Re: eclipse crashes when code complete is invoked [message #224828 is a reply to message #224806] |
Sun, 26 February 2006 20:01 |
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
Muhammad Momin Rashid a écrit :
> My eclipse crashes as soon as I invoke the code complete feature in a
> java file.
> I am using eclipse 64 bit build for 3.2 m5a, same thing used to happen
> with build 3.2 m5.
> I was using 64 bit jdk 1.5 release 6, I even upgraded to latest version
> of 64 bit jdk 1.6 (beta). The problem didn't go away.
> The 64 bit build of eclipse 3.2 m4 seems to work fine in the scenario,
> but I do observe crashes here and there, especially when I am building
> my project for deployment.
Could you please provide the VM dump?
This could help to find out what component is concerned with this issue.
I would tend to say that the problem might come from SWT.
Olivier
Re: eclipse crashes when code complete is invoked [message #224860 is a reply to message #224846] |
Mon, 27 February 2006 14:51 |
> Attached is the VM dump file, hope it helps.
Seems to be a problem with SWT.
j org.eclipse.swt.internal.gtk.OS._g_object_set(J[BIJ)V+0
j org.eclipse.swt.internal.gtk.OS.g_object_set(J[BIJ)V+12
j org.eclipse.swt.widgets.Table.cellDataProc(JJJJJ)J+382
j org.eclipse.swt.widgets.Display.cellDataProc(JJJJJ)J+25
Please open a bug report against SWT and provide build id, the VM dump
and steps to reproduce.
Olivier
FUDForum. Page generated in 0.05129 seconds
