  Announcement:  Please use MoDisco Discussions
By: Eclipse Webmaster on Wed, 12 February 2025
0 13269 Wed, 12 February 2025 08:55
  Plans for java>7
By: Eclipse User on Tue, 02 April 2024
2 2545 Mon, 29 July 2024 01:54
  Java 8 compatibility for Eclipse 4.33 (2024-09) in MoDisco 1.5.5
By: Eclipse User on Mon, 29 July 2024
0 5596 Mon, 29 July 2024 01:49
  Drops and Updates are now Builds
By: Eclipse User on Fri, 08 March 2024
0 1404 Fri, 08 March 2024 14:18
  Register XMI without ECORE source
How to navigate through an XMI that is not made out of an ecore mmodel
By: Eclipse User on Mon, 23 April 2012
3 7838 Mon, 12 December 2022 13:59
  Running Modisco Headless
Reusing Modisco Tooling in CI/CD and DevOps
By: Eclipse User on Mon, 01 August 2022
2 2339 Mon, 01 August 2022 20:06
  MoDisco has OOMPH
By: Eclipse User on Sun, 17 October 2021
0 3612 Sun, 17 October 2021 03:28
  Can Modisco generate the calling relationship between methods?
By: Eclipse User on Fri, 20 August 2021
0 2786 Fri, 20 August 2021 09:28
  Static/initialization blocks in BlockUnit
BlockUnit, Static blocks initialization
By: Eclipse User on Sat, 05 September 2020
0 3316 Sat, 05 September 2020 02:37
  Problem in resolving cross-reference between kdm fragments and java models.
By: Eclipse User on Fri, 28 February 2020
1 2703 Sat, 29 February 2020 11:59
  Announcing MoDisco 1.5.0M3
By: Eclipse User on Wed, 27 November 2019
4 6022 Sun, 23 February 2020 04:07
  Converting Java to KDM for analysis
I am trying to generate KDM from Java souce
By: Eclipse User on Tue, 11 February 2020
1 2361 Wed, 12 February 2020 07:06
  MoDisco 1.5.1M2 amputations - UML2 and BIRT
By: Eclipse User on Wed, 15 January 2020
0 29450 Wed, 15 January 2020 06:09
  On the immediate future of the MoDisco project
By: Eclipse User on Thu, 03 October 2019
2 2789 Wed, 20 November 2019 14:33
  Extracting the parameters from (Calls)
extracing paramerets using Modisco
By: Eclipse User on Tue, 13 August 2019
2 5957 Thu, 22 August 2019 13:32
  Unable to get KDM Plugin installed
KDM installation
By: Eclipse User on Tue, 23 July 2019
0 24682 Tue, 23 July 2019 17:13
  Cast Errors in a Custom Metamodel
By: Eclipse User on Tue, 16 July 2019
2 7924 Sun, 21 July 2019 19:26
  Code Generation - Unresolved Reference in GenerateJava.emtl
By: Eclipse User on Wed, 05 June 2019
3 7030 Fri, 21 June 2019 10:36
  Metamodelo KDM
Referencing KDM metamodel (kdm.ecore) in top-level
By: Eclipse User on Thu, 20 June 2019
1 4698 Fri, 21 June 2019 10:34
  How to transform uml into java model ?
Inverted Simple Transformation Chain
By: Eclipse User on Sun, 05 May 2019
1 4671 Mon, 06 May 2019 04:34
  EMF Refactor & Modisco Java model
is it possible to using EMF Refactor with modisco java model ?!
By: Eclipse User on Fri, 03 May 2019
2 2670 Fri, 03 May 2019 11:49
  Problem with Java model to source code transformation
How to use modisco source code generation
By: Eclipse User on Fri, 15 March 2019
8 14072 Tue, 26 March 2019 09:21
  Generate Java code from a Java model
By: Eclipse User on Mon, 09 January 2012
12 21099 Fri, 15 March 2019 18:51
  Is it possible to generate Java code from a resource only loaded in memory?
