Announcement: FORUM MOVED TO GITHUB FORUM MOVED TO https://github.com/eclipse/windowbuilder/discussions By: Eclipse User on Sat, 09 October 2021 |
4349 |
Sat, 09 October 2021 09:52 By: Eclipse User  |
Announcement: DOWNLOAD AREA REORGANIZED By: Eclipse User on Thu, 13 September 2018 |
8675 |
Mon, 01 October 2018 09:35 By: Eclipse User  |
Jframe and its components are resizing Jframe and its components are resizing By: Eclipse User on Mon, 05 December 2022 |
3341 |
Mon, 05 December 2022 03:33 By: Eclipse User  |
Poll: WindowBuilder eclipse WindowBuilder "unknown GUI toolkit" By: Eclipse User on Sun, 04 December 2022 |
3817 |
Sun, 04 December 2022 10:23 By: Eclipse User  |
Windows builder Drag and Drop i can not drag and drop components tree. By: Eclipse User on Mon, 23 May 2022 |
3971 |
Mon, 23 May 2022 17:35 By: Eclipse User  |
Window builder fails to install Tried to install window builder 1.9.7, it fails to install By: Eclipse User on Sun, 09 January 2022 |
4559 |
Sun, 09 January 2022 00:32 By: Eclipse User  |
Extending Swing Class - View Properties Does WindowBuilder understand properties for Extended Class By: Eclipse User on Sat, 02 October 2021 |
28686 |
Sat, 09 October 2021 10:09 By: Eclipse User  |
Eclipse Marketplace install options (versions) WindowBuilder from MarketPlace By: Eclipse User on Sat, 02 October 2021 |
28429 |
Sat, 09 October 2021 09:46 By: Eclipse User  |
Design tab disappear when importing project JFrame Solved By: Eclipse User on Mon, 04 October 2021 |
28303 |
Mon, 04 October 2021 19:46 By: Eclipse User  |
Eclipse Preferences - WindowBuilder - LookandFeel Trying to set default look and feel results in beach ball on macOS By: Eclipse User on Sat, 02 October 2021 |
27827 |
Sat, 02 October 2021 08:41 By: Eclipse User  |
error with new version WindowBuilder switching to design tab i updated to windowbuilder 1.9.7 and now opening a form page in designer gives an error By: Eclipse User on Sun, 15 August 2021 |
3278 |
Mon, 16 August 2021 00:58 By: Eclipse User  |
Extended JPanel background/foreground properties blank dropdown instead of color chooser WindowBuilder setting extended class properties By: Eclipse User on Sun, 07 June 2020 |
6509 |
Mon, 09 August 2021 11:11 By: Eclipse User  |
[Resolved] Palette is empty Swing class palette is empty. By: Eclipse User on Thu, 29 July 2021 |
3900 |
Mon, 02 August 2021 04:06 By: Eclipse User  |
Component field without value By: Eclipse User on Fri, 02 July 2021 |
2652 |
Fri, 02 July 2021 10:06 By: Eclipse User  |
[RESOLVED]Photon Windowbuilder palette empty Photon seems to behave differently from Oxygen By: Eclipse User on Mon, 19 February 2018 |
13066 |
Thu, 17 June 2021 02:35 By: Eclipse User  |
Eclipse windows builder design's components disappear My Eclipse windows builder design's components disappear By: Eclipse User on Tue, 25 May 2021 |
3679 |
Sun, 30 May 2021 10:43 By: Eclipse User  |
windowbuilder palette component is empty By: Eclipse User on Sat, 08 May 2021 |
4612 |
Sun, 16 May 2021 05:51 By: Eclipse User  |
Components and Pallete are empty WindowBuilder design view has failed By: Eclipse User on Thu, 08 April 2021 |
2864 |
Sun, 16 May 2021 04:18 By: Eclipse User  |
Window Builder no me muestra ni los componentes ni sus propiedades problemas para usar window builder By: Eclipse User on Sun, 11 April 2021 |
6672 |
Wed, 05 May 2021 15:14 By: Eclipse User  |
Application Window and JFrame By: Eclipse User on Mon, 03 May 2021 |
5720 |
Mon, 03 May 2021 15:58 By: Eclipse User  |
Help understanding WindowBuilder Log WindowBuilder Hangs during view of JFrame By: Eclipse User on Sun, 25 April 2021 |
1553 |
Sun, 25 April 2021 13:22 By: Eclipse User  |
WindowBuilder Update 1.9.5 202102231114 Failing Eclipse Update of WindowBuilder Pro Errors By: Eclipse User on Thu, 25 February 2021 |
2936 |
Mon, 15 March 2021 05:53 By: Eclipse User  |
jrt-fs.jar problem with new install Failed to init ct.sym for ... jrt-fs.jar By: Eclipse User on Fri, 13 November 2020 |
13070 |
Mon, 22 February 2021 12:59 By: Eclipse User  |
Design Tab Not Showing Anything Design Tab has all the little boxes but with nothing in them By: Eclipse User on Sun, 29 April 2018 |
