Topic |
Replies |
Views |
Last message |
Jubula doesnt record my Project Error or Log file |
6 |
2865 |
Thu, 11 December 2014 10:27 By: Alexandra Schladebeck |
Object Mapping in AUT "application_aut" for this node is incomplete |
1 |
2534 |
Thu, 11 December 2014 10:25 By: Alexandra Schladebeck |
Jubula in Jenkins on a Remote Desktop Can jubula run without grafical UI? |
2 |
1475 |
Wed, 10 December 2014 13:54 By: Joost Andrae |
Actions between Suites in a Job Is it possible to configure something that would happen before every suite? |
1 |
947 |
Wed, 10 December 2014 12:02 By: Alexandra Schladebeck |
Test on interface graphic |
2 |
1918 |
Wed, 10 December 2014 09:50 By: Dorian DE NICOLA |
Corrupted Database Embedded H2 Database Issues |
2 |
2920 |
Wed, 10 December 2014 09:35 By: Alva Christeen |
AUT Application throws Error's - just in Jubula |
4 |
2326 |
Wed, 10 December 2014 08:02 By: Alexandra Schladebeck |
Jubula and Perforce Can I use the Jubula Database with Perforce? |
0 |
3872 |
Tue, 09 December 2014 08:29 By: Sergej Ritter |
Jubula Installation Problems Unable to Locate Installation Folder |
1 |
1302 |
Thu, 04 December 2014 07:11 By: Oliver Goetz |
Jubula Installation Problem Unable to Locate Jubula Installation Folder |
1 |
1327 |
Thu, 04 December 2014 07:08 By: Oliver Goetz |
Click on Button do not work Test execution do not perform Click |
6 |
6080 |
Wed, 03 December 2014 08:35 By: Helios Fernández Tomé |
Problem with Component mapping for windows application Configuration error in Test step and "AbstractDotNetComponent" not supported error in rc_win.log |
2 |
4660 |
Mon, 01 December 2014 19:45 By: Shyam Meduri |
Tests in database, database structure |
1 |
1339 |
Mon, 01 December 2014 15:45 By: Alexandra Schladebeck |
Does Jubula recognize changes of the java project? Does Jubula recognize changes of the java project? |
3 |
1641 |
Mon, 01 December 2014 15:41 By: Alexandra Schladebeck |
Testjob does not start if started from Maven First click not accomplished |
5 |
2334 |
Mon, 01 December 2014 11:00 By: fab jubulator |
Cannot open a different project Impossible to switch projects |
2 |
1834 |
Mon, 01 December 2014 08:40 By: fab jubulator |
testexec via cmd using eclipse plugin Is it possible to run a test from the windows command line via using the eclipse plugin? |
2 |
2996 |
Fri, 28 November 2014 12:46 By: Anna Hofstaetter |
Problem with object Mapping object mapping unassigned component names |
3 |
2544 |
Fri, 28 November 2014 08:25 By: Alexandra Schladebeck |
AutStarter - sending message failed |
1 |
3781 |
Thu, 27 November 2014 10:06 By: Oliver Goetz |
Problem with ?parseDate function Incorrect Function argument value. |
8 |
7735 |
Thu, 27 November 2014 06:33 By: Dominik Gabriel |
Problem clicking with an HTML app |
10 |
16253 |
Wed, 26 November 2014 10:13 By: Dave Ball |
JUBULA:Resource Leak while Importing and exporting project Memory leak |
3 |
4271 |
Wed, 26 November 2014 07:46 By: Oliver Goetz |
Problem with Mars AUT Got Problems when changed AUT Target Platform to Mars |
4 |
2178 |
Tue, 25 November 2014 10:31 By: Dominik Gabriel |
Does Jubula need a UI to run the tests? |
3 |
2800 |
Tue, 25 November 2014 07:42 By: Achim Loerke |
Sharing a testcase among different AUTs under the same project |
3 |
2991 |
Fri, 21 November 2014 08:33 By: Oliver Goetz |
possible to define / use conditions? |
3 |
1479 |
Thu, 20 November 2014 21:26 By: David Hickernell |
