  Question: How to implement a Viewer Databinding for a list property
By: Eclipse User on Mon, 12 August 2024
0 1795 Mon, 12 August 2024 06:17
  LabelProvider.getImage is not called when viewer.input is called
labelprovider viewer image
By: Eclipse User on Mon, 17 June 2024
0 1189 Mon, 17 June 2024 10:53
  Simple Comboviewer databinding issue
By: Eclipse User on Wed, 31 July 2013
1 3729 Tue, 19 March 2024 10:03
  TreeViewer, how to jump say what element to show on top?
By: Eclipse User on Wed, 02 October 2013
8 14566 Thu, 08 February 2024 04:41
  Update TableViewer with new data on top of existing one.
By: Eclipse User on Mon, 11 September 2023
0 1729 Mon, 11 September 2023 13:22
  How to add custom tooltip to ColumnLabelProvider?
By: Eclipse User on Fri, 02 June 2017
1 14678 Mon, 24 July 2023 07:11
  Text Wrapping Row/Column Label Provider for TreeViewer ?
By: Eclipse User on Mon, 18 October 2021
1 3619 Mon, 24 July 2023 07:18
  SourceViewer with SpellChecking
By: Eclipse User on Fri, 21 April 2023
0 1394 Fri, 21 April 2023 18:43
  TreeViewerColumn images not centering
By: Eclipse User on Fri, 17 March 2023
0 2193 Fri, 17 March 2023 22:17
  Unable to see Caret in Jface TableViewer for StyledTextCellEditor on Ubuntu 20.04.2 LTS
By: Eclipse User on Thu, 06 October 2022
1 3120 Wed, 02 November 2022 07:07
  how interrupt the treeviewer refresh behavior
By: Eclipse User on Mon, 15 August 2022
0 2651 Mon, 15 August 2022 01:01
  Window Resize issue when updating the ToolbarManager
By: Eclipse User on Wed, 13 October 2021
0 3221 Wed, 13 October 2021 04:52
  When can I use run() from ApplicationWindow?
By: Eclipse User on Wed, 06 May 2009
2 86855 Fri, 08 October 2021 20:38
  HiDPI aware icons in MessageDialog
By: Eclipse User on Wed, 03 March 2021
0 3226 Wed, 03 March 2021 04:11
  Using TableViewerColumns does not refresh viewer entries
By: Eclipse User on Tue, 22 December 2020
0 2416 Tue, 22 December 2020 04:13
  Face data binding strange behavior
0 3208 Tue, 22 December 2020 03:04
  Jface EOL versions?
end-of-life
By: Eclipse User on Wed, 16 December 2020
0 3646 Wed, 16 December 2020 10:40
  Databing with viewer input
ViewerProperties.input().observe(tableViewer);
By: Eclipse User on Mon, 23 July 2012
3 4464 Wed, 09 December 2020 10:11
  Horizontal toolbar on custom DPI settings
By: Eclipse User on Mon, 23 November 2020
0 2332 Mon, 23 November 2020 03:41
  Thread hangs in TreeViewer.setExpandedElements();
By: Eclipse User on Thu, 09 July 2020
0 2745 Thu, 09 July 2020 08:12
  Show filepaths as links in TextViewer
By: Eclipse User on Wed, 03 June 2020
0 2623 Wed, 03 June 2020 04:52
  Validation for dynamically created fields on WizardPage
By: Eclipse User on Thu, 14 May 2020
0 2347 Thu, 14 May 2020 11:10
  Optional Fields on WizardPage
0 2281 Thu, 14 May 2020 10:27
  How to Retain focus on View after opening Editor
Selection retaining in View when editor opens
By: Eclipse User on Tue, 28 April 2020
1 3443 Wed, 29 April 2020 09:00
  TreeViewer with Columns: Horizontal scroll first column only
By: Eclipse User on Sat, 21 March 2020
0 3635 Sat, 21 March 2020 06:55
  when I drag the composite edge,It not work very well!Why?
