rotate Figure & MouseListener [message #224443] |
Mon, 16 October 2006 12:26 |
Originally posted by: mouna.feki.siemens.com
I drew a IFigur . Now my goal is the following:
If I press two times on this Figure, then she will be rotated.
My Problem is: I dŽont know how to call the graphics elements in the
method
public void mouseDoubleClicked(MouseEvent e){}
I hofe that someone me help.
Thanks in Advance
Here is my Code:
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.MouseEvent;
import org.eclipse.draw2d.MouseListener;
public class CreateGleis extends Figure implements MouseListener{
protected void paintFigure(Graphics graphics)
graphics.pushState();
int width = getBounds().width;
int height = getBounds().height;
int x = getBounds().x;
int y = getBounds().y;
graphics.setLineWidth(3);
//horizontal line
graphics.drawLine( x , y +height/2 , x+width , y +height/2 );
addMouseListener(this);
graphics.popState();
public void mousePressed(MouseEvent e) {
System.out.println("mousePressed");
public void mouseReleased(MouseEvent e) {
System.out.println("mouseReleased");
public void mouseEntered(MouseEvent e) {
System.out.println("mouseEntered");
public void mouseExited(MouseEvent e) {
System.out.println("mouseExited");
public void mouseDoubleClicked(MouseEvent e) {
//graphics.rotate(45);
Re: rotate Figure & MouseListener [message #224476 is a reply to message #224443] |
Mon, 16 October 2006 15:42 |
Originally posted by: ingo.koch[nospam].sap.com
Hi Mouna,
save the angle of your figure in a variable and rotate the figure
respectively in the paint method.
you cannot access the graphics object outside the paint methods.
Ingo
"Mouna Feki" <mouna.feki@siemens.com> wrote in message
news:34550f637f3b05fab63301e543f21f70$1@www.eclipse.org...
> My Problem is: I d
Re: rotate Figure & MouseListener [message #224491 is a reply to message #224476] |
Mon, 16 October 2006 16:01 |
But schould be not the Transformation written in the "
mouseDoubleClicked(MouseEvent e)" Method.
If i write rotate in the paint Methode, then will be the figure rotated
(one times and without DoubleClick)
Are there another solution, to solve this Problem?
Mouna
Re: rotate Figure & MouseListener [message #224976 is a reply to message #224553] |
Tue, 24 October 2006 05:45 |
Originally posted by: geetesh.jain.gmail.com
Hi Mouna,
Even iam trying to add a rotate function for one of my element. But didnt
got any success in it.
I would really appreciate if you Can share your code if its working fine.
Geetesh
FUDForum. Page generated in 0.04131 seconds