Easiest way to debug an AUTAgent? |
1 |
1220 |
Tue, 18 November 2014 16:23 By: Dave Ball |
com.bredexsw.jubula.rc.html.web source? |
2 |
1638 |
Sat, 15 November 2014 09:20 By: Dave Ball |
NullPointerException on new Test step |
2 |
2994 |
Fri, 14 November 2014 14:46 By: Michael Remme |
show actual variable values Is there something like an echo function |
0 |
2828 |
Thu, 13 November 2014 14:50 By: Dominik Gabriel |
Can't delete Event handler |
1 |
2184 |
Thu, 13 November 2014 10:58 By: Oliver Goetz |
How to customize the results filename? |
2 |
1355 |
Tue, 11 November 2014 07:31 By: Vipin Sharma |
Run a DOS command from Jubula |
3 |
2518 |
Mon, 10 November 2014 12:27 By: Tony Hedoux |
Problem recording HTML test steps |
5 |
2510 |
Thu, 06 November 2014 17:32 By: Achim Loerke |
Strange behaviour of data sets |
2 |
1639 |
Thu, 06 November 2014 10:03 By: Michael Remme |
How to continue test execution after few test fails |
2 |
1977 |
Wed, 05 November 2014 11:01 By: Vipin Sharma |
Is it possible to verify an Icon od a TreeItem? Is it possible to verify an Icon od a TreeItem? |
2 |
1402 |
Tue, 04 November 2014 09:38 By: Dominik Gabriel |
Report in JUnit Format Is it Possible to get a Report in JUnit forma |
3 |
2610 |
Tue, 04 November 2014 07:10 By: Alexandra Schladebeck |
5009: AUT start failed Cannot start AUT with an SWT project |
5 |
3891 |
Tue, 28 October 2014 08:41 By: Joost Andrae |
Is it possible to avoid mapping? Avoid Object Mapping |
3 |
2419 |
Thu, 16 October 2014 07:18 By: Achim Loerke |
autrun on remote agent |
3 |
2844 |
Wed, 15 October 2014 16:34 By: Achim Loerke |
Is it possible to run parallel tests on one server |
2 |
1427 |
Mon, 13 October 2014 13:02 By: Jurjen Hofstra |
Error 5009 : Start AUT failed Javascript code threw out entity not found message |
3 |
54197 |
Mon, 13 October 2014 08:07 By: Anna Hofstaetter |
Read Hour and save in Variable. |
4 |
3347 |
Tue, 07 October 2014 17:27 By: Plinio Froener |
[solved] How to check if a variable is already set? Test Execution Error 7009 when trying to read unset variable By: Sup SC on Fri, 23 March 2012 |
2 |
2215 |
Fri, 03 October 2014 19:19 By: Plinio Froener |
Jubula does not detect AUT Running |
4 |
3316 |
Thu, 25 September 2014 15:52 By: Victor Martin |
Event Handler - Not executed |
2 |
1520 |
Wed, 24 September 2014 07:57 By: Alexandra Schladebeck |
[unsolved] Selecting a remote Database how to? |
8 |
7552 |
Fri, 19 September 2014 07:18 By: Ludwig Moser |
Select last row in a table |
1 |
1994 |
Thu, 18 September 2014 14:18 By: Alexandra Schladebeck |
Jubula7.2 is crashing in Ubuntu14.04 while trying to open project Jubula7.2 is crashing in Ubuntu14.04 while trying to open project from menu bar |
0 |
5038 |
Tue, 16 September 2014 10:29 By: Vipin Sharma |
Swing AUT on mac computer? |
4 |
2795 |
Mon, 15 September 2014 10:16 By: Sascha Fedorenko |
Jubula External DLL |
4 |
2353 |
Thu, 11 September 2014 07:13 By: David Vlek |
MacOS 10.9.2 - ub_cti_replaceText - Timeout received before confirming the posted event |
5 |
4174 |
Mon, 08 September 2014 08:19 By: Alexandra Schladebeck |
Can test cases contain java code? |
3 |
1800 |
Sat, 06 September 2014 12:47 By: Achim Loerke |
Jubula and version control |
1 |
1155 |
Sat, 06 September 2014 08:42 By: Achim Loerke |
JSlider example extension - 5009: AUT start failed AUT start fails with the provided JSlider example extension |
4 |
3215 |
Thu, 04 September 2014 18:49 By: Thomas Küstermann |
