Topic |
Replies |
Views |
Last message |
Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom Itemnum below the barcode when displayed vertically in BIRT 232 getting truncated at the bottom |
3 |
2763 |
Wed, 03 August 2016 07:20 By: Mark Kaisarglass |
Create and Arrange Grids per Row dynamically Create and Arrange Grids per Row dynamically |
0 |
2940 |
Tue, 02 August 2016 15:32 By: Juan Gonzalez |
2.6.1 Excel Export Formatting issue with Excel export |
0 |
2991 |
Tue, 02 August 2016 15:08 By: James Buller |
pdf annotations in BIRT reports automatically add pdf annotations while rendering BIRT reports as pdf |
0 |
3387 |
Tue, 02 August 2016 09:05 By: Christian Wagner |
Managing Legend items |
0 |
3449 |
Sun, 31 July 2016 19:54 By: Alain Picard |
Date i/p param value not coming to backend DB Date input for datset stored procedure |
0 |
3206 |
Thu, 28 July 2016 12:15 By: Rakhi AR |
Grid borders invisible in BIRT Viewer 4.2.1 Windows 10 machine Microsoft Edge |
0 |
3393 |
Thu, 28 July 2016 05:09 By: manoj kumar |
Error: A JNI error has occurred, please check your installation and try again generate BIRT Report from command line |
0 |
13668 |
Wed, 27 July 2016 21:00 By: Liqun Sun |
BIRT on AIX Requesting Installer files and documentation for BIRT on AIX Platform |
0 |
2531 |
Mon, 25 July 2016 22:38 By: Shlok Naik |
DB2 connect blank Using Data Explorer, DB2 connection is blank |
1 |
3966 |
Mon, 25 July 2016 10:55 By: Ricardo Paz |
Related Cascade Parameters Related Cascade Parameters |
0 |
3012 |
Mon, 25 July 2016 09:56 By: Ricardo Paz |
jQuery and Sample Viewer Problem Table of Contents entries break jQuery features |
2 |
6426 |
Fri, 22 July 2016 07:24 By: David Good |
Birt 4.4.2 Excel image changed table column with Birt 4.4.2 Excel image changed table column with |
0 |
4177 |
Thu, 21 July 2016 16:51 By: XIAOAN ZHENG |
NoClassDefFoundError for IBM's SimpleDataFormat when integrating Integrating with existing Java web application including only BIRT runtime API By: Ed on Fri, 26 March 2010 |
5 |
7325 |
Thu, 21 July 2016 15:28 By: ness info |
Splitting and putting in boxes in BIRT Can we split a string and put it in a grid, each character in a cell in BIRT |
2 |
1330 |
Thu, 21 July 2016 15:06 By: Ankit Choudhary |
Problem with style tag Birt Design |
0 |
3833 |
Thu, 21 July 2016 11:33 By: Alessandro Gois |
Binding new column to already existing data binding of a table Binding Refresh not considering new output columns in dataset |
0 |
4046 |
Wed, 20 July 2016 06:03 By: Rakhi AR |
Exporting Excel functions from Birt report How do we export the excel formula's from birt report to xlsx, i.e., in the Column C1 it shud display the formula as =A1+B1 |
1 |
9851 |
Tue, 19 July 2016 19:55 By: ganesh kamarapu |
Receiving Server Error when Previewing Reports in Birt 4.3.2 Receiving Server Error when Previewing Reports in Birt 4.3.2 |
0 |
4045 |
Tue, 19 July 2016 14:35 By: Jason McGill |
Applying styles to table caption I am using a table with caption. I am trying to apply styles to the table caption. Is there any way I can do it? I am trying to use setCaption method in tableHandle through which I am setting the capt |
0 |
3507 |
Tue, 19 July 2016 12:22 By: Pravin KK |
Font Weight, can't use a light font |
