Kura Use Case Kura Use Cases |
1377 |
Sun, 15 October 2023 18:26 By: Kevin Hanover |
Installing with p2 director application with credentials Installing with p2 director application with credentials |
2164 |
Wed, 11 October 2023 18:26 By: Jack Jones |
Help with understanding OSGi |
2380 |
Wed, 11 October 2023 18:20 By: Jack Jones |
Kura bundles Start Levels Change bundles start level from configuration |
2614 |
Wed, 11 October 2023 18:18 By: Jack Jones |
Upgrading org.eclipse.osgi jar Want to use org.eclipse.osgi_3.10.1 instead of org.eclipse.osgi_3.8.1 |
7335 |
Thu, 05 October 2023 12:15 By: Jack Jones |
How to map Antlr to Eclipse editor plugin I have started creating an editor plugin for a custom language and need to know how to map Antlr to Eclipse PDE. |
8121 |
Thu, 05 October 2023 12:14 By: Jack Jones |
Eclipse RCP A problem encountered during development org.eclipse.swt.widgets.text Unable to edit |
10418 |
Tue, 05 September 2023 02:51 By: Hu Jackling |
Using Eclipse on GraalVM for Windows |
4051 |
Thu, 30 December 2021 12:12 By: Maik Greubel |
Verify/detect errors in interactions between GUI elements Formal analysis to identify interaction defects between views, pages, listeners, etc. |
2756 |
Thu, 01 July 2021 10:43 By: Steve Vestal |
LinkageError: loader constraint violation Different Class objects for the type javax/xml/namespace/NamespaceContext used in the signature |
2611 |
Wed, 31 March 2021 19:53 By: amit phadke |
OSGI Services- java.util.ServiceLoader problem OSGI Services- java.util.ServiceLoader problem |
4230 |
Tue, 22 October 2019 07:45 By: Bhondawe Patil |
exception while starting bundle "org.eclipse.gemini.web.tomcat_1.1.0.RELEASE" with java 7 update 201, exception while starting bundle "org.eclipse.gemini.web.tomcat_1.1.0.RELEASE" |
3723 |
Wed, 13 February 2019 12:45 By: Vishakha More |
log4j properties of bundle I want to store my bundle log files in folder. i added the file appender properties in emulator log4j properties but i want to separate log files related to my wire component |
4774 |
Thu, 30 August 2018 11:11 By: ganesh boddu |
Eclipse not running Activator from latest installed plugin. |
1998 |
Wed, 04 July 2018 12:32 By: Archana Singh |
@References annotation of Apache felix |
2596 |
Wed, 27 June 2018 08:42 By: Rashid Jorvee |
SHOW AN ERROR LOG FILE when i click on eclipse launcher application it show mee an error message chek error in log file and some rendom number apper ... |
6834 |
Fri, 26 January 2018 10:43 By: kanhaiya panchal |
Problem downloading artifact osgi.bundle.org.apache.xerces.2.8.0.v200705301630 |
5973 |
Thu, 25 January 2018 08:58 By: Stig Vestergaard |
Virgo-apache tomcat - Bundledependency error Not able to load the jar file from viro-apache tomcat |
10075 |
Tue, 11 July 2017 10:53 By: SREE YADAVALLI |
What does it take to add an editor as an internal editor? |
10993 |
Thu, 25 May 2017 20:28 By: Larson Smith |
Eclipse Plugin ContentAssist suggestions ContentAssist variable sussestions |
20159 |
Fri, 05 May 2017 13:01 By: Michal Michal |
Ho to provide ContentProvider and LabelProvider to Emf Compare dialog/Editor Ho to provide ContentProvider and LabelProvider to Emf Compare dialog/Editor |
15626 |
Wed, 22 February 2017 14:37 By: Manish Kumar |
Size: Unknown in plugin |
6806 |
Fri, 25 November 2016 12:22 By: asdasd as |
Need to know how to plug bundles |
7388 |
Wed, 11 May 2016 10:49 By: Prakash Kumar |
OSGI ExtensionPoints Contribution with OSGI Services |
6523 |
Wed, 27 January 2016 01:05 By: Aurélien Mora |
Restricting Plug-in Dependency to fixed version Restricting Plug-in Dependency to fixed version |
7050 |
Thu, 10 December 2015 06:59 By: kirankumar B S |
Help to recovery files ransonware virus attack |
7787 |
Mon, 19 October 2015 14:14 By: Fernando P. |
Apache Felix - Spring DM server - Eclipse IDE To increase developer productivity by using IDE for develop, build, deploy, unit test By: raj s on Thu, 19 April 2012 |