By: Eclipse User on Mon, 24 February 2020
1 1896 Mon, 24 February 2020 21:43
  How to drag clabel,button,table widgesfrom left,right,top and bottom(resize a composite)
resize a composite
By: Eclipse User on Fri, 21 February 2020
0 5517 Fri, 21 February 2020 03:38
  Display Table viewer with many columns
By: Eclipse User on Fri, 16 April 2010
7 7671 Wed, 22 January 2020 04:07
  How to make BrowserInformationControl focusable
TextHover
By: Eclipse User on Thu, 27 September 2018
2 4732 Thu, 09 January 2020 04:23
  How to make TextHover sticky?
By: Eclipse User on Thu, 20 July 2017
1 8481 Wed, 08 January 2020 12:27
  move RuleBasedScanner to org.eclipse.text?
By: Eclipse User on Wed, 11 December 2019
0 5080 Wed, 11 December 2019 12:21
  Undo/Redo keyboard shortcuts in a JFace dialog
By: Eclipse User on Wed, 11 June 2014
2 5915 Wed, 11 December 2019 04:38
  Can not register multiple widget for the same menuContribution ID
By: Eclipse User on Wed, 13 November 2019
1 2373 Mon, 18 November 2019 01:42
  TreeViewer doesn't work well on Ubuntu
By: Eclipse User on Fri, 07 June 2013
1 20843 Mon, 28 October 2019 02:12
  Binding for CTabFolder
How to bind single elements from a list to CTabItems
By: Eclipse User on Mon, 02 September 2019
0 264281 Mon, 02 September 2019 03:53
  Keybinding conflicts
By: Eclipse User on Tue, 30 July 2019
0 22108 Tue, 30 July 2019 09:16
  NPE in ColumnViewerEditor due to cellEditor is null
when I switch the focus from one tree cell to another, the NPE occurs in ColumnViewerEditor
By: Eclipse User on Wed, 24 July 2019
0 25658 Wed, 24 July 2019 06:05
  ModalContext.setAllowReadAndDispatch does not work correct as comment
By: Eclipse User on Tue, 23 April 2019
2 7722 Wed, 24 April 2019 23:33
  Best way to make data-binding conditional
By: Eclipse User on Mon, 11 February 2019
1 1965 Mon, 11 February 2019 10:07
  AutoCompleteField with comma-separated values?
By: Eclipse User on Mon, 04 February 2019
0 6722 Mon, 04 February 2019 16:43
  Databinding WidgetProperties.editable()
By: Eclipse User on Sat, 05 January 2019
0 3591 Sat, 05 January 2019 13:49
  What is the standard way of setting key bindings for SourceViewer
SourceViewer KeyBindings
By: Eclipse User on Thu, 08 November 2018
0 4056 Thu, 08 November 2018 20:24
  How to make a shell behaves like CompletionProposalPopup#fProposalShell
By: Eclipse User on Mon, 05 November 2018
2 3572 Mon, 05 November 2018 11:13
  JFace Action that supports drop-down AND checkbox
By: Eclipse User on Mon, 08 October 2018
1 2266 Mon, 08 October 2018 06:49
1 2137 Mon, 08 October 2018 04:51
1 2031 Mon, 08 October 2018 04:50
  JFace databinding
WindowBuilders generated code has warning
By: Eclipse User on Thu, 09 August 2018
1 2469 Thu, 09 August 2018 14:10
  Where to get Jface source code including compile information
By: Eclipse User on Mon, 21 May 2018
5 6220 Sat, 02 June 2018 02:12
  How to get scolling in a wizard dialog
By: Eclipse User on Thu, 30 April 2009
6 27968 Wed, 30 May 2018 12:31
  Pack tree columns on property sheet entry change
By: Eclipse User on Tue, 15 May 2018
0 3552 Tue, 15 May 2018 18:20
  The performance optimization of updateChildren() in org.eclipse.jface.viewers.AbstractTreeViewer
0 4905 Tue, 15 May 2018 05:55
  Problems with checked elements in CheckboxTableViewer based on virtual table
By: Eclipse User on Mon, 12 July 2010
2 13307 Mon, 14 May 2018 10:45
  Downloading Jface separately
By: Eclipse User on Mon, 26 March 2018
1 3435 Mon, 26 March 2018 14:54
  [SOLVED] [Databinding] - Bind a Text widget and a ListViewer for modification
By: Eclipse User on Sat, 17 March 2018
1 7462 Sat, 17 March 2018 07:46
  ErrorDialog.openError IStatus character limit
Large error causes error not to paint in Details button view
By: Eclipse User on Tue, 06 February 2018
2 3677 Wed, 07 February 2018 13:13
  DataBinding with Image on Label: no Change Event?
