Topic |
Replies |
Views |
Last message |
Report is erroring out with an error in onFetch method. Error while generating a report. |
1 |
2377 |
Tue, 31 July 2012 15:15 By: Jason Weathersby |
How to set text in master page header using data from report? |
5 |
8131 |
Tue, 31 July 2012 13:15 By: Ricardo Rodrigues |
How to create functions which can be reused in different chart script |
7 |
7255 |
Tue, 31 July 2012 03:50 By: Jason Weathersby |
How to change Y Series to reflect data in chart |
2 |
2197 |
Mon, 30 July 2012 20:06 By: Matt Rhoads |
Passing file to remote server Using a XML file parameter By: Dave C on Mon, 30 July 2012 |
1 |
1680 |
Mon, 30 July 2012 17:24 By: Jason Weathersby |
can't load birt-viewer on hosting,frameset was not recognized |
2 |
4061 |
Mon, 30 July 2012 16:51 By: Jason Weathersby |
RCP Designer 4.2: Script tab is blank |
3 |
3259 |
Mon, 30 July 2012 15:36 By: Jason Weathersby |
Handling the BIRT Report large amount of Data |
2 |
2486 |
Fri, 27 July 2012 16:52 By: Annette Rego |
Report viewer on Tomcat Multi users running same report By: Dave C on Thu, 26 July 2012 |
2 |
2278 |
Fri, 27 July 2012 12:18 By: Dave C |
Being Prompted for Parameters Again After Choosing to Print |
8 |
3712 |
Thu, 26 July 2012 22:23 By: Jason Weathersby |
COM.ibm.db2.jdbc.net.DB2Driver (v8.1) - for db2 Problem in preview results using a type jdbc driver |
3 |
4463 |
Thu, 26 July 2012 22:09 By: Jason Weathersby |
BIRT Displaying new report below the current report in BIRT |
1 |
1551 |
Thu, 26 July 2012 22:06 By: Jason Weathersby |
Create my own parameter window? It's possible to create my own parameter window? |
1 |
3698 |
Thu, 26 July 2012 22:03 By: Jason Weathersby |
Cannot run report properly while using aggregations |
6 |
3391 |
Thu, 26 July 2012 21:56 By: Jason Weathersby |
Multiple values for dynamic parameter Multiple values for dynamic parameter By: A R on Wed, 11 July 2012 |
6 |
4514 |
Thu, 26 July 2012 21:38 By: Jason Weathersby |
Placing library in RAP environment |
7 |
7067 |
Wed, 25 July 2012 04:07 By: Jay Hamilton |
Dynamic text with page number |
6 |
6876 |
Tue, 24 July 2012 20:53 By: Jason Weathersby |
How to hide crosstab columns at runtime (in Excel) |
8 |
10793 |
Tue, 24 July 2012 20:16 By: Jason Weathersby |
Accessing any dataset from a scripted datasource |
14 |
20541 |
Tue, 24 July 2012 20:06 By: Jason Weathersby |
upgrate birt 2.3.2 to birt 4.2 |
9 |
7923 |
Tue, 24 July 2012 19:56 By: Jason Weathersby |
Convert crosstable to chart with DE API |
2 |
2245 |
Tue, 24 July 2012 09:49 By: David Vinicz |
Creating BIRT report with Tags. |
2 |
2552 |
Tue, 24 July 2012 08:10 By: BRAROU NABIL |
BIRT Chart Engine Tutorial |
3 |
5979 |
Tue, 24 July 2012 06:24 By: Jan Meier |
Hive and Birt |
9 |
11572 |
Tue, 24 July 2012 01:31 By: Jason Weathersby |
BIRT SWT + dynamic data |
1 |
4095 |
Tue, 24 July 2012 01:13 By: Jason Weathersby |
Export report to excel Export report to excel By: A R on Fri, 20 July 2012 |
4 |
3524 |
Mon, 23 July 2012 16:47 By: A R |
Error when generating the Birt report BIRT |
1 |
2915 |
Fri, 20 July 2012 20:39 By: Jason Weathersby |
How to add HTML attributes in BIRT |
1 |
4969 |
Fri, 20 July 2012 20:38 By: Jason Weathersby |
Report eating memory in viewer Report eating memory in viewer |
1 |
1570 |
Fri, 20 July 2012 13:42 By: Robert Waltz |
Numbering Rows Numbering Rows by Group |
5 |
5686 |
Thu, 19 July 2012 07:41 By: Ingoos Ficher |