70417 |
Thu, 18 February 2021 12:55 By: Eclipse User  |
Locked Components moving Windowbuilder By: Eclipse User on Thu, 18 February 2021 |
2499 |
Thu, 18 February 2021 02:40 By: Eclipse User  |
Control handles offset from controls in WindowBuilder Adding controls to a window places the control away from its handles By: Eclipse User on Sat, 06 February 2021 |
1865 |
Sat, 06 February 2021 21:20 By: Eclipse User  |
Newly installed 2020/12 for Java - WindowBuilder not working I cannot create a GUI with 2020/12 for Java developers By: Eclipse User on Wed, 03 February 2021 |
3508 |
Fri, 05 February 2021 06:20 By: Eclipse User  |
What java tool does Window Maker use for Properties? What can I used for mixes text, checkboxes, color chooser, etc By: Eclipse User on Sun, 31 January 2021 |
6134 |
Sun, 31 January 2021 17:45 By: Eclipse User  |
Window Builder. HELP ME! Window Builder. HELP ME! By: Eclipse User on Fri, 08 January 2021 |
3978 |
Sun, 10 January 2021 00:12 By: Eclipse User  |
Ubuntu/Linux Drag and Drop problem in Window Builder Components are positioned outside the Window and not added the Content Pane By: Eclipse User on Mon, 04 January 2021 |
3337 |
Mon, 04 January 2021 16:18 By: Eclipse User  |
Window Builder Window wont work By: Eclipse User on Wed, 02 December 2020 |
3532 |
Wed, 02 December 2020 15:56 By: Eclipse User  |
WB added org.eclipse.wb.swt.SWTResourceManager.java SOURCE to my project? By: Eclipse User on Fri, 06 November 2020 |
1994 |
Sun, 08 November 2020 09:52 By: Eclipse User  |
WindowBuilder in Eclipse Java Oxygen By: Eclipse User on Wed, 19 July 2017 |
23687 |
Wed, 28 October 2020 10:14 By: Eclipse User  |
Working example for two way databinding By: Eclipse User on Sun, 25 October 2020 |
1678 |
Sun, 25 October 2020 06:11 By: Eclipse User  |
Eclipse crash when using Window Builder By: Eclipse User on Mon, 14 October 2019 |
14114 |
Sat, 03 October 2020 13:52 By: Eclipse User  |
WindowBuilder 1.9.2 MacOS Toolbar Issue Difficult to see toolbar with Eclipse 2019.06 and WB 1.9.2 By: Eclipse User on Thu, 18 July 2019 |
25922 |
Wed, 23 September 2020 01:54 By: Eclipse User  |
Windowbuilder does not with Eclipse 4.17 Unhandled event loop exception By: Eclipse User on Wed, 16 September 2020 |
3093 |
Wed, 16 September 2020 12:07 By: Eclipse User  |
WindowBuilder Mac Crash WindowBuilder Mac Crash By: Eclipse User on Mon, 07 September 2020 |
2300 |
Mon, 07 September 2020 09:20 By: Eclipse User  |
Custom component public property not shown in property pane WindowBuilder setting extended class properties By: Eclipse User on Mon, 27 July 2020 |
2879 |
Wed, 29 July 2020 19:50 By: Eclipse User  |
Databinding uses Deprecated WidgetProperties class By: Eclipse User on Tue, 21 July 2020 |
2847 |
Tue, 21 July 2020 13:59 By: Eclipse User  |
Properties editor problem Extends JButton and can't set the properties for new Object By: Eclipse User on Sun, 24 May 2020 |
2939 |
Sun, 24 May 2020 19:14 By: Eclipse User  |
Classpath for custom components ClassNotFoundException for custom JPanel subclass in the same project By: Eclipse User on Mon, 18 May 2020 |
2653 |
Tue, 19 May 2020 04:54 By: Eclipse User  |
WindowBuilder Bean Properties Table Displays Getter Method for Custom Swing Component By: Eclipse User on Tue, 19 May 2020 |
2448 |
Tue, 19 May 2020 04:46 By: Eclipse User  |
Installed WindowBuilder but not showing up By: Eclipse User on Wed, 05 October 2016 |
17717 |
Fri, 08 May 2020 21:57 By: Eclipse User  |
Automated UI tests with WindowBuilder By: Eclipse User on Wed, 22 April 2020 |
4946 |
Wed, 22 April 2020 10:22 By: Eclipse User  |
Help with WindowBuilder By: Eclipse User on Mon, 17 June 2019 |
12932 |
Thu, 16 April 2020 10:52 By: Eclipse User  |
WindowBuilder encountered unexpected internal error. java.lang.Error: Unable to open file /resources/1.8/org/eclipse/wb/swing/FocusTraversalOnArray.java from org.eclipse.wb.swing By: Eclipse User on Tue, 24 March 2020 |
3809 |
Tue, 24 March 2020 13:24 By: Eclipse User  |
WB install error By: Eclipse User on Sat, 27 July 2019 |
2495 |
Sun, 23 February 2020 09:02 By: Eclipse User  |