variables and test data values are not getting exported |
3 |
1170 |
Thu, 04 September 2014 13:02 By: Alexandra Schladebeck |
Can not see unbound modules when testing RCP AUT |
3 |
2088 |
Thu, 04 September 2014 00:32 By: Jay Meng |
Select table row - row has to fulfill multiple conditions |
7 |
10153 |
Wed, 03 September 2014 14:08 By: Alexandra Schladebeck |
EventHandler to loop on data until correct line is found How to loop on data in a table until correct line is found |
2 |
3102 |
Wed, 03 September 2014 13:51 By: Antoine VINCENT |
Problems with Jubula and possibly Spring Autowired Function not Supported by Jubula? |
5 |
4530 |
Mon, 01 September 2014 15:09 By: Alexandra Schladebeck |
Identifying the DSL editor in Jubula How to make Jubula to identify the DSL/Xtext editor. |
3 |
2173 |
Fri, 29 August 2014 09:55 By: Alexandra Schladebeck |
Support for French Keyboard |
7 |
6580 |
Thu, 28 August 2014 11:54 By: Antoine VINCENT |
Document test cases Exported overview of defined tests for developers and testers |
3 |
3864 |
Thu, 28 August 2014 07:06 By: Alexandra Schladebeck |
Problem with test execution test disconected |
1 |
3441 |
Thu, 28 August 2014 06:40 By: Alexandra Schladebeck |
How to wait for an background job to finish? |
4 |
3725 |
Thu, 28 August 2014 06:39 By: Alexandra Schladebeck |
Problem with few steps in jubula Steps like ub_app_prepareForAUTTermination does not execute on Windows 7 |
1 |
2213 |
Thu, 28 August 2014 06:30 By: Alexandra Schladebeck |
Problem with new action in component Application |
2 |
1395 |
Wed, 27 August 2014 15:58 By: Alexandra Schladebeck |
Testing GMF component |
5 |
2524 |
Wed, 27 August 2014 11:52 By: Elise Ruelle |
Openoffice Excel and date issues how to handle excel data files with date related values |
2 |
2505 |
Mon, 25 August 2014 12:49 By: Jurjen Hofstra |
Automated Testing via Scheduled Task. Autrun.exe not starting |
3 |
3502 |
Thu, 21 August 2014 07:53 By: s dongen |
How to check which Tabbed Component is currently active? |
6 |
3257 |
Wed, 20 August 2014 15:28 By: David Hickernell |
Zip-file extension-toolkit-rc.zip |
5 |
2557 |
Wed, 20 August 2014 06:59 By: Alexandra Schladebeck |
Executing external command always returns 0 but command is not executed |
2 |
1350 |
Tue, 19 August 2014 08:47 By: Vlastimil Havrila |
Jubula sometimes loses the connection to the AUT |
2 |
1665 |
Tue, 19 August 2014 06:22 By: Sandro Schwager |
Object Mapping Jubula does not save mapped objects |
7 |
2485 |
Mon, 18 August 2014 11:27 By: nicole h |
Unable to Pass Updated Variable from Event Handler Variables no longer being passed from Event Handler to top level Test Case |
3 |
3110 |
Fri, 15 August 2014 14:12 By: Alexandra Schladebeck |
Errors which appears with the automated tests |
6 |
2596 |
Thu, 14 August 2014 15:37 By: Elise Ruelle |
update on export regarding problem |
0 |
4365 |
Wed, 13 August 2014 10:28 By: Ranjeet Gupta |
Alt-PageUp and Alt-PageDown causing test to hang only happens sometimes, no discernible pattern |
3 |
1471 |
Wed, 13 August 2014 09:50 By: Alexandra Schladebeck |
selecting a menubar item on Ubuntu 12.04 |
6 |
3881 |
Tue, 12 August 2014 09:59 By: Vipin Sharma |
Remote AUT - how to? |
2 |
1720 |
Mon, 11 August 2014 10:49 By: Alexandra Schladebeck |
Event handler does not propagate component name: Workaround wanted |
3 |
2025 |
Fri, 08 August 2014 19:43 By: David Hickernell |
Periodic Error: "Cannot delete test result" |