By: Eclipse User on Wed, 07 February 2018
1 2702 Wed, 07 February 2018 12:31
  Missing minimize, maximize buttons in Dialog on Linux
By: Eclipse User on Mon, 21 February 2011
2 11598 Wed, 17 January 2018 23:10
  Jface accelerator key not working on macOS when focus is on StyledText widget
By: Eclipse User on Sun, 07 January 2018
2 3586 Wed, 10 January 2018 12:53
  Scrolling JFace viewers on a white background (Linux/GTK)
By: Eclipse User on Fri, 04 June 2010
3 6412 Tue, 19 December 2017 02:32
  UI freezes when running a long operation in a jface wizard
By: Eclipse User on Sat, 09 December 2017
1 5154 Sat, 09 December 2017 22:12
  [SOLVED] RTL support for Wizards or TreeViewers?
By: Eclipse User on Sun, 03 December 2017
1 2856 Sun, 03 December 2017 20:18
  jface wizard becomes not responding
By: Eclipse User on Wed, 29 November 2017
2 2855 Wed, 29 November 2017 10:29
0 5363 Wed, 29 November 2017 05:35
  Not responding
0 5389 Wed, 29 November 2017 05:34
  Virtual TreeViewer setSelection problem
By: Eclipse User on Wed, 15 November 2017
0 6233 Wed, 15 November 2017 07:19
  TextEdit code design decision
Restriction of overlapping children in an edit tree
By: Eclipse User on Mon, 02 October 2017
0 8938 Mon, 02 October 2017 09:31
  Trigger multivalidator in AggregateValidationStatus changelistener
By: Eclipse User on Wed, 27 September 2017
0 13191 Wed, 27 September 2017 07:47
  How to remove the default the Filter Text Box from ElementListSelectionDialog
By: Eclipse User on Tue, 26 September 2017
1 4322 Tue, 26 September 2017 09:08
  How to change default sorting of ElementListSelectionDialog
How to change default sorting of ElementListSelectionDialog?
By: Eclipse User on Mon, 25 September 2017
2 8207 Tue, 26 September 2017 01:26
  adding wizardPages and get the result dynamically
By: Eclipse User on Fri, 01 September 2017
2 12720 Tue, 19 September 2017 11:52
  ValueBinding not catching converter exception
By: Eclipse User on Fri, 18 August 2017
0 10737 Fri, 18 August 2017 11:05
  Any reason why the "org.eclipse.jface.preference.PreferenceStore" class has no "remo
By: Eclipse User on Tue, 15 August 2017
5 7575 Thu, 17 August 2017 16:38
  Enable disable custom import export wizards
I want to enable and disable custom new project wizard, export and import wizards based upon perspective.
By: Eclipse User on Tue, 08 August 2017
0 12462 Tue, 08 August 2017 01:56
  How to populate custom list data (two levels) using CheckedTreeSelectionDialog
By: Eclipse User on Thu, 06 July 2017
0 13647 Thu, 06 July 2017 00:19
  Editing in TreeViewer
By: Eclipse User on Tue, 30 May 2017
0 11915 Tue, 30 May 2017 03:31
  Custom Control in menu item
By: Eclipse User on Thu, 25 May 2017
4 15455 Mon, 29 May 2017 03:03
  Need ComboBoxCellEditor drop down multi selection functionality in SWT
am using treeviewer, in this viewer using comboBoxCellEditor.i want to multiSelection functionality in comboBoxCellEditor. Please suggest.
