    Replies Views Last message
  How to verify that result set is cached
By: Radek Mensik on Wed, 26 November 2014
0 8977 Wed, 26 November 2014 14:14
By: Radek Mensik
  Caching queries created by Criteria API
Cache is not used on queries created by Criteria query API
By: Radek Mensik on Mon, 24 November 2014
1 3000 Mon, 24 November 2014 15:12
By: Eric Rizzo
  EL cache invalidation capabilities does not work
By: Taurine T on Mon, 24 November 2014
0 9224 Mon, 24 November 2014 14:58
By: Taurine T
  Why do subqueries with nested properties in EclipseLink always produce unnecessary/redundant joins?
By: Tiny 2000 on Sun, 20 July 2014
3 11758 Sun, 23 November 2014 05:00
By: Tiny 2000
  EclipseLink with Ucanaccess driver
EclipseLink table creation fail with ucanaccess driver
By: Vilson Balestero on Fri, 21 November 2014
0 10422 Fri, 21 November 2014 11:32
  Lazy OneToOne Relationship traversed on Insert
By: Jason Spies on Wed, 19 November 2014
0 7221 Wed, 19 November 2014 02:31
By: Jason Spies
  Generated metamodel doesn't extend base metamodel from another jar
By: Sergey Ka on Mon, 17 November 2014
0 7978 Mon, 17 November 2014 07:13
By: Sergey Ka
  @PreUpdate on One of OneToMany?
By: Mike Summers on Fri, 14 November 2014
0 3580 Fri, 14 November 2014 16:29
By: Mike Summers
  x
By: Eclipse User on Thu, 13 November 2014
4 5124 Fri, 14 November 2014 14:33
By: Chris Delahunt
  EclipseLink and WebSphere 8
Is EclipseLink compatible with WebSphere 8?
By: João Pereira on Wed, 12 November 2014
2 1731 Thu, 13 November 2014 09:20
By: João Pereira
0 2850 Wed, 12 November 2014 18:43
By: João Pereira
  convert mapping source to mapping XML
By: raj s on Sun, 09 November 2014
1 3360 Wed, 12 November 2014 02:07
By: Chris Delahunt
  Eclipselink merge does not insert a new row in many-to-many relationship
eclipselink merge, many-to-many
By: Sina Alizadeh on Fri, 07 November 2014
1 3343 Wed, 12 November 2014 01:49
By: Chris Delahunt
icon9.gif EclipseLink ddlgen doesn't work in eclipse
By: Stephen Buergler on Sat, 08 November 2014
0 8423 Sat, 08 November 2014 20:31
  wrong id returned when inserting
By: Robert Sutton on Wed, 05 November 2014
0 2698 Wed, 05 November 2014 20:27
By: Robert Sutton
  Orderby NULL FIRST / LAST using Criteria API
How to use the criteria api in order to use nullsFirst / last
By: Juan Flores on Wed, 05 November 2014
0 3346 Wed, 05 November 2014 08:52
By: Juan Flores
  AuditingEntityListener - updating on child add
By: adam green on Tue, 04 November 2014
0 3347 Tue, 04 November 2014 19:21
By: adam green
  Possible bug retrieving single Boolean column
By: Brendan Healey on Mon, 25 October 2010
3 4397 Tue, 04 November 2014 07:21
By: manuel jaehnig
  Can't find orm.xml in <jar-file>
By: Paul Benedict on Fri, 31 October 2014
1 2645 Mon, 03 November 2014 16:58
By: Rick Curtis
  POJO persistance and discrepancy tolerance
By: ModelGeek Mising name on Mon, 03 November 2014
0 3249 Mon, 03 November 2014 16:25
  Eclipselink jpa should provide a PersistenceProvider service
By: Christian Schneider on Mon, 03 November 2014
0 3565 Mon, 03 November 2014 16:04
  OneToOneMapping error on insertableField
By: dirvan vargas on Tue, 28 October 2014
2 1991 Mon, 03 November 2014 10:21
By: dirvan vargas
  Named Query of SQL type with EclipseLink2.4.2 throws IndexOutOfBoundsException on execute.
Named query and parameters
By: ELUser Mising name on Wed, 15 October 2014
1 5103 Fri, 31 October 2014 20:16
  Many to many with extra data in join table
Dev
By: Toni T on Fri, 31 October 2014
0 3457 Fri, 31 October 2014 11:35
By: Toni T
Dev
0 3034 Fri, 31 October 2014 11:34
By: Toni T
  No [ManagedType] was found for the key class.. JPA, H2, EclipseLink, Java Config (no xml)
I am getting an error that suggests I add something to persistence.xml, but I am using a no-XML configuration.