Deploying BIRT application to Geronimo 3.0 How best to package and deploy the BIRT runtime on Geronimo |
6 |
4169 |
Thu, 19 July 2012 00:46 By: Jason Weathersby |
Data Set Computed Column problem |
1 |
2552 |
Wed, 18 July 2012 23:59 By: Jason Weathersby |
BIRT temporary files cleanup By: sam va on Tue, 17 July 2012 |
5 |
4997 |
Wed, 18 July 2012 03:22 By: Jason Weathersby |
BIRT 4.2 Default Value for Dataset Input parameter is not working |
6 |
9141 |
Tue, 17 July 2012 21:56 By: Rama Krishna |
Editable Chart in BIRT doc file Not able to edit chart in BIRT doc file |
5 |
6261 |
Tue, 17 July 2012 11:58 By: Nitin Sharma |
Extending the BIRT viewer? |
1 |
3242 |
Tue, 17 July 2012 11:34 By: sam va |
Birt report export to excel error Birt report export to excel error |
4 |
10648 |
Tue, 17 July 2012 11:00 By: Peter Lux |
Birt rcp report designer 4.2.0 does not lauch |
6 |
10787 |
Tue, 17 July 2012 03:12 By: Jason Weathersby |
Support for Multiple Excel worksheets |
5 |
8858 |
Tue, 17 July 2012 02:50 By: Jason Weathersby |
Example for drill down feature By: Anurag on Mon, 26 September 2011 |
4 |
15330 |
Tue, 17 July 2012 02:48 By: Jason Weathersby |
Only one column in crosstab |
2 |
1855 |
Tue, 17 July 2012 02:43 By: Jason Weathersby |
Stored Procedure Stored Procedure By: A R on Fri, 13 July 2012 |
1 |
1632 |
Fri, 13 July 2012 22:48 By: A R |
Re: Setting Persistent Global Variable from DataSet |
6 |
11294 |
Fri, 13 July 2012 14:17 By: Eleanor Dilay |
How to get chart legend value as an input in parameter of target report |
2 |
6302 |
Fri, 13 July 2012 10:29 By: Sameer Singh |
Return a byte[] array from Java extension function to JavaScript |
5 |
13656 |
Fri, 13 July 2012 06:01 By: karthik singavel |
How to display table based on dynamic table name |
5 |
7404 |
Thu, 12 July 2012 16:44 By: Jason Weathersby |
How to pass a parameter with in the page?? I am able to pass a parameter through a pop-up and get the results. With in the page how can I pass a parameter?? |
4 |
3121 |
Wed, 11 July 2012 23:38 By: Jason Weathersby |
Report Designer's Web viewer error |
1 |
4150 |
Wed, 11 July 2012 23:33 By: Jason Weathersby |
which event occurs when we close the report in report viewer ?? |
1 |
2089 |
Wed, 11 July 2012 20:07 By: Jason Weathersby |
Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site Unsigned Birt Chart Framework Feature and Plugin for Custom Update Site |
3 |
2609 |
Wed, 11 July 2012 18:44 By: Vinay Kumar |
Remove BIRT database connection |
1 |
2494 |
Wed, 11 July 2012 17:25 By: Jason Weathersby |
Cognos migration to BIRT Cognos migration to BIRT |
1 |
2741 |
Wed, 11 July 2012 17:24 By: Jason Weathersby |
Duplicate call to Store Procedure birt duplicate calls to store procedure using scripted data source |
1 |
2650 |
Wed, 11 July 2012 17:19 By: Jason Weathersby |
Addition of two number fields Example(Java script through expression builder) I need one complete script for adding two fields Under Expression Builder |
3 |
5480 |
Wed, 11 July 2012 17:04 By: Jason Weathersby |
Generate excel reports |
1 |
2111 |
Tue, 10 July 2012 18:17 By: Michael Williams |
Incorrect pagination for a report with chart and tabular data. By: R J on Fri, 06 July 2012 |
4 |
2975 |
Tue, 10 July 2012 02:29 By: Michael Williams |
BIRT Problem in Export into Excel sheet BIRT Problem in Export into Excel sheet |
4 |
4965 |
Mon, 09 July 2012 23:57 By: Michael Williams |
how to change excel sheet name? |
3 |
9871 |
Mon, 09 July 2012 23:32 By: Michael Williams |