By: Eclipse User on Thu, 11 May 2017
0 58882 Thu, 11 May 2017 06:38
  [ComboViewer]Cannot get the add image for one item when using ComboViewer
getImage() in LabelProvider cannot worked as expected.
By: Eclipse User on Fri, 24 March 2017
2 7625 Sun, 26 March 2017 23:16
  How do I update a column label provider when using ObservableValueEditingSupport? [SOLVED]
By: Eclipse User on Tue, 28 February 2017
0 11532 Tue, 28 February 2017 11:42
  Why is ObservableListTreeContentProvider not meant to be subclassed?
By: Eclipse User on Thu, 23 February 2017
1 3256 Thu, 23 February 2017 13:42
  Databinding to mutable property stops in SimplePropertyObserverValue
By: Eclipse User on Thu, 02 February 2017
0 12253 Thu, 02 February 2017 09:25
  TextEditor substring Content proposals`?
By: Eclipse User on Thu, 19 January 2017
1 2941 Thu, 19 January 2017 15:34
  JFace TableViewer Number of Columns header
JFace TableViewer Number of Columns header are not displaying fully
By: Eclipse User on Fri, 23 December 2016
0 6450 Fri, 23 December 2016 01:53
  TableViewer hiding columns in MAC
A thick line gets appeneded in MAC
By: Eclipse User on Wed, 23 November 2016
0 16099 Wed, 23 November 2016 00:42
  Resize tree on collapsing and expanding
By: Eclipse User on Tue, 22 November 2016
2 10129 Wed, 23 November 2016 04:46
  Slow reaction of Eclipse Editors on a Windows VM
Eclipse Luna vs Eclipse Kepler performance of application
By: Eclipse User on Thu, 17 November 2016
0 55452 Thu, 17 November 2016 14:44
  Is there a PathEditorField decorator ?
How do I ? decorating some PathEditorField Instance ...
By: Eclipse User on Tue, 11 October 2016
0 5783 Tue, 11 October 2016 14:59
  Best way to open a TreeViewer
By: Eclipse User on Mon, 26 September 2016
0 6319 Mon, 26 September 2016 12:01
  StackOverflowError with databinding
By: Eclipse User on Tue, 13 September 2016
1 5606 Fri, 16 September 2016 06:15
  Viewers
What do you mean by viewers?
By: Eclipse User on Wed, 07 September 2016
0 4823 Wed, 07 September 2016 10:04
  news.eclipse.org is shutting down.
By: Eclipse Webmaster on Wed, 31 August 2016
0 2566 Wed, 31 August 2016 14:44
  Add Scroller to a long JFace MenuManager
I have a MenuManager with many items. Some items are not visible on the Screen.
By: Eclipse User on Tue, 30 August 2016
0 3217 Tue, 30 August 2016 08:01
  [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL?
By: Eclipse User on Thu, 18 August 2016
5 4896 Fri, 19 August 2016 03:29
  [Databinding/E4] Binding of nested properties
By: Eclipse User on Fri, 22 July 2016
2 7200 Fri, 12 August 2016 03:32
  issue with tree node
After search option returns no parent match, further unable to expand parent, even if we get any match
By: Eclipse User on Thu, 16 June 2016
0 5616 Thu, 16 June 2016 05:51
  VIRTUAL (Checkbox)TreeViewer has inconsistent selection
By: Eclipse User on Mon, 06 June 2016
0 6262 Mon, 06 June 2016 05:27
  WordWrap in Tabbed Property
Problem getting word wrap work in (Styled-)Text field in Tabbed Property View
By: Eclipse User on Tue, 26 April 2016
0 6667 Tue, 26 April 2016 18:26
  Caret reset on StyledText
By: Eclipse User on Thu, 21 April 2016
0 6760 Thu, 21 April 2016 14:32
  ViewPart tab edge (square vs soft)
By: Eclipse User on Thu, 10 March 2016
0 4657 Thu, 10 March 2016 11:20
  Show dialog on startup in JFace application
By: Eclipse User on Sun, 06 March 2016
0 6297 Sun, 06 March 2016 10:36
  No Text Wrap support in Table cell
We are not able to wrap text of table cell which is created using Jface
By: Eclipse User on Mon, 01 February 2016
1 4470 Tue, 02 February 2016 02:06
  SWTObservables deprecated
By: Eclipse User on Wed, 20 January 2016
0 7959 Wed, 20 January 2016 21:12
icon7.gif Horizontal scroll bar disappears for TreeViewer
Gridlayot data after re sizing of view horizontal scroll bar disappears for TreeViewer
By: Eclipse User on Fri, 15 January 2016
1 5029 Fri, 15 January 2016 09:47
  Button-clicked listeners in Wizard
By: Eclipse User on Thu, 07 January 2016
1 3039 Thu, 07 January 2016 10:30
  JFace Layout Mystery - What am I doing wrong?
