Re: Unable to create Eclipse Dynamic web project!! Can anybody help?? [message #212049 is a reply to message #212020] |
Tue, 08 April 2008 11:29 |
Jasphior,
I see logged messages about "Caused by: java.lang.OutOfMemoryError".
Have you tried increasing the heap space allocated to the running JVM?
You might do that by editing eclipse.ini and changing -Xmx256m to a
significantly bigger value.
jasphior wrote:
> I'm using Eclipse Europa JEE 3.3.2 on fedora 8 with Java 6 & Tomcat 6...
> In eclipse when I try to create a Dynamic web project (selecting
> Dynamic web module 2.5 and java 6), the project is created only with
> the Java Facet added to the project without Dynamic web module!!
> I tried modifying the project with different versions of Dynamic Web
> module 2.5/2.4/2.3/2.3 but in vain...
> Also I downloaded Eclipse SDK for linux, WTP, EMF & GEF and tried
> again but the problem still persists...
> I also tried this as root user thinking there might be some
> access/privilege related issues but the problem still persists...
> I think I'm missing some thing in eclipse configuration/some XYZ...
> any help will be really useful...
> below is the eclipse log file:
> Thanks...
Re: Unable to create Eclipse Dynamic web project!! Can anybody help?? [message #212063 is a reply to message #212056] |
Tue, 08 April 2008 12:13 |
Jasphior,
You might still try increasing it, clearing the log (remove
<workspace>/.metadata/.log) and run again... I'm not sure if you need
to run eclipse.exe -clean to make the ini change take effect...
jasphior wrote:
> Hi Ed,
> I don't think thats due to the memory pbm, coz the sys has 2 GB RAM &
> has the heap space of allocated upto 512mb!
> Butm, I think there is some thing else likely to be configured in this
> system because, the same eclipse bundle is working on other systems
> with lower h/w configs...
> Anyways thanks, any further help 'll be really useful...
Re: Unable to create Eclipse Dynamic web project!! Can anybody help?? [message #212117 is a reply to message #212020] |
Tue, 08 April 2008 12:58 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
From your log, I think your problem is:
java.fullversion=GNU libgcj 4.1.2 20070925 (Red Hat 4.1.2-33)
I have never successfully run Eclipse using GNU Java on Linux. Instead,
I use a Sun Java distribution. I have always downloaded a JDK since it
is required by earlier versions of Tomcat. For Eclipse and Tomcat 6, a
JRE should be fine.
However, when using a Sun JDK or JRE, you will need to include
"-XX:MaxPermSize=256m" in the Eclipse startup VM arguments (append it to
the end of your eclipse.ini). Windows Eclipse distributions include
some special handling to automatically add this argument when run with a
Sun VM, but this doesn't appear to be included for Linux distributions.
It has to be addressed manually when using a Sun VM on Linux.
The eclipse.ini already includes standard heap size arguments which are
more than sufficient to create Dynamic Web Projects. Depending on what
you do, you may still find it necessary to increase them at some point.
Larry
> In eclipse when I try to create a Dynamic web project (selecting Dynamic
> web module 2.5 and java 6), the project is created only with the Java
> Also I downloaded Eclipse SDK for linux, WTP, EMF & GEF and tried again
> I think I'm missing some thing in eclipse configuration/some XYZ... any
> !SESSION 2008-04-08 11:01:41.779
> eclipse.buildId=M20080221-1800
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> Command-line arguments: -os linux -ws gtk -arch x86
> This is a continuation of log file /home/asd/workspace/.metadata/.bak_1.log
> Created Time: 2008-04-08 11:04:48.015
> !ENTRY org.eclipse.wst.common.modulecore 4 0 2008-04-08 11:04:48.015
> !MESSAGE Plug-in org.eclipse.jst.j2ee was unable to load class
> org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponen t.