By: Robert Mark Bram on Mon, 27 October 2014
1 5692 Tue, 28 October 2014 08:10
  Problem with ReadAllQuery and hierarchical data
Exception if executing a query
By: Ralf Heydenreich on Thu, 23 October 2014
2 3280 Mon, 27 October 2014 18:42
  Schema per Tenant issues
By: Thomas Kratz on Fri, 07 June 2013
11 32763 Mon, 27 October 2014 18:34
By: dirvan vargas
  Database Persistence both via JPA and Stored Procedure Calls
By: Thorsten Siebel on Wed, 10 September 2014
1 6007 Sun, 26 October 2014 14:19
By: Srikanth Goteti
  How can I exclude the type element from marshalled generic type in Moxy?
Excluding type element from marshalled generic type in Moxy
By: John Douglass on Fri, 24 October 2014
0 4738 Fri, 24 October 2014 19:27
By: John Douglass
  @CacheIndex with Extended Class
Newbie problems saving an extended class whose parent uses a @CacheIndex
By: Richard Harrison on Tue, 21 October 2014
1 1609 Wed, 22 October 2014 12:47
By: Chris Delahunt
icon4.gif Batch insert extremely slow
By: John Lewis on Fri, 17 October 2014
2 17085 Tue, 21 October 2014 00:00
By: John Lewis
  How can I generate ddl scripts without using Dali?
By: Jhonny Lora on Sat, 18 October 2014
1 1195 Mon, 20 October 2014 13:40
By: Rick Curtis
  @Inheritante with @OneToOne And @ID - Internal error
By: Eduardo Frazão on Wed, 23 January 2013
15 12034 Thu, 16 October 2014 23:41
By: Chris Delahunt
  Option to do "explicit updates"? (modify flush list ...)
By: Christoph Weiss on Tue, 14 October 2014
1 1482 Tue, 14 October 2014 18:15
By: Rick Curtis
  EclipseLink javadocs
By: John Cecere on Fri, 10 October 2014
2 1490 Fri, 10 October 2014 16:10
By: Eric Rizzo
  I'm getting a Eclipselink-93 while trying to use a relationship in an embeddable.
By: ritesh Mising name on Fri, 10 October 2014
0 3272 Fri, 10 October 2014 04:30
  DB Access problem
Intermittent failure to read DB
By: Neil Cohen on Mon, 06 October 2014
8 12831 Thu, 09 October 2014 19:11
By: Neil Cohen
  Exception Description: Missing descriptor for [class strategysvcs.entity.StrategyProfileDetails
By: Pradeep Gondhichatnahalli on Wed, 08 October 2014
1 14809 Thu, 09 October 2014 16:12
By: Chris Delahunt
  Generate index for foreign keys in oracle
How to enable automatic generation of indices for foreign key fields using Oracle database
By: Ga'bor Pe'ntek on Wed, 14 March 2012
5 11181 Wed, 08 October 2014 06:54
By: Luca Morettoni
  EclipseLink with dynamically defined object model?
By: Rafael Chaves on Fri, 26 September 2014
1 4433 Wed, 08 October 2014 03:09
By: jason zhang
  Using DTOs as Entities
By: Dan Hargreaves on Tue, 07 October 2014
0 4670 Tue, 07 October 2014 09:05
By: Dan Hargreaves
  Problem when joining padded CHAR fields of different lengths
By: Max Brante on Mon, 06 October 2014
1 1984 Tue, 07 October 2014 01:20
By: Rick Curtis
  problem with embedded object
By: Rainer H. on Fri, 03 October 2014
3 7098 Mon, 06 October 2014 18:35
By: Rainer H.
icon4.gif Jpa prepersist callback not called on parent
By: kraken kraken on Sun, 28 September 2014
4 7381 Sat, 04 October 2014 08:41
By: Michele Mariotti
  Eclipselink 2.5.2 giving exception on executing jpql having CASE expression
By: Abhijeet Bongarde on Tue, 30 September 2014
2 3637 Wed, 01 October 2014 07:58
  EclipseLink 2.5.2 multi root JPQL/Criteria issue
org.eclipse.persistence.exceptions.QueryException: Invalid query key [deliverableList] in expression.