By: Eclipse User on Tue, 05 January 2016
1 8182 Fri, 05 February 2016 07:20
  How to draw Annotation in SourceViewer
By: Eclipse User on Tue, 15 December 2015
0 6809 Tue, 15 December 2015 15:22
  Table using ColumnWeightData not resizing correctely
By: Eclipse User on Tue, 01 December 2015
0 6682 Tue, 01 December 2015 04:23
  ContentProposalAdapter popup to show on top of textbox
By: Eclipse User on Mon, 30 November 2015
1 3096 Tue, 01 December 2015 02:29
  ComboViewer color change issue
By: Eclipse User on Wed, 25 November 2015
1 2781 Wed, 25 November 2015 10:50
  Is there a way to change fonts in Completion Popup?
By: Eclipse User on Tue, 17 November 2015
0 5581 Tue, 17 November 2015 21:55
  TextWidget catches SWT.CR key event when complement a word
By: Eclipse User on Sun, 15 November 2015
5 8679 Fri, 20 November 2015 01:55
  Using a table to display a hierarchy of objects
By: Eclipse User on Tue, 10 November 2015
0 4963 Tue, 10 November 2015 05:26
  64-bit applications don't respond when a 32-bit Java application displays a dialog in 64bit windows7
By: Eclipse User on Tue, 03 November 2015
0 6405 Tue, 03 November 2015 05:13
icon5.gif Factor out logic from Dialog?
Is it worth the effort factoring out that bit of logic from a Dialog?
By: Eclipse User on Thu, 22 October 2015
0 8239 Thu, 22 October 2015 11:11
  connected lists widget
By: Eclipse User on Wed, 21 October 2015
3 6903 Sun, 25 October 2015 11:25
  SWT Drop Target Problem on Linux
DropTarget Area not correctly drawn on gtk ?
By: Eclipse User on Mon, 12 October 2015
0 5091 Mon, 12 October 2015 01:26
  selectionChanged event not triggered after opening EditPart from TreeView
By: Eclipse User on Thu, 01 October 2015
1 4574 Sun, 04 October 2015 11:10
  TableViewer.setInput does not update the table
By: Eclipse User on Mon, 28 September 2015
1 4235 Tue, 29 September 2015 09:06
  [Databinding] Relation to ReactiveX?
What is the relation of JFace Data binding to RxJava ja ReactiveX frameworks?
By: Eclipse User on Thu, 24 September 2015
0 5929 Thu, 24 September 2015 04:15
  [databinding] How to observe EMF model changes?
By: Eclipse User on Sat, 19 September 2015
2 3394 Tue, 22 September 2015 05:14
  problem with the CheckboxCellEditor
CheckboxCellEditor Issue
By: Eclipse User on Fri, 11 September 2015
0 6363 Fri, 11 September 2015 09:35
  TableViewer column header loses image on sorting
By: Eclipse User on Tue, 01 September 2015
2 6341 Tue, 20 October 2015 11:15
  [Databinding] How to refresh a ComboViewer's filter properly?
By: Eclipse User on Mon, 10 August 2015
3 7667 Tue, 25 August 2015 08:41
  Find Tree Node
Implementation of Find Tree Node
0 9133 Mon, 10 August 2015 03:53
  How to Build a "searchable" Combo?
