Home » Eclipse Projects » GEF » Construct Tabbed Properties at Runtime
Construct Tabbed Properties at Runtime [message #225931] Fri, 03 November 2006 13:45 Go to next message
Originally posted by: something.eclipse.org
I have a GEF view for which I am trying to provide tabbed
properties. However, since everything is data driven, I won't know the
tabs I need until runtime. Is there a way to provide tabs without using
the extension points?
thanks!
adam
Re: Construct Tabbed Properties at Runtime [message #225946 is a reply to message #225931] Fri, 03 November 2006 14:10 Go to previous messageGo to next message
AdamC 写道:
> Hello,
> thanks!
> adam
No, TabbedProperties for special design target, that's design first and
use later, no design and no use, do designed and no changed.
So its api is same like cannot close view, fixed again changing.
Qinxian
Re: Construct Tabbed Properties at Runtime [message #225954 is a reply to message #225931] Fri, 03 November 2006 14:18 Go to previous messageGo to next message
Hi Adam,
Unfortunately the answer is no, no dynamic support.
As a workaround, what others have done is to have tabs for the domain
objects and then one section in the tab that changes dynamically and is
refreshed by calling composite.layout().
For example, your data model has a box.
When the box is selected on the diagram, the box tab and box section are
displayed. In the box section, you change the widgets in the composite based
on the real state of the box in your data model and call layout().
Let me know if this helps. If you can provide any more information on
"everything is data driven" it probably would help.
Cheers...
Anthony
"AdamC" <something@eclipse.org> wrote in message
news:eig2p7$7lm$2@utils.eclipse.org...
> Hello,
> I have a GEF view for which I am trying to provide tabbed properties.
> However, since everything is data driven, I won't know the tabs I need
> until runtime. Is there a way to provide tabs without using the extension
> points?
> thanks!
> adam
Re: Construct Tabbed Properties at Runtime [message #225959 is a reply to message #225954] Fri, 03 November 2006 14:27 Go to previous messageGo to next message
Thanks Anthony. I am using an xml (EMF) model, so I have a field called
"Category" that I wanted to use to construct the tabs. Since it sounds
like this won't work, I will look into using a multi-level hierarchy
instead of tabs. BTW - thanks so much for the article! Lately, it
seems like there is a shortage of updated Eclipse info. I can't even
find any new books in the pipeline.
Anthony Hunter wrote:
> Hi Adam,
> Cheers...
> Anthony
>> Hello,
>> points?
>> thanks!
>> adam
Re: Construct Tabbed Properties at Runtime [message #225966 is a reply to message #225959] Fri, 03 November 2006 14:54 Go to previous messageGo to next message
--------------050206060803060107070209
Adam,
Coincidentally I was just playing this morning (it's Think Friday) to
learn how tabbed properties worked and I too found Anthony's example to
be extremely useful. I quickly reached the same conclusion as expressed
here: you can't generate the stuff dynamically. And looking at the
implementation, it can't easily be changed to support that. I was
chatting with Anthony just now, after reading this posting and he
pointed out that there is a bugzilla open for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131855
But it's just not very likely that the resource to do this will be
available. :-(
> called "Category" that I wanted to use to construct the tabs. Since
> it sounds like this won't work, I will look into using a multi-level
> hierarchy instead of tabs. BTW - thanks so much for the article!
> Lately, it seems like there is a shortage of updated Eclipse info. I
> can't even find any new books in the pipeline.
>> Hi Adam,
>> is refreshed by calling composite.layout().
>> are displayed. In the box section, you change the widgets in the
>> composite based on the real state of the box in your data model and
>> call layout().
>> Cheers...
>> Anthony
>>> Hello,
>>> the tabs I need until runtime. Is there a way to provide tabs
>>> without using the extension points?
>>> thanks!
>>> adam
<html>
<head>
</head>
Adam,<br>
<br>
be extremely useful.&nbsp; I quickly reached the same conclusion as
expressed here: you can't generate the stuff dynamically.&nbsp; And looking
at the implementation, it can't easily be changed to support that.&nbsp; I
was chatting with Anthony just now, after reading this posting and he
pointed out that there is a bugzilla open for this:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=131855">https://bugs.eclipse.org/bugs/show_bug.cgi?id=131855</a><br>
</blockquote>
available.&nbsp; :-(<br>
<br>
<br>
AdamC wrote:
<blockquote cite="mideig56n$mek$1@utils.eclipse.org" type="cite">Thanks
Anthony.&nbsp; I am using an xml (EMF) model, so I have a field called
"Category" that I wanted to use to construct the tabs.&nbsp; Since it sounds
instead of tabs.&nbsp; BTW - thanks so much for the article!&nbsp; Lately, it
seems like there is a shortage of updated Eclipse info.&nbsp; I can't even
<br>
<br>
<br>
<blockquote type="cite">Hi Adam,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
call layout().
<br>
<br>
<br>
<br>
Cheers...
<br>
Anthony
<br>
<br>
"AdamC" <a class="moz-txt-link-rfc2396E" href="mailto:something@eclipse.org">&lt;something@eclipse.org&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:eig2p7$7lm$2@utils.eclipse.org">news:eig2p7$7lm$2@utils.eclipse.org</a>...
<br>
<blockquote type="cite">Hello,
<br>
&nbsp;&nbsp; I have a GEF view for which I am trying to provide tabbed
tabs I need until runtime.&nbsp; Is there a way to provide tabs without
<br>
<br>
thanks!
<br>
adam </blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050206060803060107070209--
Re: Construct Tabbed Properties at Runtime [message #225988 is a reply to message #225966] Fri, 03 November 2006 16:20 Go to previous messageGo to next message
Thanks for the info. In this case, I'm just glad that I'm not stuck and
have a fall-back. I'm looking at implementing a 3 level hierarchy
instead of using tabs.
adam
Ed Merks wrote:
> Adam,
> available. :-(
>>> Hi Adam,
>>> call layout().
>>> Cheers...
>>> Anthony
>>>> Hello,
>>>> thanks!
>>>> adam
Re: Construct Tabbed Properties at Runtime [message #236908 is a reply to message #225931] Wed, 11 July 2007 16:51 Go to previous messageGo to next message
Hey Anthony,
I just saw your contribution to the bug on this. Thanks - I can
really use this and can't wait to try it out.
adam
AdamC wrote:
> Hello,
> the tabs I need until runtime. Is there a way to provide tabs without
> thanks!
> adam
Re: Construct Tabbed Properties at Runtime [message #239816 is a reply to message #236908] Fri, 16 November 2007 09:10 Go to previous messageGo to next message
AdamC wrote:
> Hey Anthony,
> adam
> AdamC wrote:
>> Hello,
>> thanks!
>> adam
Which bug?
Re: Construct Tabbed Properties at Runtime [message #239863 is a reply to message #239816] Sun, 18 November 2007 06:43 Go to previous message
On Fri, 16 Nov 2007 15:10:48 +0100, Maarten Meijer wrote:
> Which bug?
I'm guessing it's this one.
Rem
Previous Topic:Is this a bug, the right curly bracket disappear in GEF sample text editor
Next Topic:getTargetingConditional on SelectionTool
Current Time: Thu Jul 10 01:50:20 EDT 2025
Powered by FUDForum. Page generated in 0.12794 seconds