0 |
4963 |
Mon, 18 July 2016 13:31 By: Thoren Horstmann |
Errors when generating report with BIRT Runtime Errors when generating report with BIRT Runtime |
0 |
4596 |
Thu, 14 July 2016 11:28 By: moe eido |
Average/GrandTotal to show in BIRT Chart Average/GrandTotal to show in BIRT Chart |
0 |
3558 |
Thu, 14 July 2016 04:58 By: ABHISHEK ZAKHARIA |
Adding multiple series to a chart dynamically |
0 |
3862 |
Wed, 13 July 2016 09:02 By: Christian Fender |
BIRT 4.6.0 failed under Wildfly 8.0 Keep getting a ClassNotFoundException |
0 |
4301 |
Mon, 11 July 2016 13:04 By: Marcel Bonin |
Cannot Load JDBC Driver class: oracle.jdbc.driver.OracleDriver |
2 |
12760 |
Fri, 08 July 2016 15:44 By: Marcus Lee |
fill the entire page by repetitive text |
0 |
3557 |
Thu, 07 July 2016 12:43 By: omid torabzadeh |
BIRT - error rendering xls report |
0 |
3059 |
Wed, 06 July 2016 19:55 By: Jorge Perea |
Maximo - Birt 3.7.1 - Child Data Set returns results on wrong row |
0 |
3518 |
Tue, 05 July 2016 13:37 By: Corey Hill |
PDF emitter page overflow configuration |
5 |
6772 |
Sat, 02 July 2016 03:16 By: Cullen Bond |
Maximo System Library Irregularity |
0 |
5537 |
Fri, 01 July 2016 17:14 By: Norm Merrill |
Using data cube tables leads to error "There is no report design object available" |
2 |
3028 |
Fri, 01 July 2016 09:28 By: Jörg Steffen |
Javascript problem in 2.5.2 -> 4.5.0 upgrade Getting "TypeError: Cannot find default value for object." when trying to pass row object to custom function. |
0 |
4379 |
Thu, 30 June 2016 14:54 By: Steve Schafer |
Tuning report design for high performance By: sam va on Wed, 28 March 2012 |
5 |
4357 |
Wed, 29 June 2016 15:01 By: Cullen Bond |
Distributable Report with hyperlinks pointing to relative image files via BIRT |
0 |
3987 |
Tue, 28 June 2016 07:23 By: Hanaa Ab |
0 |
4085 |
Linking Images Stored in a Folder to a Report (with Changeable Hyperlinks) |
0 |
4102 |
Mon, 27 June 2016 08:23 By: Hanaa Ab |
Embedded Image not working in BIRT4.2.2 Embedded Image not working in BIRT4.2.2 |
14 |
27476 |
Thu, 23 June 2016 15:07 By: Eric Daly |
MongoDB collection field empty After connecting with MongoDB, collection drop down menu was empty |
5 |
10234 |
Thu, 23 June 2016 13:31 By: Lietwin AR |
BIRT unable to get data from MONGO DB Secondary node BIRT unable to get/read data from MONGO DB Secondary node |
0 |
4266 |
Thu, 23 June 2016 13:13 By: Manivannan Mahalingam |
Map and table on first page, then table each subsequent page Having trouble expanding the table to be full page on subsequent pages |
2 |
1435 |
Wed, 22 June 2016 23:08 By: Ben Van Kesteren |
Text overlapping Text overlapping in Birt |
0 |
4604 |
Wed, 22 June 2016 17:44 By: Geert Soet |
Page Break Inside "Auto" not working |
0 |
4259 |
Thu, 16 June 2016 04:57 By: Ajay Kotapati |
0 |
4607 |
Thu, 16 June 2016 04:37 By: Ajay Kotapati |
Does BIRT support Angular 2 Does BIRT support Angular 2 |
0 |
4805 |
Wed, 15 June 2016 14:43 By: Sasi Kiran Gunda |
Websphere 8.5.x And Birt 4.5 can birt 4.5 run on websphere 8.5 |
0 |
3542 |
Tue, 14 June 2016 23:21 By: John Milmont |
Cannot write in Arabic |
0 |
4511 |
Tue, 14 June 2016 14:06 By: Hope Sh |
Progress BAR in BIRT Report Progress BAR in BIRT Report |
0 |
4708 |
Tue, 14 June 2016 13:54 By: lokesh mh |
