Topic |
Replies |
Views |
Last message |
AbstractMethodError: _persistence_shallow_clone() |
3 |
17455 |
Thu, 11 July 2013 16:44 By: ronald Mising name |
Schema creation slow with informix |
3 |
3563 |
Thu, 11 July 2013 11:23 By: Oliver Pfau |
How to prevent eclipse-link from loading lazy fetched attributes ? |
3 |
4385 |
Thu, 11 July 2013 07:26 By: Nicolas Baumgardt |
Cache coordination per entity type |
2 |
2211 |
Tue, 09 July 2013 14:52 By: Christoph Smaul |
Strange behaviour if weaving is enabled |
2 |
2083 |
Tue, 09 July 2013 14:43 By: Reiner Lott |
Not able to get the inserted Entity after Query.getSingleResult(INSERT INTO..... VALUES......) Not able to get the inserted Entity after Query.getSingleResult(INSERT INTO..... VALUES......) |
2 |
2935 |
Mon, 08 July 2013 15:00 By: Amrit Debasis |
Customizing schema generation |
2 |
3005 |
Sun, 07 July 2013 12:53 By: dan pomerchik |
3 |
1954 |
Sun, 07 July 2013 12:48 By: dan pomerchik |
MOXy: Insert/Replacement scenario using Xpath |
0 |
3315 |
Sun, 07 July 2013 00:43 By: Tim Braun |
Eclipse link DBWS -Connection is null Connection is null when dbwsbuilder,cmd excecuted |
17 |
11529 |
Thu, 04 July 2013 13:25 By: David McCann |
JPQL Question - empty string |
1 |
2486 |
Wed, 03 July 2013 14:20 By: James Sutherland |
Nulling an embedded object does not affect the database upon merge |
4 |
6479 |
Wed, 03 July 2013 14:08 By: James Sutherland |
missing Embeddable |
5 |
6368 |
Wed, 03 July 2013 14:06 By: Hannes Kühtreiber |
Predeployment of PersistenceUnit [. . .] failed |
2 |
17095 |
Wed, 03 July 2013 14:06 By: James Sutherland |
How to customize the update query? |
1 |
2567 |
Wed, 03 July 2013 14:03 By: James Sutherland |
EclipseLink RestService entityManager is null |
1 |
2966 |
Wed, 03 July 2013 13:54 By: James Sutherland |
ElementCollection Map and CriteriaQuery |
1 |
4365 |
Wed, 03 July 2013 13:34 By: James Sutherland |
Mapping Oracle NUMBER type to Java Type Options Can Java Integer be used for Oracle NUMBER instead of the default Java BigDecimal |
3 |
8485 |
Wed, 03 July 2013 13:31 By: James Sutherland |
Opened EntityManager |
1 |
1477 |
Tue, 02 July 2013 18:44 By: Chris Delahunt |
Birt with JBOSS 5 Issue Unable to load the birt report |
1 |
1604 |
Mon, 01 July 2013 15:55 By: SRIHARIRAO M |
Problem with ObjectGraph and xml attributes |
0 |
2082 |
Mon, 01 July 2013 13:07 By: Joni Ollila |
Multiple JPA Persistences loading issue in JBOSS 5 Multiple products with in same JBOSS Issue |
4 |
4336 |
Fri, 28 June 2013 07:29 By: SRIHARIRAO M |
java.lang.ArrayIndexOutOfBoundsException: -1 java.lang.ArrayIndexOutOfBoundsException: -1 in org.eclipse.persistence.mappings.ForeignReferenceMapping.extractResultFromBatchQuery |
5 |
12627 |
Thu, 27 June 2013 22:13 By: Michael Nielson |
ConversionException When Using Enum in Composite Primary Keys ConversionException When Using Enum in Composite Primary Keys |
4 |
60606 |
Wed, 26 June 2013 05:17 By: Aslam Ahmed |
JPA Mapping Multi-Rows with ElementCollection |
1 |
3357 |
Tue, 25 June 2013 14:41 By: James Sutherland |
OPEN - Disable delete an entity when is its linked in relationships |
1 |
1541 |
Tue, 25 June 2013 14:39 By: James Sutherland |
entitymanager problem merge merge() problem |
1 |
3120 |
Tue, 25 June 2013 14:33 By: James Sutherland |
How to access Primary Key instance of entity relationship? |