birt when group count is equal to page break in next page extra group header appears with no data birt group count is equal to page break on the table then next group header repeat with no data |
12 |
11370 |
Mon, 09 July 2012 23:25 By: Michael Williams |
How to add a value in dynamic filter to select all the values of that filter |
1 |
2431 |
Mon, 09 July 2012 22:46 By: Michael Williams |
web service data source and security By: Eclipse User on Tue, 29 April 2008 |
1 |
11424 |
Mon, 09 July 2012 15:38 By: Jana Fischereit |
Error in Localization? By: Dnns . on Thu, 21 June 2012 |
17 |
6858 |
Mon, 09 July 2012 08:17 By: Dnns . |
how to change export file name |
2 |
9374 |
Mon, 09 July 2012 02:02 By: smith link |
Adhoc Reporting in Open Source BIRT By: sam va on Tue, 13 September 2011 |
9 |
6318 |
Sat, 07 July 2012 03:17 By: Jason Weathersby |
Output Format Doubt reg Output Format By: A R on Thu, 05 July 2012 |
2 |
2198 |
Fri, 06 July 2012 20:32 By: A R |
SEVERE: An exception occurred during processing.../SELECT command denied to user... When I deploy the report in the production server, BIRT throws an exception... |
2 |
7073 |
Fri, 06 July 2012 15:17 By: sidharth mv |
How to save old BIRT rptdesign in newer version? By: R J on Thu, 05 July 2012 |
2 |
4667 |
Fri, 06 July 2012 14:28 By: Jason Weathersby |
Values in a chart are not in sorting order Values in a chart are not in sorting order By: A R on Wed, 27 June 2012 |
3 |
2438 |
Thu, 05 July 2012 18:24 By: A R |
Change Table Group interval in script |
2 |
3865 |
Thu, 05 July 2012 15:27 By: karvesh ghunsam |
Load font by relative path instead of full path for birt 3.7.2 |
12 |
14631 |
Thu, 05 July 2012 14:21 By: Jason Weathersby |
Using BIRT Parameter with LIKE |
1 |
2249 |
Thu, 05 July 2012 14:18 By: Jason Weathersby |
Report Design Perspective missing from Open Perspective Window issue with BIRT installation, cannot see Report Design perspective |
3 |
9034 |
Thu, 05 July 2012 13:34 By: Jason Weathersby |
Several table filters : "or" condition |
24 |
23068 |
Wed, 04 July 2012 14:51 By: Stephane Turpin |
Performance analyasis of BIRT I need to know 1. Time required to generate the report. 2. Heap usage. |
0 |
17153 |
Wed, 04 July 2012 14:05 By: Neeta Kulkarni |
fixed chart bar width fixed chart bar width |
16 |
8836 |
Tue, 03 July 2012 17:34 By: Hao Song |
How to color only specific records within list table? |
2 |
2096 |
Tue, 03 July 2012 16:06 By: Dejan Vujanic |
How to automatically change fonts on all LABELS ,DETAILS ROWS and master page FOOTERS AND HEADERS? |
2 |
2597 |
Tue, 03 July 2012 12:57 By: Dejan Vujanic |
JDBC Driver problem for MSSQL- Schema not showing up in Data Source |
2 |
3770 |
Tue, 03 July 2012 12:32 By: Madhura Damare |
BIRT support for PDF and Excel report Generation |
4 |
3774 |
Tue, 03 July 2012 09:57 By: Sneha Patil |
White space where rows are empty Inner table is sparse, outer table displays white space for empty rows |
5 |
10339 |
Mon, 02 July 2012 22:14 By: Jason Weathersby |
pdf generator's source code Where can I get iText source cod? |
1 |
2220 |
Mon, 02 July 2012 05:43 By: Toshiaki Motegi |
library with joint data set not setting parameter By: mike b on Wed, 27 June 2012 |
4 |
2490 |
Fri, 29 June 2012 18:58 By: Jason Weathersby |
Bug on the two dimensional with depth chart? |
6 |
3778 |
Fri, 29 June 2012 17:58 By: Jason Weathersby |
Bug 382145 - Render Task order of magnitude slower in BIRT 3.7.2 than BIRT 2.6.2 |
1 |
2769 |
Fri, 29 June 2012 17:49 By: Jason Weathersby |