Issue with User Properties added to Cell Issue with User Properties added to Cell |
0 |
5100 |
Tue, 14 June 2016 10:22 By: purnima d |
Run BIRT report Unable to run report |
2 |
8170 |
Tue, 14 June 2016 08:50 By: Aruna DAnde |
org.eclipse.birt.report.exception.ViewerException: The viewing session is not available or has expir BIRT report with proxy server |
0 |
4373 |
Mon, 13 June 2016 18:46 By: Srilekha Ch |
Connecting Eclispe BIRT to Blackboard ASR |
0 |
3932 |
Mon, 13 June 2016 15:18 By: Barbara Becker |
Count Distinct of a Column by certain group show result always expected result +1 |
0 |
4749 |
Thu, 09 June 2016 15:53 By: Jonathan Hindharta |
Tooltips in BIRT charts |
5 |
5762 |
Thu, 09 June 2016 09:26 By: Abhishek Chakraborty |
Unable to chart from joint data set CHart Help |
0 |
3973 |
Wed, 08 June 2016 18:27 By: Josh Pritchard |
Repeat whole form instead of just a row Contains ASCII drawings for easy understanding :) |
1 |
4833 |
Mon, 06 June 2016 16:36 By: Marcus Casagrande |
Possible Bug Can't generate PDF reports using tables with large 'detail row' |
0 |
4591 |
Mon, 06 June 2016 13:30 By: Marcus Casagrande |
chart: hide legend entry |
6 |
10214 |
Mon, 06 June 2016 12:18 By: Jörg Steffen |
Report on word changes the font Unable to change the font |
0 |
3265 |
Sun, 05 June 2016 13:44 By: Mahmut Ogrek |
Birt - Bar code |
2 |
9263 |
Wed, 01 June 2016 12:30 By: Moataz Eljaky |
Multipage report with cover page? By: TK LS on Mon, 30 May 2016 |
0 |
3719 |
Mon, 30 May 2016 13:52 By: TK LS |
Report Engine Error no such method CAn generate report from Birt Report Designer but not with report Engine |
0 |
4018 |
Mon, 30 May 2016 13:38 By: Laurent Laurent |
Problem updating tools in Eclipse Problem updating BIRT tools 4.4 in Eclipse Version: Mars.2 Release (4.5.2) |
0 |
4765 |
Sun, 29 May 2016 11:16 By: ness info |
create stacked bar chart |
0 |
4857 |
Sun, 29 May 2016 00:18 By: Michael Reiter |
Can't get a fixed layout to print additional rows correctly |
0 |
2148 |
Fri, 27 May 2016 18:35 By: Ryan Stefani |
Error CannotStartupOSGIPlatform Integrating BIRT 4.5 in Standalone App |
0 |
4134 |
Fri, 27 May 2016 10:18 By: Juraj Piar |
"Java heap space" OutOfMemory error in Report Design |
6 |
21117 |
Thu, 26 May 2016 16:07 By: swati sharma |
How i call stored procedure before the execution of report ? How i call stored procedure before the execution of report ? |
0 |
3213 |
Thu, 26 May 2016 04:06 By: Kamran Ali Kalwar |
Change report title property value at runtime By: j k on Fri, 05 October 2012 |
4 |
9304 |
Wed, 25 May 2016 20:44 By: udaya yarasi |
Oracle Stored Procedure Query type Dataset loads huge metadata |
0 |
2664 |
Wed, 25 May 2016 16:23 By: Viktor Kalman |
Get values selected dinamically Replace values selected into a Data Set script |
0 |
2513 |
Wed, 25 May 2016 10:14 By: Oscar Chamache |
Creating Dynamic Dataset How to send the entire query as a parameter to the RPT |
1 |
1850 |
Wed, 25 May 2016 04:23 By: Colin Sutton |
How to add search box By: FL Kx on Fri, 20 May 2016 |
1 |
852 |
Mon, 23 May 2016 17:03 By: Jerry Sheets |
Hide series depending on month for a 2 series Hide series depending on month for a 2 series |
0 |
2173 |
Mon, 23 May 2016 09:59 By: RAFAEL HERNANDEZ |
