Topic |
Replies |
Views |
Last message |
Debugging Eclipse Application Problem: Launches repeatedly |
0 |
3519 |
Thu, 18 September 2008 16:21 By: Paul Reiners |
export wizard and team provider |
0 |
2547 |
Thu, 18 September 2008 04:08 By: Jason Hocker |
0 |
3328 |
Get IFile from IWorkspaceRoot and location String |
2 |
2534 |
Wed, 17 September 2008 17:39 By: Paul Reiners |
0 |
2650 |
Wed, 17 September 2008 16:01 By: Paul Reiners |
Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows Vista |
0 |
2480 |
Wed, 17 September 2008 14:41 By: Steffen Zschaler |
0 |
3553 |
eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) By: Eclipse User on Fri, 12 September 2008 |
10 |
4055 |
Wed, 17 September 2008 08:30 By: Eclipse User |
p2'izing an application takes too long |
4 |
1715 |
Wed, 17 September 2008 04:09 By: Ketan Padegaonkar |
memory snapshots of eclipse plugins |
0 |
2596 |
Tue, 16 September 2008 21:02 By: Carolyn Duby |
PDE Build failure: OutOfMemoryError: Java heap space |
8 |
4027 |
Tue, 16 September 2008 16:00 By: Will Horn |
Help plugin functions in 3.3, but not in 3.4 By: test on Wed, 10 September 2008 |
8 |
2023 |
Mon, 15 September 2008 18:27 By: Ketan Padegaonkar |
0 |
2644 |
Mon, 15 September 2008 18:13 By: Ketan Padegaonkar |
ClassNotFoundException (org.eclipse.swt.widgets.Composite) when running the Testing Framework |
6 |
2715 |
Mon, 15 September 2008 18:10 By: Ketan Padegaonkar |
0 |
3211 |
Mon, 15 September 2008 16:29 By: Matt Sither |
Problem Exporting Product with Eclipse 3.4 By: Joe on Fri, 12 September 2008 |
6 |
1716 |
Mon, 15 September 2008 14:56 By: Andrew Niefer |
PrefernceTransfer |
0 |
2628 |
Mon, 15 September 2008 13:44 By: Fabian Schmidt |
PrefernceTransfer |
0 |
3391 |
Restarting Eclipse |
2 |
1453 |
Mon, 15 September 2008 10:35 By: Fabian Schmidt |
0 |
2722 |
Mon, 15 September 2008 09:50 By: Fabian Schmidt |
Launching a "RunAs" Task from a Wizard |
0 |
2754 |
Sat, 13 September 2008 11:18 By: Karl Philipp |
Dynamic Views |
0 |
2504 |
Sat, 13 September 2008 05:25 By: Ricky Patel |
Dynamic Views |
0 |
3322 |
0 |
2815 |
Fri, 12 September 2008 15:40 By: Eclipse User |
0 |
2819 |
Fri, 12 September 2008 15:34 By: Joe |
Running inside Eclipse and Exporting (Import-Package: Conflicts) |
0 |
2771 |
Fri, 12 September 2008 11:40 By: Thomas Schindl |
Icon for contenttype is not displayed when plugin is deployed |
2 |
1122 |
Fri, 12 September 2008 09:03 By: Helmut Duregger |
File | Export | PDE | Deployable Plugins - Bug with nested src By: Eclipse User on Mon, 04 August 2008 |
10 |
3031 |
Fri, 12 September 2008 06:30 By: Eclipse User |
plugin.xml created by PDE for plug-in with sample help contents By: Eclipse User on Thu, 11 September 2008 |
4 |
1557 |
Thu, 11 September 2008 17:07 By: Eclipse User |
0 |
3117 |
Thu, 11 September 2008 16:23 By: Helmut Duregger |
0 |
2767 |
Thu, 11 September 2008 13:06 By: Eclipse User |
0 |
3327 |
Thu, 11 September 2008 12:13 By: Matt Sither |
JUnit Plugin Tests are not recognised by PDE test run |
12 |
3659 |
Thu, 11 September 2008 07:30 By: Roland Brand |
missing org.eclipse.pde.ui By: Eclipse User on Wed, 10 September 2008 |
2 |
1578 |
Wed, 10 September 2008 20:13 By: Eclipse User |
missing org.eclipse.pde.ui |
0 |
2678 |