Group Totals are not calculated correctly if Table > Properties > Sort By Groups is set to Fal Group Totals are not calculated correctly if Table > Properties > Sort By Groups is set to False |
2 |
2150 |
Fri, 29 June 2012 14:34 By: ivkina Mising name |
Does Birt 2.3.x support IE9? |
3 |
2643 |
Fri, 29 June 2012 05:48 By: smith link |
Zero Display ... Zero Display ... By: A R on Mon, 18 June 2012 |
19 |
6024 |
Thu, 28 June 2012 18:23 By: A R |
question on report design |
7 |
3108 |
Thu, 28 June 2012 15:54 By: Jason Weathersby |
'Internal error' when opening PDF preview window |
3 |
2764 |
Thu, 28 June 2012 14:22 By: Jason Weathersby |
How to use charAt() in a highlight expression? |
11 |
7805 |
Thu, 28 June 2012 14:18 By: Jason Weathersby |
Birt Memory Usage Memory Usage |
9 |
10038 |
Thu, 28 June 2012 13:42 By: Stacey Hopkins |
Java Crashing when using BIRT within RCP |
0 |
17511 |
Thu, 28 June 2012 13:41 By: Gourishankar Menon |
Error while starting the GlassFish server + BIRT 3.7.1 |
0 |
18873 |
Wed, 27 June 2012 18:18 By: Claude B |
Problem with creating radar chart |
3 |
2932 |
Wed, 27 June 2012 15:15 By: hage Mising name |
Problem with Script Datasource Getting error running a java script |
4 |
18703 |
Wed, 27 June 2012 14:14 By: Carlos Ferrer |
Performance of Birt By time, memory, threats |
0 |
17019 |
Wed, 27 June 2012 12:24 By: Neeta Kulkarni |
Adobe live cycle & POI comparison Comparision of Adobe livecycle & POI |
0 |
17111 |
Wed, 27 June 2012 12:20 By: Neeta Kulkarni |
bigint problem |
3 |
3444 |
Wed, 27 June 2012 02:01 By: smith link |
How to override the function for the "Finish" button on a Data Source Wizard Page? I want to override the code behind the "Finish" button on a custom data source wizard page. This is needed for authenticating to a server. |
3 |
2716 |
Wed, 27 June 2012 01:08 By: Jason Weathersby |
BIRT chart engine issue client disconnect |
3 |
4418 |
Wed, 27 June 2012 00:30 By: Jason Weathersby |
Custom Parameter Page in Run Time |
4 |
3391 |
Tue, 26 June 2012 18:37 By: Eclipse user Chennai |
How to influence sorting rules in a group |
5 |
3362 |
Tue, 26 June 2012 15:56 By: Jason Weathersby |
Best SWT emitter? |
2 |
2811 |
Tue, 26 June 2012 05:08 By: Alexey Romanov |
Suppress Message "The resource of this report item is not reachable" By: mike b on Mon, 25 June 2012 |
2 |
7450 |
Mon, 25 June 2012 20:41 By: Jason Weathersby |
[HELP] Two data sources. How to select data sources. |
1 |
1988 |
Mon, 25 June 2012 20:18 By: Jason Weathersby |
Security access |
1 |
2232 |
Mon, 25 June 2012 19:53 By: Jason Weathersby |
How to create subreport within birt report using scripted dataset How to create subreport within birt report using scripted dataset |
5 |
15516 |
Mon, 25 June 2012 06:19 By: Amit akvhbti606@gmail.com |
How to hide the first line in cross table |
2 |
2155 |
Mon, 25 June 2012 03:08 By: smith link |
Display asterisk for null values in Bar chart By: S K on Tue, 19 June 2012 |
3 |
4397 |
Fri, 22 June 2012 22:47 By: S K |
Suppress group headers based on condition By: S K on Thu, 21 June 2012 |
3 |
2441 |
Fri, 22 June 2012 22:34 By: Jason Weathersby |
look-ahead aggregate look-ahead aggregate |
3 |
2390 |
Fri, 22 June 2012 21:09 By: Jason Weathersby |
JSP-Files behind Toolbar By: Dnns . on Fri, 22 June 2012 |
3 |
3027 |
Fri, 22 June 2012 21:01 By: Jason Weathersby |
genreport -m render split pdf file |
3 |
5350 |
Fri, 22 June 2012 20:44 By: Jason Weathersby |