Hide/Disable the Hyperlink after Exporting How to Disable the hyperlink in columns when exporting in Excel/PDF |
0 |
3985 |
Fri, 20 May 2016 05:35 By: Suvarnni M V |
setPersistentGlobalVariable null on PDF Summary |
0 |
1668 |
Thu, 19 May 2016 14:43 By: ALEXANDRE SOARES |
Duplicating Row in BIRT Report BIRT |
0 |
3697 |
Thu, 19 May 2016 09:58 By: vignesh thandapani |
detail : org.eclipse.birt.report.engine.api.EngineException: Can not load the report query: 186. Err |
0 |
3885 |
Wed, 18 May 2016 19:01 By: Naresh Bahety |
I need to use Windows Authentication for my report connection string. Getting errors JDBC for SQL Server 4.0 Windows Auth error |
0 |
4725 |
Wed, 18 May 2016 16:46 By: LIsa Boman |
No output from report -upgraded to BIRT runtime 4.2.0 from 3.7.0 |
0 |
3640 |
Wed, 18 May 2016 12:02 By: Naresh Bahety |
Email distribution Automated email distribution tool |
2 |
5770 |
Tue, 17 May 2016 17:20 By: udaya yarasi |
Adding mysql data from a java script - Problem with JDBC Drivers jdbc driver |
0 |
5011 |
Tue, 17 May 2016 15:04 By: Antoniol Matthieu |
is there birt report engine written in nodejs? |
1 |
7363 |
Mon, 16 May 2016 23:03 By: Adam Brusselback |
Problem with chart and report parameters |
0 |
4896 |
Mon, 16 May 2016 12:46 By: fabio santullo |
How to set a value of a variable into a table cell? |
2 |
4676 |
Fri, 13 May 2016 13:27 By: Daniel Aguirre |
Birt Unable to connect with Hive-2.0.0 and HDFS-2.7.X Birt Unable to connect with Hive-2.0.0 and HDFS-2.7.X |
0 |
5482 |
Fri, 13 May 2016 10:02 By: Kumar Ratan |
0 |
5487 |
Fri, 13 May 2016 09:27 By: Kumar Ratan |
Birt Report highlight Issue |
4 |
4281 |
Thu, 12 May 2016 21:10 By: swati sharma |
How to Set a Variable Value into a Table Cell ?? |
0 |
5187 |
Thu, 12 May 2016 17:31 By: Daniel Aguirre |
BIRT and MongoDB 3.2 |
0 |
4337 |
Wed, 11 May 2016 12:06 By: Serge Ka |
Xpath referencing different XML field |
0 |
4107 |
Tue, 10 May 2016 17:45 By: Daniel de Carlos |
Table as a BIRT Subreport for a Pie Chart BIRT Subreports |
1 |
4019 |
Tue, 10 May 2016 09:04 By: Ekaterina Kessner |
HTML embed in dynamic text HTML embed in dynamic text |
0 |
4520 |
Mon, 09 May 2016 09:47 By: wagner la paz |
Cannot open the connection [Birt 2.2] |
0 |
4708 |
Mon, 09 May 2016 04:30 By: Edgar Chen |
How do I use Multi Select Parameters in an Expression? |
0 |
5235 |
Fri, 06 May 2016 12:36 By: Kandice Bozora |
is BIRT right choice for huge data reporting? |
1 |
2166 |
Thu, 05 May 2016 14:45 By: Jerry Sheets |
Borders not displaying in PDF Borders not displaying in PDF |
0 |
4736 |
Wed, 04 May 2016 19:17 By: ronald hagan |
Can not upgrade from BIRT version 2.6.2 to 4.5.0 |
0 |
5109 |
Wed, 04 May 2016 16:13 By: Pratima Uchate |
Set height element tr frame view |
0 |
4894 |
Wed, 04 May 2016 09:30 By: longtqdayma Mising name |
Display format of report page Display format of report page |
0 |
4638 |
Tue, 03 May 2016 09:26 By: Billy Zafack |
Different aggregations on a crosstab Perform an aggregation on an aggregate column of a crosstab |
0 |
4920 |
Tue, 03 May 2016 09:15 By: Billy Zafack |
export to pdf file too slow |
0 |
4946 |
Tue, 03 May 2016 05:39 By: John Chang |
Trouble Deploying BIRT Report Designs to Tomcat 7 Trouble Deploying BIRT Report Designs to Tomcat 7 |
