Topic |
Replies |
Views |
Last message |
Can I force the report to run in frameset? |
0 |
3652 |
Wed, 26 August 2015 17:30 By: Justin Husted |
Enumerating installed fonts? |
2 |
4822 |
Wed, 26 August 2015 14:58 By: Piero Campalani |
Migration BIRT 4.2.2 to 4.4.2: Does Formatter.format behave differently? A printed value differs from one version to another printing the same report. |
0 |
3560 |
Wed, 26 August 2015 12:19 By: Cristiano Zanotti |
Does Eclipse BIRT Supports Easy Script? Does Eclipse BIRT Supports Easy Script to pass Excel formulas to output |
6 |
3934 |
Wed, 26 August 2015 08:50 By: vinay kalyan |
Stepwise graph - same x-axis values with different y-axis values How to get BIRT to plot same x-axis values with different y-axis values |
0 |
4137 |
Mon, 24 August 2015 10:17 By: Pau Barter |
Interfacing BIRT Report Viewer with ASP.NET How to get the BIRT Report Viewer open in a button Click of a webpage. |
3 |
4977 |
Mon, 24 August 2015 03:21 By: Suvarnni M V |
Set colors for barchart globally |
1 |
2393 |
Fri, 21 August 2015 08:12 By: donino donino |
how to read value of a column into another dataset's script I have a dataset feching some values , now i want to read that value into another dataset's script console, I dont know how to achieve that please provide me a solution. |
0 |
8353 |
Wed, 19 August 2015 14:03 By: Arshad Khan |
Error creating joint data set using BIRT Error return when creating joint data set using BIRT |
2 |
2460 |
Tue, 18 August 2015 23:35 By: Tara Jan |
Hostname in Birt report Hostname in Birt report |
1 |
2399 |
Tue, 18 August 2015 18:02 By: Russell Bateman |
Scatter plot with numeric X & Y values and points linked Plotting a scatter chart with points linked by order instead of value |
3 |
2313 |
Tue, 18 August 2015 15:22 By: Lukas Serj |
Cannot load JDBC Driver class: com.mysql.jdbc.Driver. Report does not display |
0 |
9258 |
Tue, 18 August 2015 05:22 By: Scott Elliott |
Birt reports cause temporary files to be generated in /Tmp folder Birt reports cause temporary files to be generated |
0 |
8313 |
Tue, 18 August 2015 05:11 By: Naveen Kumar |
[HOW] : Dynamically changing Label value Label value should be changed dynamically through java code |
5 |
6147 |
Mon, 17 August 2015 22:09 By: Mario Flores |
Indigo API Online Documentation no longer available |
0 |
8134 |
Mon, 17 August 2015 09:26 By: Paul Cooper |
Cascading parameter on upper parameter of type date Using cascading parameters if the upper parameter is of datatype date |
0 |
3296 |
Fri, 14 August 2015 13:19 By: Christian Wagner |
Cross tab month names and dates How to display monthname, weeknumber and day of month |
0 |
5074 |
Fri, 14 August 2015 12:45 By: Jeroen Bosch |
Incorrect Image Dimensions |
0 |
3402 |
Thu, 13 August 2015 11:06 By: Martin Jay |
Excel file name at BIRT Set Excel file name at BIRT Report Desing |
4 |
6683 |
Thu, 13 August 2015 07:25 By: Nacho Excelia |
use parameter to set runtime xlsx report document passing parameter value to runtime report document name |
5 |
5611 |
Wed, 12 August 2015 20:29 By: Jeff Stouse |
Date function |
1 |
2980 |
Wed, 12 August 2015 20:27 By: Jesse Freeman |
Date in chart title searching a way to insert date in the chart's title |
1 |
1848 |