Annoying graphic bug on Ubuntu graphic bug on Ubuntu By: Eclipse User on Mon, 02 December 2019 |
7970 |
Sun, 23 February 2020 08:53 By: Eclipse User  |
Window Builder Crashes, but code still runs fine By: Eclipse User on Tue, 18 February 2020 |
5021 |
Sun, 23 February 2020 08:44 By: Eclipse User  |
WindowBuilder Pro: Delete window configuration By: Eclipse User on Mon, 18 November 2019 |
4320 |
Thu, 12 December 2019 06:47 By: Eclipse User  |
WindowBuilder encountered unexpected internal error WindowBuilder encountered unexpected internal error. This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc. java.lang.NoClassDefFoundError: org/e By: Eclipse User on Tue, 02 April 2013 |
47563 |
Thu, 07 November 2019 06:59 By: Eclipse User  |
Palette is empty When opening .java file with WindowBuilder, design palette is empty By: Eclipse User on Sun, 08 September 2019 |
22904 |
Mon, 30 September 2019 21:47 By: Eclipse User  |
Update To 1.9.2 An error occurred while installing the items By: Eclipse User on Wed, 12 June 2019 |
6439 |
Thu, 13 June 2019 02:03 By: Eclipse User  |
Preference page initialize error Formlayout preference page fails By: Eclipse User on Sun, 09 June 2019 |
3907 |
Mon, 10 June 2019 04:51 By: Eclipse User  |
ContenPane smaller than JFrame By: Eclipse User on Tue, 04 June 2019 |
6408 |
Thu, 06 June 2019 13:03 By: Eclipse User  |
How to useJFileChooser with WindowBuilder JFileChooser with WindowBuilder By: Eclipse User on Wed, 01 May 2019 |
11398 |
Sat, 11 May 2019 09:39 By: Eclipse User  |
JFrame not displaying for a user. By: Eclipse User on Tue, 02 February 2016 |
12921 |
Sat, 20 April 2019 10:41 By: Eclipse User  |
Workaround for WindowBuilder Problems? WindowBuilder crashes due to JComboBox & sqLite interactions By: Eclipse User on Sat, 05 May 2018 |
8389 |
Wed, 17 April 2019 02:01 By: Eclipse User  |
Gremlins breed rapidly Unexpected compilation problems/operation problems because I get non-printing characters, e.g., EOT, into java files somehow and need to get rid of them By: Eclipse User on Wed, 17 April 2019 |
42242 |
Wed, 17 April 2019 01:54 By: Eclipse User  |
Window Builder contents don't load By: Eclipse User on Thu, 21 March 2019 |
5668 |
Tue, 26 March 2019 13:58 By: Eclipse User  |
Custom component with extra features By: Eclipse User on Wed, 13 March 2019 |
11126 |
Sun, 17 March 2019 13:49 By: Eclipse User  |
Support for EMF Edit Properties? By: Eclipse User on Mon, 15 February 2016 |
7594 |
Wed, 26 December 2018 16:25 By: Eclipse User  |
JavaBean Customizer Write to Workspace Log By: Eclipse User on Tue, 11 December 2018 |
3255 |
Tue, 11 December 2018 12:47 By: Eclipse User  |
Weird design preview in WindowBuilder - ContentPane larger than Jframe After creating a new Jframe with Windowbuilder, contentPane doesnt seem to fit in Jframe By: Eclipse User on Sat, 01 December 2018 |
2866 |
Mon, 03 December 2018 12:44 By: Eclipse User  |
pallete empty swt designer By: Eclipse User on Sun, 21 October 2018 |
5702 |
Fri, 23 November 2018 11:10 By: Eclipse User  |
Databinding Swing beansbinding-1.2.1.jar JTextField not 100% working By: Eclipse User on Mon, 29 October 2018 |
4109 |
Tue, 30 October 2018 09:03 By: Eclipse User  |
Incompatible Java Version for WindowBuilder By: Eclipse User on Sun, 15 July 2018 |
15378 |
Thu, 18 October 2018 14:28 By: Eclipse User  |
hello. Unable to connect to repository... trying to install windowbuilder I am trying to install windowbuilder and am unable to connect to repositories / websites with eclipse By: Eclipse User on Fri, 12 October 2018 |
2941 |
Sun, 14 October 2018 13:15 By: Eclipse User  |
Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405) Works in one workspace but not in other workspace By: Eclipse User on Wed, 03 October 2018 |
10992 |
Thu, 11 October 2018 04:15 By: Eclipse User  |
WindowBuilder reverse engineering Debug WindowBuilder with the aim to look its structure By: Eclipse User on Tue, 22 May 2018 |
3575 |
Wed, 10 October 2018 08:56 By: Eclipse User  |
Custom property editor Unable to add custom property editor using configurableEditor By: Eclipse User on Mon, 05 February 2018 |
5754 |