0 |
4567 |
Mon, 02 May 2016 18:49 By: Jared Patton |
Can't upgrade to BIRT Runtime 4.3 |
5 |
8081 |
Mon, 02 May 2016 13:21 By: Pratima Uchate |
crosstab sorting on mapped display values of a dimension? Is there some other javascript keyword than "data[...]" which returns values of a dimension AFTER mapping to display values? |
0 |
3867 |
Wed, 27 April 2016 16:31 By: Luc Lechien |
aggregation performance is performance better to aggregate multiple groups on detail or on lower level group aggregatesa |
0 |
3734 |
Wed, 27 April 2016 15:30 By: Mike Pace |
Birt runtime 4.4.1 : EXCEPTION the logger can not be NULL or children or in namespace of org.eclipse Facing exception with Birt 4.4.1 |
0 |
5238 |
Wed, 27 April 2016 15:12 By: RWIL Mising name |
Dependent parameter values Limiting parameter value set based previously selected value |
0 |
4224 |
Wed, 27 April 2016 14:23 By: Miguel Orlans |
Hyperlinks problem in Silk Central Hyperlinks aren't showing... |
0 |
5878 |
Wed, 27 April 2016 13:28 By: Julien Rod |
Show/Hide errors |
3 |
26712 |
Tue, 26 April 2016 16:11 By: Ramya Lagadapati |
I have a little question about the integration of BIRT with maven web application. BIRT Report Viewer with maven web application |
1 |
1826 |
Fri, 22 April 2016 21:13 By: Diego F. Ruiz S. |
When deploy birt.war build 4.6SNAPSHOT from git master got ClassNotFoundException: ResourceInjector Problems deploy viewer on tomcat after a fresh build |
0 |
6276 |
Thu, 21 April 2016 15:02 By: Clovis Wichoski |
birt connection profile file how i create birt connection profile file programmatically and encrpt it ? |
0 |
6071 |
Thu, 21 April 2016 11:21 By: Kamran Ali Kalwar |
BIRT REPORT how to pass database username and password in url |
0 |
5308 |
Wed, 20 April 2016 13:35 By: Kamran Ali Kalwar |
select max value in date select max value in date |
1 |
4854 |
Wed, 20 April 2016 07:51 By: Florent Lesage |
Report running hardcoded query. Not substituting params Report data is showing based on hardcoded query. It is not based on user selected paramaetrs |
0 |
4398 |
Tue, 19 April 2016 23:08 By: sid kumar |
Display Birt engine report on iPad |
21 |
14562 |
Tue, 19 April 2016 22:08 By: James Swafford |
Exporting data into excel error Exporting data into excel error |
1 |
2243 |
Tue, 19 April 2016 15:01 By: Jerry Sheets |
Hive Datasource is not connected |
0 |
5505 |
Mon, 18 April 2016 08:18 By: Eric Chen |
BIRT vtiger |
3 |
1685 |
Sat, 16 April 2016 17:49 By: Zoà Oosthuizen |
Charts are Not Visible in Excel |
0 |
5184 |
Fri, 15 April 2016 05:47 By: Suvarnni M V |
Birt 4.3.1 Maximo Report error The following items have errors: TableGroup TaskOrder: + A report document error occurred when loading: Result Data |
0 |
5330 |
Thu, 14 April 2016 02:42 By: Holli Parris |
Line graph based on date columns Need to create a line graph based on two date columns |
0 |
5028 |
Thu, 14 April 2016 01:25 By: Rollie Copp |
Adding text in master page (header and footer) problem I am not able to add my text in header and footer |
13 |
21048 |
Tue, 12 April 2016 21:44 By: swati sharma |
Compute value based on next row or update previous row based on current row |
0 |
4046 |
Tue, 12 April 2016 18:35 By: Miker Irick |
Eclipse MARS will not preview report Unable to preview report |