Wed, 12 August 2015 17:18 By: Jesse Freeman |
1 |
1911 |
Wed, 12 August 2015 17:17 By: Jesse Freeman |
1 |
2343 |
Wed, 12 August 2015 17:16 By: Jesse Freeman |
ODA Connection |
1 |
3579 |
Wed, 12 August 2015 16:11 By: Jesse Freeman |
Failed to initialize emitter |
1 |
7811 |
Wed, 12 August 2015 16:08 By: Jesse Freeman |
Integrating BIRT 4.5 into web application with tomcat8 NoClassDefFoundError: org/eclipse/core/runtime/CoreException |
1 |
6860 |
Wed, 12 August 2015 06:55 By: Marina Orth |
Birt SWT Emitter |
0 |
2900 |
Mon, 10 August 2015 16:06 By: Thibault Le Ouay |
JBoss Deployment ( 1 2) By: Alex on Sat, 26 January 2008 |
273 |
37484 |
Mon, 10 August 2015 08:45 By: Eclipse User |
Value of Report Parameters |
3 |
2483 |
Fri, 07 August 2015 20:10 By: Jesse Freeman |
Birt Report in Eclipse i want to Display text(Popup Message) while not selecting any parameter |
3 |
5387 |
Fri, 07 August 2015 18:29 By: Jesse Freeman |
BIRT Report Viewer Multiple exceptions occurred |
1 |
4166 |
Thu, 06 August 2015 22:08 By: Jesse Freeman |
Password authentication fails for PostgreSQL server connection |
1 |
6264 |
Thu, 06 August 2015 21:15 By: Jesse Freeman |
BIRT Report Fails (Just shows frame) |
1 |
4597 |
Thu, 06 August 2015 21:05 By: Jesse Freeman |
how to add javascript widgets in report how to add javascript widgets in report |
1 |
7686 |
Thu, 06 August 2015 21:01 By: Jesse Freeman |
NullPointerException in BIRT web Services |
1 |
4512 |
Thu, 06 August 2015 20:55 By: Jesse Freeman |
[Resolve] How use variable BIRT_VIEWER_WORKING_FOLDER in java code |
1 |
4507 |
Thu, 06 August 2015 20:50 By: Jesse Freeman |
Export BIRT reports to PDF, Excel or Word is not working properly Export BIRT reports to PDF, Excel or Word is not working properly |
1 |
3631 |
Thu, 06 August 2015 20:46 By: Jesse Freeman |
How to format series labels of a BIRT chart by script |
1 |
5388 |
Thu, 06 August 2015 20:41 By: Jesse Freeman |
Migrating Cognos Reports to Birt Best approach for Migrating Cognos Reports to Birt By: Tn Ku on Mon, 13 July 2015 |
2 |
2186 |
Thu, 06 August 2015 20:38 By: Jesse Freeman |
BIRT 2.5 run-time is missing |
1 |
2234 |
Thu, 06 August 2015 20:31 By: Jesse Freeman |
Dynamic and static text in Master page header |
1 |
2604 |
Thu, 06 August 2015 20:27 By: Jesse Freeman |
Drill Down Functionality to hyperlink Drill Down Functionality to hyperlink |
1 |
3127 |
Thu, 06 August 2015 20:22 By: Jesse Freeman |
1 |
3243 |
Thu, 06 August 2015 20:21 By: Jesse Freeman |
Linked report To show on same details line |
1 |
3123 |
Thu, 06 August 2015 20:17 By: Jesse Freeman |
Column name equal to display name (Driver Impl) |
1 |
2983 |
Thu, 06 August 2015 20:14 By: Jesse Freeman |
Error happened while running the report-BIRT org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report |
1 |
6908 |
Thu, 06 August 2015 20:12 By: Jesse Freeman |
BIRT - how to draw a chart? |
1 |
2789 |
Thu, 06 August 2015 19:55 By: Jesse Freeman |
There is no report design object available |
1 |
2411 |
Thu, 06 August 2015 19:54 By: Jesse Freeman |
Farsi letters not displayed correctly in BiRT reports |
1 |
2892 |
Thu, 06 August 2015 19:52 By: Jesse Freeman |
Generate BIRT design from HTML page Is it possible? |
1 |
4325 |
Thu, 06 August 2015 19:48 By: Jesse Freeman |