By: Eclipse User on Tue, 04 August 2015
0 5461 Tue, 04 August 2015 09:32
  how to convert eclipse plug-in project to java project
want to convert project without rewriting every thing
By: Eclipse User on Wed, 29 July 2015
0 4704 Wed, 29 July 2015 11:59
icon5.gif [Databinding] Tableviewer only updates new entries
2 3993 Sun, 02 August 2015 18:52
  How to trigger updateMarker for TextEditor from code
By: Eclipse User on Thu, 23 July 2015
0 5753 Thu, 23 July 2015 11:12
  Select column showing expand/collapse buttons in jface TreeViewer
By: Eclipse User on Tue, 14 July 2015
0 2806 Tue, 14 July 2015 09:20
  saving changes to database after editing a cell
By: Eclipse User on Thu, 02 July 2015
2 3497 Sun, 09 August 2015 17:00
icon5.gif how to enter data directly in a table using tableviewer
By: Eclipse User on Fri, 26 June 2015
0 3229 Fri, 26 June 2015 07:31
  Problems with properties view
Properties view doesn't notified after undo action
0 3331 Fri, 26 June 2015 06:03
  Packaging the new Bind API
By: Eclipse User on Thu, 25 June 2015
0 3195 Thu, 25 June 2015 04:40
  Issue with EditingSupport.
By: Eclipse User on Wed, 24 June 2015
0 3493 Wed, 24 June 2015 04:40
  Lazy content provider with data-binding?
By: Eclipse User on Tue, 23 June 2015
0 3319 Tue, 23 June 2015 12:53
  [DataBinding] Model and UI Independence for Collections
How do you fully separate the UI and Model for Collections?
By: Eclipse User on Sun, 21 June 2015
0 3679 Sun, 21 June 2015 11:46
  Jface TreeView File list drag and drop
By: Eclipse User on Mon, 18 May 2015
3 5419 Thu, 21 May 2015 06:16
  Custom PatternFilter in TreeViewer
By: Eclipse User on Wed, 13 May 2015
2 3902 Wed, 13 May 2015 16:02
  How to select the tree item when a char is typed
By: Eclipse User on Thu, 07 May 2015
0 3559 Thu, 07 May 2015 04:01
  Keeping CellEditors open
By: Eclipse User on Tue, 28 April 2015
0 3173 Tue, 28 April 2015 06:50
  How toHow to draw lines between jface tree items
By: Eclipse User on Mon, 27 April 2015
0 2950 Mon, 27 April 2015 15:49
  Undo/Redo with TextViewers and Dirty State Handling
Dirty State Handling for TextViewer Objects in the Context of Undo/Redo in an Editor
By: Eclipse User on Thu, 23 April 2015
1 5112 Mon, 27 April 2015 16:25
  Single Selection ViewerProperties Databinding with Converter
Unable to have the Viewer Selection automatically set using databinding
By: Eclipse User on Thu, 16 April 2015
0 4034 Thu, 16 April 2015 20:58
  Passing data between ViewerDropAdapter and DragSourceListener
By: Eclipse User on Sat, 04 April 2015
3 4340 Mon, 06 April 2015 09:40
  TreeViewer with ILazyTreeContentProvider
updateElement() from ILazyTreeContentProvider gets called for expanded elements, although they are not visible
By: Eclipse User on Tue, 24 March 2015
2 10729 Fri, 26 May 2017 02:29
  TreeViewer & Columns number
too many column!
By: Eclipse User on Fri, 13 March 2015
4 6565 Thu, 19 March 2015 06:48
  Syncing different Parts together
By: Eclipse User on Wed, 11 March 2015
3 3547 Mon, 16 March 2015 12:08
  Data binding to an EMF model via feature path
By: Eclipse User on Tue, 03 March 2015
1 2750 Wed, 04 March 2015 12:57
  add listener to next button wizard page
By: Eclipse User on Mon, 23 February 2015
2 11231 Mon, 11 January 2016 11:36
  Eclipse warns about deprecated methods
...which are not deprecated instead.