MoDisco - Acceleo
By: Eclipse User on Sat, 09 February 2019
0 9533 Sat, 09 February 2019 02:17
  Every attribute is marked as public
By: Eclipse User on Fri, 08 June 2018
0 4319 Fri, 08 June 2018 17:58
  Feature type does not exist on MethodInvocation
By: Eclipse User on Thu, 07 June 2018
0 4217 Thu, 07 June 2018 01:54
  Java generation bug using MoDisco
By: Eclipse User on Tue, 05 June 2018
0 4482 Tue, 05 June 2018 12:44
0 4460 Tue, 05 June 2018 12:44
  C/C++ Discoverer
Looking for c/c++ discoverer
By: Eclipse User on Wed, 27 June 2012
7 11665 Sat, 10 March 2018 15:27
  java2kdm.atl
By: Eclipse User on Tue, 01 August 2017
5 11323 Fri, 20 October 2017 10:08
  The linenumber of Source-Code in KDM
Effort to implement this requeriment.
By: Eclipse User on Fri, 22 September 2017
0 14670 Fri, 22 September 2017 08:48
  Which versions of Java are supported?
By: Eclipse User on Thu, 31 August 2017
0 13199 Thu, 31 August 2017 12:30
  How did MoDisco generated the file java.ecore
By: Eclipse User on Wed, 21 June 2017
10 23999 Tue, 08 August 2017 08:32
  JDTVisitor Assignment Node
By: Eclipse User on Tue, 20 June 2017
0 11048 Tue, 20 June 2017 10:38
  Discoverer Not Appearing in UI (Discoverers list)
By: Eclipse User on Tue, 06 June 2017
1 5380 Tue, 06 June 2017 11:30
  Implement new Discover and Metamodel
By: Eclipse User on Sat, 20 May 2017
0 11669 Sat, 20 May 2017 13:52
  Transformation megamodel
Discover a high order transformation from a set of transformations
By: Eclipse User on Wed, 17 May 2017
4 9532 Fri, 19 May 2017 10:24
  how install the Method call Graph discovery of Modisco ?
By: Eclipse User on Sun, 23 April 2017
1 5967 Mon, 24 April 2017 10:52
  Discovery
By: Eclipse User on Mon, 10 April 2017
1 6721 Tue, 11 April 2017 07:51
  Return in methods
By: Eclipse User on Thu, 15 December 2016
1 3252 Fri, 16 December 2016 04:21
  How to perform an OCL query with Facet?
OCL query
By: Eclipse User on Wed, 23 November 2016
1 17047 Thu, 01 December 2016 04:37
icon4.gif JEE WebApp Metamodel No documentation !!!!
MoDisco, WebApp Metamodel
By: Eclipse User on Tue, 29 November 2016
2 5238 Wed, 30 November 2016 05:00
  How to convert Modisco Java model to Ecore Genmodel
Looking for a way to generate a quick test UI from existing Java model code.
By: Eclipse User on Sun, 13 November 2016
1 6598 Mon, 14 November 2016 05:29
  [QVTO] Adding a new StorableUnit to a KDM model with its type
KDM model transformation
By: Eclipse User on Thu, 22 September 2016
1 3421 Fri, 23 September 2016 00:23
  news.eclipse.org is shutting down.