By: Michele Mariotti on Wed, 01 October 2014
0 5947 Wed, 01 October 2014 07:14
  Randomly occurring missing parameter while using @Multitenant and @AdditionalCriteria
Mixing @Multitenant and @AdditionalCriteria in the same system creates randomly occurring bug
By: Aki-Petteri Leinonen on Mon, 29 September 2014
0 6150 Mon, 29 September 2014 11:51
  tenant_id column set blank after persist
when I persist a multitenant object the column that refer the tenant go in blank
By: Mário Santos Sousa on Sat, 27 September 2014
0 4732 Sat, 27 September 2014 02:21
  Listening for cache coordination
cache coordination listener
By: Ross Goldberg on Thu, 18 September 2014
3 2267 Fri, 26 September 2014 15:50
By: Chris Delahunt
  Managing Multiple Database Connections
By: Leonardo Jines on Fri, 19 September 2014
1 3040 Thu, 25 September 2014 14:10
By: Rick Curtis
  Query by example in eclipselink
By: Nicolas Steinhilber on Tue, 16 September 2014
3 5308 Tue, 23 September 2014 10:30
  Multiple JTA data sources for single PU
By: Ramu M on Thu, 18 September 2014
1 3996 Fri, 19 September 2014 15:44
By: Chris Delahunt
  eclipselink: generate entities without joins
By: G M on Thu, 11 September 2014
1 4253 Wed, 17 September 2014 16:32
By: Chris Delahunt
  EclipeLink with Maven
optimize the pom file
By: reda Mohamed on Wed, 17 September 2014
0 4257 Wed, 17 September 2014 10:53
By: reda Mohamed
  A web application to define/view/edit Dynamic Entity
introduce a web application related to dynamic entity
By: jason zhang on Mon, 15 September 2014
0 5842 Mon, 15 September 2014 18:03
By: jason zhang
  JPA stuck thread with releaseDeferredLock
By: subhasis swain on Mon, 01 September 2014
1 5655 Fri, 12 September 2014 14:03
By: John Bedell
  Dynamic Entity with OneToOne relationship
By: Matt Dehring on Tue, 02 September 2014
1 2356 Tue, 09 September 2014 07:20
By: jason zhang
  Mongo DB online training in USA, UK, Japan
By: abhilash falls on Fri, 05 September 2014
0 3965 Fri, 05 September 2014 10:55
By: abhilash falls
  IBM MQ and EclipseLink CacheCoordination
By: Sascha Smoo on Thu, 04 September 2014
2 4029 Fri, 05 September 2014 09:46
By: Sascha Smoo
  Using Minus in JPQL
Minus in allowed in EclipseLink
By: Gowthami Shanmugam on Fri, 29 August 2014
0 5198 Fri, 29 August 2014 16:58
  Left join with where condition
By: Gowthami Shanmugam on Wed, 27 August 2014
2 4159 Fri, 29 August 2014 16:52
  Migration Glassfish 3.1.2 to Wildfly: Challenge trying to get EclipseLink to Work
By: daslan govender on Thu, 28 August 2014
0 4646 Thu, 28 August 2014 11:11
By: daslan govender
  Right outer join
I want to confirm that eclipse link 2.4 implementation of JPA will not right outer join
0 3471 Wed, 27 August 2014 18:27
  ElipseLink configuration problem in E4 RCP app
EclipseLink works fine in a test but not within e4 RCP
By: Don Smyth on Tue, 26 August 2014
1 5482 Wed, 27 August 2014 07:26
By: Don Smyth
  Generating Metadata using M2E
By: Ralf Heydenreich on Tue, 26 August 2014
0 3881 Tue, 26 August 2014 20:42
icon4.gif ManyToMany Virtual Map in Moxy for inheritance
Virtual Relation with inheritance in Moxy seems not working correctly.
By: jason zhang on Fri, 22 August 2014
1 2832 Mon, 25 August 2014 17:06
By: jason zhang
  EclipseLink 2.5.2 is returning empty vector with size 1 with getResultList
EclipseLink 2.5.2 is returning empty vector with size 1 with getResultList when using relationship in select in jpql
By: Santhosh Thatipally on Mon, 25 August 2014
0 4190 Mon, 25 August 2014 04:38
  DescriptorEventAdapter and Invoice Header/Line
By: Omar Carvajal on Thu, 21 August 2014
1 2095 Thu, 21 August 2014 22:35
By: Omar Carvajal
  Error binding to externally managed transaction
By: Shelli Orton on Thu, 21 August 2014
0 11525 Thu, 21 August 2014 20:40
By: Shelli Orton
  Entity Maintenance
Best method to maintain entity java classes
By: Travis Seiler on Tue, 19 August 2014
0 3561 Tue, 19 August 2014 21:06
By: Travis Seiler
  Eclipselink OptimisticLock causing deadlocks
Eclipselink deadlocks
By: maverickml ml on Sun, 17 August 2014
0 5493 Sun, 17 August 2014 19:42
By: maverickml ml
  orm.xml equivalent for @JoinColumns
By: ritesh Mising name on Sat, 16 August 2014
0 4701 Sat, 16 August 2014 04:16
  Two way ( mutual )SSL with EclipseLink, JPA, and MongoDB
How to configure eclipselink and mongo driver to use SSL
By: smart water on Thu, 14 August 2014
0 4935 Thu, 14 August 2014 17:52
By: smart water
  _persistence_checkFetched
By: Tom Eugelink on Tue, 12 August 2014
0 5358 Tue, 12 August 2014 08:23
By: Tom Eugelink
  Transaction Support EclipseLink + JPA + MongoDB
By: Manoj Hoskeri on Sat, 09 August 2014
0 5218 Sat, 09 August 2014 07:06
By: Manoj Hoskeri
  @ReadOnly & @Cacheable
@ReadOnly @Cacheable
By: Ross Goldberg on Thu, 07 August 2014
0 3775 Thu, 07 August 2014 05:43
By: Ross Goldberg
  deadlock issues in eclipselink version 2.4.2
Are there any known deadlock issues in eclipselink v2.4.2
By: Prakash Guggilam on Mon, 04 August 2014
1 2903 Wed, 06 August 2014 14:19
By: Chris Delahunt
  transient attributes at commit
By: Clementi Ursula on Fri, 01 August 2014
0 3646 Fri, 01 August 2014 06:44
By: Clementi Ursula
  Shared/Global Persistence Unit?
