Creating watchpoints for global variables [message #1297083] |
Tue, 15 April 2014 12:04 |
Alan Rouse Messages: 2 Registered: July 2013 Location: UK |
Junior Member |
I use Eclipse to develop and debug firmware written in C for an ARM processor.
With the old Eclipse Indigo I was able to right-click in the Variables window then select Add Global Variables to be presented with a list of all global variables. When a global variable was in the Variables window I could right-click on it and select Add Watchpoint (C/C++) as required. If the variable was an array I could expand it and right-click on the required element to select a watchpoint.
This feature has been deleted from later versions of Eclipse. Now if I want to watch a global variable I can drag it from the editor window to the Expressions window. However, I can find no way of setting a watchpoint on a global variable. The documentation infers that I should be able to highlight it in the editor then select from the menu Run/Toggle watchpoint, but this option is always greyed out. Even if it wasn't, it wouldn't cover the case where I might want to set a watchpoint on an element of an array if the editor line read, for example Array[Index].
The newer versions of Eclipse offer many nice additional features, so I like using the latest Kepler. However, until I can resolve this issue I need to keep Indigo and switch between them, depending what I want to do.
FUDForum. Page generated in 0.08468 seconds