0 |
5113 |
Fri, 08 August 2014 13:03 By: Carsten Neumann |
Not allowed to save an unlocked workversion Not allowed to save an unlocked workversion |
2 |
3842 |
Thu, 07 August 2014 12:39 By: Carsten Neumann |
Native dialog (file chooser) |
8 |
9848 |
Thu, 07 August 2014 12:28 By: Badr BADDOU |
testexec can't connect to AUT |
2 |
2112 |
Thu, 07 August 2014 12:08 By: Elise Ruelle |
Parametrise Eventhandler: Retry Wanna parametrise the count of maximum retries |
5 |
3032 |
Thu, 07 August 2014 05:52 By: Dominik Gabriel |
TestStep fails and Event Handler succed, whole testCase fails? |
1 |
1349 |
Wed, 06 August 2014 16:09 By: Alexandra Schladebeck |
ignoring text input component ignoring text input with component in swing |
4 |
2802 |
Wed, 06 August 2014 15:31 By: olgierd koslowski |
Manual test step in headless mode Is there any possibility to execute Manual Test Step while running test by testexec? |
1 |
3439 |
Wed, 06 August 2014 15:02 By: Alexandra Schladebeck |
Slow Mouse Motion |
1 |
3471 |
Wed, 06 August 2014 14:59 By: Alexandra Schladebeck |
Drag & drop between AUT and another app / two AUTs By: J K on Wed, 06 August 2014 |
1 |
1083 |
Wed, 06 August 2014 12:17 By: Oliver Goetz |
Problems using Jubula with MySQL Creation and Import of Projects is not possible |
4 |
8154 |
Mon, 04 August 2014 12:50 By: Dominik Gabriel |
Importing the xml file After completing the test case and exporting it as .xml file, when i tried to import it again it says already project is present in the database |
0 |
4047 |
Mon, 04 August 2014 12:48 By: Vijay Vasanthkumar |
How to click minimize/maximize/close(X) Swing frame / dialog from Jubula By: J K on Sat, 02 August 2014 |
1 |
2715 |
Sun, 03 August 2014 06:54 By: Achim Loerke |
How to wait for text on button? By: J K on Fri, 01 August 2014 |
1 |
1713 |
Fri, 01 August 2014 14:12 By: Achim Loerke |
Does ub_app_waitForWindow_matches support Swing JInternalFrame? By: J K on Fri, 01 August 2014 |
0 |
3682 |
Fri, 01 August 2014 13:39 By: J K |
SOLVED: Test Case Browser view broken: Comparison method violates its general contract Error |
1 |
2202 |
Fri, 01 August 2014 13:21 By: Chris Champion |
Database connection |
4 |
1741 |
Fri, 01 August 2014 07:16 By: Déborah D |
Problem to extend Jubula |
6 |
2623 |
Fri, 01 August 2014 07:09 By: Déborah D |
Jubula to test Eclipse plugin Jubula to test Eclipse IDE |
1 |
1607 |
Thu, 31 July 2014 15:34 By: Achim Loerke |
File is inconclusive |
2 |
2799 |
Thu, 31 July 2014 15:25 By: Achim Loerke |
Store multiple values in a Variable How to store a list of values from a table into an array/variable using Jubula? |
4 |
3593 |
Tue, 29 July 2014 16:16 By: David Hickernell |
Out of memory while writing test result report GC overhead limit exceeded - Error while writing Test Result Report |
4 |
2298 |
Tue, 29 July 2014 06:45 By: Jurjen Hofstra |
Create an action for Application |
3 |
2250 |
Fri, 25 July 2014 14:36 By: Déborah D |
Show AUT's variable on screen |
3 |
1896 |
Thu, 24 July 2014 10:17 By: Antoine VINCENT |
Bringing AUT back into focus By: Todd P on Mon, 21 July 2014 |
2 |
2103 |
Thu, 24 July 2014 10:10 By: Antoine VINCENT |
HTML AUT and Swing AUT Automating sing GUI |
1 |
2096 |
Sun, 20 July 2014 11:29 By: Tony Hedoux |
Iteration of items Jubula could be more powerful with support for iterations of tests |
1 |
2366 |
Fri, 18 July 2014 20:39 By: David Hickernell |
Externalisation of string for Jubula |
2 |
1691 |
