Topic |
Replies |
Views |
Last message |
Search disabled The Search function of this forum has been disabled, as it is currently the target of abuse. We apologize for the inconvenience. |
Looking for guidelines in creating plug-in for unit tests |
0 |
4574 |
Thu, 12 November 2009 01:19 By: No real name |
Cleanest way to allow plugin version ranges |
1 |
1163 |
Wed, 11 November 2009 16:03 By: Andrew Niefer |
Eclipse stopped treating plug-in project as a plug-in project - again! |
20 |
6859 |
Tue, 10 November 2009 13:31 By: Dr. Christian Betz |
problem triggering checkstyle jar |
0 |
3559 |
Tue, 10 November 2009 13:07 By: silent_Thunder |
0 |
4918 |
Adding annotation model to default text editor |
0 |
3767 |
Tue, 10 November 2009 12:42 By: Mekk Elek |
Adding annotation model to default text editor Adding annotation model to default text editor |
0 |
5148 |
Plug-in Fragment cannot resolve classes from host By: Eclipse User on Tue, 29 September 2009 |
10 |
9628 |
Tue, 10 November 2009 09:10 By: Mickael Istria |
Does doc.zip no longer work in 3.5? |
4 |
2887 |
Mon, 09 November 2009 15:48 By: Kristina Taylor |
0 |
3609 |
Thu, 05 November 2009 20:47 By: Kristina Taylor |
Adding multiple dynamic menus |
2 |
2465 |
Thu, 05 November 2009 09:34 By: Michael Matzen |
Hiding commands' UI elements By: Joel on Tue, 13 October 2009 |
3 |
2418 |
Wed, 04 November 2009 20:21 By: Joel |
Some inter-plug-in dependencies have not been satisfied |
0 |
4180 |
Tue, 03 November 2009 07:34 By: Matthias Kohles |
0 |
8210 |
Imported JUnit package is not resolved |
0 |
3413 |
Tue, 03 November 2009 03:47 By: Setya Nugdjaja |
0 |
4945 |
How to export source in headless build? |
3 |
1457 |
Mon, 02 November 2009 16:02 By: Matthias Kohles |
3 |
2696 |
Getting position (Point) of text cursor in editor By: Andrey on Mon, 26 October 2009 |
1 |
1347 |
Mon, 02 November 2009 14:15 By: Matthias Kohles |
Building org.eclipse.epp.package.java |
8 |
3970 |
Mon, 02 November 2009 13:45 By: Dimitrios Kolovos |
How do i lock a toolbar in an extension point? |
1 |
1139 |
Fri, 30 October 2009 17:47 By: Artur Kronenberg |
1 |
2143 |
0 |
3542 |
Fri, 30 October 2009 13:06 By: Dimitrios Kolovos |
Project Explorer vs. Navigator problems |
3 |
1666 |
Thu, 29 October 2009 20:10 By: Robert Lewis |
5 |
4263 |
Headless build contribute root files twice when p2.gathering=true |
4 |
5501 |
Thu, 29 October 2009 15:25 By: Andrew Niefer |
Use eclipsec.exe when building headless RCP |
4 |
6032 |
Thu, 29 October 2009 10:11 By: Matthias Erche |
Use of eclipse.buildScript, need help!! |
4 |
2916 |
Wed, 28 October 2009 16:32 By: valerossi46 |
p2.gathering causing target does not exist error |
6 |
7584 |
Wed, 28 October 2009 15:06 By: Andrew Niefer |
0 |
3485 |
Wed, 28 October 2009 14:00 By: valerossi46 |
Need help in creating a P2 provisioned and custom branded Eclipse build By: Eclipse User on Wed, 28 October 2009 |
0 |
3431 |
Wed, 28 October 2009 12:26 By: Eclipse User |
Extensions Details not visible |
0 |
3596 |
Wed, 28 October 2009 09:55 By: Christian Eugster |
Extensions Details not visible plugin.xml Extension Page Contextmenuitems and Extensiondetailentries missing |
0 |
4892 |
Re: Generate "Ant build file" outside Eclipse |
1 |
1324 |
Wed, 28 October 2009 09:13 By: valerossi46 |
0 |
3463 |
Wed, 28 October 2009 08:24 By: valerossi46 |
Extending PDE? |
0 |
3424 |
Tue, 27 October 2009 21:49 By: No real name |
Extending PDE? |
0 |
4877 |
0 |
3465 |
Tue, 27 October 2009 15:31 By: Franck Mising name |