By: Scott Dudley on Thu, 31 July 2014
0 2854 Thu, 31 July 2014 23:24
By: Scott Dudley
  JPA Generate Entities from Tables fails
JPA Generate Entities from Tables fails on Foreign Keys
By: Brad OHearne on Wed, 30 July 2014
0 3059 Wed, 30 July 2014 05:29
By: Brad OHearne
  JAXB : EclipseLink-3002 while unmarshalling xml even JAXB RI works
By: Arnaud MERGEY on Thu, 22 August 2013
4 9751 Sun, 27 July 2014 00:23
By: chandra kotha
  Running JPA entity with native queries from TestNG
By: supraja jayakumar on Fri, 25 July 2014
0 2650 Fri, 25 July 2014 23:09
  Cache coordination with tomcat 6
By: Sascha Smoo on Wed, 23 July 2014
2 4553 Thu, 24 July 2014 09:21
By: Sascha Smoo
  Same code not working same way in JSE as in JEE
By: Simon Joseph Aquilina on Fri, 18 July 2014
2 2330 Sat, 19 July 2014 09:29
icon7.gif JPA: Join two tables
By: hun k on Fri, 23 May 2014
2 16775 Wed, 16 July 2014 05:26
By: hun k
  running dbws from eclipse and deploying on tomcat/geronimo
By: Jeroen van Veldhuizen on Tue, 15 July 2014
0 3277 Tue, 15 July 2014 13:51
  JPA EclipseLink copy restriction error
By: Dave Tiger on Tue, 15 July 2014
1 2382 Tue, 15 July 2014 13:11
By: Dave Tiger
  get varchar data as bytes
By: harry rajan on Tue, 15 July 2014
0 3664 Tue, 15 July 2014 08:32
By: harry rajan
  read blob as byte array issue
By: andiqo on Mon, 06 April 2009
6 13373 Tue, 15 July 2014 08:30
By: harry rajan
  GROUP BY on a datetime field without time part
By: Clementi Ursula on Thu, 10 July 2014
2 2741 Mon, 14 July 2014 14:46
By: Clementi Ursula
  how to implement join for Same table
By: hun k on Mon, 14 July 2014
0 2864 Mon, 14 July 2014 08:37
By: hun k
  MSSQL encoding issue
By: harry rajan on Thu, 10 July 2014
0 2907 Thu, 10 July 2014 00:28
By: harry rajan
  Hanging and long delays obtaining read locks
By: Randy Tidd on Sat, 14 September 2013
15 23681 Wed, 09 July 2014 16:56
By: John Bedell
  SecondaryTable causes invalid join (Bug)
By: Omid Pourhadi on Tue, 01 July 2014
2 3510 Wed, 09 July 2014 07:19
By: Omid Pourhadi
  JPQL passing binary enum instead of enum's ordinal as SQL param value for key in Map<enum, String
By: Ross Goldberg on Tue, 08 July 2014
0 3416 Tue, 08 July 2014 20:42
By: Ross Goldberg
  Tricky custom ClassLoader problem
By: Peter Sauer on Thu, 03 July 2014
0 3701 Thu, 03 July 2014 18:07
By: Peter Sauer
  Best type for JPA version field for Optimistic locking
By: Alberto Otero on Thu, 05 June 2014
2 4088 Thu, 03 July 2014 14:07
By: Jakub Hertyk
  Get old entity even after caching is disabled.
By: Dave Tiger on Fri, 27 June 2014
1 2956 Mon, 30 June 2014 13:43
By: Chris Delahunt
  EclipseLink Performance (vs. OpenJPA)
By: An Hoe on Mon, 16 June 2014
2 3159 Fri, 27 June 2014 21:50
By: Dave Tiger
  EclipseLink 2.3: Clear cache through application
By: Subhadip Chatterjee on Wed, 25 June 2014
4 2607 Thu, 26 June 2014 04:21
  Moxy map attribute that doesn't exist in the object model.
