Home » Language IDEs » C / C++ IDE (CDT) » file search
file search [message #221817] Tue, 12 August 2008 10:02 Go to next message
when doing a file search with Eclipse (with C/C++ Dev. stuff installed), I
would expect that when specifying "workspace" as search area, that the
search goes through all subfolders in workspace. Obviously this is not the
case, because when searching for a string that I copied from a file deeply
rooted in a folder in workspace there is no hit.
Worse: Even when searching for a string copied from e. g.
workspace/myfile.c there is no hit. Do I get it wrong or is this a bug?
Let me add that when using "remote Search" - and the subfolders-box
checked - there are hits. I this "remote search" the only method to search
through a folder and optionally its subfolders?
Robert
Re: file search [message #221923 is a reply to message #221817] Wed, 13 August 2008 07:57 Go to previous messageGo to next message
Robert wrote:
> Hi
> Robert
I never experienced any problems with the file search. Are you sure you
selected the corrected file type? Did you select 'regular expression' or
'case sensitive'? Is the text your are seraching in a derived file?
Are we talking about the search window that is invoked when you press
CTRL-H (in the menu select Search->File..)? (See
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/gettingStarted/qs-36a.htm)
I have never seen the option "remote search".
Axel
Re: file search [message #221945 is a reply to message #221923] Wed, 13 August 2008 10:23 Go to previous messageGo to next message
Axel Müller wrote:
> Robert wrote:
>> Hi
>> checked - there are hits. Is this "remote search" the only method to search
>> Robert
> Axel
Yes - the menu entry Search->File.. and in the same menu I also have the
entry Search->Remote..
I had copied my search string for this test from the file
/home/rwb/ecosws/arm_install/include/cyg/io/serial.h
where ecosws is the current workspace of Eclipse.
Then I called Search->File.., pasted my string - did NOT select regular
expression nor case sensitive, specified the file as *.h, selected scope
workspace and clicked search. Result: 0 hits -- strange.
Robert
Re: file search [message #221959 is a reply to message #221945] Thu, 14 August 2008 02:23 Go to previous messageGo to next message
Robert wrote:
> Axel Müller wrote:
>> Robert wrote:
>>> Hi
search
>>> Robert
>> Axel
> Robert
Is the file arm_install/include/cyg/io/serial.h or any parent folder
marked as derived (look at the properties)? By default, derived ressources
are excluded from search. In Eclipse 3.4 there is an option to include
derived ressources in the search.
If it still does not work then I guess it is a bug and you should file in
a bug report.
Axel
Re: file search [message #221980 is a reply to message #221959] Thu, 14 August 2008 10:38 Go to previous messageGo to next message
> a bug report.
> Axel
HEUREKA! It works. One has to check the "consider derived resources" and
then it finds the stuff. I simply had not checked the meaning of the term
"derived resources".
In fact, I still do not grasp the accurate meaning of this term. In my
case - the target file with the searched string was in a
sub-sub-...-folder of a folder in my current workspace. And the this
folder (with all its subfolders) was generated there by the ecos
configuration software. Derived resources? Certainly not derived by
Eclipse.. Anywhy - I am happy I now know how to do such searches. :-)
Robert
Re: file search [message #221985 is a reply to message #221980] Thu, 14 August 2008 11:03 Go to previous message
>> a bug report.
>> Axel
> Robert
The "derived" option informs Eclipse that this folder consists of
generated resources that should not be directly edited. E.g. these
resources are automagically created for every build (or new build) and do
not go to CVS.
Axel
Previous Topic:Allow save during build
Next Topic:Standard build issues
Current Time: Thu Jul 03 22:21:33 EDT 2025
Powered by FUDForum. Page generated in 0.49189 seconds