2 |
4400 |
Tue, 25 June 2013 14:27 By: James Sutherland |
How to use eclipselink.batch with em.find()? eclipselink.batch will speed up queries -- but how to use with em.find()? |
4 |
4087 |
Tue, 25 June 2013 13:52 By: James Sutherland |
Could not load the method for the property name |
0 |
2961 |
Tue, 25 June 2013 08:34 By: Hannes Kühtreiber |
Unknown column hashcode, value, count, offset |
2 |
2145 |
Fri, 21 June 2013 19:15 By: Alex Mising name |
merge problem merge problem |
1 |
2247 |
Thu, 20 June 2013 19:01 By: Chris Delahunt |
BeanValidation at preUpdate for unchanged entities? |
2 |
11911 |
Thu, 20 June 2013 16:19 By: Chris Delahunt |
merge problem |
0 |
2997 |
Wed, 19 June 2013 20:43 By: kamal na |
Problem with QueryHints.FETCH and ORDER BY clause By: F C on Tue, 18 June 2013 |
3 |
6472 |
Wed, 19 June 2013 19:07 By: Chris Delahunt |
InheritancePolicy SingleTableStrategy in Dynamic Persistence |
2 |
66026 |
Wed, 19 June 2013 15:49 By: Gaurav Gupta |
JPQL Composite Key in Dynamic Persistence |
3 |
31445 |
Wed, 19 June 2013 15:46 By: Gaurav Gupta |
jaxb marshalling unmarshalling exception in jboss servlet jaxb servlet marshalling |
0 |
7825 |
Wed, 19 June 2013 07:29 By: yaron illouz |
CanonicalModelProcessor not found CanonicalModelProcessor not found during RCP plugin export with EclipseLink |
0 |
6537 |
Tue, 18 June 2013 19:31 By: Alan Willard |
@OneToMany and @ManyToOne in MongoDB and JPA -EISOneToOneMapping cannot be cast to |
1 |
10541 |
Tue, 18 June 2013 14:56 By: James Sutherland |
EclipseLink and MongoDB - Auto incrementing field |
2 |
50907 |
Tue, 18 June 2013 14:52 By: Michael Hunziker |
SetFirstResult and setMaxResult problem if exist @OneToMany relation By: F C on Wed, 12 June 2013 |
3 |
9184 |
Tue, 18 June 2013 14:19 By: James Sutherland |
Mapping Joda Interval Aggregation of 2 columns |
1 |
56891 |
Tue, 18 June 2013 14:15 By: James Sutherland |
org.eclipse.persistence.annotations.CacheInterceptor org.eclipse.persistence.annotations.CacheInterceptor By: P Soma on Mon, 17 June 2013 |
0 |
15389 |
Mon, 17 June 2013 15:03 By: P Soma |
ClassLoader problem using JPA with Native Eclipselink project file ClassLoader problem using JPA with Native Eclipselink project file |
1 |
12350 |
Mon, 17 June 2013 05:42 By: Kishore Kirdat |
MultiTenant cache headache |
0 |
26170 |
Sun, 16 June 2013 15:49 By: Thomas Kratz |
Composite Primary key Sequence in JPA EclipseLink DynamicPersistence |
1 |
52027 |
Sun, 16 June 2013 09:36 By: Gaurav Gupta |
Please vote to publish standard JPA 2.0 & 2.1 jars to Maven |
1 |
2473 |
Thu, 13 June 2013 18:20 By: Matthew T. Adams |
Composite Primary key in JPA EclipseLink DynamicPersistence |
2 |
5100 |
Tue, 11 June 2013 18:59 By: Gaurav Gupta |
Paid Support Fortune 15 Company |
1 |
15071 |
Tue, 11 June 2013 15:06 By: James Sutherland |
CacheInterceptor Cache Coordination using CacheInterceptor By: P Soma on Wed, 29 May 2013 |
3 |
49976 |
Tue, 11 June 2013 15:05 By: James Sutherland |
EclipseLink 1.x on JBoss 7 Known issues or incompatibility ? |
2 |
43263 |
Tue, 11 June 2013 14:47 By: Rafael Vanderlei |
JPQL problems with JOIN FETCH on List<Entity> By: F C on Wed, 05 June 2013 |
2 |
2628 |
Tue, 11 June 2013 14:44 By: James Sutherland |
NamedQuery of name ... not found. By: Rob V on Tue, 04 June 2013 |
1 |
63897 |