Omniture Tags in BIRT Reports Omniture Tracking using Tags in BIRT Reports |
1 |
2434 |
Thu, 06 August 2015 19:38 By: Jesse Freeman |
Cant startup OSGI Framework |
1 |
4079 |
Thu, 06 August 2015 19:35 By: Jesse Freeman |
Excel Font changed after BIRT engine upgrade from 3.7 to 4.3.1 Excel font changed from serif to TimesNew Roman with BIRT 4.3.1 excel spudsoft emitter |
1 |
2844 |
Thu, 06 August 2015 19:31 By: Jesse Freeman |
passing date from client in birt |
0 |
3939 |
Thu, 06 August 2015 07:27 By: babburi raju |
remove embedded image |
1 |
3647 |
Wed, 05 August 2015 22:00 By: Jesse Freeman |
How to use value from one data set in other data set SQL select. How to use value from one data set in other data set SQL select. |
1 |
963 |
Wed, 05 August 2015 19:45 By: Jerry Sheets |
default value of report parameter how to get the default value? By: xoto on Thu, 12 August 2010 |
3 |
6542 |
Wed, 05 August 2015 17:19 By: udaya yarasi |
Birt Report Engine Model as an EMF Model |
0 |
4022 |
Wed, 05 August 2015 12:30 By: Thibault Le Ouay |
Nesting of Tables/Grids to avoid query attached to the element being executed |
0 |
4058 |
Tue, 04 August 2015 13:46 By: Nishant Mintri |
Access the report parameters as array |
0 |
3634 |
Tue, 04 August 2015 09:41 By: Juan Alfredo Santos Luque |
To fix bars width in the bar chart |
5 |
9494 |
Sat, 01 August 2015 08:02 By: babburi raju |
BIRT DE with POJO and ODA (not a Scripted Source) BIRT DE with POJO and ODA (not a Scripted Source) |
3 |
44958 |
Fri, 31 July 2015 11:56 By: Simone D\'Amario |
Report is running without asking for parameters |
1 |
2632 |
Thu, 30 July 2015 19:35 By: Jerry Sheets |
Error while running Birt Report through eclipse |
5 |
11263 |
Wed, 29 July 2015 12:52 By: Robert Unknown |
"Cannot get parameter type" exception in logs BIRT Viewer Runtime's "Cannot get parameter type" exception |
1 |
9109 |
Wed, 29 July 2015 11:46 By: Jernej Gosar |
Expand/Collapse by Column value |
2 |
2210 |
Tue, 28 July 2015 06:02 By: Layla Wolf |
Report Coupon Page Break? |
1 |
2911 |
Mon, 27 July 2015 14:17 By: Anthony Bone |
BIRT Extension - adding a new "Number Format" category |
0 |
2540 |
Mon, 27 July 2015 07:46 By: Amir Gr |
Loads locally but not on server |
1 |
1218 |
Thu, 23 July 2015 20:33 By: Tharpa Roberts |
Does BIRT integrate with Windows AD? BIRT Security |
1 |
1095 |
Thu, 23 July 2015 17:17 By: Jerry Sheets |
Group Footer not printing the calculated values correctly Group Footer |
0 |
4267 |
Wed, 22 July 2015 22:01 By: KRISHNAKUMAR CHINNASAMY |
Report works fine in RCP but loaded into application errors out. MySQL 5.5 and BIRT 3.7.1 MYSQL report issues |
2 |
43788 |
Wed, 22 July 2015 16:42 By: joujou joujou |
BIRT does not parse all Chinese characters in HTML An XML datasource contains HTML with Chinese characters encoded like , w |
1 |
3535 |
Wed, 22 July 2015 14:36 By: Mica J. Block |
HTML Entities in Private Font Area |
0 |
4122 |
Mon, 20 July 2015 16:02 By: Thomas P. |
How to design a bubble chart Data points with a same measure value are merged |
6 |
8736 |
Wed, 15 July 2015 14:02 By: donino donino |
Multiple Values to Display in a row Generate BIRT Report |
1 |
1088 |
Tue, 14 July 2015 20:17 By: Jerry Sheets |