XMLTransformationMapping equivalent in annotations or oxm
By: Jaime Metcher on Wed, 25 June 2014
1 2953 Thu, 26 June 2014 04:17
By: Jaime Metcher
  Generating tables from entities
Internal Exception: java.lang.NoClassDefFoundError: org/eclipse/persistence/jpa/jpql/parser/ExpressionVisitor
By: Tuan Nguyen on Thu, 26 June 2014
0 3726 Thu, 26 June 2014 02:33
By: Tuan Nguyen
  Embeded Object JPQL query not working
By: Mahendran Mahesh on Wed, 25 June 2014
0 3048 Wed, 25 June 2014 09:47
  EclipseLink 2.3: One-to-one association
Internal query formation isn't proper
By: Subhadip Chatterjee on Fri, 20 June 2014
4 3642 Wed, 25 June 2014 07:25
  OneToOne Mapping Exception
By: Subhadip Chatterjee on Thu, 06 March 2014
4 3169 Fri, 20 June 2014 17:51
By: Chris Delahunt
  eclipselink stackoverflow exceptions - repeating same query thousand of time
eclipselink gives stackoverflow exceptions as keeps executing same query thousand of times
By: Ahmad Bahaaeldin on Wed, 18 June 2014
0 5162 Wed, 18 June 2014 21:13
  Spring managed transactions, EclipseLink JPA, custom isolation level
By: M K on Wed, 18 June 2014
0 5492 Wed, 18 June 2014 20:28
By: M K
  Unmapped attributes of superclass have wrong value
By: Stefan Loewe on Tue, 17 June 2014
1 2521 Wed, 18 June 2014 11:59
By: Stefan Loewe
  Multitenancy & single table inheritance
Queries work directly to the base entity and ignore child entity or oposite
By: Viliam Kois on Thu, 05 June 2014
3 4375 Tue, 17 June 2014 08:34
By: Viliam Kois
  EL QBE JPA2
EclipseLink with JPA2 - Query By Example - 'Session'?
By: Ludwig Moser on Mon, 16 June 2014
0 4088 Mon, 16 June 2014 08:11
By: Ludwig Moser
  SessionCustomizer not used
By: Tom Dunstan on Fri, 06 June 2014
2 4042 Mon, 16 June 2014 06:32
By: Tom Dunstan
  UnaryTableSequence per entity vs single table-sequence table
By: Alberto Otero on Fri, 13 June 2014
0 4182 Fri, 13 June 2014 20:35
By: Alberto Otero
  Lazy-loaded basic attribute never refreshed
By: Peter Nehrer on Wed, 04 June 2014
4 6556 Tue, 10 June 2014 20:23
By: Peter Nehrer
  MOXy failes to serialize list of objects
By: Erland Lewin on Mon, 09 June 2014
1 2725 Tue, 10 June 2014 07:48
By: Erland Lewin
  Sequence Generating with MappedSuperclass id
By: Jacob Champlin on Fri, 06 June 2014
0 2732 Fri, 06 June 2014 18:54
By: Jacob Champlin
  Query on Saveable Helper
Had a question on how to check if yes,no,cancel was pressed when saving a part
By: Badri narayan on Fri, 06 June 2014
0 2913 Fri, 06 June 2014 06:02
By: Badri narayan
  Eclipse link Create
How to provide protection on create?
By: Ranjith Nagesh Belagodu on Wed, 04 June 2014
0 4436 Wed, 04 June 2014 19:02
  EL issues SELECT 1 after every exception [SYBASE]
By: Faz Mu on Sun, 01 June 2014
3 16978 Wed, 04 June 2014 13:11
By: Chris Delahunt
  @OneToMany relations with @NOSQL don't works
Using @OneToMany relation with a @nosql database leads to errors
By: jm collin on Wed, 27 February 2013
4 6688 Mon, 02 June 2014 08:34
By: Murthy Bhat
  positional parameter in query
By: Rainer H. on Wed, 28 May 2014
0 69730 Wed, 28 May 2014 20:44
By: Rainer H.
  AdditionalCriteria Annotation
By: Dan Cebotarenco on Tue, 27 May 2014
0 78747 Tue, 27 May 2014 09:16
By: Dan Cebotarenco
  Stored Procedures
By: Andrew H. on Tue, 27 May 2014
0 67511 Tue, 27 May 2014 02:26
By: Andrew H.
  EclipseLink-MONGODB search not working
By: Chandre Gowda on Mon, 26 May 2014
0 85182 Mon, 26 May 2014 05:51
By: Chandre Gowda
  Eclipselink 2.3 deadlock issues
Deadlock issues - EJB 3.0 with Eclipselink on WL12c
By: Venkatesh Loganathan on Fri, 23 May 2014
0 77016 Fri, 23 May 2014 20:53
  wrong xsd is generated for subclass
By: jason zhang on Thu, 22 May 2014
0 71152 Thu, 22 May 2014 23:39
By: jason zhang
  Problem adding more entity classes
By: Kathrin Kahlhoefer on Tue, 20 May 2014
2 4078 Wed, 21 May 2014 18:09
  Problem persisting without cascade
By: Randy Tidd on Tue, 20 May 2014
3 11192 Wed, 21 May 2014 17:18
By: Chris Delahunt
  Prepersist ISSUE with merge(when creating a new entity).