Tue, 11 June 2013 14:21 By: James Sutherland |
JMS cache coordination on GlassFish cluster |
3 |
7839 |
Tue, 11 June 2013 08:52 By: Andreas S |
Null value if read the same @ManyToOne Entity By: F C on Fri, 07 June 2013 |
6 |
6337 |
Tue, 11 June 2013 07:41 By: F C |
Determine 'create' or 'update' Entity What is the best way to generically determine if an Entity is for 'create' or 'update'? |
4 |
4794 |
Mon, 10 June 2013 19:45 By: Chris Delahunt |
Validation exception on spurious insert during a query transaction Confusing insert during a transaction that simply loads and returns an object. |
1 |
4698 |
Thu, 06 June 2013 18:26 By: Chris Delahunt |
OnetoOne mapping issue |
9 |
7478 |
Thu, 06 June 2013 15:47 By: Dario Galvis |
DISTINCT and ORDER BY Bug? - EclipseLink Problem with DISTINCT and ORDER BY |
2 |
10316 |
Thu, 06 June 2013 14:23 By: Oliver Baum |
Eclipse Data Partition Question |
2 |
9681 |
Wed, 05 June 2013 03:37 By: Oliver Zhou |
EclipseLink 2.5 schema generation |
2 |
25559 |
Wed, 05 June 2013 02:57 By: Oliver Zhou |
3 table cascade reference @JoinFetch |
4 |
8256 |
Tue, 04 June 2013 15:52 By: alex alex |
Accesing Eclipselink DBWS Accesing Eclipselink DBWS from Eclipse RCP client |
1 |
9695 |
Tue, 04 June 2013 14:18 By: James Sutherland |
JPQL queries on Virtual Access Method fields JPQL queries on Virtual Access Method fields (Extensible Entities) |
1 |
19633 |
Tue, 04 June 2013 13:54 By: James Sutherland |
EclipseLink DBWS with JPQL Examples of creating EclipseLink DBWS with JPQL and Criteria |
2 |
24514 |
Tue, 04 June 2013 05:50 By: Panisha RN |
JMS Cache coordination Issue MDB message contains Command type object instead of RemoteCommand |
10 |
5920 |
Mon, 03 June 2013 19:01 By: Chris Delahunt |
When a merge does not update? Sametimes the merge does not update, I would know that restrictions to better use this JPA implementation |
3 |
26143 |
Mon, 03 June 2013 17:35 By: Everton Fujimoto |
Cascade Remove problem I have a problem with cascade Remove in Eclipselink |
1 |
6875 |
Mon, 03 June 2013 12:49 By: Chris Delahunt |
Object: is not a known entity type. Entity Meta-Data is not recognised ? |
7 |
37232 |
Sun, 02 June 2013 16:54 By: Rodrigo Soares de Almeida |
Unidirectional OneToMany Insert |
2 |
7846 |
Fri, 31 May 2013 09:46 By: pdvmipv Mising name |
Modify schema using persistence layer |
2 |
11842 |
Fri, 31 May 2013 07:53 By: Florian Pirchner |
Model-Evolution best practices |
0 |
61830 |
Thu, 30 May 2013 09:37 By: Florian Pirchner |
Slow Query Extraction |
2 |
14576 |
Thu, 30 May 2013 07:22 By: pdvmipv Mising name |
Cannot find jpa.osgi plugin in Eclipselink 2.5.0 Cannot find jpa.osgi plugin in Eclipselink 2.5.0 |
1 |
2010 |
Wed, 29 May 2013 17:11 By: Shaun Smith |
DML without transaction |
4 |
26219 |
Wed, 29 May 2013 07:02 By: Daniel Elstner |
Trying to Marshall/Unmarshall xjc generated classes that don't have a @XmlRootElement annotation |
1 |
15278 |
Fri, 24 May 2013 13:55 By: Blaise Doughan |
Call Oracle Function Call Oracle Function |
1 |
12662 |
Fri, 24 May 2013 06:23 By: Oliver Baum |
Problems with Eclipselink batching statements When making consecutive calls to the same stored procedure in a transaction, exception occurrs |
7 |
17423 |
Wed, 22 May 2013 15:36 By: John Dugo |
Modify database schema for class based entities |
1 |
5274 |
Wed, 22 May 2013 15:10 By: James Sutherland |