> !STACK 1
> org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.jst.j2ee was
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager$ComponentImplDescriptor$1.run(ComponentImplManag er.java:212)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager$ComponentImplDescriptor.createFactory(ComponentI mplManager.java:205)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager.getComponentImplFactory(ComponentImplManager.jav a:87)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager.findFactoryForProject(ComponentImplManager.java: 125)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager.createFolder(ComponentImplManager.java:147)
> at
> org.eclipse.wst.common.componentcore.ComponentCore.createFol der(ComponentCore.java:111)
> at
> org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent. <init>(VirtualComponent.java:62)
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager.createComponent(ComponentImplManager.java:169)
> at
> org.eclipse.wst.common.componentcore.ComponentCore.createCom ponent(ComponentCore.java:63)
> at
> org.eclipse.jst.common.jdt.internal.classpath.FlexibleProjec tContainer.computeClasspathEntries(FlexibleProjectContainer. java:174)
> at
> org.eclipse.jst.common.jdt.internal.classpath.FlexibleProjec tContainer. <init>(FlexibleProjectContainer.java:122)
> at
> org.eclipse.jst.j2ee.internal.web.classpath.WebAppLibrariesC ontainer. <init>(WebAppLibrariesContainer.java:48)
> at
> org.eclipse.jst.j2ee.internal.web.classpath.WebAppLibrariesC ontainerInitializer.initialize(WebAppLibrariesContainerIniti alizer.java:34)
> at
> org.eclipse.jdt.internal.core.JavaModelManager.initializeCon tainer(JavaModelManager.java:2220)
> at
> org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:1546)
> at
> org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore .java:1571)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.isInClas spath(JavaModelListener.java:345)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.isInClas spath(JavaModelListener.java:297)
> at
> org.eclipse.jem.internal.adapters.jdom.JavaReflectionSynchro nizer.processJavaElementChanged(JavaReflectionSynchronizer.j ava:117)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.processD elta(JavaModelListener.java:108)
> at
> org.eclipse.jem.internal.adapters.jdom.JavaReflectionSynchro nizer.processDelta(JavaReflectionSynchronizer.java:341)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.processC hildren(JavaModelListener.java:75)
> at
> org.eclipse.jem.internal.adapters.jdom.JavaReflectionSynchro nizer.processChildren(JavaReflectionSynchronizer.java:334)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.processJ avaElementChanged(JavaModelListener.java:168)
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.processD elta(JavaModelListener.java:105)
> at
> at
> org.eclipse.jem.workbench.utility.JavaModelListener.elementC hanged(JavaModelListener.java:61)
> at
> org.eclipse.jem.internal.adapters.jdom.JavaReflectionSynchro nizer.elementChanged(JavaReflectionSynchronizer.java:263)
> at
> org.eclipse.jdt.internal.core.DeltaProcessor$3.run(DeltaProc essor.java:1552)
> at
> org.eclipse.jdt.internal.core.DeltaProcessor.notifyListeners (DeltaProcessor.java:1542)
> at
> org.eclipse.jdt.internal.core.DeltaProcessor.firePostChangeD elta(DeltaProcessor.java:1377)
> at
> org.eclipse.jdt.internal.core.DeltaProcessor.fire(DeltaProce ssor.java:1353)
> at
> org.eclipse.jdt.internal.core.DeltaProcessor.resourceChanged (DeltaProcessor.java:1916)
> at
> org.eclipse.jdt.internal.core.DeltaProcessingState.resourceC hanged(DeltaProcessingState.java:368)
> at
> org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:282)
> at
> org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:276)
> at
> org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
> at
> org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:311)
> at
> org.eclipse.core.internal.resources.Workspace.checkpoint(Wor kspace.java:365)
> at
> org.eclipse.ltk.core.refactoring.PerformChangeOperation$1.ru n(PerformChangeOperation.java:263)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
> at
> org.eclipse.ltk.core.refactoring.PerformChangeOperation.exec uteChange(PerformChangeOperation.java:306)
> at
> org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion.executeChange(UIPerformChangeOperation.java:109)
> at
> org.eclipse.ltk.core.refactoring.PerformChangeOperation.run( PerformChangeOperation.java:223)
> at
> org.eclipse.jdt.internal.ui.refactoring.RefactoringExecution Helper$Operation.run(RefactoringExecutionHelper.java:101)
> at
> org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:39)
> at
> org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:720)
> at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4466)
> at
> org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:87)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
> at
> org.eclipse.jdt.internal.ui.refactoring.RefactoringExecution Helper.perform(RefactoringExecutionHelper.java:178)
> at
> org.eclipse.jdt.internal.ui.refactoring.reorg.ReorgMoveStart er.run(ReorgMoveStarter.java:83)
> at
> org.eclipse.jdt.internal.ui.packageview.SelectionTransferDro pAdapter.handleDropMove(SelectionTransferDropAdapter.java:20 5)
> at
> org.eclipse.jdt.internal.ui.packageview.SelectionTransferDro pAdapter.drop(SelectionTransferDropAdapter.java:136)
> at
> org.eclipse.jdt.internal.ui.dnd.JdtViewerDropAdapter.drop(Jd tViewerDropAdapter.java:131)
> at
> org.eclipse.jdt.internal.ui.dnd.DelegatingDropAdapter$3.run( DelegatingDropAdapter.java:134)
> at
> org.eclipse.jdt.internal.ui.dnd.DelegatingDropAdapter.drop(D elegatingDropAdapter.java:132)
> at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :90)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1125)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1110)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:9 51)
> at org.eclipse.swt.dnd.DropTarget.drag_data_received(DropTarget .java:365)
> at org.eclipse.swt.dnd.DropTarget.Drag_Data_Received(DropTarget .java:246)
> org.eclipse.core.runtime.CoreException[1]:
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
> An error occurred while automatically activating bundle
> org.eclipse.jst.j2ee (112).