Wed, 19 September 2018 11:08 By: Eclipse User  |
Where to find Design Tab By: Eclipse User on Tue, 26 June 2018 |
23191 |
Wed, 19 September 2018 04:08 By: Eclipse User  |
where can i download Source code about WindowBuilder? where can i download Source code about WindowBuilder? By: Eclipse User on Tue, 15 May 2018 |
3597 |
Thu, 13 September 2018 08:41 By: Eclipse User  |
Design view won't work WindowBuilder design view won't seem to work By: Eclipse User on Sat, 11 August 2018 |
4368 |
Thu, 13 September 2018 05:30 By: Eclipse User  |
WindowBuilder Updates By: Eclipse User on Mon, 03 September 2018 |
5085 |
Thu, 13 September 2018 05:21 By: Eclipse User  |
Install fail from eclipse market, for eclipse4.8 Install fail from eclipse market, for eclipse4.8 By: Eclipse User on Mon, 10 September 2018 |
9899 |
Thu, 13 September 2018 05:02 By: Eclipse User  |
WindowBuilder Update Fail By: Eclipse User on Fri, 03 August 2018 |
4320 |
Sat, 04 August 2018 02:25 By: Eclipse User  |
manual download of Windowbuilder cant find link for manual download of Windowbuilder to Eclipse 4.8 By: Eclipse User on Wed, 20 June 2018 |
14374 |
Mon, 30 July 2018 13:20 By: Eclipse User  |
Eclipse is running under 0, but this Java project has a 9 Java Working with WindowsBuilder in Design Tab not possible, Message above By: Eclipse User on Fri, 27 April 2018 |
14773 |
Thu, 12 July 2018 22:10 By: Eclipse User  |
WindowBuilder Crashes WindowBuilder crashes on mac osx yosemite when trying to modify spinner model By: Eclipse User on Tue, 12 May 2015 |
4278 |
Sun, 24 June 2018 13:28 By: Eclipse User  |
WB not working in Linux and Windows 7 + Photon 4.8.0RC1 By: Eclipse User on Tue, 29 May 2018 |
38029 |
Tue, 19 June 2018 03:21 By: Eclipse User  |
Windowbuilder design tab problem By: Eclipse User on Fri, 05 February 2016 |
16278 |
Wed, 13 June 2018 16:27 By: Eclipse User  |
Method setColumnHeader(javax.swing.JViewport) not found in class javax.swing.JPanel I have looked on the web for solutions By: Eclipse User on Wed, 06 June 2018 |
2065 |
Wed, 06 June 2018 15:15 By: Eclipse User  |
Parser error WindowBuilder does not show anything By: Eclipse User on Fri, 01 June 2018 |
3065 |
Fri, 01 June 2018 10:52 By: Eclipse User  |
"Incompatible Java versions" Eclipse is running under 0, but this Java project has a 10 Java compliance level By: Eclipse User on Fri, 04 May 2018 |
23676 |
Wed, 23 May 2018 13:57 By: Eclipse User  |
macOS sierra: new a SWT/JFace project failed in Eclipse By: Eclipse User on Thu, 05 April 2018 |
7284 |
Wed, 23 May 2018 13:37 By: Eclipse User  |
No JFace ColorSelector Design view doesn't show JFace ColorSelector component By: Eclipse User on Wed, 11 April 2018 |
6226 |
Wed, 16 May 2018 14:55 By: Eclipse User  |
AHK Type GUI Send Keystrokes From GUI By: Eclipse User on Tue, 15 May 2018 |
4616 |
Tue, 15 May 2018 22:37 By: Eclipse User  |
Installing Window Builder Help Required By: Eclipse User on Wed, 28 March 2018 |
11873 |
Wed, 25 April 2018 09:12 By: Eclipse User  |
WindowBuilder Design is Updown Design is Updown By: Eclipse User on Sun, 07 January 2018 |
6249 |
Fri, 13 April 2018 13:30 By: Eclipse User  |
Invisible garbage chars in text input into Eclipse input errors By: Eclipse User on Wed, 04 April 2018 |
3838 |
Thu, 12 April 2018 15:32 By: Eclipse User  |
BugReport lambda EventHandler By: Eclipse User on Thu, 29 March 2018 |
3714 |
Wed, 04 April 2018 15:23 By: Eclipse User  |
Component Orientation Bug By: Eclipse User on Tue, 20 March 2018 |
5831 |
Tue, 27 March 2018 13:08 By: Eclipse User  |
Offline installer Neon or Oxygen By: Eclipse User on Thu, 22 March 2018 |
14912 |
Mon, 26 March 2018 06:22 By: Eclipse User  |
Windowbuilder in Eclipse Oxygen/Java SE-9? Having some events trouble By: Eclipse User on Sun, 11 March 2018 |
3782 |
Tue, 13 March 2018 14:55 By: Eclipse User  |
Unable to activate bundle windowbuilder unable to use windowbuilder By: Eclipse User on Sun, 11 March 2018 |
4857 |
Sun, 11 March 2018 14:03 By: Eclipse User  |
Eclipse Neon Freezes when adding components in windowBuilder design window When trying to add components to window design the eclipse freezes for 2 minutes By: Eclipse User on Tue, 27 September 2016 |