By: Eclipse Webmaster on Wed, 31 August 2016
0 3121 Wed, 31 August 2016 14:44
icon9.gif Parsing JSP to KDM
How can I parse JSP pages to KDM using MoDisco
By: Eclipse User on Tue, 28 June 2016
1 3256 Wed, 29 June 2016 11:16
  From PowerBuilder to KDM
By: Eclipse User on Fri, 06 May 2016
3 6301 Mon, 23 May 2016 05:49
  get the main thread from java model
generate call graph from java model
By: Eclipse User on Tue, 10 May 2016
6 7910 Fri, 13 May 2016 09:30
  KDM to UML does not work
By: Eclipse User on Wed, 20 April 2016
3 8347 Tue, 26 April 2016 04:32
icon9.gif Some 'calls' are lost
By: Eclipse User on Wed, 13 April 2016
1 5339 Fri, 15 April 2016 04:12
  XML Discoverer - standalone
By: Eclipse User on Mon, 04 April 2016
0 6109 Mon, 04 April 2016 12:30
  Converting Java POJOs to EMF model
By: Eclipse User on Thu, 19 November 2015
6 6803 Fri, 11 December 2015 11:42
  AM3 project code whereabouts
looking for AM3 builds & source code
By: Eclipse User on Tue, 24 November 2015
3 4178 Thu, 26 November 2015 07:37
icon5.gif Support for Cobol (Copybook) ?
By: Eclipse User on Mon, 09 November 2015
4 5023 Mon, 09 November 2015 04:32
  Can I create KDM model from only part of Java project?
By: Eclipse User on Tue, 20 August 2013
3 6070 Tue, 03 November 2015 11:25
icon5.gif Querying an Ecore Instance
By: Eclipse User on Fri, 30 October 2015
1 4675 Mon, 02 November 2015 08:46
  Abstract Syntax Tree Metamodel
Specification and implementation of the ASTM
By: Eclipse User on Wed, 07 October 2015
2 5035 Thu, 08 October 2015 06:34
  Using Modisco discoverer from maven
By: Eclipse User on Mon, 28 September 2015
1 3749 Tue, 29 September 2015 10:05
  reverse engineering
python source code
By: Eclipse User on Sun, 30 August 2015
1 4010 Mon, 31 August 2015 04:46
  MoDisco and its usage within the ARTIST project referenced in IEEE Computer magazine
By: Eclipse User on Mon, 24 August 2015
0 5683 Mon, 24 August 2015 12:09
  Custom Discoverer
Writting a PHP Discoverer
By: Eclipse User on Mon, 10 August 2015
1 6551 Mon, 24 August 2015 04:34
  Loading metamodel uri='MyModel' failed
i cant load the metamodel
By: Eclipse User on Tue, 09 June 2015
5 6569 Wed, 10 June 2015 10:08
  MoDisco used/referenced in/from the ARTIST Open Source Release for Cloud migration
By: Eclipse User on Tue, 26 May 2015
0 4613 Tue, 26 May 2015 05:24
  Enumeration Type in MediniQVT
Exception occured in transformation
By: Eclipse User on Mon, 04 May 2015
3 4102 Tue, 05 May 2015 15:45
  Running Modisco discoverer programmatically and standalone
By: Eclipse User on Mon, 09 December 2013
4 11914 Sat, 04 April 2015 08:36
  Discoverer doesn't set xmi:id
The resulting xmi file doesn't contain reference ids, it uses xpath format instead
By: Eclipse User on Mon, 23 March 2015
4 4667 Wed, 25 March 2015 09:00
  KDM to UML converter
By: Eclipse User on Sat, 28 February 2015
1 4851 Mon, 02 March 2015 07:46
  MoDisco mentioned (and used) at Eclipse DemoCamp Nantes 2015 - ARTIST project & industrial feedb
By: Eclipse User on Mon, 09 February 2015
0 4022 Mon, 09 February 2015 10:58
  MoDisco in practice shown during coming ARTIST workshop @CloudScape Brussels - March 10, 2015
By: Eclipse User on Mon, 19 January 2015
0 4105 Mon, 19 January 2015 09:47
  MoDisco and PL/SQL
Way to reverse engeneering PL/SQL code
By: Eclipse User on Thu, 11 December 2014
9 7030 Wed, 14 January 2015 12:46
  Modisco, XMI and Mongodb
Import KDM Model into database
By: Eclipse User on Mon, 29 December 2014
1 5665 Mon, 12 January 2015 10:15
  KDM2Java
Transforming a KDM to Java
By: Eclipse User on Wed, 12 September 2012
3 6505 Tue, 02 December 2014 09:59
  Can't discover UML model from KDM model: exception
By: Eclipse User on Wed, 19 November 2014
7 7615 Thu, 20 November 2014 12:09
  MoDisco installation for UML reverse engineering
1 4615 Wed, 19 November 2014 08:40
  Is there any plan to implement a Java 8 discoverer?