How to use BIRT 3.7.1 on NetBeans? |
4 |
15099 |
Fri, 22 June 2012 15:52 By: Jason Weathersby |
Birt Report Problems in Browser Will not load the GET page after running Reports |
1 |
3954 |
Fri, 22 June 2012 15:39 By: Jason Weathersby |
Problem in executing the birt report from JFace Null pointer exception occuring while running birt report from JFace application |
1 |
2882 |
Thu, 21 June 2012 20:37 By: Jason Weathersby |
Table grouping BIRT.- java heap space |
10 |
9463 |
Thu, 21 June 2012 20:22 By: Jason Weathersby |
Can BIRT template accept images from an XML datasource |
1 |
2242 |
Thu, 21 June 2012 20:14 By: Jason Weathersby |
Hide empty table |
4 |
13165 |
Thu, 21 June 2012 09:04 By: Bluish Joe |
How to hide the table header when there is no content in the table ? |
4 |
23767 |
Thu, 21 June 2012 08:57 By: Bluish Joe |
How to write an expression which uses items from multiple data sets? |
1 |
2508 |
Wed, 20 June 2012 21:33 By: Jason Weathersby |
Some Questions By: Dnns . on Wed, 30 May 2012 |
22 |
12696 |
Wed, 20 June 2012 19:42 By: Dnns . |
0 |
15093 |
Wed, 20 June 2012 16:15 By: Raishad |
0 |
15610 |
0 |
15786 |
0 |
16673 |
0 |
17225 |
Can BIRT supports updatation of PDF?? |
2 |
2733 |
Wed, 20 June 2012 04:00 By: Neeta Kulkarni |
BIRT Delivery Mechanism Can Birt provide automatic email seding functionality ? |
1 |
2068 |
Tue, 19 June 2012 21:26 By: Jason Weathersby |
BIRT Annotations Does BIRT3.7.2 support any annotations? |
3 |
2767 |
Tue, 19 June 2012 21:24 By: Jason Weathersby |
XML DataSource report with XML tag as parameter XML tag as parameter to another xml dataset |
3 |
2406 |
Mon, 18 June 2012 20:34 By: Jason Weathersby |
Best practice for managing design, test and production environments |
3 |
3195 |
Mon, 18 June 2012 15:48 By: Jason Weathersby |
BIRT timezone value |
1 |
7513 |
Mon, 18 June 2012 15:41 By: Jason Weathersby |
Some text in charts are not anti-aliased |
5 |
2481 |
Fri, 15 June 2012 21:07 By: Shannon Hardt |
Runtime parameter issue Runtime parameter issue By: A R on Wed, 13 June 2012 |
6 |
2583 |
Fri, 15 June 2012 20:16 By: A R |
Call Javascript From Report Drill Down |
3 |
5517 |
Fri, 15 June 2012 18:00 By: Jason Weathersby |
How to import (include) new font in BIRT? |
1 |
4269 |
Fri, 15 June 2012 17:58 By: Jason Weathersby |
rpt document generated with large size (900 MB) experiencing problem with the size of rpt document generated as 900 MB |
1 |
3171 |
Fri, 15 June 2012 17:49 By: Jason Weathersby |
Additional Stored Proc Question Parameters and Stored Proc |
7 |
3884 |
Thu, 14 June 2012 19:58 By: Jason Weathersby |
BIRT features BIRT features |
3 |
2728 |
Thu, 14 June 2012 19:57 By: Jason Weathersby |
NPE in ObjectWriter.write using BIRT 2.6 NPE in ObjectWriter.write using BIRT 2.6 |
20 |
8118 |
Thu, 14 June 2012 18:41 By: Jason Weathersby |
Multiple graphs per report By: Olly on Mon, 11 June 2012 |
11 |
6600 |
Thu, 14 June 2012 12:37 By: Olly |
replacing string with parameter Replae Funcion By: A R on Tue, 12 June 2012 |
3 |
3111 |
Thu, 14 June 2012 08:12 By: Dnns . |
Custom StyleSheet not included when viewed? |
1 |
1703 |
Wed, 13 June 2012 21:24 By: Jason Weathersby |
Problem with Mysql Stored Procedure |
5 |
5815 |
Wed, 13 June 2012 03:10 By: karvesh ghunsam |
Replace Function syntax By: A R on Tue, 12 June 2012 |
0 |
17477 |
Tue, 12 June 2012 21:42 By: A R |
Linking query with Parameters in Data Set - Reports |
1 |
1792 |
Tue, 12 June 2012 20:37 By: david wilder |