Wed, 10 September 2008 19:53 By: exquisitus |
Why can't a plug-in see a fragment's additions? By: Eclipse User on Tue, 09 September 2008 |
4 |
1600 |
Wed, 10 September 2008 18:11 By: Eclipse User |
PDE tutorial? By: Mark on Sat, 06 September 2008 |
6 |
2202 |
Wed, 10 September 2008 17:21 By: Lars Vogel |
0 |
2763 |
Wed, 10 September 2008 15:30 By: test |
how to display log4j output in plugin console? By: Eclipse User on Fri, 29 August 2008 |
8 |
4308 |
Wed, 10 September 2008 06:46 By: Eclipse User |
Building an update site using PDE Build By: Eclipse User on Mon, 08 September 2008 |
2 |
1191 |
Tue, 09 September 2008 19:56 By: Andrew Niefer |
How to specify <launcherIcons> in product.properties file |
2 |
1593 |
Tue, 09 September 2008 19:44 By: Andrew Niefer |
Problem with p2 and version qualifiers By: Eclipse User on Sun, 07 September 2008 |
6 |
1941 |
Tue, 09 September 2008 19:43 By: Andrew Niefer |
0 |
2692 |
Tue, 09 September 2008 18:47 By: Eclipse User |
How to open programmatically my Preference Page? |
6 |
5727 |
Tue, 09 September 2008 13:03 By: Drug Vignera |
0 |
2689 |
Mon, 08 September 2008 20:32 By: Eclipse User |
0 |
2669 |
Mon, 08 September 2008 15:45 By: Lisa Jett |
Using PDE and Maven2 to create OSGi bundle By: Eclipse User on Fri, 25 July 2008 |
4 |
2221 |
Mon, 08 September 2008 06:48 By: Eclipse User |
0 |
2611 |
Sun, 07 September 2008 03:27 By: Eclipse User |
PDE Build failure |
4 |
3638 |
Sun, 07 September 2008 02:35 By: Eclipse User |
0 |
2580 |
Sat, 06 September 2008 22:57 By: Mark |
0 |
2725 |
Sat, 06 September 2008 20:02 By: Drug Vignera |
How to enable or disable an action based on the kind of selection? By: Eclipse User on Sun, 17 August 2008 |
12 |
3021 |
Sat, 06 September 2008 15:50 By: Eclipse User |
Need help with 'menus' extension |
6 |
2343 |
Sat, 06 September 2008 15:45 By: Eclipse User |
Eclipse PDE creates invalid zip files that can't be installed By: Eclipse User on Sat, 06 September 2008 |
2 |
1440 |
Sat, 06 September 2008 14:55 By: Eclipse User |
Eclipse PDE creates invalid zip files that can't be installed |
0 |
3005 |
Sat, 06 September 2008 13:21 By: Nicholas Allen |
PDE build/test problems after migrating to 3.4 |
0 |
2681 |
Sat, 06 September 2008 04:11 By: Ketan Padegaonkar |
0 |
3562 |
[P2] Problem creating repository with .product when exporting for multiple platforms |
8 |
2274 |
Fri, 05 September 2008 22:47 By: Thomas Schindl |
PDE Builder: Copy eclipsec.exe to root folder |
2 |
2028 |
Fri, 05 September 2008 14:55 By: Eclipse User |
0 |
2635 |
Fri, 05 September 2008 14:44 By: Andreas Buchen |
import existing project into workspace extension point By: Eclipse User on Tue, 02 September 2008 |
6 |
4489 |
Thu, 04 September 2008 08:00 By: Eclipse User |
Add new prespective : createInitialLayout never gets called. |
2 |
2307 |
Wed, 03 September 2008 12:23 By: Eclipse User |
0 |
2714 |
Wed, 03 September 2008 11:54 By: Thomas Schindl |
How can I force the workbench to switch to a perspective By: Eclipse User on Tue, 02 September 2008 |
4 |
1579 |
Wed, 03 September 2008 11:12 By: Eclipse User |
0 |
2670 |
Tue, 02 September 2008 15:22 By: Eclipse User |
How can I force the workbench to switch to a perspective |
0 |
2764 |