By: Eclipse User on Sun, 12 October 2014
2 5022 Wed, 15 October 2014 07:20
  Enumeration in an extended gastm
How to define a new enumation in an gastm extension
By: Eclipse User on Tue, 07 October 2014
3 4027 Tue, 07 October 2014 12:18
  Creating a new discoverer
By: Eclipse User on Fri, 03 February 2012
10 13716 Sat, 27 September 2014 11:01
  Running modisco discover on save action
By: Eclipse User on Fri, 05 September 2014
1 4102 Fri, 05 September 2014 08:07
  Developer Setup
What I need to compile from the source
By: Eclipse User on Fri, 22 August 2014
4 5476 Mon, 25 August 2014 11:03
  How to load a Java model
By: Eclipse User on Tue, 19 August 2014
2 4109 Tue, 19 August 2014 10:55
  Custom discoverer
By: Eclipse User on Sat, 19 July 2014
1 4675 Mon, 21 July 2014 08:25
  java metamodel in MoDisco
By: Eclipse User on Fri, 16 May 2014
2 17855 Thu, 12 June 2014 17:34
  How to discover XML KDM File Programatically
XML Discoverer
By: Eclipse User on Mon, 02 June 2014
1 11432 Tue, 03 June 2014 04:12
  Problems with modify plugins
By: Eclipse User on Mon, 28 April 2014
4 15883 Mon, 26 May 2014 03:36
  Accessing source line number from Java Model
By: Eclipse User on Thu, 01 May 2014
3 11751 Mon, 05 May 2014 08:24
  Full long paper on MoDisco published in Information and Software Technology (Elsevier)
By: Eclipse User on Fri, 25 April 2014
0 37513 Fri, 25 April 2014 07:57
  Problems importing org.eclipse.modisco.java package
By: Eclipse User on Tue, 25 March 2014
1 4523 Tue, 25 March 2014 14:31
  Word DOCX Generic Discoverer
By: Eclipse User on Thu, 13 March 2014
1 4511 Mon, 17 March 2014 13:15
  Feature type does not exist on java
By: Eclipse User on Sun, 23 June 2013
3 6535 Sat, 15 March 2014 14:11
  Reading a _java.xmi file programmatically
Package with uri 'http://www.eclipse.org/MoDisco/Java/0.2.incubation/java' not found.
By: Eclipse User on Tue, 18 February 2014
15 20383 Thu, 20 February 2014 05:29
  Discovering a Java Project
Where is the discover output?
By: Eclipse User on Sat, 15 February 2014
2 8886 Mon, 17 February 2014 10:02
icon5.gif enable discoverers' stack-trace / activity-logging
By: Eclipse User on Fri, 27 December 2013
6 7964 Mon, 30 December 2013 05:35
  How can i persist a new created KDM model?
By: Eclipse User on Wed, 18 December 2013
5 11984 Fri, 20 December 2013 08:29
  How can i generate a KDM code model programatically?
