Why can not tomcat be started from within eclipse ? [message #226848] |
Sun, 18 January 2009 11:57 |
Tom Messages: 4 Registered: July 2009 |
Junior Member |
My environment:
Windows XP, SP3
Eclipse 3.4.1 (and I have also tried with 3.4)
Java JRE configured in eclipse: version 1.6.0_02
Tomcat 6.0.18 (and I have also tried with versions 6.0.14 and 6.0.16)
I have downloaded tomcat (and have even tried with three version 6.0.14,
6.0.16 and 6.0.18) and then configured eclipse (3.4 and have now also
tried with eclipse 3.4.1) to use some of these tomcat servers, but with no
luck.
I have configured them with Window-Preferences-Server-Runtime
Environments, and then pointed to the root directory where I unzipped
tomcat, as described here:
http://www.vogella.de/articles/EclipseWTP/article.html#termi nology
though with the difference that I am using tomcat 6, and also I use
jre1.6.0_02.
When I go to Window-Show View-Servers, and then rightclick some of my
configured tomcat servers (e.g. 6.0.18) then it looks fine, i.e. the state
says "Started" and I see no exceptions in the "Console" view, but it looks
like this:
2009-jan-18 12:20:40 org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path: D:\Program
Files\Java\jre1.6.0_02\bin;.;D:\WINDOWS\Sun\Java\bin;D:\WIND OWS\system32;D:\WINDOWS;D:/Program
Files/Java/jre1.6.0_02/bin/client;D:/Program
Files/Java/jre1.6.0_02/bin;D:\ruby\bin;D:\PHP\;D:\Perl\site\ bin;D:\Perl\bin;D:\WINDOWS\system32;D:\WINDOWS;D:\WINDOWS\Sy stem32\Wbem;D:\Program
Files\ATI
Technologies\ATI.ACE\Core-Static;D:\Sun\SDK\bin;D:\Sun\SDK\j dk\bin;D:\Program
Files\MySQL\MySQL Server 5.0\bin;D:\Program
Files\TortoiseSVN\bin;D:\Program
Files\PostgreSQL\8.3\bin;D:\gtk\bin;D:\Program Files\Common
Files\GTK\2.0\bin;D:\groovy\bin;D:\grails-1.0.3\grails\bin;
2009-jan-18 12:20:42 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
2009-jan-18 12:20:42 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1471 ms
2009-jan-18 12:20:42 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
2009-jan-18 12:20:42 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
2009-jan-18 12:20:42 org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
2009-jan-18 12:20:42 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
2009-jan-18 12:20:42 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/16 config=null
2009-jan-18 12:20:42 org.apache.catalina.startup.Catalina start
INFO: Server startup in 169 ms
Then when I try my web browser with the URL
http://localhost:8080/
I get the message
"HTTP Status 404 - /
description The requested resource (/) is not available."
However, when I start the same tomcat (e.g. 6.0.18) by using the command
prompt and executing
"D:\apache-tomcat-6.0.18\bin\startup.bat"
then I can indeed go to
without a problem...
So, to sum up, my problem is that I can not start tomcat from within
eclipse, while eclipse does not seem to give me any clues about what is
wrong (i.e. no exception message, and it displays a green "Started" state
as everything would be okay... while the web browser message obviously
does not agree...)
/ Tom
Re: Why can not tomcat be started from within eclipse ? [message #226854 is a reply to message #226848] |
Sun, 18 January 2009 14:55 |
Originally posted by: dcarver.starstandard.org
Have you reviewed the Tomcat FAQ?
http://wiki.eclipse.org/WTP_Tomcat_FAQ
It might have your answer.
Dave
Tom wrote:
> My environment:
> Windows XP, SP3
> no luck.
> jre1.6.0_02.
> state says "Started" and I see no exceptions in the "Console" view, but
> it looks like this:
> Files\ATI
> I get the message
> prompt and executing "D:\apache-tomcat-6.0.18\bin\startup.bat"
> then I can indeed go to http://localhost:8080/
> state as everything would be okay... while the web browser message
> obviously does not agree...)
> / Tom
FUDForum. Page generated in 0.04106 seconds