Hyperlinks stopped linking Hyperlink menu appears but clicking does nothing |
2 |
1818 |
Tue, 14 July 2015 07:50 By: Nick Fortune |
Eclipse Mars has broken exisitng JDBC Data source connection to Oracle via. JDBC causes exception |
1 |
1067 |
Mon, 13 July 2015 10:17 By: Jim Seconde |
Data Set with multiple ref cursors Birt Data Set using procedure which returns multiple ref cursors |
0 |
2959 |
Fri, 10 July 2015 04:58 By: Mohammed Anwar |
Updating Birt Engine from 3.7 to 4.3 |
0 |
2544 |
Thu, 09 July 2015 12:59 By: Nishant Mintri |
Birt is not OSGi ready? [SOLVED] How can I deploy it inside a OSGi Ready Container |
10 |
10846 |
Thu, 09 July 2015 10:56 By: malnoe carolin |
New wizards menu not shown on Report Design perspective swith |
1 |
1292 |
Thu, 02 July 2015 21:14 By: Aboubacar Kaba |
View Report in Web Viewer Error Unable to use BIRT Web Viewer within Eclipse |
15 |
93801 |
Thu, 02 July 2015 09:49 By: Rajat Khedekar |
EMF object type in column outputs "null" in Web viewer while it works in preview |
1 |
2836 |
Tue, 30 June 2015 22:02 By: Aboubacar Kaba |
Can not load the report query: 61. Can not load the report query: 61. Errors occurred when generating the report document for the report element with ID 61. |
0 |
2282 |
Tue, 30 June 2015 11:24 By: Dominic Fenelon |
Query preview works; report generation fails Error message reported by report generation fails doesn't make sense |
4 |
7213 |
Fri, 26 June 2015 22:01 By: Jeff Stouse |
PDF: How to stretch last cell of inner table to cell height of outer table? |
1 |
2198 |
Fri, 26 June 2015 16:53 By: Jesse Freeman |
Waiting Status in HTML Reports generated in BIRT |
3 |
1979 |
Fri, 26 June 2015 16:48 By: Jesse Freeman |
NPE when rendering donut chart |
4 |
4034 |
Fri, 26 June 2015 16:44 By: Jesse Freeman |
Omniture Tracking script Hi, can we enable the omniture web usage tracking script inside the BIRT reports, we tried implementing the omniture script into BIRT report, but it is not pushing the report tags |
1 |
2933 |
Fri, 26 June 2015 16:28 By: Jesse Freeman |
Close window after printing report Close window after printing report |
0 |
2965 |
Thu, 25 June 2015 07:27 By: longtqdayma Mising name |
Chart Icon Missing |
7 |
2883 |
Thu, 25 June 2015 03:18 By: Rich Wellson |
Column value missing in BIRT report for Cassandra data source Column value missing in BIRT report for Cassandra data source |
0 |
2772 |
Tue, 23 June 2015 10:01 By: arun M R |
Chart Library for Standalone SWT Application? |
5 |
2369 |
Fri, 19 June 2015 11:31 By: Alexander pears |
rounded corners on chart container how do I do that? |
2 |
1913 |
Wed, 17 June 2015 22:22 By: Jesse Freeman |
WebService DataSet |
4 |
2140 |
Wed, 17 June 2015 22:07 By: Jesse Freeman |
Unable to run Hyperlink report from another hyperlink report with direct pdf export. Unable to run Graphical Hyperlink report from another Graphical hyperlink report will direct pdf export |
1 |
1419 |
Wed, 17 June 2015 21:50 By: Jesse Freeman |
4 byte UTF-8 Characters in PDF Report Generating PDF Report with 4 byte UTF-8 characters |
1 |
2188 |
Wed, 17 June 2015 21:47 By: Jesse Freeman |
PDF works, web viewer has problems PDF vs Web Viewer |
1 |
1596 |
Wed, 17 June 2015 21:45 By: Jesse Freeman |
White Space in PDF Unwanted white space at the bottom of pdfs |