7344 |
Sat, 10 March 2018 09:14 By: Eclipse User  |
WindowBuilder design show shows frame incorrectly WindowBuilder Issue By: Eclipse User on Fri, 23 February 2018 |
5886 |
Fri, 23 February 2018 10:11 By: Eclipse User  |
Error in Designer using Observable Collections By: Eclipse User on Fri, 16 February 2018 |
3503 |
Fri, 16 February 2018 10:29 By: Eclipse User  |
Resize/Move Problems in Designer Unable to move/resize objects in designer. By: Eclipse User on Thu, 01 February 2018 |
25728 |
Wed, 07 February 2018 22:08 By: Eclipse User  |
WindowBuilder Mars 2 IDE for JAVA developpers Unable to set preferences By: Eclipse User on Fri, 26 January 2018 |
5866 |
Tue, 06 February 2018 04:11 By: Eclipse User  |
WindowBuilder 4.7 & java.beans.BeanInfo WindowBuilder ignores BeanInfo By: Eclipse User on Fri, 12 January 2018 |
4989 |
Sat, 27 January 2018 10:04 By: Eclipse User  |
WindowBuilder Offline Install By: Eclipse User on Tue, 23 January 2018 |
4727 |
Wed, 24 January 2018 06:38 By: Eclipse User  |
WindowBuilder in Eclipse Java Neon/Oxygen Using JTable with MAC By: Eclipse User on Fri, 12 January 2018 |
4131 |
Fri, 12 January 2018 12:34 By: Eclipse User  |
Components appearing as mirrored By: Eclipse User on Fri, 27 October 2017 |
7251 |
Fri, 12 January 2018 09:28 By: Eclipse User  |
What is current state of WindowBuilder? requirements, JRE support, etc for Windowbuilder? By: Eclipse User on Thu, 07 December 2017 |
4348 |
Fri, 08 December 2017 18:16 By: Eclipse User  |
Show another component in Design Mode Trouble showing a second frame of the class By: Eclipse User on Sun, 03 December 2017 |
4838 |
Sun, 03 December 2017 02:50 By: Eclipse User  |
Unhandled event loop exception with WindowBuilder Unhandled event loop exception with WindowBuilder By: Eclipse User on Tue, 28 November 2017 |
5919 |
Thu, 30 November 2017 17:25 By: Eclipse User  |
Preview Window Error Window Builder By: Eclipse User on Thu, 23 November 2017 |
3919 |
Thu, 23 November 2017 18:51 By: Eclipse User  |
someone to review and merge minor contributions to WindowBuilder ? By: Eclipse User on Fri, 10 November 2017 |
6145 |
Fri, 10 November 2017 04:58 By: Eclipse User  |
WindowBuilder Eclipse Preferences Swing Look&Feel Default Crash Eclipse Windowsbuilder Look&Feel Preferences crashes when setting Swing default By: Eclipse User on Sat, 04 November 2017 |
5560 |
Sat, 04 November 2017 12:40 By: Eclipse User  |
Unable to open file on WindowBuilder Error message By: Eclipse User on Sat, 21 October 2017 |
8378 |
Fri, 27 October 2017 01:06 By: Eclipse User  |
problem with creating a new visual classes By: Eclipse User on Mon, 23 October 2017 |
4590 |
Mon, 23 October 2017 13:24 By: Eclipse User  |
creating a palette for Editors which doesn't extends Composite in a XWT context By: Eclipse User on Wed, 11 October 2017 |
5214 |
Wed, 11 October 2017 04:46 By: Eclipse User  |
Need help about palette Contribution for custom Element By: Eclipse User on Fri, 06 October 2017 |
6469 |
Tue, 10 October 2017 09:36 By: Eclipse User  |
Fresh Eclipse Install and Window Builder Design tab crash New install simple test and crashes By: Eclipse User on Sun, 01 November 2015 |
8709 |
Tue, 29 August 2017 19:35 By: Eclipse User  |
WindowBuilder Pro Zip Installation Unable to perform Zip Installation of WindowBuilder Pro By: Eclipse User on Thu, 23 June 2011 |
25403 |
Mon, 12 June 2017 12:31 By: Eclipse User  |
Putting MasterDetailBlock on a FormPage By: Eclipse User on Thu, 08 June 2017 |
14857 |
Thu, 08 June 2017 03:33 By: Eclipse User  |
Eclipse Mars 4.5.1 & WB 1.8.0 not finding i18n strings in design view By: Eclipse User on Tue, 16 May 2017 |
12411 |
Wed, 24 May 2017 12:04 By: Eclipse User  |
Linux distros and the design view... Design view is totallying bugged. By: Eclipse User on Tue, 16 May 2017 |
15723 |
Tue, 16 May 2017 21:42 By: Eclipse User  |
Design mode bugged By: Eclipse User on Mon, 27 March 2017 |
8685 |
Tue, 16 May 2017 15:26 By: Eclipse User  |
WindowBuilder offline installation - Eclipse Neon Looking for offline installations file for windows builder on eclipse neon By: Eclipse User on Fri, 05 May 2017 |