9228 |
Tue, 06 October 2015 11:54 By: David Benoit |
Install New Software shows error dialog when clicked Error message is: Cannot complete the request. This installation has not been configured properly for software updates. |
5123 |
Thu, 16 July 2015 12:51 By: Dan Connell |
Starting org.eclipse.wst.jsdt.ui plug in |
2884 |
Mon, 06 July 2015 16:35 By: Nikolaos Galerakis |
OSGI with BIRT Reportin How to make BIRT report engine as OSGI bundle By: San P on Tue, 23 June 2015 |
3112 |
Tue, 23 June 2015 05:01 By: San P |
could not find plugin org.eclipse.persistence.jpa.equinox.weaving For RCP Project By: no no on Mon, 15 June 2015 |
3362 |
Mon, 15 June 2015 14:49 By: no no |
Cost saving with OSGI in Business to Business (B2B) Model |
3871 |
Tue, 05 May 2015 08:28 By: Missing name Mising name |
Unable to launch gogo shell out of eclipse Unable to launch gogo shell out of eclipse |
4331 |
Sun, 22 March 2015 18:27 By: Prakash Chauhan |
OSGi Projects broken in Luna The creation of an OSGi- based project fails in Eclipse Luna |
3846 |
Tue, 17 March 2015 15:25 By: Robert Brown III |
Calling OSGI from the Annotation Processor |
3382 |
Tue, 10 February 2015 14:30 By: Nieves Salor |
Osgi - Razberry /dev/ttyAMA0 doesn't exist |
6306 |
Tue, 08 July 2014 09:26 By: cyril praz |
Using OSGI OSGI |
4249 |
Fri, 04 July 2014 14:23 By: Drew Jocham |
Creating Bundles OSGI: OSGI |
3644 |
Tue, 01 July 2014 01:56 By: Drew Jocham |
OSGI servlet hacks How to add servlet init params programatically |
4327 |
Thu, 19 June 2014 13:11 By: Igor Masternoy |
OSGI | Export Interface vs Implementation Best Practice advice |
2878 |
Fri, 14 March 2014 14:58 By: ashish abrol |
eclipse team project set with egit |
2921 |
Tue, 18 February 2014 01:58 By: fu duhui |
Refer to OSGI bundles from a WAB project |
11064 |
Thu, 02 January 2014 06:01 By: Arpan Mukhopadhyay |
Problem in Struts2 with OSGI Problem in Struts2 with OSGI |
5719 |
Sun, 29 December 2013 15:17 By: novaeye liang |
How to setup Equinox properly |
51133 |
Sun, 29 December 2013 14:11 By: Ulrich Schmidt |
Class not found in Log4j configuration Existing local class is not loaded by the Log4j configuration |
5487 |
Fri, 20 September 2013 13:16 By: Uri Shani |
Winstone-Osgi DEBUG How to debug OSGI bundles |
4017 |
Tue, 27 August 2013 12:08 By: Borja Tellado |
Is it possible to develop eclipse by eclipse as a standard OSGi project By: Jun Yu on Mon, 26 August 2013 |
3448 |
Mon, 26 August 2013 09:22 By: Jun Yu |
Exporting OSGI product export with target Exporting OSGI product export with target |
9286 |
Fri, 31 May 2013 16:08 By: Tsahar Sobe |
How to launch an OSGi launcher out of eclipse |
4721 |
Tue, 21 May 2013 07:39 By: Paine Pan |
help with declarative services |
6454 |
Sun, 05 May 2013 08:13 By: Kumail Haider |
Problems with Equinox and Eclipse Indigo Exception when I tried to run a simple hello world bundle/plugin |
48475 |
Fri, 03 May 2013 01:45 By: karychien Mising name |
Equinox doesn't start |
5052 |
Thu, 10 January 2013 10:59 By: Eclipse User |
IllegalArgumentException:name in jetty IllegalArgumentException:name in jetty |
5155 |
Thu, 27 December 2012 10:44 By: Abhishek Lodha |
Class not found error FilterableUAElement Class not found error but it present. |
5955 |
Sat, 20 October 2012 06:24 By: gauraw gupta |
Migrating my application to OSGi porting my web application to OSGi |
6577 |
Mon, 24 September 2012 06:10 By: omprakash visvanathan |
can't start OSGi need help |
19363 |
Fri, 24 August 2012 10:20 By: guokai zhang |
How to Export Dependent Plugins in Eclipse how to export dependent plugins form eclipse |
4838 |
Thu, 23 August 2012 07:59 By: Muhammad Tahir |
OSGi new to used OSGi |
5715 |
Fri, 10 August 2012 01:57 By: nadir salih |
Launching Virgo via Tanuki Launching Virgo via Tanuki |
5017 |
Wed, 08 August 2012 09:44 By: Salil Gandhi |
Start Eclipse Virgo Tomcat programatically Start Eclipse Virgo Tomcat programatically |
5333 |
