Eclipse and jax-ws [message #255929] |
Fri, 09 May 2008 10:21 |
Originally posted by: stivazzi.gmail.com
Hello.
I need to create an application using IDE Myeclipse.
i first tried using axis2, with wsdl2java plugin, and everything worked
fine.
but this is an encoded wsdl and axis2 does not support encoding
So I decided for JAX-WS2.0.
Does myeclipse support JAX-WS 2.0?
Trying to create WEB services project using Myeclipse, it always wants me
to use XFire, but i want to use JAX-WS 2.0
Is there a plugin like the one i used with axis2 for jax-ws?
Thanks in advance
Andy
Re: Eclipse and jax-ws [message #255944 is a reply to message #255929] |
Fri, 09 May 2008 10:40 |
Andy,
I suspect it's best to use the resources available at
http://www.myeclipseide.com/ to ask this question.
andy wrote:
> Hello.
> worked fine.
> me to use XFire, but i want to use JAX-WS 2.0
> Thanks in advance
> Andy
Re: Eclipse and jax-ws [message #255972 is a reply to message #255929] |
Fri, 09 May 2008 14:28 |
Andy, you might find the following article of help, it applies to
eclipse in general so should also work with MyEclipse.
https://jax-ws.dev.java.net/guide/Developing_with_Eclipse.ht ml
Dave
FUDForum. Page generated in 0.07975 seconds