Tue, 02 September 2008 13:21 By: Jeroen Lankheet |
Queries on Headless PDE Build |
0 |
2715 |
Mon, 01 September 2008 12:42 By: Neeraj Bhusare |
How to save information between the sessions of Eclipse? |
10 |
3167 |
Mon, 01 September 2008 12:09 By: Drug Vignera |
Unwanted plugin/bundle getting deployed (jetty 1.1.0 ticked, jetty 2.0.0 NOT, both deployed) |
2 |
1458 |
Sun, 31 August 2008 01:02 By: Eclipse User |
0 |
2570 |
Sat, 30 August 2008 16:45 By: Neale Upstone |
PDE Product Build using existing config.ini |
2 |
1686 |
Sat, 30 August 2008 16:07 By: Neale Upstone |
0 |
2861 |
Fri, 29 August 2008 09:38 By: Eclipse User |
Ganymede desparately slow when setting target platform |
6 |
3809 |
Thu, 28 August 2008 20:51 By: Tara Simpson |
refresh editor |
2 |
1724 |
Thu, 28 August 2008 20:44 By: Eclipse User |
refresh editor |
0 |
2688 |
Thu, 28 August 2008 19:32 By: Jason Hocker |
Mac and Windows different for plugin included on classpath? |
0 |
2754 |
Wed, 27 August 2008 16:13 By: David Wynter |
Mac and Windows different for plugin included on classpath? By: Eclipse User on Wed, 27 August 2008 |
0 |
3500 |
Wed, 27 August 2008 16:13 By: Eclipse User |
0 |
2742 |
Wed, 27 August 2008 15:11 By: Dennis O'Flynn |
Use project source instead of jar? By: Eclipse User on Wed, 27 August 2008 |
0 |
2528 |
Wed, 27 August 2008 13:36 By: Eclipse User |
0 |
3259 |
0 |
2639 |
Wed, 27 August 2008 11:26 By: Drug Vignera |
contributing to PackageExplorer view |
0 |
2571 |
Wed, 27 August 2008 10:58 By: Santosh |
0 |
3337 |
-debug and .options By: Eclipse User on Tue, 26 August 2008 |
8 |
1971 |
Wed, 27 August 2008 06:13 By: Eclipse User |
question about resourcetraversal By: Eclipse User on Tue, 26 August 2008 |
0 |
2546 |
Tue, 26 August 2008 22:17 By: Eclipse User |
0 |
3580 |
Eclipse 3.2.2: Contribute a pull down action (button) to (not-owned) View's toolbar. Possible? |
0 |
2566 |
Tue, 26 August 2008 18:12 By: Sandip Chitale |
0 |
3231 |
Problem Generating Metadata repository |
0 |
2618 |
Tue, 26 August 2008 15:16 By: Gladyston Agra Franca |
0 |
3302 |
-debug and .options |
0 |
2735 |
Tue, 26 August 2008 14:16 By: exquisitus |
PDE Build failure |
0 |
3201 |
Mon, 25 August 2008 15:34 By: Jimmy Royer |
0 |
2685 |
Mon, 25 August 2008 11:03 By: Tara Simpson |
close editor when delete occurs |
2 |
2300 |
Tue, 19 August 2008 22:29 By: Eclipse User |
Finding the Plugins directory By: Eclipse User on Tue, 19 August 2008 |
2 |
1403 |
Tue, 19 August 2008 17:17 By: Andrew Niefer |
Project Explorer view does not show loaded project By: Eclipse User on Mon, 18 August 2008 |
2 |
1273 |
Tue, 19 August 2008 15:56 By: Eclipse User |
0 |
2400 |
Tue, 19 August 2008 14:14 By: Jason Hocker |
Finding the Plugins directory |
0 |
2619 |
Tue, 19 August 2008 03:37 By: Richard Hughes |
PDE Automated Testing Classloader problem By: Mike on Mon, 18 August 2008 |
0 |
2766 |
Mon, 18 August 2008 21:36 By: Mike |
PDE Automated Testing Classloader problem By: Eclipse User on Mon, 18 August 2008 |
0 |
3559 |
Mon, 18 August 2008 21:36 By: Eclipse User |
Project Explorer view does not show loaded project |
0 |
2597 |
Mon, 18 August 2008 13:38 By: Jeroen Lankheet |
Getting list of selected files from ISelection By: Eclipse User on Sun, 17 August 2008 |