3 |
5842 |
Wed, 17 June 2015 21:43 By: Jesse Freeman |
Passing multiple parameter values to a BIRT report |
1 |
3450 |
Wed, 17 June 2015 21:41 By: Jesse Freeman |
Parameter validation fails |
3 |
3610 |
Wed, 17 June 2015 21:27 By: Jesse Freeman |
Report Issues with intigration on web application Brit Report |
0 |
2440 |
Wed, 17 June 2015 08:20 By: Prasad MSD |
Highlight data using background image Asking for support on how to use an image dependent on the data in a table cell - instead of using a simple background color. |
1 |
3051 |
Fri, 12 June 2015 17:36 By: donino donino |
Birt Eclipse Questions regarding Birt Eclipse |
2 |
1243 |
Wed, 10 June 2015 08:38 By: Hemant Mehta |
Dynamic table header on pagebreak Pagebreak, dynamic,, table |
1 |
3049 |
Fri, 05 June 2015 21:20 By: Jesse Freeman |
Parameter with multiple entry Entering multiple value in parameter box |
1 |
3653 |
Fri, 05 June 2015 21:14 By: Jesse Freeman |
Manage webservice string return data as XML String to XML |
1 |
1782 |
Fri, 05 June 2015 21:10 By: Jesse Freeman |
[Luna] SQL Data Source connects, but returns no tables [Luna] SQL Data Source connects, but returns no tables |
1 |
2664 |
Fri, 05 June 2015 21:06 By: Jesse Freeman |
Chart not save correctly changes |
1 |
2338 |
Fri, 05 June 2015 21:02 By: Jesse Freeman |
Parameter with multi entry value, value, value |
1 |
3209 |
Fri, 05 June 2015 20:51 By: Jesse Freeman |
Aligning BIRT charts regardless of the legend/series name size Fix sizing the legends or wrapping the series titles. |
1 |
3481 |
Fri, 05 June 2015 20:44 By: Jesse Freeman |
Sharing Publishing BIRT reports distributing reports to end users with real-time data interactive charts |
1 |
3929 |
Fri, 05 June 2015 20:40 By: Jesse Freeman |
Long value being changed Computed column in data set does not act as expected |
2 |
2265 |
Fri, 05 June 2015 20:33 By: Jesse Freeman |
Birt footer problem in libre office |
1 |
3364 |
Fri, 05 June 2015 20:31 By: Jesse Freeman |
Securize report |
1 |
2882 |
Fri, 05 June 2015 20:29 By: Jesse Freeman |
Merge output several reports in only pdf |
1 |
3530 |
Fri, 05 June 2015 20:27 By: Jesse Freeman |
Table header and page break questions By: M S on Fri, 26 September 2014 |
3 |
5110 |
Thu, 04 June 2015 10:47 By: hatra atrin |
no Available Items in JDBC DataSet By: Eclipse User on Thu, 28 August 2008 |
3 |
2948 |
Thu, 04 June 2015 08:21 By: Zlaty Fenix |
Use own formatter for values on y-axis |
0 |
2712 |
Tue, 02 June 2015 19:47 By: Akif Etkü |
BIRT 3.7.2 run time problem Schedule Birt 3.7.2 reports on Windows 2008 with Maximo 7.5 not work |
0 |
3146 |
Mon, 01 June 2015 23:53 By: Eric Zuo |
Showing Validation Message in BIRT Reports ReportServiceException Handling |
0 |
2960 |
Wed, 27 May 2015 09:24 By: Ramit Pal |
Horizontal table Page Break And aggregations Horizontal table Page Break, Sort and Aggregations |
0 |
2436 |
Tue, 26 May 2015 14:39 By: Nikhil Mandaara |
In BIRT, how to view different master pages with different parameters |
1 |
1170 |
Mon, 25 May 2015 18:35 By: Jerry Sheets |
Dynamic database adaption Where to detect externalized database properties |
0 |
3243 |
Fri, 22 May 2015 09:55 By: Stefan Seitz |