BIRT Preview Report BIRT throwing error on one of the result set column |
2 |
3618 |
Tue, 12 June 2012 17:09 By: Carlos Ferrer |
Missing pre-defined styles for grid-row, grid-cell, table-row, table-cell Missing pre-defined styles for grid-row, grid-cell, table-row, table-cell |
2 |
2606 |
Tue, 12 June 2012 15:10 By: ivkina Mising name |
Decreasing image quality in PDF-Export |
9 |
10642 |
Tue, 12 June 2012 15:04 By: Jason Weathersby |
org.eclipse.birt.core.archive.FolderArchive Example? |
5 |
5295 |
Tue, 12 June 2012 14:55 By: Jason Weathersby |
API: setProperty() with Type |
2 |
5314 |
Tue, 12 June 2012 09:13 By: Chris K |
Debugging BIRT Source (2.6.0) |
3 |
3584 |
Mon, 11 June 2012 20:34 By: Boyd Nolan |
Export to DOC Microsoft Word Issue |
7 |
10596 |
Mon, 11 June 2012 17:31 By: Jason Weathersby |
Chart not visible when exporting to Excel |
4 |
4512 |
Mon, 11 June 2012 16:47 By: Jason Weathersby |
How to script a Stored Procedure on beforeOpen |
14 |
11026 |
Mon, 11 June 2012 14:44 By: Jason Weathersby |
org.eclipse.birt.report.exception.ViewerException: There is no report design object available. org.eclipse.birt.report.exception.ViewerException: There is no report design object available. |
7 |
19284 |
Mon, 11 June 2012 14:40 By: Jason Weathersby |
String matching for data in grid Using BIRT eclipse plug-in designer By: Olly on Mon, 04 June 2012 |
3 |
7296 |
Mon, 11 June 2012 14:16 By: Olly |
PHP Birt Chart Drill Down Drilling down into more than one report |
1 |
2913 |
Mon, 11 June 2012 03:28 By: karvesh ghunsam |
Errors occurred when generating the report document for the report element with ID 217. (Element ID: Errors occurred when generating the report document for the report element with ID 217. (Element ID:217) |
4 |
8267 |
Sat, 09 June 2012 05:01 By: Soumita Saha |
Arial font required in PDF (BIRT pdf renderer, Linux) |
1 |
16004 |
Fri, 08 June 2012 12:21 By: Rick Missing name |
A few questions on Crosstab |
1 |
2113 |
Thu, 07 June 2012 21:53 By: Jason Weathersby |
Activities do not hide BIRT views |
5 |
4345 |
Thu, 07 June 2012 21:39 By: Jason Weathersby |
a ReportServiceException while running the report using BIRT Viewer 3.7.1 |
2 |
5287 |
Thu, 07 June 2012 09:03 By: Claude B |
Filtering crosstab data by dates crosstab filter |
3 |
4576 |
Thu, 07 June 2012 00:06 By: Jason Weathersby |
Problem with namespace on web service parameters |
1 |
3064 |
Wed, 06 June 2012 20:12 By: Jason Weathersby |
Excel Report Error Excel Report Error |
2 |
5117 |
Wed, 06 June 2012 09:57 By: Deepak P |
No SOAP parameters displayed for my web service when using the BIRT Data Set wizard |
2 |
3787 |
Wed, 06 June 2012 06:10 By: Paul Ramsden |
Bookmarks missing from PDF Reports |
4 |
2586 |
Tue, 05 June 2012 22:22 By: Jason Weathersby |
Any way to set page break at render time? |
4 |
3548 |
Tue, 05 June 2012 17:08 By: Denis Volkov |
Exporting Dynamic Images From BIRT Is there an enhancement in the works or a plugin for this task |
3 |
2808 |
Tue, 05 June 2012 15:08 By: Jason Weathersby |
Forecast using BIRT BIRT Forecast integration suing BIRT |
1 |
1950 |
Tue, 05 June 2012 15:00 By: Jason Weathersby |
Problem with executing Stored Proc in BIRT Having issues accessing DB2 Z/OS v9.1 via birt |
7 |
5624 |
Mon, 04 June 2012 17:36 By: Carlos Ferrer |
How to avoid ReferenceError error messages? |
2 |
5301 |
Thu, 31 May 2012 21:23 By: Alexey Romanov |
How to get the absolute location of a data source |
5 |
2583 |
Thu, 31 May 2012 21:19 By: Jason Weathersby |