4 |
1883 |
Sun, 17 August 2008 22:34 By: Craig Foote |
Getting list of selected files from ISelection |
0 |
2641 |
Sun, 17 August 2008 21:03 By: Nicholas Allen |
How to enable or disable an action based on the kind of selection? |
0 |
2679 |
Sun, 17 August 2008 20:28 By: Nicholas Allen |
0 |
2468 |
Sat, 16 August 2008 03:41 By: Craig Foote |
packaging problems with plugin By: Eclipse User on Fri, 15 August 2008 |
0 |
2674 |
Fri, 15 August 2008 22:54 By: Eclipse User |
0 |
3676 |
acmeproduct.exe appears not to work when placed in the recommended directory |
6 |
2124 |
Fri, 15 August 2008 15:38 By: Andrew Niefer |
Need help with new file wizard and selection By: Eclipse User on Tue, 22 July 2008 |
4 |
1867 |
Thu, 14 August 2008 09:48 By: Eclipse User |
0 |
2713 |
Wed, 13 August 2008 21:03 By: Tim Stephenson |
Classes in a jar within a plugin are not visible to other plugins |
0 |
2750 |
Wed, 13 August 2008 16:04 By: Bruce Skingle |
Classes in a jar within a plugin are not visible to other plugins By: Eclipse User on Wed, 13 August 2008 |
0 |
3518 |
Wed, 13 August 2008 16:04 By: Eclipse User |
0 |
2801 |
Wed, 13 August 2008 15:09 By: Roland Brand |
NoClassDefFoundError when accessing libraries in the JRE's ext folder |
0 |
2678 |
Wed, 13 August 2008 13:27 By: Tom Seidel |
PDE doesn't recognize dropins folder in 3.4 target (p2) By: Eclipse User on Fri, 01 August 2008 |
22 |
4542 |
Tue, 12 August 2008 07:45 By: Eclipse User |
Regarding Extending the Universal Intro By: Eclipse User on Tue, 05 August 2008 |
4 |
2120 |
Mon, 11 August 2008 17:21 By: Chris Goldthorpe |
IAction.ischecked() returns wrong value for radio button in popup menu |
2 |
1456 |
Mon, 11 August 2008 06:46 By: No real name |
Need hints for change editor font size By: Eclipse User on Sun, 10 August 2008 |
2 |
1720 |
Sun, 10 August 2008 10:09 By: Eclipse User |
Need hints for change editor font size |
0 |
2775 |
Sun, 10 August 2008 05:11 By: No real name |
problem with pde plugin 'export wizard' By: Eclipse User on Fri, 08 August 2008 |
2 |
1253 |
Fri, 08 August 2008 07:39 By: Eclipse User |
0 |
2881 |
Fri, 08 August 2008 06:25 By: Eclipse User |
config.ini and osgi.splashPath By: Eclipse User on Thu, 07 August 2008 |
2 |
1737 |
Thu, 07 August 2008 23:17 By: Eclipse User |
0 |
2721 |
Thu, 07 August 2008 22:56 By: Eclipse User |
My plugins test ok. Now what? By: Eclipse User on Thu, 07 August 2008 |
6 |
1976 |
Thu, 07 August 2008 22:52 By: Eclipse User |
0 |
2754 |
Thu, 07 August 2008 18:26 By: Eclipse User |
0 |
2705 |
Thu, 07 August 2008 14:17 By: No real name |
AbstractEditor and scrolling By: Eclipse User on Wed, 06 August 2008 |
0 |
2660 |
Wed, 06 August 2008 16:25 By: Eclipse User |
0 |
3361 |
Regarding Extending the Universal Intro |
0 |
2623 |
Tue, 05 August 2008 21:16 By: Mahim Lakhani |
0 |
2759 |
Mon, 04 August 2008 08:16 By: Eclipse User |
PDE doesn't recognize dropins folder in 3.4 target (p2) |
0 |
2785 |
Fri, 01 August 2008 19:25 By: Randy Hudson |
Need help using 'adapt' in core expression |
0 |
2582 |
Fri, 01 August 2008 03:41 By: Craig Foote |
0 |
3546 |
Class of a dependant plugin, "NoClassDefFoundError". By: Eclipse User on Wed, 30 July 2008 |
2 |
1279 |
Thu, 31 July 2008 22:59 By: Eclipse User |
