Re: SSE editor content [message #226022 is a reply to message #226002] |
Tue, 06 January 2009 17:52 |
Originally posted by: dcarver.starstandard.org
A sample file might help and what is the other editor?
You haven't given us enough information in order to help diagnose what
is happening.
Dave
Navatski Siarhei wrote:
> Hi All.
> Is it possible that the SSE editor displays the content, which is
> different from his document?
> example:
> the file contains that text:
> <tag></tag>
> SSE editor displays:
> <tag>
> bla-bla-bla
> </tag>
> and when I open this file in the other editor I see:
> <tag></tag>
Re: SSE editor content [message #226090 is a reply to message #226002] |
Tue, 06 January 2009 23:42 |
> Hi All.
> example:
> <tag></tag>
> <tag>
> bla-bla-bla
> </tag>
> <tag></tag>
Not unless you have code folding enabled in that other editor. You
should see the full text if you open the file with the Text Editor
while it's open in the SSE editor.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: SSE editor content [message #226215 is a reply to message #226196] |
Thu, 08 January 2009 15:33 |
As Nitin said, it sounds like code folding. Which you just need to turn
on for the SSE Editor, by default all the tags will be open, even with
code folding enabled. This is under
Preferences->General->Editor->Structured Text Editor
Dave
> The other editor is Text Editor for example.
> It is no problem, it is feature which I want to realize. For example,
> depending on the name tag, I want to show a some comment in my editor
> after the tag. But this comment should not be kept in the file
> (document) and not be display in other editor.
> David Carver пишет:
>> is happening.
>> Dave
>>> Hi All.
>>> example:
>>> <tag></tag>
>>> <tag>
>>> bla-bla-bla
>>> </tag>
>>> <tag></tag>
FUDForum. Page generated in 0.03968 seconds
