30 June 2021 |
4002 |
Thu, 08 July 2021 07:25 By: Eclipse User  |
Multiple object type assignment to one object type By: Eclipse User on Fri, 02 July 2021 |
1701 |
Sat, 03 July 2021 04:34 By: Eclipse User  |
One source multiple targets By: Eclipse User on Sun, 13 June 2021 |
5622 |
Fri, 02 July 2021 05:47 By: Eclipse User  |
Awesome MDE GitHub repo - help needed By: Eclipse User on Thu, 01 July 2021 |
1920 |
Fri, 02 July 2021 02:54 By: Eclipse User  |
Traceability By: Eclipse User on Wed, 16 June 2021 |
1278 |
Wed, 16 June 2021 07:33 By: Eclipse User  |
How to use the collection() method? By: Eclipse User on Mon, 14 June 2021 |
1501 |
Tue, 15 June 2021 01:00 By: Eclipse User  |
Mapping of abstract types By: Eclipse User on Fri, 04 June 2021 |
23 |
5894 |
Tue, 15 June 2021 00:56 By: Eclipse User  |
Empty placeholders instead of required values. By: Eclipse User on Sun, 13 June 2021 |
1562 |
Mon, 14 June 2021 01:27 By: Eclipse User  |
Accessing Model Repository Data Persistency of and access to EOL-managed data By: Eclipse User on Tue, 08 June 2021 |
3322 |
Fri, 11 June 2021 02:46 By: Eclipse User  |
Maximum amount of sheets allowable by epsilon By: Eclipse User on Thu, 10 June 2021 |
2302 |
Fri, 11 June 2021 02:05 By: Eclipse User  |
Epsilon Workflow Casting Issue By: Eclipse User on Mon, 30 March 2020 |
3373 |
Tue, 08 June 2021 18:56 By: Eclipse User  |
Extracting metamodel from ETL How to extract target metamodel from ETL By: Eclipse User on Mon, 07 June 2021 |
1439 |
Tue, 08 June 2021 06:07 By: Eclipse User  |
Embedding EOL using xtext in a Sirius VSM By: Eclipse User on Thu, 03 June 2021 |
1536 |
Thu, 03 June 2021 23:44 By: Eclipse User  |
Epsilon in Papyrus RT RCP By: Eclipse User on Tue, 25 May 2021 |
1620 |
Tue, 25 May 2021 10:03 By: Eclipse User  |
EOL By: Eclipse User on Thu, 07 March 2013 |
4455 |
Sat, 22 May 2021 03:15 By: Eclipse User  |
[Evl] Eclipse MessageDialog Errors Suppress error dialogs By: Eclipse User on Thu, 13 May 2021 |
1920 |
Thu, 13 May 2021 07:48 By: Eclipse User  |
Epsilon ETL - Ecore2Ecore full copy By: Eclipse User on Tue, 04 May 2021 |
1979 |
Thu, 06 May 2021 05:57 By: Eclipse User  |
Exporting ECL Traces in Ant Tasks By: Eclipse User on Sat, 01 May 2021 |
2811 |
Mon, 03 May 2021 09:08 By: Eclipse User  |
Model to text transformations By: Eclipse User on Mon, 26 April 2021 |
1637 |
Mon, 26 April 2021 15:17 By: Eclipse User  |
Setting IUserInput from Workflow Adapting ant input management to EOL By: Eclipse User on Tue, 09 March 2021 |
3150 |
Mon, 26 April 2021 15:08 By: Eclipse User  |
etl in multithreaded standalone application By: Eclipse User on Fri, 16 April 2021 |
1708 |
Sat, 17 April 2021 11:02 By: Eclipse User  |
EUnit Examples By: Eclipse User on Thu, 15 April 2021 |
1501 |
Fri, 16 April 2021 10:28 By: Eclipse User  |
Check in selenium java code is not working By: Eclipse User on Fri, 19 June 2020 |
2406 |
Fri, 16 April 2021 09:01 By: Eclipse User  |
Read-only Access to Epsilon source code How to create a patch feature By: Eclipse User on Thu, 08 April 2021 |
1546 |