By: Eclipse User on Tue, 17 December 2013
4 13547 Wed, 18 December 2013 04:14
  created kdm.xmi - but can't do anything with it
how from kdm to uml
By: Eclipse User on Mon, 25 June 2012
2 7063 Fri, 22 November 2013 18:10
  Oracle Forms KDM from XMI
By: Eclipse User on Tue, 05 November 2013
2 6322 Tue, 19 November 2013 08:22
  Introduction to MoDisco: some slides and demo available online
By: Eclipse User on Wed, 23 October 2013
0 4454 Wed, 23 October 2013 05:32
  MoDisco workflow running out of order
By: Eclipse User on Thu, 10 October 2013
2 4707 Thu, 10 October 2013 06:25
  Modisco excluded elements regex
By: Eclipse User on Fri, 20 September 2013
2 5630 Tue, 24 September 2013 05:18
  Modisco standalone
By: Eclipse User on Mon, 07 March 2011
2 6994 Tue, 10 September 2013 17:34
  Creating a Java Class Programmatically by means of Java Model
By: Eclipse User on Mon, 02 September 2013
15 16735 Fri, 06 September 2013 04:13
  Changing KDM programatically
By: Eclipse User on Thu, 16 May 2013
8 8130 Mon, 02 September 2013 06:59
  KDM Method Invocation
By: Eclipse User on Tue, 13 August 2013
2 5865 Wed, 21 August 2013 09:26
  Discovering multiple related java projects
By: Eclipse User on Thu, 02 August 2012
5 13210 Fri, 16 August 2013 04:47
  MetaModel Util Packages
By: Eclipse User on Tue, 11 December 2012
1 6755 Thu, 15 August 2013 08:04
  Nightly Update Site outdated?
Nightly update still provides Version 0.10.1
By: Eclipse User on Thu, 15 August 2013
0 4070 Thu, 15 August 2013 05:24
  Abstraction layer
By: Eclipse User on Sun, 04 August 2013
1 4391 Mon, 12 August 2013 10:13
  KDM Model Creation from C++ code?
How to create a KDM Model from C++ source code.
By: Eclipse User on Fri, 14 December 2012
3 8867 Mon, 12 August 2013 10:08
icon5.gif Status of CDO Backend?
By: Eclipse User on Mon, 15 July 2013
5 6371 Fri, 26 July 2013 07:56
  MoDisco in Kepler
By: Eclipse User on Fri, 26 July 2013
2 5049 Fri, 26 July 2013 04:18
  Parameter Initialization
Unable to set the initial value of a discoverer parameter
By: Eclipse User on Mon, 24 June 2013
3 5508 Wed, 26 June 2013 08:53
  Modisco & Papyrus don't generate UML
By: Eclipse User on Mon, 04 March 2013
10 16849 Thu, 20 June 2013 04:54
  step by step guide to reverse engineering java code to uml
By: Eclipse User on Thu, 05 April 2012
8 38122 Tue, 18 June 2013 16:29
  MoDisco Tool - Relational Database Information Discovery Tool
By: Eclipse User on Thu, 23 May 2013
1 5008 Thu, 23 May 2013 13:05
  How to extract the complete source code, not only the signatures
Is there a way, or a discover, that extracts the complete code, not only the signatures?
By: Eclipse User on Tue, 21 May 2013
5 8396 Wed, 22 May 2013 02:41
  From .jar to any model
How to get a representation of a .jar file with modisco?
By: Eclipse User on Tue, 30 April 2013
4 7731 Tue, 21 May 2013 09:12
  A simpler ecore java model?
By: Eclipse User on Fri, 19 April 2013
1 5225 Fri, 19 April 2013 03:36
  Modisco and Eclipse Juno
By: Eclipse User on Thu, 18 April 2013
2 4224 Thu, 18 April 2013 13:21
  Binds To KDM relation
Binds To KDM relation is not implemented conform specs?