10355 |
Mon, 08 May 2017 12:25 By: Eclipse User  |
Gridbaglayout unwanted columnWidths, rowHeights, etc... Unwanted code generated for GridBagLayout By: Eclipse User on Fri, 21 April 2017 |
32188 |
Fri, 21 April 2017 00:40 By: Eclipse User  |
WB not rendering/painting in IDE By: Eclipse User on Wed, 05 November 2014 |
19 |
24190 |
Mon, 10 April 2017 03:32 By: Eclipse User  |
Howto extend WindowBuild by custom editor for specific Swing client property. WindowBuild customization By: Eclipse User on Fri, 17 March 2017 |
5146 |
Fri, 17 March 2017 11:52 By: Eclipse User  |
class-Open With-WindowBuilder Editor, problem to open existing file By: Eclipse User on Sun, 12 February 2017 |
33363 |
Thu, 16 March 2017 21:39 By: Eclipse User  |
Someone can use Window Builder? By: Eclipse User on Mon, 23 January 2017 |
27543 |
Thu, 16 March 2017 20:49 By: Eclipse User  |
How to open windowBuilder with a parent custom class By: Eclipse User on Mon, 27 February 2017 |
10016 |
Sun, 05 March 2017 16:57 By: Eclipse User  |
Offer to help with project By: Eclipse User on Thu, 16 February 2017 |
21421 |
Thu, 23 February 2017 10:40 By: Eclipse User  |
Existing Eclipse project run on new version of Eclipse By: Eclipse User on Tue, 14 February 2017 |
3963 |
Tue, 14 February 2017 15:03 By: Eclipse User  |
Internal Error WindowBuilder encountered unexpected internal error. Internal Error WindowBuilder encountered unexpected internal error. By: Eclipse User on Mon, 13 February 2017 |
34116 |
Mon, 13 February 2017 06:22 By: Eclipse User  |
how to open design view from existing SWT application developed 2007 By: Eclipse User on Sun, 12 February 2017 |
28651 |
Sun, 12 February 2017 09:48 By: Eclipse User  |
WindowBuilder Designer shows mixed and disorderly with Neon2 By: Eclipse User on Thu, 12 January 2017 |
28237 |
Thu, 12 January 2017 07:13 By: Eclipse User  |
how to load design view for existing swing eclipse project written from scratch? By: Eclipse User on Tue, 30 August 2011 |
144030 |
Tue, 10 January 2017 20:20 By: Eclipse User  |
Update Site for 4.4 M1 Luna RCP Package By: Eclipse User on Fri, 30 August 2013 |
10770 |
Fri, 16 December 2016 18:16 By: Eclipse User  |
How to handle direct edit with setText method with 2 signatures actually it crashes By: Eclipse User on Fri, 02 December 2016 |
7728 |
Fri, 02 December 2016 05:52 By: Eclipse User  |
Internal error WindowBuilder By: Eclipse User on Mon, 21 November 2016 |
26866 |
Mon, 21 November 2016 08:48 By: Eclipse User  |
misplaced selection-frame for elements By: Eclipse User on Mon, 24 June 2013 |
10226 |
Sun, 20 November 2016 11:26 By: Eclipse User  |
Neon/WindowBuilder crashes By: Eclipse User on Tue, 20 September 2016 |
5996 |
Thu, 17 November 2016 16:36 By: Eclipse User  |
How can I find the window builder zip file archive for eclipse Helios version? Eclipse window builder plugins and their corresponding eclipse vereions path By: Eclipse User on Fri, 11 November 2016 |
5665 |
Mon, 14 November 2016 12:48 By: Eclipse User  |
Cannot Preview Custom Look And Feel in Eclipse Neon Window Builder Custom Look and Feel By: Eclipse User on Sun, 13 November 2016 |
57494 |
Sun, 13 November 2016 08:02 By: Eclipse User  |
Will subscription base will help windowbuilder not ? Will subscription base will help windowbuilder not ? By: Eclipse User on Fri, 30 September 2016 |
5831 |
Sun, 02 October 2016 20:57 By: Eclipse User  |
WindowBuilder- how to start in Eclipse Neon WindowBuilder- how to start in Eclipse Neon By: Eclipse User on Fri, 23 September 2016 |
3703 |
Fri, 23 September 2016 12:17 By: Eclipse User  |
Eclipse Neon crashes The eclipse crashes when I try to add a JButton to app By: Eclipse User on Thu, 08 September 2016 |
5835 |
Thu, 08 September 2016 08:39 By: Eclipse User  |
Adding another Source tab How can I add another Source tab? By: Eclipse User on Tue, 30 October 2012 |
29 |
17746 |
Thu, 25 August 2016 17:01 By: Eclipse User  |
Liclipse first install - design tab crashes Opening design page. Parsing... LiClipse crashes By: Eclipse User on Mon, 15 August 2016 |
7012 |
Mon, 15 August 2016 11:06 By: Eclipse User  |