0 |
2716 |
Wed, 30 July 2008 20:10 By: Eclipse User |
Launching PDE app does not include all plugins in target environment By: Eclipse User on Wed, 30 July 2008 |
4 |
1815 |
Wed, 30 July 2008 19:55 By: Eclipse User |
0 |
2551 |
Wed, 30 July 2008 18:25 By: Eclipse User |
JUnit plugin test fails trying to load part of HTTP Client within Eclipse plugin |
0 |
2575 |
Wed, 30 July 2008 15:21 By: Neale Upstone |
0 |
3553 |
Obtain Information from the JavaEditor By: Eclipse User on Tue, 29 July 2008 |
0 |
2781 |
Tue, 29 July 2008 17:26 By: Eclipse User |
0 |
3790 |
Referencing Java Projects By: Eclipse User on Sat, 26 July 2008 |
6 |
1785 |
Mon, 28 July 2008 11:26 By: Eclipse User |
Export Deployable plugins and fragments error: File specified more then once By: Eclipse User on Wed, 23 July 2008 |
4 |
2357 |
Sat, 26 July 2008 08:34 By: Eclipse User |
Referencing Java Projects By: Chris on Sat, 26 July 2008 |
0 |
2522 |
Sat, 26 July 2008 07:52 By: Chris |
accessing another plugins preferences |
0 |
2533 |
Fri, 25 July 2008 15:33 By: Andreas Pakulat |
0 |
3330 |
0 |
2719 |
Fri, 25 July 2008 12:30 By: Prasanna K |
Using PDE and Maven2 to create OSGi bundle |
0 |
2701 |
Fri, 25 July 2008 07:45 By: Martin Ahrer |
Bundled library jar, importing classes gives compiler errors |
2 |
1826 |
Thu, 24 July 2008 06:56 By: Manuel Steurer |
Building a plugin-producing plugin |
0 |
2910 |
Wed, 23 July 2008 20:57 By: Richard Hughes |
Building a plugin-producing plugin By: Eclipse User on Wed, 23 July 2008 |
0 |
3400 |
Wed, 23 July 2008 20:57 By: Eclipse User |
Problem with reloading target platform By: Eclipse User on Sat, 19 July 2008 |
14 |
3664 |
Wed, 23 July 2008 13:51 By: Eclipse User |
0 |
2954 |
Wed, 23 July 2008 13:12 By: Manuel Steurer |
0 |
3025 |
Wed, 23 July 2008 10:32 By: Eclipse User |
Problem with icon-states in debugger |
2 |
1308 |
Tue, 22 July 2008 21:53 By: Stefan Schulze |
Need help with new file wizard and selection |
0 |
2762 |
Tue, 22 July 2008 09:20 By: Jeroen Lankheet |
0 |
2592 |
Tue, 22 July 2008 06:35 By: Stefan Schulze |
CombinedWordRule and strange bugs in IPresentationReconciler By: Eclipse User on Tue, 15 July 2008 |
10 |
2432 |
Mon, 21 July 2008 21:19 By: Eclipse User |
Extension point schema for org.eclipse.ui.editors (and others) cannot be found By: Eclipse User on Thu, 17 July 2008 |
4 |
5174 |
Mon, 21 July 2008 12:42 By: Eclipse User |
Problem to create update site for Ganymed By: Eclipse User on Tue, 08 July 2008 |
2 |
1523 |
Sat, 19 July 2008 10:05 By: Eclipse User |
Problem with reloading target platform |
0 |
2748 |
Sat, 19 July 2008 08:45 By: Bruce Kelly |
uninstalling a plugin By: Eclipse User on Fri, 27 June 2008 |
6 |
2032 |
Thu, 17 July 2008 14:49 By: Eclipse User |
launching eclipse application By: Eclipse User on Thu, 17 July 2008 |
0 |
2531 |
Thu, 17 July 2008 14:28 By: Eclipse User |
0 |
3563 |
Extension point schema for org.eclipse.ui.editors (and others) cannot be found |
0 |
2886 |
Thu, 17 July 2008 13:28 By: Marcus Ilgner |
Ganymede Plug-In Exports don't work in Linux By: Eclipse User on Tue, 01 July 2008 |
14 |
2782 |
Thu, 17 July 2008 13:15 By: Eclipse User |
CombinedWordRule and strange bugs in IPresentationReconciler |
0 |
2691 |