By: Eclipse User on Wed, 10 April 2013
2 5181 Thu, 18 April 2013 12:08
  Integration of xText and Modisco
1 3738 Thu, 18 April 2013 11:15
  Incremental mode
By: Eclipse User on Thu, 14 March 2013
5 6747 Thu, 18 April 2013 08:41
  how to transform .uml to .xmi in modisco
By: Eclipse User on Mon, 01 April 2013
4 7685 Wed, 17 April 2013 09:52
  EMF from java? (reverse engineer)
By: Eclipse User on Fri, 22 March 2013
1 8415 Sun, 24 March 2013 09:53
  Small API break to be compatible with Helios
By: Eclipse User on Mon, 11 March 2013
0 4177 Mon, 11 March 2013 07:01
icon5.gif How to process my KDM models
By: Eclipse User on Mon, 28 January 2013
9 11425 Tue, 12 February 2013 23:20
  Help with KDM transformation
By: Eclipse User on Tue, 05 February 2013
1 4874 Tue, 05 February 2013 08:55
  How to specifiy query parameters in the Query Executions view?
By: Eclipse User on Wed, 12 December 2012
2 5293 Wed, 12 December 2012 10:41
  How to return multiple results for query on ecore model
By: Eclipse User on Fri, 07 December 2012
2 6078 Tue, 11 December 2012 04:09
  edit generated java model
By: Eclipse User on Thu, 06 December 2012
4 7206 Mon, 10 December 2012 04:36
  MoDisco already supports SMM (structured metrics metamodel) ?
By: Eclipse User on Thu, 01 November 2012
6 10063 Fri, 07 December 2012 06:47
  Question about ATL
By: Eclipse User on Sat, 01 December 2012
3 6828 Mon, 03 December 2012 06:46
  Querying KDM model
By: Eclipse User on Wed, 14 November 2012
5 9200 Fri, 23 November 2012 21:50
  Migration from EJB 2.1 to EJB 3.0
By: Eclipse User on Thu, 15 November 2012
2 10215 Thu, 22 November 2012 04:42
  How to Load JavaModel (file.javaxmi)
By: Eclipse User on Tue, 13 November 2012
2 4845 Tue, 13 November 2012 13:16
  Programmatically get kdm instance v0.10
By: Eclipse User on Fri, 09 November 2012
2 4984 Mon, 12 November 2012 16:02
  startLine and endLine attributes
KDM region attributes
By: Eclipse User on Thu, 25 October 2012
1 4787 Wed, 31 October 2012 05:56
  Problems with kdm in an ATL transformation
By: Eclipse User on Tue, 02 October 2012
2 6560 Tue, 30 October 2012 05:04
  how to get uml model from java project
By: Eclipse User on Mon, 22 October 2012
2 6386 Mon, 29 October 2012 05:14
  kdm to uml (still) fails
2 7368 Tue, 23 October 2012 01:52
  Method AbstractDeploymentDescriptorDiscoverer.getDescXmlVersion
By: Eclipse User on Mon, 02 July 2012
6 9837 Mon, 22 October 2012 12:21
  KDM model edit and editor plugins missing
By: Eclipse User on Thu, 29 March 2012
8 12053 Mon, 22 October 2012 07:22
  Browser Customization and QuerySets
By: Eclipse User on Mon, 15 October 2012
3 7041 Wed, 17 October 2012 03:55
  Processing the XMI of the KDM
By: Eclipse User on Thu, 06 September 2012
3 6745 Wed, 26 September 2012 15:46
  Junit Model discoverer
By: Eclipse User on Wed, 29 June 2011
9 26987 Wed, 26 September 2012 15:34
  Extending KDM Model
By: Eclipse User on Mon, 03 September 2012
6 7610 Tue, 11 September 2012 08:49
  Do I need a new discoverer to pull out a metamodel described in xml
probably similar to hibernate mapping file in concept
3 5988 Fri, 07 September 2012 05:01
  Extracting the compilation unit info
how to extract the compilation unit from a discovered XMI java model
By: Eclipse User on Fri, 24 August 2012
2 5377 Mon, 27 August 2012 13:31
  Ignoring Elements completely in custom Match and Diff Engine
By: Eclipse User on Thu, 09 August 2012
1 4768 Thu, 09 August 2012 07:58
  Loading java2kdm Models - Best Practices?