Fri, 18 July 2014 11:52 By: Tony Hedoux |
Problem with example to extend Jubula |
1 |
2481 |
Fri, 18 July 2014 07:57 By: Déborah D |
Object Mapping doesn't work |
8 |
4035 |
Wed, 16 July 2014 15:23 By: Déborah D |
Cann´t test after a Software update(my AUT) |
10 |
4691 |
Wed, 16 July 2014 14:36 By: Byron Kooima |
Summer time - vacation time |
0 |
3359 |
Tue, 15 July 2014 13:45 By: Achim Loerke |
ub_app_activate step failing ub_app_activate step failing By: Bala S on Fri, 11 July 2014 |
1 |
2566 |
Tue, 15 July 2014 13:33 By: Achim Loerke |
test HTML and RCP in a same AUT |
3 |
3896 |
Tue, 15 July 2014 13:23 By: Achim Loerke |
How to custom parameters?? |
5 |
8428 |
Tue, 15 July 2014 13:16 By: Oliver Goetz |
Object mapping : Highlight in AUT not working By: Bala S on Fri, 11 July 2014 |
2 |
3058 |
Tue, 15 July 2014 12:41 By: Oliver Goetz |
No testresults table & no XML or HTM output After Jubula upgrade, resultdir no longer respected |
2 |
1807 |
Fri, 11 July 2014 14:54 By: Youssef Bagoulla |
Check list of combobox visible or not |
10 |
4127 |
Fri, 11 July 2014 07:41 By: Déborah D |
how to "objet map" theory and how to objet map component ID. |
1 |
1358 |
Thu, 10 July 2014 07:21 By: Alexandra Schladebeck |
JavaFX javafx automation |
1 |
1822 |
Thu, 10 July 2014 07:07 By: Alexandra Schladebeck |
Change AUT Config Path before executing test |
8 |
2444 |
Wed, 09 July 2014 23:44 By: David Hickernell |
Check If a Gigantic Mult Line Text Matches |
3 |
1194 |
Wed, 09 July 2014 23:22 By: David Hickernell |
Kill the AUT at the end of the test Is there a way to kill the AUT at the end of the test? |
10 |
4871 |
Wed, 09 July 2014 23:05 By: Fernando Gomes |
Size of ComboBox |
3 |
1877 |
Tue, 08 July 2014 07:39 By: Déborah D |
How to use AltGr as a modifier key? |
3 |
5240 |
Fri, 04 July 2014 10:45 By: Antoine VINCENT |
How to custom parameters?? In Reference Manual,I can't use the parameters,How to custom parameters? |
1 |
1533 |
Fri, 04 July 2014 05:50 By: Alexandra Schladebeck |
Double cell in a table |
2 |
1601 |
Fri, 27 June 2014 15:41 By: Déborah D |
Project Quality Day at Eclipse Con Europe |
0 |
3311 |
Fri, 27 June 2014 12:13 By: Alexandra Schladebeck |
Check status of a ComboBox in a table |
2 |
2103 |
Fri, 27 June 2014 07:41 By: Déborah D |
KeyCombination + MouseButton |
3 |
1426 |
Fri, 27 June 2014 07:20 By: Déborah D |
Expand every node on a tree? |
4 |
3508 |
Tue, 24 June 2014 20:27 By: David Hickernell |
start new AUT inside a test case Jubula 8 |
2 |
2203 |
Mon, 16 June 2014 15:45 By: Alexandra Schladebeck |
Running tests with testexec html toolkit Is it possible? |
5 |
2603 |
Wed, 11 June 2014 06:53 By: Alexandra Schladebeck |
Creating a plugin to extract a substring from a long string Creating a plugin to extract a substring from a long string |
1 |
1520 |
Tue, 10 June 2014 15:25 By: Alexandra Schladebeck |
Automate the startup and login Can't import a project or parts from local file system |
1 |
1405 |
Thu, 05 June 2014 13:36 By: Alexandra Schladebeck |
Multiple error messages when switching projects Multiple error messages when switching to another project |
5 |
14911 |
Wed, 04 June 2014 12:09 By: Jurjen Hofstra |
Use a different Datasets on a nested case Use a different Datasets on a nested case |
5 |
25964 |
Tue, 03 June 2014 21:24 By: David Hickernell |
Is there a way to disable logging? |
12 |
8182 |
Tue, 03 June 2014 06:24 By: Alexandra Schladebeck |