Question about buildDirectory and pluginPath |
1 |
1133 |
Tue, 27 October 2009 14:24 By: Andrew Niefer |
Override Variables Views on Debug Perspective |
0 |
3322 |
Mon, 26 October 2009 19:06 By: Cleber Souza |
0 |
4998 |
0 |
3957 |
Mon, 26 October 2009 14:38 By: Matthias Erche |
Get a file from the workspace? By: Erwan on Tue, 20 October 2009 |
3 |
1716 |
Mon, 26 October 2009 09:30 By: Erwan |
7 |
4564 |
Programmatically adding a plug-in dependency By: Matt R on Mon, 26 October 2009 |
0 |
3719 |
Mon, 26 October 2009 09:20 By: Matt R |
0 |
5177 |
Is it possible to set plugin and feature versions from ant build? |
6 |
2439 |
Mon, 26 October 2009 08:26 By: Mickael Istria |
Feature build.xml not generated in headless build |
1 |
1893 |
Sun, 25 October 2009 10:31 By: Franck Mising name |
1 |
2465 |
Build plugin to a folder instead to jar it Build plugin to a folder instead to jar it By: Alain on Fri, 23 October 2009 |
3 |
2445 |
Sat, 24 October 2009 19:28 By: Alain |
1 |
1485 |
Fri, 23 October 2009 17:28 By: Chris Aniszczyk |
Modifying other Plugins |
0 |
3324 |
Fri, 23 October 2009 16:07 By: No real name |
0 |
4849 |
Undefined context exception when activating a plug-in |
0 |
3479 |
Fri, 23 October 2009 16:04 By: Michael Matzen |
0 |
6429 |
One editor for many files |
3 |
1652 |
Fri, 23 October 2009 15:47 By: Brian de Alwis |
One editor for many files How do not to open editor twice? |
5 |
2842 |
Hiding incompatible features in update site? |
0 |
3344 |
Fri, 23 October 2009 15:46 By: Richard Bone |
Hiding incompatible features in update site? Is there a way to hide features with unsatisfied dependencies? |
0 |
5054 |
Plugin classpath problems |
1 |
1170 |
Fri, 23 October 2009 15:38 By: Brian de Alwis |
1 |
1774 |
Changing eclipse icon |
2 |
2129 |
Fri, 23 October 2009 03:06 By: Anthony Do |
Cannot export RCP app |
2 |
2100 |
Thu, 22 October 2009 19:53 By: Michael Y |
0 |
3327 |
Thu, 22 October 2009 18:04 By: Michael Y |
Modify the environment option |
0 |
3305 |
Thu, 22 October 2009 10:10 By: No real name |
0 |
4874 |
Eclipse WorkbenchStatusDialogManager |
0 |
3325 |
Wed, 21 October 2009 23:36 By: dwain Missing name |
Eclipse WorkbenchStatusDialogManager How and where do you access this |
0 |
4974 |
How to add a bundle in the Run configurations Add a bundle that is not a project in the "Run Configurations..." |
5 |
2316 |
Wed, 21 October 2009 17:13 By: Chris Aniszczyk |
trouble disabling the 'Search' button on the eclipse SearchDialog |
0 |
4001 |
Wed, 21 October 2009 16:55 By: Josh O'Dowd |
trouble disabling the 'Search' button on the eclipse SearchDialog By: Eclipse User on Wed, 21 October 2009 |
0 |
4864 |
Wed, 21 October 2009 16:55 By: Eclipse User |
How to add a bundle in the Run configurations |
1 |
1378 |
Wed, 21 October 2009 15:31 By: Chris Aniszczyk |
0 |
3482 |
Wed, 21 October 2009 14:03 By: Andreas Gellendin |
Eclipse Process running in background has SVN import completed |
3 |
3147 |
Wed, 21 October 2009 10:21 By: Rahul Yadav |
databinding.observable and databinding.property missing after headless build |
0 |
3481 |
Wed, 21 October 2009 10:00 By: Alessandro Caproni |
PDE Build and P2 publisher |
2 |
1398 |
Wed, 21 October 2009 08:50 By: Franck Mising name |
2 |
1333 |
Eclipse.buildscript is ignoring Plugins in feature.xml |
2 |
1514 |
Wed, 21 October 2009 07:07 By: Matthias Kohles |
2 |
2104 |
Is there any views about Feature at PDE? |
3 |
1836 |
Wed, 21 October 2009 00:33 By: Hiroki Kondo |
1 |