Thu, 08 April 2021 01:13 By: Eclipse User  |
Suppressing or Redirecting Stacktraces from Workflow By: Eclipse User on Tue, 30 March 2021 |
1900 |
Wed, 07 April 2021 04:34 By: Eclipse User  |
Junit eunit example - test with resource models By: Eclipse User on Tue, 09 March 2021 |
2904 |
Fri, 26 March 2021 09:50 By: Eclipse User  |
Load Hutn file programmatically By: Eclipse User on Wed, 24 March 2021 |
2336 |
Thu, 25 March 2021 05:08 By: Eclipse User  |
Broken link in Epsilon Hutn documentation By: Eclipse User on Tue, 23 March 2021 |
1370 |
Tue, 23 March 2021 05:49 By: Eclipse User  |
No Matching Comparator error while using Eunit through Gradle By: Eclipse User on Mon, 15 March 2021 |
2652 |
Sat, 20 March 2021 11:30 By: Eclipse User  |
Persisting Model repository over the boundary of the ant run workflow shows poor performance if used in loops By: Eclipse User on Wed, 03 March 2021 |
2352 |
Sun, 14 March 2021 04:49 By: Eclipse User  |
Running EGX headless Coordinating a templating process from ant By: Eclipse User on Wed, 10 March 2021 |
1430 |
Wed, 10 March 2021 18:54 By: Eclipse User  |
Want to know the future scope ETL Testing Question Regarding ETL Testing By: Eclipse User on Tue, 09 March 2021 |
1469 |
Tue, 09 March 2021 16:08 By: Eclipse User  |
Picto Layers By: Eclipse User on Fri, 05 March 2021 |
2158 |
Sun, 07 March 2021 11:30 By: Eclipse User  |
Mylyn Driver By: Eclipse User on Fri, 05 March 2021 |
1334 |
Fri, 05 March 2021 06:37 By: Eclipse User  |
Problem using append in EGX By: Eclipse User on Wed, 03 March 2021 |
2204 |
Thu, 04 March 2021 21:43 By: Eclipse User  |
Code generation By: Eclipse User on Wed, 13 February 2013 |
5089 |
Mon, 01 March 2021 14:00 By: Eclipse User  |
Xtext integration with GMF By: Eclipse User on Wed, 24 February 2021 |
1713 |
Wed, 24 February 2021 13:53 By: Eclipse User  |
accessing runtime models with reflection By: Eclipse User on Thu, 21 January 2021 |
2521 |
Sat, 20 February 2021 09:10 By: Eclipse User  |
Using reflection By: Eclipse User on Wed, 22 January 2020 |
341499 |
Thu, 18 February 2021 16:37 By: Eclipse User  |
[ETL]Creating xmi file from ETL transformation output file(.model) [ETL]Creating xmi file from ETL transformation output file(.model) By: Eclipse User on Tue, 07 July 2015 |
3562 |
Wed, 17 February 2021 11:03 By: Eclipse User  |
EOL-native model instance creation EOL model creation M2 By: Eclipse User on Mon, 15 February 2021 |
1547 |
Tue, 16 February 2021 03:17 By: Eclipse User  |
Control-flow Feedback to Ant from Epsilon Advanced Workflow for Epsilon By: Eclipse User on Wed, 10 February 2021 |
2428 |
Thu, 11 February 2021 17:50 By: Eclipse User  |
Validating Excel using Epsilon Java API By: Eclipse User on Wed, 03 February 2021 |
3922 |
Sat, 06 February 2021 04:46 By: Eclipse User  |
Simulink Requirements By: Eclipse User on Mon, 01 February 2021 |
1542 |
Mon, 01 February 2021 08:30 By: Eclipse User  |
Running Epsilon Server-Side Epsilon embedded in OSGI server By: Eclipse User on Sun, 24 January 2021 |
1690 |
Mon, 25 January 2021 03:49 By: Eclipse User  |