Sum of RowsCount of Two Tables(DataSets) How to get count of rows in two different tables(datasets) in the third table |
0 |
3871 |
Fri, 22 May 2015 07:11 By: Kamal Subedi |
joining two tables in birt How and where we Join two tables in birt |
1 |
1584 |
Wed, 20 May 2015 18:24 By: Jerry Sheets |
Enabling emitter for Birt not working |
0 |
10358 |
Tue, 19 May 2015 13:46 By: Andreas Truszkowski |
Can't set a font typeface for the Body of a report Can't set a font typeface for the Body of a report |
11 |
8139 |
Tue, 19 May 2015 02:41 By: Al Koch |
Operation between two row |
4 |
2469 |
Mon, 18 May 2015 07:15 By: Massimilino Oreto |
Embedded report in plugin, where's the JavaScript function? |
1 |
2130 |
Fri, 15 May 2015 16:18 By: James Clark |
Sorting bar chart based on y-axis values By: Eclipse User on Mon, 14 February 2011 |
14 |
15460 |
Fri, 15 May 2015 10:25 By: Arpit Jain |
Formatting tool tips on a Chart |
1 |
2196 |
Fri, 15 May 2015 04:06 By: Michael Williams |
Birt filter data and problems with two detail rows Birt filter |
1 |
1384 |
Fri, 15 May 2015 03:57 By: Michael Williams |
Number of rows for visible rows only Number of rows for visible rows only |
1 |
3821 |
Fri, 15 May 2015 03:47 By: Michael Williams |
Birt bug 364412 OOME Error for bubble charts |
3 |
1698 |
Fri, 15 May 2015 03:43 By: Michael Williams |
diffDay with condition Need to get the numbers of days between 2 dates except specific days in the week for each row |
1 |
3569 |
Thu, 14 May 2015 16:58 By: Jesse Freeman |
report engine and using pojo dataset |
0 |
3376 |
Wed, 13 May 2015 11:42 By: stefan makarewicz |
[SOLVED] BIRT Meter Chart - setting the width By: Eclipse User on Wed, 13 May 2015 |
0 |
3809 |
Wed, 13 May 2015 10:04 By: Eclipse User |
Birt: Query errors on SQL 2000 [SOLVED] Connection to SQL server is good, but errors on query |
7 |
3136 |
Mon, 11 May 2015 13:14 By: Michael Williams |
Get the y-axis coordinate on a chart given the axis value |
0 |
2738 |
Sat, 09 May 2015 10:42 By: george philos |
find the y axis coordinate of a bar value in a bar chart |
0 |
2714 |
Sat, 09 May 2015 08:48 By: george philos |
[WORKAROUND IN PLACE] Retrieving OUT parameters from a stored procedure By: Eclipse User on Fri, 08 May 2015 |
0 |
3655 |
Fri, 08 May 2015 14:38 By: Eclipse User |
How do I create Temp tables (using Go) Using SQL commands that fail in a dataset query |
2 |
4871 |
Thu, 07 May 2015 21:24 By: Michael Williams |
How I can show chart legend series dynamically based on Y series value? By: Amy on Tue, 24 August 2010 |
7 |
5432 |
Thu, 07 May 2015 21:14 By: Michael Williams |
Birt report not showing in IE11 - when in iframe |
6 |
5177 |
Thu, 07 May 2015 20:45 By: Michael Williams |
Inaccuracies in PDF and HTML reports rendering |
8 |
2944 |
Thu, 07 May 2015 15:58 By: Michael Williams |
Problems with rptlibrary By: Eclipse User on Mon, 18 September 2006 |
6 |
5575 |
Thu, 07 May 2015 15:56 By: Michael Williams |
Video from Actuate: Aggregation Filter |
1 |
3728 |
Thu, 07 May 2015 03:28 By: Michael Williams |
Unable to sum two different tables Need to create new data using column of existing tables |
1 |
3890 |
Thu, 07 May 2015 02:39 By: Michael Williams |
Error :Could not initialize class org.apache.axis.transport.http.AxisServlet java.lang.NoClassDefFoundError: Could not initialize class org.apache.axis.transport.http.AxisServlet |