How to check a part of Text on TextComponent I need some help to get success !! |
3 |
19023 |
Tue, 27 May 2014 19:23 By: Plinio Froener |
Observation Mode - Wait for Window to Close |
3 |
2857 |
Mon, 19 May 2014 06:31 By: nicole h |
Problem with Jubula8 and MySQL The TESTRESULT table will not be created |
3 |
8308 |
Thu, 15 May 2014 09:18 By: Achim Loerke |
An error ocurred: Could not connect to AUT: AppName |
1 |
34421 |
Mon, 12 May 2014 06:23 By: Alexandra Schladebeck |
Toolbar button in Properties view not found during test but Object Mapping mode confirms its identity |
7 |
37055 |
Thu, 08 May 2014 13:29 By: Marvin Mueller |
Meaning of "-DGD_ignore_timeout=true"? AUT changes behavior |
5 |
51584 |
Thu, 08 May 2014 12:29 By: Marvin Mueller |
Cannot install Jubula 2.3.0 Plugin |
3 |
1671 |
Wed, 30 April 2014 14:45 By: Chris Champion |
Integrate Jubula with Jenkins Integrate Jubula with Jenkins for a test of an Eclipse plugin |
4 |
6087 |
Wed, 30 April 2014 12:18 By: Stefan Miller |
Use the Default Parameter in Datasets is it possible to Use the Default Parameter in Datasets? |
5 |
12544 |
Mon, 28 April 2014 15:40 By: David Hickernell |
Integrating specific code/checks not directly related to UI |
3 |
3287 |
Thu, 17 April 2014 11:41 By: Achim Loerke |
Jubula 8 does not start on Ubuntu 13 |
5 |
2580 |
Thu, 17 April 2014 11:28 By: Alexandra Schladebeck |
Jubula 8.0 released! JavaFX testing, HP ALM integration, .... |
1 |
18196 |
Thu, 17 April 2014 06:16 By: Alexandra Schladebeck |
Negative Margin |
4 |
2682 |
Wed, 16 April 2014 11:31 By: Tankut Koray |
cant get component properties in object mapping mode Viewing properties for a component in the Object Mapping Mode |
6 |
2530 |
Wed, 16 April 2014 11:25 By: Alexandra Schladebeck |
central data set value ignored |
20 |
8299 |
Tue, 15 April 2014 06:47 By: Alexandra Schladebeck |
Adding checks to Teststyle |
8 |
3544 |
Fri, 11 April 2014 08:14 By: Achim Loerke |
Does each external command happen in its own terminal? using ub_app_executeExternalCommand in Linux |
2 |
1469 |
Fri, 04 April 2014 15:16 By: David Hickernell |
Newbie - Observation Console doesn't open in Observation Mode |
3 |
2067 |
Thu, 27 March 2014 17:18 By: Alexandra Schladebeck |
Custom methods in Jubula |
1 |
1454 |
Wed, 26 March 2014 07:00 By: Alexandra Schladebeck |
Check dateformat using slash Check dateformat using slash |
3 |
1752 |
Tue, 25 March 2014 15:29 By: David Hickernell |
Can't execute test on AUT launched from Eclipse |
4 |
8752 |
Thu, 20 March 2014 10:44 By: Elise Ruelle |
How to click on a tree entry in PrimeFaces |
1 |
2206 |
Wed, 19 March 2014 16:45 By: Achim Loerke |
Preparing for the Jubula tutorial at EclipseCon |
1 |
1488 |
Tue, 18 March 2014 18:34 By: Alexandra Schladebeck |
Migrate to a new Database MySQL |
6 |
4051 |
Tue, 18 March 2014 10:45 By: louy koko |
How can I select Tabbed Property Sheet Pages |
8 |
6569 |
Mon, 17 March 2014 16:01 By: Alexandra Schladebeck |
Jabula Jabula license |
2 |
1231 |
Tue, 11 March 2014 13:08 By: Alexandra Schladebeck |
Timeout connecting to running AUT |
5 |
10063 |
Mon, 10 March 2014 14:46 By: Alexandra Schladebeck |
Problems using executeExternalCommand |
4 |
2173 |
Mon, 10 March 2014 14:07 By: Alexandra Schladebeck |
Scout testing with Jubula Scout testing with Jubula |
8 |
12478 |
Mon, 10 March 2014 11:28 By: Afonso Remédios |
Key Combination STRG+ENTER |
1 |
1131 |
Thu, 06 March 2014 09:11 By: nicole h |
Jubula 7.2 - missing Toolbar |