By: Eclipse User on Thu, 19 February 2015
0 2991 Thu, 19 February 2015 04:35
  [DataBinding] Model to Viewer Databinding
Real-time automatically triggered viewer updates
By: Eclipse User on Wed, 18 February 2015
5 4375 Thu, 19 February 2015 09:29
  [JFace] Image of ControlDecoration is visible outside composite when the scrolling a composite
By: Eclipse User on Tue, 27 January 2015
0 3740 Tue, 27 January 2015 02:18
  Set font of ControlDecoration tooltip
Is it possible to set the font of the ControlDecoration tooltip?
By: Eclipse User on Wed, 21 January 2015
0 3850 Wed, 21 January 2015 07:07
  challenge: Setting with of last table column
I am not finding a way to set proper width of last column in Jface tableviewer
By: Eclipse User on Mon, 05 January 2015
0 4149 Mon, 05 January 2015 13:46
  can Jface table cell have selection event
wish to know if a selection listener can be created for jface table cell
By: Eclipse User on Wed, 03 December 2014
0 3239 Wed, 03 December 2014 10:14
  How to access the data provider instance created in the Activator of my plug-in
By: Eclipse User on Sat, 29 November 2014
0 7790 Sat, 29 November 2014 04:51
  How to add readonly textbox in table Viewer.
User want to select and copy the required text string from table viewers cell.
By: Eclipse User on Mon, 10 November 2014
1 5990 Mon, 17 November 2014 04:44
  TextCellEditor does not show edited content
5 4484 Mon, 10 November 2014 10:21
  How to make shell display when it is hidden
After a shell window is hidden, e.g. cover the by another program, how to make it display again
By: Eclipse User on Tue, 28 October 2014
0 4146 Tue, 28 October 2014 09:32
  Changing Label Provider for tree viewer giving null pointer exception in MAC
By: Eclipse User on Mon, 27 October 2014
3 5987 Wed, 29 October 2014 03:37
  Select With TAB in ContentProposalAdapter
Possible to select proposal with tab key in a content provider
By: Eclipse User on Fri, 24 October 2014
0 4925 Fri, 24 October 2014 04:25
  How do i enable expand feature to a table column???
By: Eclipse User on Fri, 26 September 2014
0 3129 Fri, 26 September 2014 01:36
  Using JFace data binding with an EMF List which maby be null
By: Eclipse User on Tue, 23 September 2014
0 2979 Tue, 23 September 2014 15:51
  Making User interface more attractive
Need some way of having rounded edges to shells and text entries
By: Eclipse User on Mon, 22 September 2014
0 3932 Mon, 22 September 2014 13:43
  form layout based interfaces look inconsistent on different screensf
Layout issues with complex forms when doing MDI style application
0 3311 Mon, 22 September 2014 13:35
  Need help with Jface in eclipse
This is about my query about Jface and making projects in clipse
By: Eclipse User on Mon, 08 September 2014
4 3940 Tue, 09 September 2014 09:10
  ComboViewer Horizontal Layout
By: Eclipse User on Fri, 05 September 2014
3 7210 Tue, 23 September 2014 04:11
  Content not displaced in TreeViewer
By: Eclipse User on Tue, 26 August 2014
2 3522 Thu, 28 August 2014 04:38
  ToolBarManager added to CoolBarManager grabs horizontal space?
By: Eclipse User on Fri, 22 August 2014
3 5606 Tue, 23 September 2014 08:18
icon4.gif creating JSF application in Eclipse, putting jar files in WEB-INF
By: Eclipse User on Tue, 12 August 2014
0 3873 Tue, 12 August 2014 12:51
  TableViewer with ILazyContentProvider does not remove elements
By: Eclipse User on Sat, 09 August 2014
2 6073 Sun, 10 August 2014 18:21
  Filter ComboBox content prior to its expansion
By: Eclipse User on Mon, 04 August 2014
2 4216 Mon, 04 August 2014 04:02
  How to trigger ICellModifier 's modify()?
By: Eclipse User on Sun, 27 July 2014
0 4001 Sun, 27 July 2014 15:00
  Is there any way to get SourceViewer by a known StyledText?