1099 |
Tue, 20 October 2009 16:45 By: Prakash G.R. |
Inserting very slow when in Block Selection mode |
1 |
1243 |
Tue, 20 October 2009 09:35 By: Stefan Thurnherr |
using org.eclipse.search.ui extensions By: Eclipse User on Mon, 19 October 2009 |
4 |
2378 |
Mon, 19 October 2009 19:11 By: Prakash G.R. |
using org.eclipse.search.ui extensions |
0 |
3265 |
Mon, 19 October 2009 17:58 By: Josh O'Dowd |
Accessing UI Thread |
1 |
1060 |
Mon, 19 October 2009 13:21 By: No real name |
Accessing UI Thread Accessing UI Thread |
1 |
1847 |
How to configure headless PDEbuild to build not in the source folder |
2 |
1681 |
Fri, 16 October 2009 21:55 By: Andrew Niefer |
Headless build fails when unpack="true" |
4 |
1740 |
Fri, 16 October 2009 21:40 By: Andrew Niefer |
5 |
4266 |
Listening for a view being opened/closed By: Joel on Wed, 14 October 2009 |
2 |
1303 |
Fri, 16 October 2009 14:46 By: Joel |
4 |
2167 |
Property page not visible on IProject level |
0 |
3412 |
Fri, 16 October 2009 12:03 By: No real name |
Property page not visible on IProject level Property page is visible on IFile resources, but not on IProject/IFolder resources |
0 |
5410 |
Access UI properties from extension By: Pablo on Fri, 16 October 2009 |
0 |
3314 |
Fri, 16 October 2009 11:33 By: Pablo |
0 |
4517 |
Can one trigger a refresh via/after ant-script? |
6 |
4967 |
Fri, 16 October 2009 10:17 By: Steffen Zschaler |
Galileo: Cannot complete the install because one or more required items could not be found. By: Eclipse User on Thu, 08 October 2009 |
2 |
14093 |
Thu, 15 October 2009 14:06 By: Eclipse User |
Update fails - headless pde with root.folder.jre |
2 |
1579 |
Thu, 15 October 2009 13:56 By: Matthew Trees |
Update fails - headless pde with root.folder.jre On update of my p2'ized RCP application IOException from p2.engine |
2 |
2450 |
Create new dynamic help for existing Text Editor |
0 |
3184 |
Thu, 15 October 2009 12:35 By: No real name |
0 |
4767 |
OS-specific Eclipse features in update site project |
0 |
3254 |
Thu, 15 October 2009 09:24 By: Peter Saunders |
0 |
4593 |
0 |
3308 |
Thu, 15 October 2009 09:09 By: Michael Matzen |
0 |
3321 |
Wed, 14 October 2009 15:11 By: Vitaliy Volevach |
Listener for Popupmenu command |
0 |
3443 |
Wed, 14 October 2009 10:51 By: lancel lau |
0 |
4644 |
Product build generates folder artifacts |
4 |
4079 |
Wed, 14 October 2009 09:11 By: Peter Kullmann |
1 |
1190 |
Tue, 13 October 2009 18:54 By: Lars Vogel |
0 |
3358 |
Tue, 13 October 2009 16:03 By: Peter Kullmann |
Search Page open Tab on default |
4 |
1365 |
Tue, 13 October 2009 14:07 By: Artur Kronenberg |
4 |
2453 |
PDE-SVN Build |
0 |
3103 |
Tue, 13 October 2009 13:19 By: Michael Heiss |
PDE-SVN Build |
0 |
4802 |
0 |
3558 |
Tue, 13 October 2009 11:46 By: Michael Moser |
hiding tab |
5 |
2007 |
Tue, 13 October 2009 08:18 By: Ido Mising name |
hiding tab |
1 |
982 |
Tue, 13 October 2009 07:22 By: Aurélien Pupier |
Creating a button like "Search"? By: Eclipse User on Fri, 09 October 2009 |
2 |
1878 |
Mon, 12 October 2009 14:45 By: Artur Kronenberg |
Eclipse Process running in background |
1 |
2195 |
Sat, 10 October 2009 17:15 By: Steffen Zschaler |
PDE build that uses pre-compiled artifacts |
0 |
3276 |
Sat, 10 October 2009 10:24 By: Peter Kullmann |
0 |
4427 |
0 |
3160 |
Fri, 09 October 2009 09:58 By: Andreas Gellendin |
0 |
3227 |
Fri, 09 October 2009 08:14 By: Eclipse User |
problems with root.permissions By: Ren on Thu, 08 October 2009 |
0 |
3056 |
Thu, 08 October 2009 17:40 By: Ren |