Tue, 15 July 2008 21:18 By: Richard Hughes |
Does Equinox P2 support plain OSGI features and plugins? |
2 |
1161 |
Mon, 14 July 2008 14:49 By: Shaoying Yang |
getExtensionPoint By: Eclipse User on Thu, 10 July 2008 |
4 |
1411 |
Sat, 12 July 2008 02:11 By: Wayne Beaton |
getExtensionPoint By: Ben on Thu, 10 July 2008 |
0 |
2575 |
Thu, 10 July 2008 17:22 By: Ben |
cluttered directory structure view in new file creation wizard By: Eclipse User on Wed, 09 April 2008 |
6 |
3383 |
Thu, 10 July 2008 11:37 By: Eclipse User |
How to get full path of opened file in editor By: Eclipse User on Wed, 09 July 2008 |
2 |
1911 |
Wed, 09 July 2008 13:15 By: Eclipse User |
How to get full path of opened file in editor |
0 |
2716 |
Wed, 09 July 2008 12:47 By: Jeroen Lankheet |
How do I write to the console from a plug-in? By: Eclipse User on Tue, 01 July 2008 |
10 |
3655 |
Wed, 09 July 2008 06:38 By: Eclipse User |
Plugin fails to load, red mark on Plugin Registry |
34 |
6168 |
Tue, 08 July 2008 22:45 By: John J. Barton |
Problem to create update site for Ganymed |
0 |
2578 |
Tue, 08 July 2008 10:53 By: Markus Liebelt |
0 |
2554 |
Mon, 07 July 2008 18:42 By: John J. Barton |
Number attributes in Extension Points By: Eclipse User on Mon, 07 July 2008 |
2 |
1301 |
Mon, 07 July 2008 14:33 By: Jakub Jurkiewicz |
blocking error with 3.4 when having dashes (-) in bundle symbolic names |
0 |
2399 |
Mon, 07 July 2008 10:32 By: Wouter de Vaal |
0 |
3326 |
Number attributes in Extension Points |
0 |
2673 |
Mon, 07 July 2008 05:45 By: Ralf Zahn |
How do I package a file with a plug-in? By: Eclipse User on Thu, 03 July 2008 |
8 |
2004 |
Mon, 07 July 2008 03:10 By: Eclipse User |
uitestapplication in Eclipse 3.4 |
0 |
2452 |
Sat, 05 July 2008 05:17 By: Jason Hocker |
uitestapplication in Eclipse 3.4 By: Eclipse User on Sat, 05 July 2008 |
0 |
3731 |
Sat, 05 July 2008 05:17 By: Eclipse User |
Help with core expressions By: Eclipse User on Thu, 03 July 2008 |
2 |
1235 |
Thu, 03 July 2008 21:29 By: Eclipse User |
0 |
2475 |
Thu, 03 July 2008 20:20 By: Shaoying Yang |
How do I package a file with a plug-in? |
0 |
2598 |
Thu, 03 July 2008 18:55 By: Richard Hughes |
0 |
2574 |
Thu, 03 July 2008 09:24 By: Eclipse User |
Ganymede Plug-In Exports don't work in Linux |
0 |
2717 |
Tue, 01 July 2008 23:01 By: Richard Hughes |
third party jars for dependent plugins |
6 |
2498 |
Tue, 01 July 2008 21:25 By: Sandro Boehme |
Externalize strings - insertion position |
0 |
2673 |
Tue, 01 July 2008 21:00 By: Ben Vitale |
Externalize strings - insertion position By: Eclipse User on Tue, 01 July 2008 |
0 |
3385 |
Tue, 01 July 2008 21:00 By: Eclipse User |
How to properly build a re-branded Eclipse distribution |
0 |
2714 |
Tue, 01 July 2008 18:51 By: Jason Woods |
0 |
3721 |
How do I write to the console from a plug-in? |
0 |
2528 |
Tue, 01 July 2008 15:20 By: Piyush Agarwal |
LaunchingConfigurationTab doesn't show anything |
4 |
1641 |
Tue, 01 July 2008 01:20 By: Stefan Schulze |
0 |
2705 |
Sat, 28 June 2008 19:58 By: Sandro Boehme |
Textfield with auto-completion |
6 |
3242 |
Sat, 28 June 2008 07:19 By: Lars Schneider |
0 |
2618 |
Sat, 28 June 2008 04:28 By: Stefan Schulze |
0 |
2567 |
Fri, 27 June 2008 16:07 By: Eclipse User |