By: Eclipse User on Sat, 26 July 2014
0 3384 Sat, 26 July 2014 06:43
  SourceViewer : how to create batch of actions
By: Eclipse User on Wed, 23 July 2014
2 6179 Wed, 30 July 2014 01:02
icon5.gif How to remember jFace treeviewer's expand state?
By: Eclipse User on Thu, 12 June 2014
5 9359 Fri, 27 June 2014 05:03
  Help icon in JFace Wizard
Detecting action on the Help icon present in the JFace wizard
By: Eclipse User on Tue, 10 June 2014
1 4442 Tue, 08 July 2014 12:26
  Template Proposal does not fully work
By: Eclipse User on Wed, 04 June 2014
0 7551 Wed, 04 June 2014 12:59
  CommonViewer / CommonNavigator with default EditActions
By: Eclipse User on Tue, 03 June 2014
0 12418 Tue, 03 June 2014 05:08
  FieldEditorPreferencePage
Label text does not wrap up in a FieldEditorPreferencePage window
By: Eclipse User on Tue, 20 May 2014
1 6134 Tue, 08 July 2014 12:28
  Modify the update strategy of a binding after creation
By: Eclipse User on Tue, 13 May 2014
2 14029 Thu, 05 June 2014 06:37
  Some errors from Jface...
By: Eclipse User on Fri, 02 May 2014
0 16383 Fri, 02 May 2014 14:37
icon9.gif TreeViewer::setInput() -> UI timeout
1 18354 Wed, 09 July 2014 03:37
2 15500 Wed, 09 July 2014 03:31
  TableViewer with OwnerDrawLabel only draws the first row
By: Eclipse User on Sun, 27 April 2014
2 3771 Sun, 27 April 2014 14:43
  [DATABINDING] How-to: binding the (current single) selection of treeViewers to something
By: Eclipse User on Wed, 23 April 2014
4 5987 Wed, 30 April 2014 08:14
  Getting/Setting EReferences of a EMF model instance in a TableViewer with ComboBox
By: Eclipse User on Sat, 19 April 2014
0 23520 Sat, 19 April 2014 16:56
  Calling refresh() on tableViewer clears the table data
Calling refresh() on tableViewer clears the table data but does not filter it
2 34403 Wed, 09 July 2014 10:25
  Not scroll when related scrollbar disposed
By: Eclipse User on Tue, 15 April 2014
1 19832 Thu, 17 April 2014 06:00
  how to hide the dotted lines between tree nodes
2 9328 Wed, 16 April 2014 03:11
  What are the latest databinding versions?
By: Eclipse User on Mon, 14 April 2014
3 16170 Wed, 30 April 2014 07:31
  [Databinding] multi-layered binding with master detail scenario
By: Eclipse User on Tue, 08 April 2014
1 10801 Wed, 30 April 2014 07:07
  Boolean in ComboBoxCellEditor
By: Eclipse User on Wed, 02 April 2014
2 4363 Sat, 19 April 2014 17:24
  Ctrl + A in SourceViewer returns empty TextSelection
By: Eclipse User on Wed, 26 March 2014
1 3136 Wed, 26 March 2014 08:55
  Keyboard accessibility on TableViewerColumn with a combo box
By: Eclipse User on Mon, 24 March 2014
1 4163 Tue, 25 March 2014 17:34
  Combining different cell editors in one editing support
By: Eclipse User on Sun, 23 March 2014
1 7310 Wed, 09 July 2014 03:52
  How to display the percentage text in ProgressMonitorDialog
By: Eclipse User on Thu, 20 March 2014
1 4498 Fri, 15 January 2016 02:02
  Resizable non modal dialog
By: Eclipse User on Wed, 12 March 2014
1 7425 Thu, 13 March 2014 06:22
  TreeViewer vs TableViewer
Huge performance difference
By: Eclipse User on Fri, 14 February 2014
0 5831 Fri, 14 February 2014 04:17
  [Databinding] A complex scenario
By: Eclipse User on Thu, 13 February 2014
2 6562 Fri, 28 March 2014 12:33
Current Time: Sat Jul 26 13:57:48 EDT 2025
Powered by FUDForum. Page generated in 0.09607 seconds