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
> at java.lang.ClassLoader.loadClass(libgcj.so.8rh)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.wst.common.componentcore.internal.util.Component ImplManager.createComponent(ComponentImplManager.java:159)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.internal.core.JavaModelManager$9.run(JavaMod elManager.java:2150)
> at
> org.eclipse.jdt.internal.core.JavaModelManager.initializeAll Containers(JavaModelManager.java:2166)
> at
> org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:1544)
> at
> at
> org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2558)
> at
> org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1848)
> at org.eclipse.jdt.core.JavaCore.initializeAfterLoad(JavaCore.j ava:3254)
> at
> org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob.r un(InitializeAfterLoadJob.java:35)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: org.osgi.framework.BundleException: Exception in
> org.eclipse.jst.j2ee.internal.plugin.J2EEPlugin.start() of bundle
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> ...37 more
> Caused by: java.lang.NoClassDefFoundError:
> org.eclipse.jst.j2ee.commonarchivecore.internal.helpers.Arch iveInit
> at java.lang.Class.initializeClass(libgcj.so.8rh)
> at
> org.eclipse.jst.j2ee.internal.plugin.J2EEPlugin.start(J2EEPl ugin.java:487)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
> at java.security.AccessController.doPrivileged(libgcj.so.8rh)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
> ...42 more
> <<No stacktrace available>>
> !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-04-08 11:04:48.017
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ...37 more
> at
> at
> at
> ...42 more
> !ENTRY org.eclipse.jdt.core 4 2 2008-04-08 11:04:48.024
> !MESSAGE Problems occurred when invoking code from plug-in:
> "org.eclipse.jdt.core".
> !STACK 0
> org.eclipse.wst.common.componentcore.internal.impl.WTPModule sResource
> at
> org.eclipse.wst.common.componentcore.internal.impl.WTPModule sResourceFactory.createResource(WTPModulesResourceFactory.ja va:64)
> at
> org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceFactory.doCreateResource(TranslatorResourceFactory.java:5 3)
> at
> org.eclipse.wst.common.internal.emf.resource.ReferencedXMIFa ctoryImpl.createResource(ReferencedXMIFactoryImpl.java:46)
> at
> org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.createResource(ProjectResourceSetImpl.java:92)
> at
> org.eclipse.wst.common.internal.emfworkbench.integration.Pro jectResourceSetEditImpl.createResource(ProjectResourceSetEdi tImpl.java:47)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:240)
> at
> org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:390)
> at
> org.eclipse.wst.common.internal.emfworkbench.WorkbenchResour ceHelper.getOrCreateResource(WorkbenchResourceHelper.java:38 4)
> at
> org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getResource(EditModel.java:684)
> at
> org.eclipse.wst.common.componentcore.internal.ModuleStructur alModel.getPrimaryResource(ModuleStructuralModel.java:303)
> at
> org.eclipse.wst.common.componentcore.internal.ModuleStructur alModel.prepareProjectModulesIfNecessary(ModuleStructuralMod el.java:241)
> at
> org.eclipse.wst.common.componentcore.internal.ModuleStructur alModel.getPrimaryRootObject(ModuleStructuralModel.java:115)
> at
> org.eclipse.wst.common.componentcore.internal.StructureEdit. getComponentModelRoot(StructureEdit.java:450)
> at
> org.eclipse.wst.common.componentcore.internal.StructureEdit. getWorkbenchModules(StructureEdit.java:486)
> at
> org.eclipse.wst.common.componentcore.internal.StructureEdit. getComponent(StructureEdit.java:929)
> at
> org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent.getReferences(VirtualComponent.java:273)
> at
> org.eclipse.jst.common.jdt.internal.classpath.FlexibleProjec tContainer.computeClasspathEntries(FlexibleProjectContainer. java:184)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.jdt.core 4 4 2008-04-08 11:04:48.027
> !MESSAGE Exception occurred in listener of Java element change notification
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.wst.common.modulecore 4 2 2008-04-08 11:04:48.452
> "org.eclipse.wst.common.modulecore".
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.internal.core.DeltaProcessor.fire(DeltaProce ssor.java:1349)
> at
> org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:761)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.02663 seconds