Question on BIRT 3.7.2 export PDF BIRT Export PDF Question |
6 |
3649 |
Thu, 31 May 2012 20:09 By: Jason Weathersby |
Themes missing when deploying to Tomcat Theme's are not being shown when deploying to Tomcat 6.0 |
4 |
3440 |
Thu, 31 May 2012 00:58 By: Jason Weathersby |
Facing an issue while adding a New iServer Profile Facing an issue while adding a New iServer Profile |
1 |
1736 |
Thu, 31 May 2012 00:49 By: Jason Weathersby |
java.lang.Integer cannot be cast to java.lang.Long - When trying to connect to MySQL |
1 |
3555 |
Wed, 30 May 2012 23:26 By: Jason Weathersby |
Build DataSource from code - without external resources? By: Anton on Fri, 25 November 2011 |
3 |
3156 |
Wed, 30 May 2012 23:24 By: Jason Weathersby |
BIRT Webservice ODA integration with JIRA How to deal with JIRA login token creation and passing |
3 |
3834 |
Wed, 30 May 2012 22:26 By: Jay Hamilton |
Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value Data has columns for each available series, need to suppress display based on another column value |
29 |
11242 |
Wed, 30 May 2012 20:14 By: Tom Yamada |
Customising BIRT Sample Viewer How to achieve the customization to add image etc. By: GG - on Sat, 03 March 2012 |
8 |
9111 |
Wed, 30 May 2012 16:20 By: Jason Weathersby |
Avoid aggregation for y-axis |
4 |
4313 |
Wed, 30 May 2012 09:42 By: Felix Ziesel |
Not able to sort on Grand Total in Crosstab Report |
1 |
2146 |
Tue, 29 May 2012 16:01 By: Jason Weathersby |
java.lang.ClassCastException: java.lang.OutOfMemoryError cannot be cast to java.lang.Exception |
6 |
10044 |
Tue, 29 May 2012 15:29 By: Jason Weathersby |
Tooltip location |
1 |
10479 |
Tue, 29 May 2012 12:20 By: Charu Sharma |
Hide column in a cross tab |
1 |
3938 |
Tue, 29 May 2012 09:38 By: Tomas Greif |
How to display multiple COUNT results in bar chart? How to set bar chart to display result columns from multi COUNTS |
9 |
11916 |
Tue, 29 May 2012 09:08 By: Tomas Greif |
Split the results in to Financial Quarters Split the results in to Financial Quarters By: A R on Thu, 24 May 2012 |
3 |
2735 |
Tue, 29 May 2012 08:49 By: Tomas Greif |
rap using the birt3.7.1, IReportEngineFactory is null |
2 |
3372 |
Mon, 28 May 2012 08:04 By: ocean xue |
How can I pass a parameter to my report? Trying to set and pass a parameter to a BIRT report created by the BIRT Report Designer through the BIRT API |
1 |
5259 |
Fri, 25 May 2012 14:32 By: Jason Weathersby |
BIRT with Multiple Data sets BIRT with Multiple Data sets |
1 |
4739 |
Fri, 25 May 2012 14:23 By: Jason Weathersby |
ReferenceError: "BarSeriesImpl" is not defined. at line X of chart script:'' When trying to run bar chart report in some system |
1 |
4423 |
Fri, 25 May 2012 11:18 By: Dejan Vujanic |
Problem deploying script data source report Report works in Eclipse, fails with web viewer |
6 |
3976 |
Thu, 24 May 2012 20:25 By: Jason Weathersby |
Not able to Install BIRT 3.7.2 on JVM 64 bit |
1 |
2994 |
Thu, 24 May 2012 20:23 By: Jason Weathersby |
Export feature in report Export feature in report - in SOA Soft environment By: A R on Mon, 21 May 2012 |
7 |
2928 |
Wed, 23 May 2012 22:01 By: Jason Weathersby |
Viewer request encoding |
5 |
4159 |
Wed, 23 May 2012 21:07 By: Jason Weathersby |
Birt styles priority Birt styles are broken when the report is embedded in uPortal |
5 |
3431 |
Tue, 22 May 2012 21:13 By: Jason Weathersby |
Button in a BIRT report |
4 |
7334 |
Mon, 21 May 2012 17:55 By: Jason Weathersby |
