Home » Modeling » GMF (Graphical Modeling Framework) » same instance of two or more EditParts
same instance of two or more EditParts [message #223983] Thu, 02 April 2009 03:39 Go to next message
Hello all.
In my Canvas, I have as TopNodes:
- Tasks, so I have a correspondent TaskEditPart
- Methods, as MethodEditPart
Then, a Method can also have Tasks as its children. Not new Task, but
some of the ones defined in the Canvas and I need them to show the same.
And when for example I modify something of the Task inside the Method, I
also want that change to happen in the top node Task. And the opposite too.
I was thinking of using the same instance of the EditPart, with a
different View maybe, but I don't really know if this is possible --and
if it's possible, if that's a solution.
Another option might be to use a new EditPart that contains a reference
to the one in the top and synchronize by myself every change made in one
to the other.
Has someone dealt with a similar situation? Having repeated elements in
a Diagram and want them to behave the same.
Thanks.
Re: same instance of two or more EditParts [message #224054 is a reply to message #223983] Thu, 02 April 2009 06:54 Go to previous message
Hello nottake,
Are you wriring this code manually? If you are generating code then just
don't care about EditParts - generator will create everything for you..
Alex Shatalin
Previous Topic:Probléme of link constraint
Next Topic:Graphic representation of an element with regard to the value of its attribute
Current Time: Tue Jul 15 02:10:03 EDT 2025
Powered by FUDForum. Page generated in 1.05100 seconds
