Re: Eclipse writes to Dropbox folder [message #1302634 is a reply to message #1302561] |
Fri, 18 April 2014 21:27 |
alex alexander Messages: 3 Registered: April 2014 |
Junior Member |
Quote:What makes you say that Eclipse is creating those files?
Before running eclipse, i have set the %APPDATA% to a custom location.
Described files appear in that custom location, available only to eclipse.
Quote:Perhaps you have installed a third-party plugin that might be doing that?
No plugins, clean fresh install.
I probably should have mention it straight away, but now I realised opening a project from dropbox folder. However this still does not explain what's happening:
set APPDATA=...\eclipse\data
eclipse.exe
* open project from ...\UserFolder\Dropbox\Folder\Folder\Project1\ *
* new files appear in ...\eclipse\data\Dropbox\shellext\l *
I'm just trying to understand this behavior.
Thanks for reply,
[Updated on: Fri, 18 April 2014 21:28] Report message to a moderator
FUDForum. Page generated in 0.08385 seconds