3 |
1869 |
Mon, 03 March 2014 07:48 By: nicole h |
How to extend jubula for Pshelf widget (nebula)? |
1 |
1364 |
Fri, 28 February 2014 07:35 By: Alexandra Schladebeck |
Store title of tab |
3 |
1241 |
Thu, 27 February 2014 08:03 By: Alexandra Schladebeck |
Help with AUT in Eclipse IDE (no .exe file) |
10 |
14400 |
Wed, 26 February 2014 09:45 By: Alexandra Schladebeck |
Jubula with Eclipse BPEL editor in GEF |
1 |
18361 |
Tue, 25 February 2014 12:28 By: Ajantha Yogamoorthy |
Examples for Web-Tests |
5 |
6042 |
Tue, 25 February 2014 10:11 By: nandhini vijayakumar |
Check if AUT finished saving/loading data before executing next test cases |
1 |
1250 |
Tue, 25 February 2014 07:59 By: Ajantha Yogamoorthy |
html problem problems with html review |
0 |
851 |
Fri, 21 February 2014 21:04 By: Teresa Carmona |
Testing Web Application in HTML & .net |
3 |
8107 |
Fri, 21 February 2014 13:09 By: nandhini vijayakumar |
Jubula problem in Starting AUT agent |
4 |
2513 |
Tue, 18 February 2014 05:12 By: nandhini vijayakumar |
AUT is shown under "Running AUTs" but won't start up Jubula doesn't show any error messages, works fine with previous version of AUT |
7 |
7954 |
Tue, 11 February 2014 17:10 By: Alexandra Schladebeck |
Export is not working with plugins installed in eclipse |
3 |
3330 |
Tue, 11 February 2014 17:09 By: Alexandra Schladebeck |
How to judge the telnet conneted? By: ye ye on Tue, 11 February 2014 |
1 |
1638 |
Tue, 11 February 2014 07:24 By: Alexandra Schladebeck |
Jubula and Java FX Automate test cases for an application made in JavaFX. |
1 |
6426 |
Tue, 11 February 2014 07:23 By: Alexandra Schladebeck |
2037: The import of project "{0}" failed. |
2 |
7365 |
Thu, 06 February 2014 10:18 By: Oliver Goetz |
How to switch off embedded screenshots |
2 |
2386 |
Wed, 05 February 2014 13:35 By: Jurjen Hofstra |
Jira connection from Jubula stand-alone? |
4 |
2637 |
Wed, 05 February 2014 13:26 By: Ajantha Yogamoorthy |
Linux testexec check selection always return true Linux testexec check selection always return true - even if it is not |
10 |
6308 |
Tue, 04 February 2014 08:06 By: Dirk Willert |
Can Jubula/testexec work with Xvnc ? |
3 |
5876 |
Mon, 03 February 2014 10:17 By: Alexandra Schladebeck |
Problem connect to "Default Embedded(H2)" |
1 |
6350 |
Fri, 31 January 2014 07:21 By: Alexandra Schladebeck |
2 |
5852 |
Fri, 31 January 2014 07:19 By: Alexandra Schladebeck |
Jubula doesn't recognize drop down menu drop down menu of AUT not recognized during object mapping |
7 |
6427 |
Thu, 30 January 2014 07:16 By: Alexandra Schladebeck |
Questions concerning the export and input of data |
2 |
7230 |
Wed, 29 January 2014 09:20 By: Kay Odenthal |
testexec hangs under linux autagent under windows and testexec under linux |
3 |
2734 |
Tue, 28 January 2014 09:10 By: Alexandra Schladebeck |
Autagent under Suse Linux in Xvnc Session problem |
3 |
44573 |
Mon, 27 January 2014 15:05 By: Dirk Willert |
Installing Plugin for RCP-AUT under Eclipse e4 (= Eclipse 4.2) |
3 |
5607 |
Mon, 27 January 2014 07:09 By: Alexandra Schladebeck |
Extend Jubula for ImageHyperlink By: ye ye on Thu, 23 January 2014 |
1 |
1481 |
Fri, 24 January 2014 07:38 By: Alexandra Schladebeck |
Extension with Jubula 1.3.0 |
4 |
4547 |
Thu, 23 January 2014 08:04 By: ye ye |
Error by trying to run a test Job under linux Could not connect to AUT error |
1 |
55119 |
Mon, 20 January 2014 12:17 By: Alexandra Schladebeck |