problems with root.permissions root.permissions does not work By: Ren on Thu, 08 October 2009 |
0 |
4674 |
PDE Build: Fail to generate p2 metadata properly |
0 |
3032 |
Thu, 08 October 2009 15:25 By: Frank Du |
0 |
4619 |
0 |
3226 |
Thu, 08 October 2009 12:17 By: Eclipse User |
adding action to toolbar in formpage |
0 |
3194 |
Thu, 08 October 2009 11:05 By: Ido Mising name |
how to run junit plug-in tests with ant By: goerkem on Thu, 08 October 2009 |
0 |
3282 |
Thu, 08 October 2009 07:49 By: goerkem |
0 |
4198 |
Availabity PDE JavaDoc |
1 |
1032 |
Wed, 07 October 2009 16:21 By: Curtis Windatt |
Availabity PDE JavaDoc You really need to start from a PDE distribution? |
1 |
1963 |
Re: Where did the Export Deployable Plugins and Features wizard go? |
0 |
3224 |
Wed, 07 October 2009 16:20 By: Mark Melvin |
2 |
2179 |
1 |
1085 |
Wed, 07 October 2009 16:14 By: Curtis Windatt |
Plugin to add files to Package Explorer By: Cosmin on Tue, 06 October 2009 |
1 |
971 |
Wed, 07 October 2009 16:11 By: Curtis Windatt |
1 |
2046 |
Execute console commands, show output in console view |
0 |
4851 |
Wed, 07 October 2009 09:46 By: Vitaliy Volevach |
Startup Plugin Startup Plugin By: Cosmin on Mon, 05 October 2009 |
3 |
2276 |
Tue, 06 October 2009 13:10 By: Cosmin |
Creating an editor for certain types of xml files |
2 |
1283 |
Tue, 06 October 2009 05:22 By: Saminda Wijeratne |
Creating an editor for certain types of xml files Need to know how to open specific kinds of xml from our own editor as a default behavior |
2 |
1934 |
1 |
1180 |
Mon, 05 October 2009 22:38 By: Steffen Zschaler |
Processing C-code using a Makefile and a custom builder |
0 |
4409 |
Mon, 05 October 2009 15:20 By: Vitaliy Volevach |
Export target platform |
0 |
3208 |
Sat, 03 October 2009 19:43 By: Lukasz Sierant |
Export target platform How to export plugins from target definition file to specified location |
0 |
4853 |
404 on accessong 3.5 byuild update site |
2 |
2235 |
Fri, 02 October 2009 14:24 By: Ben Vitale |
pde.test.utils and PDETestListener |
2 |
2728 |
Fri, 02 October 2009 08:48 By: Jesper Eskilson |
0 |
3288 |
Fri, 02 October 2009 07:03 By: Jesper Eskilson |
Using one key binding for multiple actions |
0 |
3370 |
Fri, 02 October 2009 00:04 By: Aaron Getz |
Using one key binding for multiple actions Binding one key to different actions in different plugins |
0 |
4645 |
Interpolating properties into .product file |
0 |
3120 |
Thu, 01 October 2009 22:44 By: Eric Jain |
0 |
4845 |
PDE Product build fails when p2.category.definition set |
2 |
3987 |
Thu, 01 October 2009 14:18 By: James Peltzer |
Trouble deploying a searchPages extention Whatever does 'testing warnings generated during RSE initialization' mean? |
2 |
2143 |
Thu, 01 October 2009 14:16 By: Stephan Herrmann |
Trouble deploying a searchPages extention |
0 |
3497 |
Thu, 01 October 2009 13:50 By: Martin Cowie |
hook global actions in editors using extensions |
0 |
3253 |
Thu, 01 October 2009 11:03 By: No real name |
0 |
4308 |
0 |
3425 |
Thu, 01 October 2009 08:22 By: Roland Tepp |
0 |
3232 |
Wed, 30 September 2009 20:28 By: James Peltzer |
Intention behind @noreference tag in API tools |
0 |
3567 |
Wed, 30 September 2009 11:58 By: Stephan Herrmann |
0 |
5001 |
Headless build: The type X is already defined |
4 |
11889 |
Wed, 30 September 2009 06:56 By: Christophe Fondacci |
Plug-in Fragment cannot resolve classes from host |
0 |
3602 |
Tue, 29 September 2009 15:48 By: Alex Shterev |
