Re: How to center the table and graph? [message #224394 is a reply to message #224301] |
Mon, 12 March 2007 21:29 |
Eric wrote:
> Greetings,
> I am currently using the BIRT 2.1.2. I have problem
> centering the table and graph and displaying the in the middle of web
> page. I used to get around with this by placing the grid and set the
> width to be 100%. After that, everything is laying on the center.
> Right now, I have migrated some of my reports from 2.0.1 to 2.1.2. All
> centerd reports are shifted to the left. Is there any way I can center
> the report?
> Please advise. Thank you.
Is the grid cell set with Vertical alignment = Middle and Text alignment
= Center?
Jason
Re: How to center the table and graph? [message #224697 is a reply to message #224450] |
Tue, 13 March 2007 16:15 |
Eric wrote:
> Jason Weathersby wrote:
>> Eric wrote:
>>> Greetings,
>>> All centerd reports are shifted to the left. Is there any way I can
>>> center the report?
>> alignment = Center?
>> Jason
> Jason,
> Yes, I have both properties set up to be Middle and Center. Please
> see the attached sample code. Please advise. Thank you.
> <!-- Written by Eclipse BIRT 2.0 -->
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.1.2.v20070205-1728 Build <20070205-1728></property>
> <property name="units">in</property>
> <property name="comments">Copyright (c) 2006 <<Your Company
> Name here>></property>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <grid id="4">
> <property name="textAlign">center</property>
> <property name="verticalAlign">middle</property>
> <property name="width">100%</property>
> <column id="5"/>
> <row id="6">
> <property name="height">2.28125in</property>
> <cell id="7">
> <text id="8">
> <property name="contentType">auto</property>
> <text-property
> name="content"><![CDATA[Hello!!]]></text-property>
> </text>
> <table id="9">
> <column id="16"/>
> <header>
> <row id="10">
> <cell id="11"/>
> </row>
> </header>
> <detail>
> <row id="12">
> <cell id="13">
> <label id="17">
> <text-property
> name="text">Hello</text-property>
> </label>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="14">
> <cell id="15"/>
> </row>
> </footer>
> </table>
> </cell>
> </row>
> </grid>
> </body>
> </report>
Is the issue that the two do not line up?
Jason
Re: How to center the table and graph? [message #224903 is a reply to message #224815] |
Tue, 13 March 2007 18:59 |
>>>> Eric wrote:
>>>>> Greetings,
>>>>> web page. I used to get around with this by placing the grid and
>>>>> set the width to be 100%. After that, everything is laying on the
>>>>> center.
>>>>> center the report?
>>>> alignment = Center?
>>>> Jason
>>> Jason,
>>> Please see the attached sample code. Please advise. Thank you.
>>> <?xml version="1.0" encoding="UTF-8"?>
>>> version="3.2.6" id="1">
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> <text-property
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <grid id="4">
>>> <column id="5"/>
>>> <row id="6">
>>> <cell id="7">
>>> <text id="8">
>>> <text-property
>>> </text>
>>> <table id="9">
>>> <column id="16"/>
>>> <header>
>>> <row id="10">
>>> <cell id="11"/>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="12">
>>> <cell id="13">
>>> <label id="17">
>>> <text-property
>>> </label>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="14">
>>> <cell id="15"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </cell>
>>> </row>
>>> </grid>
>>> </body>
>>> </report>
>> Jason
> Jason,
> This is just an example to show after setting the textAlign to
> center and verticalAlign to middle the elements inside the grid are
> supposed disply in the center of the page in the browser but it is not.
> I have done this on BIRT 2.0.1 with table and other elements display in
> the center of page using grid.
> Is there any way I can display the element in the center by setting grid
> width in 100% and textAlign to center?
This looks centered in my browser. Can you take a screenshot and
explain where you want it?
Jason
FUDForum. Page generated in 0.03048 seconds