3 8147 Wed, 08 August 2012 06:37
  PHP discoverer
PHP discoverer
By: Eclipse User on Wed, 11 July 2012
2 5672 Wed, 11 July 2012 11:02
  Looking for a tutorial
By: Eclipse User on Thu, 28 June 2012
1 6555 Fri, 29 June 2012 04:12
  no uml file from kdm
nothing happens
5 8868 Tue, 26 June 2012 05:26
  XMI from java discoverer
By: Eclipse User on Wed, 25 April 2012
6 9358 Mon, 11 June 2012 07:00
  Java Model not linked to GASTM
By: Eclipse User on Thu, 24 May 2012
9 11416 Fri, 01 June 2012 04:21
How to associate target object and arguments?
By: Eclipse User on Tue, 29 May 2012
1 6111 Wed, 30 May 2012 05:38
  Problems with webApp MoDisco model and ATL transformation
By: Eclipse User on Thu, 03 May 2012
6 17630 Tue, 15 May 2012 11:40
  Prohibited package name: java
Loading XMI model base on JavaMM
By: Eclipse User on Mon, 30 April 2012
4 10747 Thu, 10 May 2012 12:23
  JSP MoDisco discoverer with JSP files from Struts Project
By: Eclipse User on Thu, 26 April 2012
2 7595 Fri, 27 April 2012 11:21
  EMF api - constructing XMI from XMI
By: Eclipse User on Fri, 20 April 2012
3 7183 Mon, 23 April 2012 18:53
  reverse engineering source code with method body
By: Eclipse User on Sat, 24 March 2012
2 7358 Mon, 02 April 2012 01:58
  XML to UML
By: Eclipse User on Fri, 23 March 2012
3 6705 Thu, 29 March 2012 13:39
  Java AST to GAST?
By: Eclipse User on Thu, 15 March 2012
1 5461 Fri, 16 March 2012 10:03
  EMF Ecore model from java source code
By: Eclipse User on Sun, 29 January 2012
5 11719 Mon, 20 February 2012 03:27
  Modisco API
I can't find the API
By: Eclipse User on Thu, 02 February 2012
3 6353 Fri, 10 February 2012 12:24
  How can I use ATL to modify a java model based on a third party lib
6 8556 Fri, 10 February 2012 03:54
  where can I learn ATL for handling java metamodel
By: Eclipse User on Thu, 26 January 2012
10 12160 Fri, 03 February 2012 09:45
  How to manipulate java models once parsed JavaDiscoverer
By: Eclipse User on Mon, 16 May 2011
7 16247 Fri, 03 February 2012 07:54
  Generate JSP/HTML from JSP Model
By: Eclipse User on Sun, 15 January 2012
1 5624 Mon, 16 January 2012 06:33
  Name shown in Modisco navigation tree
By: Eclipse User on Sat, 14 January 2012
1 5495 Mon, 16 January 2012 05:34
  Article about MoDisco published in ERCIM News 88 - Special Theme: Evolving Software
By: Eclipse User on Wed, 04 January 2012
0 8154 Wed, 04 January 2012 08:45
  EMF editor for Java metamodel: is it possible?
Can't create EMF project using java metamodel
By: Eclipse User on Fri, 30 December 2011
5 9523 Wed, 04 January 2012 05:45
  Auto-Reverse Engineering
Usage
By: Eclipse User on Mon, 18 April 2011
3 13426 Mon, 26 December 2011 05:47
  Compare two source code files using EMF
By: Eclipse User on Mon, 12 December 2011
3 11064 Tue, 13 December 2011 05:29
  Languages Supported by MoDisco
By: Eclipse User on Sun, 20 November 2011
1 6013 Fri, 25 November 2011 06:32
  MoDisco at EclipseCon Europe 2011...