1 |
5022 |
Thu, 07 May 2015 02:34 By: Michael Williams |
Newspaper/Multi Column layout in BIRT |
5 |
8392 |
Thu, 07 May 2015 02:27 By: Michael Williams |
page break not on first page |
1 |
4329 |
Thu, 07 May 2015 01:59 By: Michael Williams |
How to convert a String to a Date Value? I have a string value (2015/004) that I want to convert to a date variable. |
4 |
8376 |
Thu, 07 May 2015 01:51 By: Michael Williams |
Urgent Capture and Insert values |
1 |
3833 |
Thu, 07 May 2015 01:45 By: Michael Williams |
Migration from 2.3.1 to 4.4.2 Migration from 2.3.1 to 4.4.2 |
3 |
2531 |
Thu, 07 May 2015 01:37 By: Michael Williams |
Reg: Unable to view Dataset- Urgent Help Required Unable to create new dataset for new Y-series |
2 |
4320 |
Thu, 07 May 2015 01:30 By: Michael Williams |
get DispalyText of Text Item |
1 |
2101 |
Tue, 05 May 2015 15:02 By: Jesse Freeman |
GROUPING on DATA Expression Value Can I Group a table based on an Expression Value? |
9 |
6135 |
Thu, 30 April 2015 20:34 By: Ken Strickland |
Error: Connection is not open. Birt Viewer and Debugger throws exception: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Connection is not open. |
1 |
2324 |
Thu, 30 April 2015 10:13 By: Michael Gerdes |
Footer at bottom of last page only in BIRT PDF report By: Preeti on Mon, 20 June 2011 |
11 |
17629 |
Wed, 29 April 2015 12:21 By: Rob Ducker |
BIRT 4.2.2 blank PDF pages By: Sen Ka on Thu, 23 April 2015 |
1 |
2010 |
Fri, 24 April 2015 11:22 By: Madhavi UR |
D3 chart in BIRT BIRT and D3 charts By: g g on Mon, 02 September 2013 |
27 |
22308 |
Thu, 23 April 2015 13:05 By: kshirod mishra |
Birt Viewer DataException Birt-Viewer is not able to show chart, org.eclipse.birt.data.engine.core.DataException is coming with Birt 4.4.2 and jetty |
2 |
3772 |
Thu, 23 April 2015 01:26 By: Michael Williams |
global variable initialize vs. beforeFactory |
1 |
6714 |
Wed, 22 April 2015 21:57 By: Michael Williams |
Get Source-Code for the eBook "BIRT: A Field Guide, 3rd Edition" |
3 |
4518 |
Wed, 22 April 2015 21:32 By: Michael Williams |
Dynamic image Display image based on the column value |
3 |
4673 |
Wed, 22 April 2015 20:55 By: Michael Williams |
How to change subtype of y axis 2? I need to change Y axis 2 to a stacked line chart (Y axis 1 is a percent bar chart) |
1 |
4038 |
Wed, 22 April 2015 15:06 By: Jesse Freeman |
BIRT HTML output split into multiple spreadsheet cells |
3 |
3465 |
Wed, 22 April 2015 14:57 By: Jesse Freeman |
Hibernate + Birt Report Engine API + Tomcat |
1 |
3332 |
Wed, 22 April 2015 14:33 By: Jesse Freeman |
IBM Java Toolbox (JT400.jar) JDBC Driver Extremely Slow Performance |
4 |
8381 |
Wed, 22 April 2015 14:32 By: kate fryatt |
Revisiting BIRT on the iSeries By: Eclipse User on Mon, 02 April 2007 |
9 |
3764 |
Wed, 22 April 2015 14:02 By: kate fryatt |
Manipulate Page Break Interval Counter |
1 |
1622 |
Wed, 22 April 2015 04:56 By: Michael Williams |
Interactive Pie Chart Drill Down Interactive Pie chart drill down into levels using a single report |
1 |
5370 |
Wed, 22 April 2015 04:45 By: Michael Williams |
BIRt 4.3.2 & WebSphere: using reportContext.getMessage throws AccessControl exception BIRt 4.3.2 & WebSphere: using reportContext.getMessage throws AccessControl exception |