TabelDefinition for JPAEntity.class |
1 |
4852 |
Wed, 22 May 2013 15:08 By: James Sutherland |
What is happening here |
3 |
6199 |
Wed, 22 May 2013 15:02 By: James Sutherland |
Retry on closed Connection Difference between EntityManager.createNamedQuery(String, Class).getResultList() and entityManager.createQuery(CriteriaQuery).getResultList() with respect to closed connections |
4 |
13071 |
Wed, 22 May 2013 15:02 By: Michael Gruebsch |
ReadallQuery alias setting |
3 |
6754 |
Wed, 22 May 2013 14:53 By: James Sutherland |
NPE in DatabaseQueryMechanism.updateObjectForWriteWithChangeSet(DatabaseQueryMechanism.java:978) |
3 |
12928 |
Wed, 22 May 2013 14:33 By: James Sutherland |
Not able to create entity after changing the primary key JPA does not allow changing primary key for it's own reason.I am tyring to work it around by first removing the entity and then creating it back with changed primary key. However, when I try to pers |
2 |
3643 |
Wed, 22 May 2013 14:30 By: James Sutherland |
Convert varchar to nvarchar for specific columns only. |
3 |
7690 |
Wed, 22 May 2013 14:19 By: James Sutherland |
Modelevolution and -migration - My approach |
0 |
20787 |
Tue, 21 May 2013 10:50 By: Florian Pirchner |
JPA and Excel import/export |
0 |
26590 |
Mon, 20 May 2013 14:19 By: Daniel McGreal |
Version 2.5.0 on maven central? |
0 |
27881 |
Thu, 16 May 2013 13:53 By: Geraldo Massahud |
[Moxy] How to efficiently create (valid) xml for given Schema |
2 |
12776 |
Wed, 15 May 2013 17:12 By: moritz du |
[Moxy] Simple unmarshalling and marshalling changes xml |
3 |
4331 |
Wed, 15 May 2013 13:01 By: moritz du |
Map<Integer, BigDecimal> causes NPE because it is backed by a Hashtable Problems mapping possible (and valid) null values |
1 |
13623 |
Tue, 14 May 2013 14:39 By: James Sutherland |
how to return value in anonymous pl sql using eclipselink |
1 |
11011 |
Tue, 14 May 2013 14:07 By: James Sutherland |
[Moxy] How to use dynamic Moxy for specific example |
6 |
12057 |
Tue, 14 May 2013 13:56 By: moritz du |
JPA database schema validation case problems in ClassDescriptor#checkDatabase(...) ClassDescriptor#checkDatabase(...): field.getName() vs. field.getNameForComparisons() |
1 |
3049 |
Tue, 14 May 2013 13:54 By: Chris Delahunt |
create a function via nativeQuery |
1 |
12207 |
Tue, 14 May 2013 13:50 By: James Sutherland |
[Solved] P2 Repository Download failure |
2 |
10180 |
Tue, 14 May 2013 12:22 By: Scott Hull |
Difficult Query to be made in Eclipselink |
0 |
25397 |
Mon, 13 May 2013 12:17 By: mohamed ibrahim mohamed |
Sorting by Date , I can't solve it |
2 |
3173 |
Sun, 12 May 2013 10:55 By: mohamed ibrahim mohamed |
I need to capture database warnings, which log level to use? I'm debugging triggers, and I need to capture PostgreSQL warnings to get there |
2 |
3612 |
Sat, 11 May 2013 15:14 By: Edson Richter |
eclipseLink inheritance joined and oneToMany |
6 |
9390 |
Fri, 10 May 2013 11:29 By: tex wilco |
create_or_extend_Tables ddl generation issue Attempts to create table when create_or_extend_Tables ddl generation |
4 |
4841 |
Wed, 08 May 2013 18:58 By: Chris Delahunt |
Foreign key constraint with create_or_extend_table is used Foreign key constraint recreated when create_or_extend_table is used |
3 |
5754 |
Wed, 08 May 2013 18:52 By: Chris Delahunt |
0 |
13995 |