Mon, 16 July 2012 05:17 By: anushka vaze |
applications osgi !! Need our help please |
4718 |
Thu, 28 June 2012 12:57 By: essttien darkness |
RCP development tutorials and PDF books RCP development tutorials and PDF books |
5614 |
Fri, 15 June 2012 08:11 By: Aniket Gujrathi |
problem running ant from starup.jar thorugh commandline |
5722 |
Tue, 08 May 2012 12:15 By: roopesh kumar |
Need to execute code while installing software |
5882 |
Thu, 12 April 2012 12:19 By: Robinson S |
Integrate Jetty/OSGI in Linux Integrate Jetty/OSGI in Linux |
6609 |
Tue, 06 March 2012 12:11 By: chen shun |
Installation path containing bracket issue |
6045 |
Fri, 02 March 2012 02:23 By: qiu xiao fan |
Exporting a bundle with dependencies with another bundles Exporting a bundle with dependencies with another bundles By: Pablo G on Mon, 16 January 2012 |
6552 |
Thu, 01 March 2012 09:50 By: Kris Reid |
export product to linux - segmentation fault OSGi application exported to linux causes segmentation fault |
7027 |
Tue, 21 February 2012 14:32 By: Kris Reid |
Add Server Admin panel in own RCP Application Add Server Admin panel in RCP Application By: shibaji on Fri, 21 October 2011 |
6307 |
Tue, 08 November 2011 21:03 By: John Steele |
OSGI Eclipse Create in Plugin project |
7074 |
Thu, 13 October 2011 05:44 By: karthik elavan |
Equinox Bundles not supported yet in virgo PDE bundle and Bundle project By: duanqi on Mon, 29 August 2011 |
6496 |
Mon, 29 August 2011 10:08 By: duanqi |
Bind Exception Jetty bind exception persisting after port is changed |
7422 |
Fri, 22 July 2011 16:04 By: tepes.lucian.victor |
Eclipse plugins cooperation Is it possible access from one plugin to another as in OSGi service |
5630 |
Thu, 30 June 2011 18:19 By: Kaloyan Raev |
Eclipse RCP wont display "Hello World" in console By: wapt49 on Fri, 10 June 2011 |
14069 |
Tue, 21 June 2011 20:26 By: Kaloyan Raev |
Using OSGi to simplify user experience around virtualization Using OSGi to simplify user experience around virtualization |
7427 |
Mon, 21 March 2011 09:09 By: Valentine |
Running a RCP plugin dynamically from another project How to Add and run a RCP hello world plugin from another project dynamically |
6157 |
Tue, 01 February 2011 07:19 By: Kaloyan Raev |
New project forum available Please post any new topics there |
5670 |
Mon, 31 January 2011 18:29 By: Kaloyan Raev |
Naming of the warproducts contribution |
4983 |
Mon, 31 January 2011 18:18 By: Kaloyan Raev |
First Libra CQ |
5552 |
Thu, 20 January 2011 19:58 By: Holger Staudacher |
Creation Review successful |
5519 |
Wed, 12 January 2011 22:01 By: Kaloyan Raev |
Creation Review delayed because of trademark check |
6646 |
Wed, 29 December 2010 18:50 By: Werner Keil |
Short name for the project Any suggestions? |
20649 |
Wed, 22 December 2010 07:49 By: Kaloyan Raev |
RAP applications... By: Tom H on Fri, 10 December 2010 |
5073 |
Fri, 10 December 2010 13:16 By: Kaloyan Raev |
Development Infrastructure |
6336 |
Fri, 26 November 2010 12:05 By: Holger Staudacher |
OSGi Enterprise Tools pre-Creation Review public phone call |
8424 |
Fri, 19 November 2010 17:06 By: Kaloyan Raev |
tomcat 5.5 + birt |
6202 |
Fri, 12 November 2010 21:10 By: Kaloyan Raev |
Interview for JAXenter |
6154 |
Thu, 11 November 2010 13:24 By: Kaloyan Raev |
Proposal document updated |
5219 |
Thu, 04 November 2010 17:37 By: Kaloyan Raev |
Screencast demonstrating the OSGi facet |
6727 |
Tue, 02 November 2010 17:01 By: Glyn Normington |
Demo of Virgo Tools, Wed 20 Oct, 9:30 am UTC |
12968 |
Tue, 26 October 2010 09:27 By: Martin Lippert |
BoF at the Eclipse Summit Europe |
5247 |
Mon, 25 October 2010 18:57 By: Holger Staudacher |
Contribution suggestion: WAR Products |
8328 |
Wed, 20 October 2010 11:54 By: Holger Staudacher |
Virgo tooling |
8881 |
Mon, 18 October 2010 08:29 By: Kaloyan Raev |
Welcome to eclipse.osgi-enterprise-tools |
6896 |
Wed, 13 October 2010 19:55 By: Eclipse Webmaster |
