Re: TTS Portuguese Characters [message #22453 is a reply to message #22031] |
Fri, 17 April 2009 20:41 |
Randy Childers Messages: 121 Registered: July 2009 |
Hi Fernando--
This issue should be fixed; the application's XML file now handles the full
UTF-8 characterset. Update your source from the VTP repository and
recompile; if you can't do this, let me know and I'll send you a current set
of the plugins directly.
Randy
On 3/13/09 4:37 PM, in article C5E03C44.3FED%randy@openmethods.com, "Randy
Childers" <randy@openmethods.com> wrote:
> Hi Fernando--
> I believe this is an encoding issue in regards to the way the CallDesign.xml
> file is being saved. We're currently working on a separate issue which may,
> inadvertently, resolve this problem. I'll make an announcement on this list
> if it does.
> Randy Childers
> OpenMethods
> On 3/12/09 6:07 PM, in article
> 55b3ca9b8b40925d3fdf4d435d1f9c6c$1@www.eclipse.org, "Fernando Pesssoa"
> <fernandojpessoa@gmail.com> wrote:
>> For Portuguese Language
>> when I try to use a TTS prompts with this Latin characters(é,ã) ,I have a
>> wrong exporting WAR. When I export the Call Flow as a Web Application I
>> get the error: null Reason: null!!!!
>> How can I configure this in OpenVxml 3.0?
>> Thanks,
Re: TTS Portuguese Characters [message #578431 is a reply to message #22031] |
Hi Fernando--
Randy
> Hi Fernando--
> if it does.
> Randy Childers
> OpenMethods
>> Thanks,
FUDForum. Page generated in 0.04428 seconds