Wed, 08 May 2013 11:35 By: Luiz E. |
Incrementing generated primary key in @PrePersist According to JPA, is it valid and portable to manually increase a JPA-generated primary key in @PrePersists? |
3 |
10429 |
Tue, 07 May 2013 15:01 By: Markus KARG |
Unique Constraints and Delete and Insert Order - Constraint Violation Constraint violation removing itens for a list, and adding new |
1 |
4981 |
Tue, 07 May 2013 14:55 By: James Sutherland |
Is UNION supported in a subquery? |
1 |
7100 |
Tue, 07 May 2013 14:53 By: James Sutherland |
Convert .NET DateTimeOffset <--> Jodatime DateTime (utc) How can I convert between these kinds of time in EclipseLink? |
2 |
10061 |
Tue, 07 May 2013 14:49 By: James Sutherland |
Problem mongodb query/find by id |
11 |
14891 |
Tue, 07 May 2013 14:28 By: James Sutherland |
When will Eclipselink 2.4.2 be released? |
1 |
4609 |
Mon, 06 May 2013 16:17 By: David Twelves |
Loading an XML file with SDO [XML SDO ECLIPSELINK] |
4 |
4156 |
Fri, 03 May 2013 14:58 By: Ayoub El Barji |
How to refresh the entities with out re starting the server How to refresh the entities with out re starting the server |
1 |
10701 |
Fri, 03 May 2013 13:47 By: Chris Delahunt |
Complex Key: Multiple writable mappings exist; Cannot figure out how to correct this error... Please help. :) |
2 |
22536 |
Wed, 01 May 2013 19:15 By: Michael Gardner |
Exception in thread "main" java.lang.ExceptionInInitializerError [SDO Tuscany XSD] |
3 |
11090 |
Tue, 30 April 2013 15:18 By: Ayoub El Barji |
JPA/Dynamic OneToOne attribute in inherited table insert new row failed when the OneToOne row is in a a table with inheritance |
1 |
3953 |
Tue, 30 April 2013 12:50 By: James Sutherland |
No data persisted to database with new JPA-RS libs |
2 |
5189 |
Thu, 25 April 2013 19:21 By: Gul Onural |
problem with entityManager.createQuery(CriteriaQuery q) |
1 |
5613 |
Thu, 25 April 2013 18:43 By: Chris Delahunt |
insert always null on embedded fields |
1 |
2975 |
Thu, 25 April 2013 15:15 By: Chris Delahunt |
Eclipse Link insert/update performance issue Eclipse link calls update after insert on persist. Causing performance issues. |
5 |
10272 |
Thu, 25 April 2013 08:24 By: Michael Hoennig |
em.merge(treeOfEntities) impossible with optimistic locking It is impossible to merge a tree of entities when using optimistic locking in leaf entities |
3 |
4804 |
Tue, 23 April 2013 14:45 By: Markus KARG |
How to use EclipseLink 2.4.1 in GlassFish 3.1.1? java.lang.NoClassDefFoundError: org/eclipse/persistence/jpa/jpql/parser/ExpressionVisitor |
4 |
6371 |
Tue, 23 April 2013 14:39 By: Markus KARG |
Query Cache in 2.4.1 Help |
1 |
3476 |
Tue, 23 April 2013 14:04 By: James Sutherland |
One to One Relationship With Shared PK not Working at Execution time JPA, One To One, MySql |
2 |
3256 |
Tue, 23 April 2013 09:44 By: Jose Garcia |
EclipseLink composite persistence unit class declaration |
1 |
17065 |
Mon, 22 April 2013 22:13 By: Tristan Paddock |
Eclipselink not reconnecting to database, after database-server downtime INFO: Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query. |
1 |
4366 |
Mon, 22 April 2013 18:37 By: Reiner Lott |
EclipseLink NoSQL support, limitations and future plans? Summary of current Eclipselink support features, limitations and future plans |
1 |
1772 |
Mon, 22 April 2013 16:06 By: Pedro Miguel Pereira Serrano Martins |
