Scrapbook page - Code assist not working... [message #267732] |
Thu, 15 January 2009 06:12 |
Originally posted by: zerocode.gmx.com
Question: I'm running 3.4.1 to dev in Java. In a new project I wanted to
create a Scrapbook page to run some tests. I added my project in to test
some code. That is when I noticed code suggestion tool (Ctrl+Space)
after typing "new", "new - create new object" doesn't appear.
Re: Scrapbook page - Code assist not working... [message #267759 is a reply to message #267745] |
Fri, 16 January 2009 01:38 |
Darin,
Thank you very much for your response. I was following Eclipse and Java
for Total Beginners video's they show using code assist with a
scrapbook. When I hit (CTRL+Space) it shows Java Class Objects.
http://www.eclipse.org/resources/resource.php?id=392
The videos are great. I had done it once but lost my laptop. After a
reinstall and a new HD it did not work. :(
Any ideas?
Darin Swanson wrote:
> I do not believe scrapbook pages support templates.
> The proposal for "new - create new object" is a code assist template
> HTH
> Darins
> http://runnerwhocodes.blogspot.com
> "Jimmy Dean" <zerocode@gmx.com> wrote in message
> news:gkmk4h$g6t$1@build.eclipse.org...
>> some code. That is when I noticed code suggestion tool (Ctrl+Space) after
Re: Scrapbook page - Code assist not working... [message #267808 is a reply to message #267804] |
Sat, 17 January 2009 02:55 |
Lession 9 Time: 2min 27Sec
in the scrapbook he types in:
new(Then CTRL+SPACE and his shows new - create new object, NEW -
com.sun.org.acpache Etc)
> Which lesson?
> Darins
> news:gkooec$86t$1@build.eclipse.org...
>> Darin,
>> for Total Beginners video's they show using code assist with a scrapbook.
>> Any ideas?
>>> HTH
>>> Darins
FUDForum. Page generated in 0.10054 seconds