By: Dan Cebotarenco on Fri, 16 May 2014
1 3629 Fri, 16 May 2014 16:28
By: Chris Delahunt
  readonly query and mix isolated and shared cache types
readonly query by entities with isolated caching doesn't use referenced entities in shared cache
By: Serge Poberezhnik on Wed, 14 May 2014
2 2855 Thu, 15 May 2014 10:55
  @Embeddable class containing type of its own
By: Murthy Bhat on Mon, 12 May 2014
0 27873 Mon, 12 May 2014 09:54
By: Murthy Bhat
  FetchGroup does not work for Embedded attribute
By: jason zhang on Sun, 11 May 2014
0 37031 Sun, 11 May 2014 04:43
By: jason zhang
  FetchGroup for relation attributes
By: jason zhang on Sat, 10 May 2014
3 10187 Sun, 11 May 2014 04:34
By: jason zhang
  JPQL LEFT JOIN FETCH Results in NPE when DescriptorCustomizer in Place
By: Scott Dudley on Fri, 09 May 2014
0 53721 Fri, 09 May 2014 17:59
By: Scott Dudley
  PersistenceContext bypassed by EntityManager.find()
Disabling second level cache after lock() is used
By: Erik Brakkee on Tue, 06 May 2014
2 3148 Thu, 08 May 2014 08:33
By: Erik Brakkee
  CursoredStream or ScrollableCursor with Native Query and SqlResultSetMapping?
By: Scott Dudley on Wed, 07 May 2014
0 64793 Wed, 07 May 2014 20:45
By: Scott Dudley
  Native Query, ScrollableCursor, Join Fetching, and Duplicate Column Names
By: Scott Dudley on Fri, 02 May 2014
2 22760 Wed, 07 May 2014 20:41
By: Scott Dudley
  Update fetching null relationships
By: Mauro Flores on Wed, 07 May 2014
0 64884 Wed, 07 May 2014 14:34
By: Mauro Flores
  Problems with JAXB and Moxy
Problem when generating java classes from xsd files
By: Endika Fernánde Cuesta on Wed, 07 May 2014
0 64849 Wed, 07 May 2014 08:44
  EclipseLink Composite Unit Error - Join Query Executes on One Datasource
By: Simon Carroll on Tue, 06 May 2014
1 1282 Tue, 06 May 2014 14:14
By: Chris Delahunt
  Transactions
Managing transactiosn with EclipseLink
By: Philippot Sébastien on Mon, 05 May 2014
2 1589 Mon, 05 May 2014 20:53
icon14.gif @TableGenerator - Pre-allocate ID block not work fine [SOLVED]
More persistence in the same transaction skip the entire id's block
By: Antonio Iovino on Mon, 28 April 2014
4 27176 Mon, 05 May 2014 15:39
By: Antonio Iovino
  Unmapped Columns in ResultSet
By: Scott Dudley on Mon, 28 April 2014
9 3888 Fri, 02 May 2014 23:17
By: Scott Dudley
  Problem removing directory with database
By: Rainer H. on Thu, 01 May 2014
1 13353 Fri, 02 May 2014 16:40
By: Shaun Smith
  Unique constraints in unidirectional one to one relationship
By: Michał Przybylak on Fri, 02 May 2014
0 53595 Fri, 02 May 2014 10:44
  Exception when updating object from outside of transaction
By: Pawel Zak on Mon, 07 April 2014
4 3981 Wed, 30 April 2014 16:14
By: Chris Delahunt
  Include json.root element as a @type attribute
By: greg Mising name on Tue, 29 April 2014
0 56610 Tue, 29 April 2014 20:36
icon7.gif Custom PoolDataSource - How to change in EclipseLink
custom pool dataSource eclipselink
By: Paco Benitez on Wed, 16 April 2014
2 1869 Wed, 16 April 2014 13:40
By: Paco Benitez
  Multiple mappings for a single xml element
By: Mar Sah on Tue, 15 April 2014
0 13288 Tue, 15 April 2014 22:58
By: Mar Sah
  Invoke JPA entity creation process from a script
By: Krz Pa on Sun, 13 April 2014
0 10116 Sun, 13 April 2014 08:38
By: Krz Pa
  @XmlInverseReference generate wrong JSON for bidirectional relations
@XmlInverseReference works with XML but generate wrong JSON for bidirectional oneToMany - ManyToone JPA
By: Clovis Wichoski on Tue, 07 January 2014
6 37831 Fri, 11 April 2014 15:36
By: Christopher Parker
  EclipseLink memory leak?
The longer our server is running, the more memory is used by EclipseLink.