Value of Column is null while Deleting in ManyToMany-Relationship |
1 |
6692 |
Mon, 22 April 2013 13:56 By: Chris Delahunt |
Sporadic and arbitrary DELETES issued by EclipseLink EclipseLink 2.4.1 sporadically deletes arbitrary rows from database |
13 |
12013 |
Sat, 20 April 2013 11:14 By: Markus KARG |
Predeployment failing on EclipseLink 2.3.2 |
2 |
12473 |
Fri, 19 April 2013 16:57 By: Manuel Frick |
Generate Tables from Entities results in NoInitialContextException |
4 |
14929 |
Fri, 19 April 2013 16:47 By: Benedikt Erdmann |
DBWS / NamingConventionTransformer NamingConventionTransformer only works partially when generating webservices based on pl/sql packages |
3 |
3102 |
Fri, 19 April 2013 06:52 By: Kurt Geens |
xsi:type with namespace using MOXy |
4 |
8140 |
Fri, 19 April 2013 05:06 By: Blaise Doughan |
JPA with extended objects Access only base class objects with EclipseLink |
2 |
2300 |
Thu, 18 April 2013 15:29 By: Neil Cohen |
Using CopyGroup and CASCADE_TREE depth always get a null as copied entity |
5 |
5875 |
Thu, 18 April 2013 13:44 By: Andrei Ilitchev |
One to many and Many to One MOXy @XmlInverseReference EclipseLink 2.5 @XmlInverseReference |
1 |
3542 |
Wed, 17 April 2013 18:07 By: Sergio Bilello |
[Moxy] Problem on unmarshalling using Document instead of InputStream |
2 |
5527 |
Wed, 17 April 2013 15:13 By: moritz du |
Static Metamodel gencode error ... for wildcard Collection field CanonicalModelProcessor generate wrong source code for ListAttribut<X, Z> if Z is like "? extends E" |
3 |
6906 |
Wed, 17 April 2013 15:08 By: Guy Pelletier |
Using Left Join without metamodel classes |
3 |
6786 |
Wed, 17 April 2013 10:12 By: Alexandre Alves |
eclipselink.id-validation=NONE not working |
1 |
8634 |
Tue, 16 April 2013 13:22 By: James Sutherland |
org.eclipse.persistence.eis.adapters package Missing in 2.4.0 org.eclipse.persistence.eis.adapters package Missing in 2.4.0 jar but available in API. Please Help. |
1 |
3579 |
Tue, 16 April 2013 13:14 By: James Sutherland |
ManyToMany mapping created when no mapping is specified |
5 |
6371 |
Tue, 16 April 2013 13:14 By: Saravanan Subiramaniam |
[oracle] Using procedures to get the cursor not working |
3 |
6405 |
Tue, 16 April 2013 13:13 By: James Sutherland |
[EclipseLink.Examples.Employee] How to configure java:global/employeeDS on GF4 |
1 |
3447 |
Tue, 16 April 2013 04:18 By: Barry Zhong |
Nested classes in JSon and removing unnecessary levels |
0 |
3461 |
Mon, 15 April 2013 15:10 By: Stuart Rivero |
Beginner's Problem / strange behavior cannot seem to use MySQL |
6 |
8677 |
Fri, 12 April 2013 19:15 By: Chris Delahunt |
em.merge() creates 2 insert statements |
2 |
2745 |
Tue, 09 April 2013 15:10 By: James Sutherland |
Sorting of hierarchical entities in EclipseLink using @Order By or JPQL doesn't seem to work |
1 |
3477 |
Tue, 09 April 2013 13:47 By: Michael Burger |
[Closed] EclipseLink.Examples.student.web JPARSApplication cannot be instantiated |
3 |
4842 |
Tue, 09 April 2013 12:36 By: Barry Zhong |
Problem with Class DB2Platform function printSQLSelectStatement |
2 |
2334 |
Mon, 08 April 2013 13:01 By: Xanas Aurel |
IN query with composite primary key bug. |
0 |
4784 |
Fri, 05 April 2013 20:58 By: Michael Nielson |
Eclipselink Query show's different data than resultset |
3 |
3612 |