By: Eclipse User on Mon, 24 October 2011
1 5281 Wed, 02 November 2011 12:29
  Modisco parsing output
can we get .ecore file generated from Modisco
By: Eclipse User on Wed, 26 October 2011
5 6790 Fri, 28 October 2011 08:28
  Feature request:: Listener to InventoryModel creation
By: Eclipse User on Thu, 27 October 2011
1 4614 Thu, 27 October 2011 11:09
  VB6 Reverse Engineering
By: Eclipse User on Tue, 27 September 2011
3 9515 Wed, 05 October 2011 05:36
  How to create eclipse like Welcome page
By: Eclipse User on Wed, 28 September 2011
1 4932 Thu, 29 September 2011 14:39
  New MoDisco presentation and demo available online
By: Eclipse User on Wed, 21 September 2011
0 9011 Wed, 21 September 2011 07:52
  installing plugins always fails
what is the secret to installing eclipse plugins on a PC?
By: Eclipse User on Fri, 09 September 2011
6 19502 Tue, 13 September 2011 11:54
  UML2Tools
By: Eclipse User on Thu, 18 August 2011
2 8838 Fri, 19 August 2011 20:29
  ModelFilter and Action menu
2 8730 Fri, 19 August 2011 20:29
  wrong MoDisco version in Indigo SR1 RC1
0 8210 Thu, 18 August 2011 11:45
  Article about MoDisco published in the JavaTech Journal #10 focusing on Eclipse Indigo
0 8289 Thu, 18 August 2011 10:44
  Error in installation MoDisco
By: Eclipse User on Tue, 16 August 2011
1 6369 Wed, 17 August 2011 08:35
  how to make AND operation between two conditions in EmfFacet
By: Eclipse User on Mon, 01 August 2011
1 5135 Tue, 02 August 2011 11:28
  Issues with Modicso 0.9
By: Eclipse User on Tue, 21 June 2011
10 23284 Mon, 25 July 2011 05:32
  Query Manager
By: Eclipse User on Wed, 13 July 2011
4 6759 Wed, 20 July 2011 03:31
  Modisco installation
By: Eclipse User on Thu, 23 June 2011
3 13025 Fri, 08 July 2011 11:16
  Infinite (?) execution when trying to discover KDM code model from ADempiere
By: Eclipse User on Fri, 10 June 2011
5 37760 Wed, 29 June 2011 08:22
  [Modisco 0.9] How to Discover Model and Generate Code programmatically?
Help needed for stepping from Modisco 0.8 to 0.9
By: Eclipse User on Wed, 15 June 2011
3 6841 Mon, 27 June 2011 12:00
  MoDisco team is organizing an Eclipse DemoCamp for Indigo next week
By: Eclipse User on Mon, 20 June 2011
0 8331 Mon, 20 June 2011 08:56
  Reuse Modisco's genmodel
6 6974 Thu, 16 June 2011 03:37
  I'm looking for a M2M transformation tool for Modisco's Java Model
I'm looking for a tool that makes transformations easier...
4 15675 Wed, 15 June 2011 05:05
  Structured Metrics Model (SMM)
By: Eclipse User on Tue, 08 March 2011
5 10405 Thu, 05 May 2011 05:21
  Exceptions when discovering java model from java project with annotations
By: Eclipse User on Thu, 28 April 2011
3 6474 Fri, 29 April 2011 08:22
  Welcome to eclipse.modisco
By: Eclipse Webmaster on Wed, 10 September 2008
2 10277 Fri, 29 April 2011 08:17
  MoDisco changing Model Load behavior
Problem loading as Meta-Model Type
By: Eclipse User on Tue, 12 April 2011
3 6992 Wed, 27 April 2011 07:50
  MoDisco 0.8 Java Code Generation
Generate Code from javaxmi model (AbstractAcceleoGenerator)
By: Eclipse User on Sat, 09 April 2011
1 4938 Wed, 13 April 2011 04:18
Current Time: Tue Jul 22 01:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.09580 seconds