By: Jens Huettemann on Wed, 09 April 2014
2 3403 Fri, 11 April 2014 05:48
By: Jens Huettemann
  Issue with orphanRemoval = true and OptimisticLockException
By: Dan Mising name on Thu, 03 April 2014
1 3060 Thu, 10 April 2014 15:18
By: Chris Delahunt
  don't get latest data from database
By: Harald Windisch on Mon, 07 April 2014
1 3183 Thu, 10 April 2014 15:12
By: Chris Delahunt
  XmlAdapter with xml-path
Moxy XmlAdapter
By: Mar Sah on Tue, 08 April 2014
0 2546 Tue, 08 April 2014 21:40
By: Mar Sah
  Insert Duplicate key Exception - Eclipselink
By: maverickml ml on Mon, 07 April 2014
0 3429 Mon, 07 April 2014 17:26
By: maverickml ml
  Custom Conversion
How can I implement a custom conversion in a database platform
By: Peter Kullmann on Tue, 19 November 2013
4 6331 Mon, 07 April 2014 14:32
By: Juan Alvarez Estrada
  CacheType.NONE
Problem with CachType.NONE
By: Stephen Hooper on Tue, 01 April 2014
0 2086 Tue, 01 April 2014 22:27
By: Stephen Hooper
  Selection criteria in any mapping
By: Senen de Diego on Tue, 01 April 2014
0 2800 Tue, 01 April 2014 19:55
By: Senen de Diego
  JPA Caching and NPE
Caching
0 3917 Tue, 01 April 2014 18:13
By: Stephen Hooper
  EclipseLink deadlock after SELECT 1 FROM DUAL
By: Kibbles Lee on Fri, 28 March 2014
0 4021 Fri, 28 March 2014 16:09
By: Kibbles Lee
icon4.gif Auto generated schemas en h2
Duda sobre como utilizar eclipseLink con H2
By: Abraham Lugo on Thu, 27 March 2014
0 2484 Thu, 27 March 2014 17:36
By: Abraham Lugo
  How to create EclipseLink DBWS builder XML file
By: Mickey Das on Thu, 27 March 2014
0 2276 Thu, 27 March 2014 16:19
By: Mickey Das
  Unknown entity bean class issue with glassfish v3
By: Christian S on Tue, 12 October 2010
5 21851 Wed, 26 March 2014 14:18
By: Nitin Soni
  Building EclipseLink OSGI from sources
Howto correctly build the EclipseLink release jars?
By: Oliver Wahlen on Wed, 26 March 2014
0 2394 Wed, 26 March 2014 10:28
By: Oliver Wahlen
  JPA Column Annotations
Is there an annotation available which accomplishes the same thing as Hibernate's @ColumnTransformer?
By: Paul Green on Mon, 24 March 2014
0 2328 Mon, 24 March 2014 19:33
By: Paul Green
  History for a OneToMany relationship not working
History of JPA Entity should include sub-entities attached thru a One-To-Many mapping
By: Heidi Hinckley on Thu, 02 January 2014
1 34588 Mon, 24 March 2014 11:51
By: Guenther Grau
  NPE merging @ManyToOne entity
By: Risto Oikarinen on Wed, 19 March 2014
2 4273 Mon, 24 March 2014 07:22
By: Risto Oikarinen
  Multi tenancy - NullPointerException
InstanceVariableAttributeAccessor.isNull
By: Viliam Kois on Wed, 05 March 2014
1 1678 Sun, 23 March 2014 21:14
By: Viliam Kois
  append Postgres Full Text Search expression after having CriteriaQuery
How to append the native where expression for use the Full Text Search on Postgres
By: Clovis Wichoski on Tue, 18 March 2014
1 3234 Fri, 21 March 2014 17:04
By: Chris Delahunt
  Example of leftJoin?
By: brad Mising name on Tue, 18 March 2014
1 2282 Tue, 18 March 2014 12:35
By: Chris Delahunt
  Help migrating (JEE6 + jboss + hibernate + jds) resolved
createQuery resolved
By: johnson russi on Mon, 17 March 2014
0 1305 Mon, 17 March 2014 02:29
By: johnson russi
  Cannot insert to 'path' field in Postgres db using EclipseLink
postgres
By: Daryl Foster on Wed, 12 March 2014
3 5939 Fri, 14 March 2014 18:54
By: Daryl Foster
  How to Obtain Persistence Unit Name in DescriptorEventAdapter
By: Scott Dudley on Fri, 14 March 2014
0 919 Fri, 14 March 2014 17:26
By: Scott Dudley
  Problems when using ApsectJ and EclipseLink weaving for LazyLoading
By: Jack Kilian on Fri, 14 March 2014
0 1158 Fri, 14 March 2014 14:07
By: Jack Kilian
  Partitioning and EclipseLink version
By: François Courtault on Thu, 13 March 2014
0 992 Thu, 13 March 2014 10:12
icon9.gif Ordered collections: ordered-column causes NPE
By: yuan yao on Mon, 17 February 2014
4 13042 Wed, 12 March 2014 02:04
By: yuan yao
  Deletion of OneToMany unidirectional mapping does not delete all children
By: kon f on Thu, 27 February 2014
5 2898 Tue, 11 March 2014 10:28
By: kon f
  Next release?
