Re: integrating ocl with emf [message #22053] |
Wed, 09 May 2007 11:00 |
Aashu,
I'm forwarding your question to the OCL newsgroup by adding it to the
"to" list in the reply. Please use that newsgroup for asking OCL in the
future.
aashu aggarwal wrote:
> i m trying to integrate my emf model with ocl
> in validator class functions defined in ecore are getting created
> my code is:
> OCLExpression oclExpr=null;
> <b>IOCLHelper helper=HelperUtil.createOCLHelper()</b>
> helper.setContext(EmployeePackage.Literals.EMPLOYEE);
> when the highlighted line is executed program exits
> can anyone help me ?
> what is the reason for this?
> TIA
> aashu
Re: integrating ocl with emf [message #22272 is a reply to message #22053] |
Wed, 09 May 2007 12:34 |
Hi, Aashu,
What do you mean by "program exits"? Are you running in an Eclipse
instance, or stand-alone? Do you see any exception in the Eclipse log?
(or, if stand-alone, a stack trace on the console?)
Without any diagnostic information, I won't be able to help much. I can't
think of a good reason why that statement should cause a stable JVM
implementation to abort, even if (for example) a class couldn't be loaded.
Christian
Ed Merks wrote:
> Aashu,
> future.
>> my code is:
>> TIA
>> aashu
FUDForum. Page generated in 0.04306 seconds