How to create an Eclipse product programatically?? |
0 |
3245 |
Tue, 29 September 2009 13:31 By: Mario Cervera |
0 |
4567 |
PDE API to manipulate Extension Point in Workspace |
0 |
3280 |
Tue, 29 September 2009 12:20 By: No real name |
0 |
4706 |
ClassNotFoundException for Application.class when launching product |
4 |
2395 |
Tue, 29 September 2009 10:59 By: Rhodan76 Mising name |
opening and closing perspective programmatically By: ankita on Tue, 29 September 2009 |
1 |
1072 |
Tue, 29 September 2009 10:47 By: Imran |
1 |
1767 |
automatically adding depended features By: Imran on Tue, 29 September 2009 |
0 |
3213 |
Tue, 29 September 2009 10:36 By: Imran |
automatically adding depended features automatically adding depended features By: Imran on Tue, 29 September 2009 |
0 |
4873 |
0 |
3313 |
Tue, 29 September 2009 10:33 By: Rhodan76 Mising name |
Where to get menubar paths? By: Lenik on Sat, 10 January 2009 |
2 |
1914 |
Tue, 29 September 2009 04:55 By: Lenik |
BundleClasspath not available in nested Eclipse instance |
16 |
4224 |
Mon, 28 September 2009 15:24 By: Sandro Boehme |
Resolution of binary plugins in a PDE Headless build By: Kevin on Wed, 23 September 2009 |
4 |
1375 |
Sat, 26 September 2009 11:25 By: Kevin |
Resolution of binary plugins in a PDE Headless build Unexpected versions of plugins being selected by PDE headless product build By: Kevin on Wed, 23 September 2009 |
4 |
2293 |
PDE Build and cross-compilation |
1 |
1153 |
Sat, 26 September 2009 03:50 By: Mark Melvin |
PDE Build and cross-compilation SWT errors when building a UI plugin on Linux build server |
1 |
2126 |
0 |
3474 |
Fri, 25 September 2009 08:16 By: Christophe Fondacci |
hyperlink listener to open a wizard |
0 |
3353 |
Fri, 25 September 2009 04:40 By: John J. Franey |
0 |
4806 |
pde build director call By: Eclipse User on Mon, 24 August 2009 |
2 |
2152 |
Wed, 23 September 2009 17:21 By: Andrew Niefer |
JUnit Plug-in Test cannot load Testclass from Fragment |
4 |
4078 |
Wed, 23 September 2009 16:52 By: Marc Schlegel |
Why is the generated p2 metadata wrong in the content.xml? By: Eclipse User on Tue, 18 August 2009 |
4 |
3837 |
Wed, 23 September 2009 16:16 By: Andrew Niefer |
Troubling messages during 'p2.gathering' build |
2 |
6978 |
Wed, 23 September 2009 15:28 By: Andrew Niefer |
Create new natures |
3 |
3696 |
Wed, 23 September 2009 15:18 By: El_justiciero |
PDE build with annotation processing |
2 |
2794 |
Wed, 23 September 2009 15:10 By: Andrew Niefer |
Preserving file permissions in exported features |
1 |
1372 |
Wed, 23 September 2009 14:57 By: Chris Aniszczyk |
1 |
1278 |
Wed, 23 September 2009 13:52 By: Steffen Zschaler |
Build multiple versions of same bundle using headless PDE build |
0 |
3369 |
Tue, 22 September 2009 22:25 By: Andrew Eisenberg |
0 |
5018 |
'PDE Tools'->'Create Ant Build File' results in NPE |
2 |
1593 |
Tue, 22 September 2009 19:51 By: Chris Aniszczyk |
0 |
3484 |
Tue, 22 September 2009 18:22 By: RefuX Zanzeebarr |
Searching Help By: breako on Tue, 22 September 2009 |
0 |
3440 |
Tue, 22 September 2009 16:33 By: breako |
Searching Help Searching Help By: breako on Tue, 22 September 2009 |
0 |
4732 |
When exactly is a plugin updated? By: breako on Tue, 22 September 2009 |
3 |
2065 |
Tue, 22 September 2009 16:30 By: breako |
1 |
976 |
Tue, 22 September 2009 15:27 By: Eric Rizzo |
Do I always need a feature and site project? By: breako on Tue, 22 September 2009 |
2 |
1835 |
Tue, 22 September 2009 15:23 By: Eric Rizzo |