Really need to Install old Instantiations window builder By: Eclipse User on Sat, 30 July 2016 |
3320 |
Sun, 31 July 2016 10:11 By: Eclipse User  |
Example on how to open up a custom setting window from one of the control property By: Eclipse User on Sun, 31 July 2016 |
4910 |
Sun, 31 July 2016 02:54 By: Eclipse User  |
Convert WindowBuilder to Tycho By: Eclipse User on Tue, 19 April 2016 |
13521 |
Sun, 31 July 2016 01:27 By: Eclipse User  |
Is there some WB 1.9.0 / Neon (4.6) integration developer preview By: Eclipse User on Sat, 16 April 2016 |
20833 |
Wed, 27 July 2016 21:48 By: Eclipse User  |
WindowBuilder DesignerException 1100 Design Tab crashes on JFrame runs and debugs ok By: Eclipse User on Mon, 25 July 2016 |
4778 |
Mon, 25 July 2016 18:42 By: Eclipse User  |
I have a problem installing Java WindowBuilder I have a problem installing Java WindowBuilder By: Eclipse User on Wed, 13 July 2016 |
12030 |
Sun, 24 July 2016 14:13 By: Eclipse User  |
Can't find SWT Designer on Eclipse Neon By: Eclipse User on Thu, 23 June 2016 |
32768 |
Fri, 22 July 2016 23:02 By: Eclipse User  |
Composite Size limit in Design view? By: Eclipse User on Tue, 12 July 2016 |
5648 |
Sat, 16 July 2016 20:30 By: Eclipse User  |
Cannot find entrance to WindowBuilder in Eclipse Luna 2 (4.4.2) on OS X Yosemite 10.10.5 SWT and WindowsBuilder are installed but not in Eclipse window By: Eclipse User on Mon, 11 July 2016 |
3429 |
Tue, 12 July 2016 18:59 By: Eclipse User  |
5164 |
Mon, 11 July 2016 22:21 By: Eclipse User  |
5268 |
Mon, 11 July 2016 22:18 By: Eclipse User  |
5080 |
Mon, 11 July 2016 22:16 By: Eclipse User  |
Parse Correctly when Eclipse first time open, Reparse fail with Exception Reparse fail every time! By: Eclipse User on Sat, 02 July 2016 |
4999 |
Sat, 02 July 2016 00:09 By: Eclipse User  |
Window Builder not working fine ubuntu Window Builder problems By: Eclipse User on Tue, 21 June 2016 |
5280 |
Tue, 21 June 2016 16:15 By: Eclipse User  |
Custom property editor SWT Custom property editor to design a plastic interface By: Eclipse User on Wed, 08 June 2016 |
6256 |
Wed, 08 June 2016 09:21 By: Eclipse User  |
Version for Mars 4.5.2 Installpage doesn't work By: Eclipse User on Tue, 07 June 2016 |
8273 |
Wed, 08 June 2016 07:41 By: Eclipse User  |
WindowBuilder Design view rendering issues Problems when working with the WindowBuilder By: Eclipse User on Wed, 27 April 2016 |
3906 |
Thu, 28 April 2016 10:20 By: Eclipse User  |
can't use GUI first WindowBuilder use By: Eclipse User on Tue, 19 April 2016 |
8243 |
Tue, 19 April 2016 05:35 By: Eclipse User  |
Error in opening windowsbuilder design interface I used windowbuilder drag and drop design menu for designing my swing application layout. But from few days when I click on design button in left corner of eclipse. It prompts error (shared below). I By: Eclipse User on Tue, 12 April 2016 |
6244 |
Sat, 16 April 2016 03:07 By: Eclipse User  |
Visual Class not working I cant create a new Visual Class By: Eclipse User on Sat, 09 April 2016 |
5982 |
Sun, 10 April 2016 13:28 By: Eclipse User  |
Can't use WindowBuilder in Eclipse 3.7 with Xming By: Eclipse User on Thu, 16 August 2012 |
6419 |
Thu, 24 March 2016 17:32 By: Eclipse User  |
Indigo repo keeps showing up By: Eclipse User on Tue, 22 March 2016 |
7176 |
Tue, 22 March 2016 22:31 By: Eclipse User  |
Where to find old WindowBuilder install? By: Eclipse User on Mon, 21 March 2016 |
5787 |
Tue, 22 March 2016 05:15 By: Eclipse User  |
Where to find old GWT Designer By: Eclipse User on Thu, 09 May 2013 |
7397 |
Mon, 21 March 2016 10:12 By: Eclipse User  |
Resolved bugs still unresolved? What to do when resolved bugs are still causing problems By: Eclipse User on Wed, 09 March 2016 |
17542 |
Wed, 16 March 2016 23:25 By: Eclipse User  |
Create BPMN2DiagramWizard avec jframe By: Eclipse User on Fri, 04 March 2016 |
5259 |
Sun, 06 March 2016 12:34 By: Eclipse User  |
Bug report Windowbuilder design view constantly errors By: Eclipse User on Sun, 28 February 2016 |
7926 |
Sat, 05 March 2016 21:48 By: Eclipse User  |
Subclasses of Swing Designer Wizards Subclasses of Swing Designer Wizards in window builder By: Eclipse User on Sun, 21 February 2016 |