Fri, 05 April 2013 20:36 By: Eduardo Frazão |
What happened in "Query" |
2 |
2984 |
Fri, 05 April 2013 04:40 By: Johnny Yeung |
Unable to read a db table Eclipselink Query problem |
1 |
3673 |
Thu, 04 April 2013 17:18 By: Neil Cohen |
Commit object with ID |
1 |
3572 |
Thu, 04 April 2013 07:57 By: Bastian Wagenfeld |
JPA/DCN - working for INSERT; trouble with UPDATE Not getting updated record when DCN received after update in DB |
2 |
2412 |
Tue, 02 April 2013 19:28 By: Julie Schenk |
Inheritance and TYPE |
1 |
2724 |
Tue, 02 April 2013 13:52 By: James Sutherland |
Refreshing an entity with a reference to a cache-isolated entity has side-effects |
4 |
4055 |
Fri, 29 March 2013 22:52 By: Sebastian Kienzl |
How to persist a class which extends List<>? |
2 |
2468 |
Fri, 29 March 2013 10:58 By: Jan Vleeshouwers |
Refresh entity doesnt work with relationships |
2 |
4119 |
Wed, 27 March 2013 16:52 By: Wilber Saca |
Custom Insert/Update/Delete (Virsioning) Need an Advice, how to realize Topic |
2 |
3871 |
Tue, 26 March 2013 20:57 By: Roman Smushkevich |
Aggregated objects cannot be written/deleted/queried independently from their owners |
2 |
4715 |
Tue, 26 March 2013 14:26 By: Luiz E. |
validate unique column before commit validate unique column before commit |
1 |
1874 |
Tue, 26 March 2013 14:13 By: James Sutherland |
metamodel with two data sources using annotations Metamodel with annotations getting data from multiple sources. |
1 |
1986 |
Tue, 26 March 2013 14:09 By: James Sutherland |
Infinite loop with self-referencing bi-directional relationship |
1 |
3882 |
Tue, 26 March 2013 14:02 By: James Sutherland |
[RESOLVED] How to Query "nextval('sequence_name');" in EclipseLink how to, better way to |
2 |
3438 |
Tue, 26 March 2013 13:56 By: James Sutherland |
how to store a page of text as string in JPA 2.0 Need advice on storing long strings in JPA 2.0 |
1 |
3071 |
Tue, 26 March 2013 13:48 By: James Sutherland |
Validate xml against multiple schema org.xml.sax.SAXParseException; lineNumber: 1353; columnNumber: 40; src-resolve: Cannot resolve the name 'xenc:EncryptedData' to a(n) 'element declaration' component. |
0 |
6815 |
Tue, 26 March 2013 10:28 By: moritz du |
Batch fetch for type IN results in sql exception Batch fetch for type IN on relationships with composite foreign keys results in sql exception |
3 |
5391 |
Tue, 26 March 2013 02:38 By: Prasad Mysore |
Scrollable ResultSet Exception "End of Stream" Scrollable ResultSet Example |
1 |
4771 |
Mon, 25 March 2013 13:39 By: Chris Delahunt |
@XmlInverseReference back pointer not set on unmarshalling |
1 |
2495 |
Fri, 22 March 2013 17:02 By: irina adam |
StuckThreadMaxTime in weblogic |
5 |
9558 |
Thu, 21 March 2013 22:30 By: jsh jsh |
JPA-RS: @OneToOne relationship problem JPA-RS: @OneToOne relationship problem: related entity is not created after POST |
9 |
9017 |
Thu, 21 March 2013 13:54 By: Gul Onural |
BLOB Handling in DBWS generated webservice |
0 |
6204 |
Wed, 20 March 2013 20:09 By: Jay Royse |
[RESOLVED] EclipseLink on Tomcat7 (Dev. in Netbeans) |
2 |
28158 |
Wed, 20 March 2013 17:38 By: Dante Basso |
MOXy point release? |
2 |
2268 |
Wed, 20 March 2013 09:12 By: Firstname Lastname |
@XmlInverseReference with interface field |
2 |
3546 |
Wed, 20 March 2013 08:22 By: irina adam |
EclipseLink adding extra parens which postgreSQL doesn't like By: Dan C on Sun, 03 June 2012 |