1 |
7097 |
Tue, 12 April 2016 15:15 By: rusel fichi |
Create a report thanks to a JSON file |
0 |
7012 |
Tue, 12 April 2016 08:43 By: Florent Lesage |
I am new to BIRT report ETL Process ETL Process |
0 |
5392 |
Tue, 12 April 2016 06:44 By: kanna venkat |
Can we use two master pages in one birt report? By: Eclipse User on Mon, 25 June 2007 |
3 |
13099 |
Mon, 11 April 2016 19:07 By: swati sharma |
highlight in report |
0 |
3537 |
Fri, 08 April 2016 23:42 By: swati sharma |
Setting y-axis title dynamically from dataset |
1 |
5042 |
Mon, 04 April 2016 12:29 By: Neill Rosenthal |
BIRT 4.3.1 compatibility with PDFBox |
0 |
5097 |
Mon, 04 April 2016 11:00 By: Ashutosh Bansal |
String index out of bound with importpackage |
5 |
11172 |
Fri, 01 April 2016 15:22 By: Eason Tang |
Pushing group trailer to page footer ? |
0 |
4980 |
Fri, 01 April 2016 09:45 By: vif dev |
birt parameters sql |
2 |
4183 |
Fri, 01 April 2016 08:54 By: Nils Faupel |
Birt source code |
2 |
6845 |
Fri, 01 April 2016 08:27 By: Nils Faupel |
Birt for Maximo Mobility Can Adhoc or Birt reports run on Maximo for tablets? |
0 |
4768 |
Wed, 30 March 2016 16:05 By: David Pattengale |
Duplicate rows in Joint Dataset Getting duplicate rows in Joint DataSet |
2 |
5355 |
Wed, 30 March 2016 09:46 By: JP Redro |
Birt eclipse designer 4.2.2 64 bits for Linux |
0 |
5140 |
Wed, 30 March 2016 07:08 By: Mathieu Hicauber |
Rerender on a birt report is losing jsf page parameters values What is the right way to rerender a birt report in jsf? |
0 |
5434 |
Tue, 29 March 2016 13:33 By: Bussard Buss |
how to build Birt report engine how to build Birt report engine |
4 |
6136 |
Mon, 28 March 2016 05:41 By: XIAOAN ZHENG |
Question using report parameters in scriped data sets using SQL |
1 |
3923 |
Fri, 25 March 2016 19:46 By: Norm Merrill |
Birt 3.72 Report Engine Rotate Text with Birt Controls Lib Trying to rotate text, images arent generated |
0 |
3745 |
Thu, 24 March 2016 21:51 By: clay cottingham |
How to extract plain text from HTML |
0 |
4768 |
Thu, 24 March 2016 19:07 By: Norm Merrill |
report parameter with MongoDB data source |
2 |
3366 |
Wed, 23 March 2016 18:59 By: Rajarshi Chakravarty |
Xpath in birt |
2 |
5427 |
Wed, 23 March 2016 11:33 By: Břetislav Če ník |
frameset not working |
0 |
6020 |
Tue, 22 March 2016 11:23 By: Rajarshi Chakravarty |
Page break and page orientation not working Page break and page orientation not working |
0 |
5654 |
Fri, 18 March 2016 14:02 By: Johann Waber |
View Report as ODT not working (Report with an eventhandler) View Report as ODT not working (Report with an eventhandler) |
0 |
5139 |
Fri, 18 March 2016 13:37 By: Johann Waber |
Chart Category (X) same name problem |
0 |
4463 |
Fri, 18 March 2016 11:58 By: Julien Rod |
Is it possible to have an "expand/collapse" function in a chart ? |
0 |
4556 |
Fri, 18 March 2016 09:52 By: Julien Rod |
Add custom authentication header to SOAP Webservice Authentication by token at webservice |
0 |
5188 |
Thu, 17 March 2016 18:56 By: André Oliveira |
how to avoid blank page at the end of pdf report in BIRT? BIRT report design |
0 |
6180 |
Thu, 17 March 2016 09:53 By: Muralidhar Yaragalla |
Set height based on a variable dynamic height of cells By: Kid A on Tue, 15 March 2016 |