When is the next release planned?
By: Tom De Wolf on Sun, 02 March 2014
1 1344 Thu, 06 March 2014 15:31
By: Jakub Hertyk
  SELECT blabla AS x... => AS (alias) not working in EclipseLink 2.5 (glassfish4)
By: Guillaume Lepinay on Wed, 26 June 2013
6 8819 Thu, 06 March 2014 11:02
By: Jacky Cai
icon5.gif SIGSEGV in org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.checkCacheForObject
By: Christoph John on Tue, 04 March 2014
2 2207 Tue, 04 March 2014 14:49
By: Christoph John
  JPQL count query slow
JPQL count query is slow
By: David Sills on Wed, 26 February 2014
1 3534 Wed, 26 February 2014 15:30
By: Chris Delahunt
  Changing lazy attributes when shared cache disabled
By: Peter Nehrer on Fri, 21 February 2014
1 2021 Tue, 25 February 2014 21:45
By: Chris Delahunt
icon5.gif Reload Persistence Unit at Runtime
By: yuan yao on Tue, 25 February 2014
1 3187 Tue, 25 February 2014 03:12
By: Shaun Smith
  Error obtaining the Transaction Manager
jndi lookup fails
By: David Libke on Mon, 24 February 2014
1 11523 Mon, 24 February 2014 14:27
By: Chris Delahunt
  Future of DBWS webservice generation
By: Jan Smets on Fri, 21 February 2014
0 1903 Fri, 21 February 2014 09:41
By: Jan Smets
icon5.gif Dynamic: how to configure generated id using API?
dynamic generated id
By: yuan yao on Tue, 11 February 2014
1 16453 Mon, 17 February 2014 06:36
By: yuan yao
  Attributes in the default namespace?
By: nate roe on Wed, 08 January 2014
8 36900 Sat, 15 February 2014 00:44
By: nate roe
  Query for entity.collection returns List with one element which is null (instead of empty list)
By: Pawel Zak on Wed, 18 December 2013
4 39834 Thu, 13 February 2014 16:06
By: Chris Delahunt
  MOXy XPath expression compatibility with DOM and javax.xml.xpath.XPath
MOXy has an excellent facility to traverse JAXB object trees, but there seem to be a few incompatibilities with how you would code XPaths for traversing a DOM
By: J F on Wed, 22 January 2014
3 14741 Wed, 12 February 2014 15:06
By: J F
  [SOLVED] For each call a new connection? Need only one when using RCP with Gemini or Swing
By: Jack Kilian on Tue, 11 February 2014
2 11493 Wed, 12 February 2014 06:54
By: Jack Kilian
  Saving a referenced existing entity results in a new entity
By: Ralf Heydenreich on Tue, 04 February 2014
2 8827 Tue, 11 February 2014 20:25
  NOT NULL FK nullification problem
incompatible side-effect of shallow update/delete behavior on FKs defined in existing schema
By: Thom Park on Mon, 10 February 2014
0 27790 Mon, 10 February 2014 23:02
By: Thom Park
  DynamicJAXBContextFactory.createContextFromXSD fails to load SchemaMetadata
Fails if deployed in glassfish 4 works in junit-test
By: Greger Sernemar on Fri, 07 February 2014
1 4457 Mon, 10 February 2014 19:30
By: Blaise Doughan
  Eclipse AspectJ vs. EclipseLink DynamicWeaving
By: Jack Kilian on Thu, 06 February 2014
1 1502 Thu, 06 February 2014 16:02
By: Jack Kilian
DescriptorEventAdapter-JPA
By: Garry Baal on Thu, 06 February 2014
1 1467 Thu, 06 February 2014 14:04
By: Lukas Jungmann
  How works dynamic weaving in EclipseLink?
1 1547 Thu, 06 February 2014 11:58
By: Lukas Jungmann
  Calculate Unit of Work before open Transaction
By: Jack Kilian on Wed, 05 February 2014
0 27369 Wed, 05 February 2014 09:14
By: Jack Kilian
  Using DescriptorEventAdapter in @EntityListeners correct
By: Jack Kilian on Tue, 04 February 2014
0 26058 Tue, 04 February 2014 13:56
By: Jack Kilian
  JAXBErrorHandler#warning
JAXBErrorHandler#warning implementation
By: Pëtr Andreev on Wed, 15 January 2014
2 13026 Mon, 03 February 2014 11:23
By: Pëtr Andreev
Legend New Messages New Messages   No New messages No New messages   Locked (w/ unread messages) Locked (w/ unread messages)   Locked Locked   Moved to another forum Moved to another forum
Current Time: Sat Apr 27 21:14:43 GMT 2024
Powered by FUDForum. Page generated in 0.04298 seconds