5 |
8529 |
Tue, 19 March 2013 14:03 By: Paul Furbacher |
@JoinFetch doesn't work with mappings on Embeddables By: J LM on Tue, 12 March 2013 |
1 |
3291 |
Tue, 19 March 2013 14:00 By: James Sutherland |
Cached Map Update NPE on element remove |
2 |
6440 |
Tue, 19 March 2013 13:54 By: James Sutherland |
IllegalArgument Exception using a Enum as Query Parameter |
3 |
4113 |
Tue, 19 March 2013 13:48 By: James Sutherland |
JOIN Syntax Worked in toplink essentials JOIN syntax different from toplink |
7 |
6723 |
Mon, 18 March 2013 23:20 By: Mike Phillips |
DoesExistQuery in nosql DoesExistQuery not yet implemented |
1 |
2400 |
Mon, 18 March 2013 14:41 By: James Sutherland |
Memory issue due to hard referenced entities RepeatableWriteUnitOfWork not garbage collected (EL 2.4.1) |
3 |
3661 |
Mon, 18 March 2013 10:29 By: Christoph Smaul |
Not able to get JPA 2 to work in EclipseLink Could not generate OneToMany records using @ElementCollection in JPA 2 |
2 |
3872 |
Mon, 18 March 2013 06:58 By: George Jackson |
Is it possible to build EclipseLink 1.1.4 from source Building older EclipseLink from source |
0 |
5042 |
Sun, 17 March 2013 12:15 By: Brett Bergquist |
strange problem with error cvc-elt.1 and name space moxy dosn't read and validation fails - in eclipse all is fine |
0 |
8238 |
Thu, 14 March 2013 15:07 By: moritz du |
How to obtain the entity ID after persit from a trigger generated value How to obtain the entity ID after persit from a trigger generated value |
1 |
3313 |
Thu, 14 March 2013 14:28 By: Chris Delahunt |
JPA-RS: @OneToMany: invalid output when retrieving relationship link GET relationship returns invalid JSON syntax in case an empty collection is POSTed |
2 |
3950 |
Wed, 13 March 2013 15:30 By: Daniel Szalay |
Incorrect Cascade Discovery of new objects mapped from managed Embeddables By: J LM on Tue, 12 March 2013 |
2 |
1845 |
Tue, 12 March 2013 17:35 By: J LM |
Entity instance not rollbacked |
2 |
2811 |
Sat, 09 March 2013 00:53 By: Cedric Tabin |
Switched to 2.4.1 - Suddenly caching of lazy relations is missing Do we miss any new default setting? |
6 |
5739 |
Thu, 07 March 2013 20:23 By: James Sutherland |
naming conflict on generating classes from xsd how to use bindings - xjb file? |
2 |
12875 |
Wed, 06 March 2013 09:00 By: moritz du |
History for OneToMany relationship with JoinColumn |
1 |
4383 |
Tue, 05 March 2013 14:54 By: James Sutherland |
Strange weaving message at startup |
3 |
4753 |
Tue, 05 March 2013 14:50 By: James Sutherland |
Is here the way to regulate result of query to child tables of an entity. |
2 |
3366 |
Fri, 01 March 2013 12:53 By: Super User |
Group by statement is not rendered with criteria api |
2 |
4912 |
Thu, 28 February 2013 15:28 By: Mathias Hauser |
A non-read-only mapping must be defined for the sequence number field sequencing problem |
4 |
10920 |
Thu, 28 February 2013 14:46 By: Chris Delahunt |
JPA-RS problem: java.lang.ClassCastException: java.util.ArrayList cannot be cast... java.lang.ClassCastException: java.util.ArrayList cannot be cast to org.eclipse.persistence.internal.descriptors.PersistenceObject |
10 |
21575 |
Thu, 28 February 2013 09:47 By: Daniel Szalay |
ClassWeaver generates buggy code ? By: J LM on Tue, 26 February 2013 |
1 |
3154 |
Wed, 27 February 2013 14:04 By: J LM |