0 |
4078 |
Tue, 15 March 2016 09:57 By: Kid A |
PostScript comments support in BiRT PostScript comments support in BiRT |
0 |
3943 |
Mon, 14 March 2016 15:17 By: Shouvik Basu |
HTML Button on reports not working HTML Button on reports not working after migrating to a new server |
0 |
4190 |
Mon, 14 March 2016 14:24 By: Naru Ilc |
Expression Builder for Visibility Settings Help Needed |
0 |
4055 |
Sun, 13 March 2016 14:31 By: Richard White |
CancelTask.jsp not found when canceling report in viewer CancelTask.jsp not found when canceling report in viewer |
1 |
5575 |
Fri, 11 March 2016 14:01 By: Garey Smiley |
BIRT 3.7.2 run time problem Schedule Birt 3.7.2 reports on Windows 2008 with Maximo 7.5 not work |
3 |
4012 |
Thu, 10 March 2016 23:35 By: Hollie Alexander |
Data in Master Page By: Kid A on Wed, 09 March 2016 |
0 |
4309 |
Wed, 09 March 2016 10:04 By: Kid A |
Format date param in a cascading param group |
0 |
4282 |
Mon, 07 March 2016 14:49 By: jean francois chalivet |
BIRT Oracle tables were missing with different Oracle schemes tables were missing using BIRT with different Oracle schemes |
0 |
3988 |
Mon, 07 March 2016 11:09 By: Gunnar Kuppermann |
Deployment from eclipse project Any link can learn how to deploy a BIRT project to Tomcat |
0 |
3915 |
Mon, 07 March 2016 06:31 By: aiden lai |
integrating birt with my sql server (programmatically) birt integration with MY SQL Server programmatically. |
0 |
3993 |
Mon, 07 March 2016 05:23 By: sriram boddapati |
Export report with sub reports to CSV Export report with sub reports to CSV |
0 |
4771 |
Sun, 06 March 2016 12:41 By: Jonathan Bacalo |
PHP Javabridge with BIRT 4 |
6 |
6597 |
Fri, 04 March 2016 14:48 By: Garey Smiley |
BIRT Viewer very verbose in Tomcat log BIRT Viewer very verbose in Tomcat log |
0 |
5126 |
Fri, 04 March 2016 14:37 By: Garey Smiley |
My BIRT plugin works debuging the report but not at Webview |
0 |
5463 |
Fri, 04 March 2016 14:07 By: Beto Neto |
Aggregation of Report Variables Aggregation of Report Variables |
0 |
5720 |
Thu, 03 March 2016 15:32 By: Sriram Nagappan |
how to repeat a table on every page By: Kid A on Thu, 03 March 2016 |
0 |
6515 |
Thu, 03 March 2016 12:19 By: Kid A |
beforeDrawAxisLabel event for setting X-Axis label |
2 |
6710 |
Wed, 02 March 2016 14:03 By: olivier loquin |
Where's the fetch method? |
0 |
7595 |
Wed, 02 March 2016 10:26 By: sanada yukimura |
JavaBridge cannot display the BIRT dataSet |
1 |
3217 |
Wed, 02 March 2016 10:16 By: sanada yukimura |
BIRT 2.3.2 launcher error. Found bug fix/patch, but not sure how to install. |
0 |
5459 |
Tue, 01 March 2016 20:30 By: Corey Hill |
Using a Remote Report not a locally file |
0 |
5493 |
Fri, 26 February 2016 14:45 By: Martin Schlesier |
Creating a Fixed Width flatfile using BIRT Creating a Fixed Width flatfile using BIRT |
0 |
5660 |
Fri, 26 February 2016 12:17 By: Sunny YS |
Blank Report on I-Series Generated report has no rows |
0 |
5471 |
Fri, 26 February 2016 06:47 By: Ambika Das |
Getting ODBC Error when the BIRT Report is called. Getting ODBC Error when the BIRT Report is called. |
0 |
5359 |
Thu, 25 February 2016 19:58 By: Arunkumar Kumaravel |