1 |
4501 |
Tue, 21 April 2015 13:30 By: Anthony Farrell |
Datasource with Teradata I want to create a Teradata source in BIRT |
0 |
4401 |
Wed, 15 April 2015 13:04 By: aurelien habibi |
Chart with 2 y-axis series - problem sorting |
10 |
11647 |
Wed, 15 April 2015 12:16 By: kshirod mishra |
Eclipse BIRT vs Actuate Birt Designer Pro |
2 |
5501 |
Tue, 14 April 2015 11:32 By: kshirod mishra |
BIRT and RTF File |
0 |
4156 |
Mon, 13 April 2015 13:32 By: Marina Orth |
Reg: Integrating BIRT with ZING Chart and AMChart Integrating BIRT with other charts |
1 |
3808 |
Mon, 13 April 2015 07:07 By: kshirod mishra |
Pie Chart Pie chart slice movement |
1 |
3499 |
Mon, 13 April 2015 07:06 By: kshirod mishra |
Line Plot -Draw Market different Y Axis values is possible to draw a marker in different position in the char ? |
1 |
39369 |
Wed, 08 April 2015 17:34 By: Ken Strickland |
Using custom BIRT libraries in plugins Using custom BIRT libraries in plugins |
4 |
1566 |
Wed, 08 April 2015 15:14 By: CG Mising name |
Read the TOC is not possible |
0 |
3796 |
Wed, 08 April 2015 11:40 By: Hans-Georg Glöckler |
Reg: Unable to load the data in Dataset Loading Error while using XML Data source |
2 |
1350 |
Wed, 08 April 2015 06:01 By: kshirod mishra |
Specify minimum height for the bars |
5 |
2210 |
Tue, 07 April 2015 11:23 By: Rupali Kundar |
Report Rendering- Urgent help My reports are not covering according to my monitor screen |
9 |
4016 |
Tue, 07 April 2015 04:49 By: kshirod mishra |
Unable to view Report Unable to view report in browser using BIRT viewer |
10 |
3992 |
Tue, 07 April 2015 04:48 By: kshirod mishra |
PDF Render: Export to PDF file exports only first page PDF Render: Export to PDF file exports only first page |
2 |
7477 |
Mon, 06 April 2015 03:12 By: Eric Leong |
fix for CVE-2015-0250 |
0 |
4163 |
Fri, 03 April 2015 15:48 By: Robin Raddatz |
Birt ODA Exception No Protocol - SSL Encryption issues calling web service |
0 |
3119 |
Fri, 03 April 2015 15:38 By: Aamer Azeem |
Getting incomplete report from server A report deployed to server contains less than run from ReportDesigner |
10 |
2452 |
Thu, 02 April 2015 16:42 By: Jesse Freeman |
Merging cell Merging cell is not happening |
5 |
1966 |
Thu, 02 April 2015 16:29 By: Jesse Freeman |
Issue with Stored Procedure call EJB+JPA(Eclipse Link)+ORACLE 11g Store Procedure call |
0 |
3790 |
Thu, 02 April 2015 07:10 By: venkat chanumoliu |
Timezone in birt reports incorrect -BirtDateTime.now returns wrong time BIRT REPORTS timezone incorrect |
0 |
4776 |
Thu, 02 April 2015 05:10 By: Richard Riviere |
Birt Report from timeclock data Attendance Report from Employee Timeclock data |
2 |
1180 |
Wed, 01 April 2015 16:36 By: Justin B |
How can I customize the ViewerServlet's "BIRT Report Viewer" report label? How can I customize the ViewerServlet's "BIRT Report Viewer" report label? |
14 |
6648 |
Tue, 31 March 2015 19:52 By: Al Koch |
BIRT Report Development XLS Tab Splitting Issue |
13 |
5213 |
Tue, 31 March 2015 18:20 By: Jesse Freeman |
Calculate the exact height of a cell on birt how can match two height of two different dynamic table |
0 |
3799 |
Tue, 31 March 2015 08:32 By: wail bat |
