Request: KeyBindings [message #224427] |
Thu, 08 April 2004 11:01 |
Standard New (3.0) key bindings introduced in 3.0M7 are very usefull,
please make them available in M9.
Thanks in advance,
Hubert.
Re: Request: KeyBindings [message #224809 is a reply to message #224427] |
Thu, 08 April 2004 19:30 |
stonecracker@earthlink.net Messages: 5 Registered: July 2009 |
Junior Member |
In article <c53b4l$scp$1@eclipse.org>, user@domain.invalid wrote:
> Hello,
> Thanks in advance,
> Hubert.
Word in this newsgroup is that the NEW keybindings are officially out
due to lack of time/resources etc. However, Douglas Pollock has supplied
a
plugin that will re-install the keybindings from M7 into M8. That
package is here:
http://www.magma.ca/~pollockd/despumate/org.eclipse.ui.keys. zip
Installing this package will make the M7 keybindings available in M8.
Sadly, NO KEYBINDINGS OTHER THAN THE DEFAULT WORK in M8, so the package
will not do you much good. This problem has been identified as bug 56240
and can be found here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=56240+
End of keybinding story, if you want the keybindings, your only options
are to get the code and fix it yourself, or to go VOTE FOR THE BUG, and
hope it gets fixed.
FUDForum. Page generated in 0.03832 seconds