Aggregation in BIRT -need to sum aggrevated values (total1+total2) coming from two different Dataset Aggregation in BIRT - need to sum aggrevated values |
1 |
5520 |
Fri, 19 February 2016 14:19 By: Jerry Sheets |
Inline Display Orientation |
0 |
6057 |
Wed, 17 February 2016 22:15 By: ronald hagan |
Set data source to BIRT report |
0 |
7143 |
Wed, 17 February 2016 12:14 By: Anuradha Kadurugasyaya |
selecting columns at runtime |
0 |
7092 |
Wed, 17 February 2016 11:13 By: Rajarshi Chakravarty |
Complex report structure Need to implement complex report structure as image below |
2 |
6248 |
Wed, 17 February 2016 10:35 By: Anuradha Kadurugasyaya |
Birt libraries for java Can someone give me a link for get jar files to view birt reports in java |
0 |
7130 |
Wed, 17 February 2016 10:30 By: Anuradha Kadurugasyaya |
BIRT report view Unable to view non-test reports using BIRT |
0 |
6719 |
Wed, 17 February 2016 09:16 By: Anurag Harsh |
Birt Runtime library, Maven repository: org.eclipse.birt.runtime 4.5 java.lang.SecurityException: class "org.eclipse.core.runtime.IExtensionRegistry"'s signer information does not match signer information of other classes in the same package |
1 |
6376 |
Tue, 16 February 2016 07:56 By: Christian Facciorusso |
Pass parameter to BIRT from java BIRT ignoring setParameterValue |
0 |
6257 |
Fri, 12 February 2016 18:11 By: David Wood |
exception occur while generate the report org.eclipse.birt.report.engine.api.EngineException: Cannot create data engine. |
1 |
5040 |
Fri, 12 February 2016 13:11 By: Kamran Ali Kalwar |
Obtaining a different value from what is being shown while inputting parameters I am displaying a dropdown for user to select data but what I am showing in dropdown is shortform and I want the full form of that shortform that the user will select from dropdown. I have mapping of |
0 |
4490 |
Thu, 11 February 2016 13:52 By: Sushil Kumar Sah |
Bubble Chart: Change bubble size using a script |
0 |
5053 |
Wed, 10 February 2016 16:58 By: Jasper D. |
Combining/Collapsing rows I'm wondering if it is possible to combine rows like in the following example. By: Roger B on Tue, 09 February 2016 |
0 |
4681 |
Tue, 09 February 2016 17:00 By: Roger B |
Custom date format problem |
0 |
4981 |
Tue, 09 February 2016 12:58 By: Jean-Luc Gyger |
Birt report in Maximo export to PDF Birt report in Maximo export to PDF |
0 |
6673 |
Tue, 09 February 2016 08:04 By: shilpi bhatnagar |
Can not load the report query |
0 |
5161 |
Mon, 08 February 2016 15:19 By: Joao Antunes |
How can I execute a SELECT statement in an expression? |
1 |
5667 |
Sat, 06 February 2016 05:41 By: Stefan Seitz |
Designing more flexible Layout Creating a flexible layout which load report data on a background image, which includes its own grid |
1 |
4423 |
Sat, 06 February 2016 05:18 By: Stefan Seitz |
How to set the value of a report parameter |
1 |
6083 |
Sat, 06 February 2016 05:03 By: Stefan Seitz |
BIRT- Crosstab Group. Script to hide or shrink width to 0 depending on parameter |
0 |
5955 |
Fri, 05 February 2016 14:34 By: james allen |
error while viewing a report Errors in Report Line 1: The style sheet with the name "test.css" is not found. |
0 |
5290 |
Fri, 05 February 2016 09:40 By: Patrick Cazaux |
Drop and Add Table Again |
0 |
5093 |
Thu, 04 February 2016 17:26 By: Uanderson Leonel |