8768 |
Sat, 05 March 2016 16:10 By: Eclipse User  |
JEP 223: New Version-String Scheme - Window Builder not working By: Eclipse User on Thu, 03 March 2016 |
9281 |
Thu, 03 March 2016 05:20 By: Eclipse User  |
Catch drop events into WB editor from other views How to extend the WB so that notficiations can be received on drop events By: Eclipse User on Mon, 21 May 2012 |
6787 |
Fri, 26 February 2016 10:10 By: Eclipse User  |
Design page crashed By: Eclipse User on Sat, 20 February 2016 |
7400 |
Fri, 26 February 2016 08:59 By: Eclipse User  |
No root methods found Error when using WindowBuilder in RAP Application By: Eclipse User on Sun, 10 January 2016 |
10641 |
Wed, 24 February 2016 09:47 By: Eclipse User  |
Windowbuilder does not work well New install Windowbuilder on Eclipse Luna and does not work correctly By: Eclipse User on Fri, 29 January 2016 |
6564 |
Fri, 29 January 2016 14:46 By: Eclipse User  |
WindowBuilder and EMF databinding Tutorial By: Eclipse User on Fri, 07 October 2011 |
15552 |
Sun, 24 January 2016 02:21 By: Eclipse User  |
Support for rollback/cancel-button for EMF data binding actions? By: Eclipse User on Thu, 21 January 2016 |
3073 |
Thu, 21 January 2016 10:33 By: Eclipse User  |
bug report - font disappear in the component tree By: Eclipse User on Fri, 07 August 2015 |
3944 |
Sun, 13 December 2015 09:05 By: Eclipse User  |
Which WindowBuilder wizards for plugin development ? By: Eclipse User on Fri, 11 December 2015 |
7159 |
Fri, 11 December 2015 07:19 By: Eclipse User  |
Unable to add child to ScrolledComposite By: Eclipse User on Sun, 25 October 2015 |
5654 |
Sun, 25 October 2015 20:03 By: Eclipse User  |
Windows Builder Install How to instal Windows Builder By: Eclipse User on Mon, 21 September 2015 |
7523 |
Tue, 22 September 2015 23:15 By: Eclipse User  |
Jpopup not opening when I try to open a new popup to edit, it gives me an error By: Eclipse User on Sat, 19 September 2015 |
3930 |
Tue, 22 September 2015 23:13 By: Eclipse User  |
cant open GUI swing designer view. By: Eclipse User on Tue, 01 September 2015 |
5732 |
Sat, 05 September 2015 21:01 By: Eclipse User  |
WindowBuilder for JavaFX By: Eclipse User on Fri, 21 August 2015 |
14244 |
Mon, 31 August 2015 13:50 By: Eclipse User  |
SWT Installation Error WindowBuilder couldn't start By: Eclipse User on Tue, 14 July 2015 |
9863 |
Wed, 19 August 2015 20:24 By: Eclipse User  |
Crashing WindowBuilder and I invisible structure in Eclipse Mars When I create a project of windowBuilder, Eclipse is stop By: Eclipse User on Sun, 19 July 2015 |
21373 |
Thu, 06 August 2015 15:38 By: Eclipse User  |
Internal error Windows Builder Design window crashes - java.lang.NullPointerException By: Eclipse User on Sat, 01 August 2015 |
4802 |
Wed, 05 August 2015 18:32 By: Eclipse User  |
Parse hand written code By: Eclipse User on Fri, 24 July 2015 |
5122 |
Mon, 03 August 2015 09:39 By: Eclipse User  |
WindowBuilder replacement product after it is obsolete By: Eclipse User on Mon, 20 July 2015 |
6148 |
Tue, 21 July 2015 12:26 By: Eclipse User  |
Run time update on Button name and Action of Button By: Eclipse User on Mon, 13 July 2015 |
3535 |
Tue, 14 July 2015 09:47 By: Eclipse User  |
Open dynamically JRadioButtons add JRadioButtons according to xml objects By: Eclipse User on Thu, 09 July 2015 |
3305 |
Thu, 09 July 2015 22:40 By: Eclipse User  |
How can I install WindowBuilder for Eclipse Mars? By: Eclipse User on Sat, 27 June 2015 |
48569 |
Mon, 29 June 2015 08:54 By: Eclipse User  |
WB Fails to render custom component with NoDefClassFoundException By: Eclipse User on Fri, 19 June 2015 |
3959 |
Tue, 23 June 2015 07:17 By: Eclipse User  |
WB causes Eclipse to hang after closing Preview window By: Eclipse User on Wed, 17 June 2015 |
4957 |
Thu, 18 June 2015 09:48 By: Eclipse User  |
Window Builder causes a copy of the project to run, and it will not close? Whenever I load my GUI into the WindowBuilder, it creates a "ghost" copy of the project that will not close. By: Eclipse User on Thu, 21 May 2015 |
7606 |
Tue, 02 June 2015 22:51 By: Eclipse User  |
