Home » Archived » Buckminster » Product export fails for macosx / cocoa / x86 with Buckminster 3.6 (FileNotFoundException: /tmp/p2.b
Product export fails for macosx / cocoa / x86 with Buckminster 3.6 (FileNotFoundException: /tmp/p2.b [message #511121] Fri, 29 January 2010 14:20 Go to previous message
my Mail build example http://github.com/ralfebert/com.example.mail.buckminster
runs fine with Buckminster 3.5 but fails to export the product for macosx /
cocoa / x86 with Buckminster 3.6 (which I'm trying out for the testing support).
Any ideas what could cause this? Should a 3.5 application with 3.5 target
platform be buildable with the 3.6 tooling out of the box?
INFO: perform '-D' 'target.os=macosx' '-D' 'target.ws=cocoa' '-D'
'target.arch=x86' 'com.example.mail.site#create.product.zip'
INFO: [start com.example.mail:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO: [end com.example.mail:osgi.bundle$1.0.0.qualifier#eclipse.build]
INFO: [start com.example.mail:osgi.bundle$1.0.0.qualifier#source.bundle.j ar]
INFO: [end com.example.mail:osgi.bundle$1.0.0.qualifier#source.bundle.j ar]
INFO: [start com.example.mail.site:eclipse.feature$1.0.0.qualifier#site.p 2]
java.io.FileNotFoundException:
/tmp/p2.brandingIron1262719610169768451/mail.app/Contents/Ma cOS/mail.ini (No
such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:137)
org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zipFi le(FileUtils.java:357)
at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(F ileUtils.java:286)
at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.zip(F ileUtils.java:251)
org.eclipse.equinox.p2.publisher.AbstractPublisherAction.pub lishArtifact(AbstractPublisherAction.java:481)
org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAc tion.publishExecutableIU(EquinoxExecutableAction.java:122)
org.eclipse.equinox.p2.publisher.eclipse.EquinoxExecutableAc tion.perform(EquinoxExecutableAction.java:65)
org.eclipse.equinox.p2.publisher.eclipse.ApplicationLauncher Action.perform(ApplicationLauncherAction.java:67)
org.eclipse.equinox.p2.publisher.eclipse.ProductAction.perfo rm(ProductAction.java:95)
at org.eclipse.buckminster.pde.tasks.ProductAction.perform(Prod uctAction.java:137)
at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher .java:172)
at org.eclipse.buckminster.pde.tasks.P2SiteGenerator.run(P2Site Generator.java:321)
org.eclipse.buckminster.pde.tasks.P2SiteGenerator.internalPe rform(P2SiteGenerator.java:427)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:201)
org.eclipse.buckminster.core.internal.actor.PerformManager$D irectActionInvocation.execute(PerformManager.java:151)
org.eclipse.buckminster.core.internal.actor.PerformManager.i nternalPerform(PerformManager.java:507)
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:335)
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:350)
at org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:118)
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:191)
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
INFO: [end com.example.mail.site:eclipse.feature$1.0.0.qualifier#site.p 2]
INFO: [start com.example.mail.site:eclipse.feature$1.0.0.qualifier#create .product]
[ant] /opt/buckminster-3.6/plugins/org.eclipse.equinox.launcher_1. 1.0.v20091116.jar
[ant]
file:/opt/hudson/jobs/mail/workspace/buckminster.output/com. example.mail.site_1.0.0-eclipse.feature/site.p2/
[ant]
/opt/hudson/jobs/mail/workspace/buckminster.output/com.examp le.mail.site_1.0.0-eclipse.feature/mail.cocoa.macosx.x86
[ant] An error occurred while collecting items to be installed
[ant] session context was:(profile=MailProfile,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect,
operand=, action=).
[ant] No repository found containing:
binary,com.example.mail.product.executable.cocoa.macosx.x86, 1.0.0
[ant] Application failed, log file location:
/opt/buckminster-3.6/configuration/1264810247618.log
ERROR: org.eclipse.core.runtime.CoreException:
/opt/hudson/jobs/mail/workspace/com.example.mail.site/build/ product.ant:22: Java
returned: 13
returned: 13
org.eclipse.buckminster.ant.AntRunner.handleInvocationTarget Exception(AntRunner.java:189)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:352 )
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(A ntActor.java:281)
Caused by:
returned: 13
at org.apache.tools.ant.taskdefs.Java.execute(Java.java:108)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:662)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
at sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:344 )
... 25 more
returned: 13
Caused by:
Archiving artifacts
Finished: FAILURE
http://www.ralfebert.de/blog/eclipsercp/
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:variables not replaced in generator.buildTimestamp.format
Next Topic:Custom zip filename in CSPECX
Current Time: Sun Aug 31 09:04:25 EDT 2025
Powered by FUDForum. Page generated in 0.03269 seconds
