Home » Language IDEs » Java Development Tools (JDT) » Eclipse 3.1 RC4(?), Opening javadoc, Hmmm...
Eclipse 3.1 RC4(?), Opening javadoc, Hmmm... [message #208108] |
Tue, 28 June 2005 08:45 |
Originally posted by: allkvist.yahoo.se
Opening the javadoc for (in this case) an interface, triggers a strange
behavior. Internet Explorer 6 (my default browser) seems to loop/recurse
idefinitly opening frame after frame, each with the requested javadoc-URL.
The javadoc was an URL I've attached to an external jar (basicplayer2.3.jar,
http://javazoom.net/jlgui/docs/docs2.3/index.html) in my project.
The exact URL of the requested interface is
http://javazoom.net/jlgui/docs/docs2.3/javazoom/jlgui/basicp layer/BasicPlayerListener.html.
Needless to say, the javadoc in itself looks OK; I can browse it manually...
Ingemar Allkvist
Platform: Windows XP SP2.
*** Date: Tue Jun 28 10:41:46 CEST 2005
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
catalina.base=/d:/Program/eclipse31/eclipse/plugins/org.ecli pse.tomcat_4.1.30.1/
catalina.home=/d:/Program/eclipse31/eclipse/plugins/org.ecli pse.tomcat_4.1.30.1/
catalina.useNaming=true
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20050624-1300
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
D:\Program\eclipse31\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
214_60
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1119946437171
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
D:\Program\eclipse31\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\Program\eclipse31\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program\Java\jre1.5.0_04\lib\endorsed
java.ext.dirs=C:\Program\Java\jre1.5.0_04\lib\ext
java.home=C:\Program\Java\jre1.5.0_04
java.io.tmpdir=C:\DOCUME~1\INGEMA~1\LOKALA~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;C:\Program\Delade
filer\Ulead Systems\MPEG;C:\Program\Microsoft Visual
Studio\Common\Tools\WinNT;C:\Program\Microsoft Visual
Studio\Common\MSDev98\Bin;C:\Program\Microsoft Visual
Studio\Common\Tools;C:\Program\Microsoft Visual
Studio\VC98\bin;C:\Program\Microsoft Visual Studio\Common\VSS\win32
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_04-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_04
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_04-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=sv
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=d:\Program\eclipse31\eclipse\configuration\ org.eclipse.osgi\bundles
osgi.configuration.area=file:/d:/Program/eclipse31/eclipse/c onfiguration/
osgi.framework=file:/d:/Program/eclipse31/eclipse/plugins/or g.eclipse.osgi_3.1.0.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.0.0
osgi.install.area=file:/d:/Program/eclipse31/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/Ingemar
Allkvist/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/Ingemar
Allkvist/workspace/
osgi.logfile=C:\Documents and Settings\Ingemar
Allkvist\workspace\.metadata\.log
osgi.manifest.cache=d:\Program\eclipse31\eclipse\configurati on\org.eclipse.osgi\manifests
osgi.nl=sv_SE
osgi.os=win32
osgi.splashLocation=d:\Program\eclipse31\eclipse\plugins\org .eclipse.platform_3.1.0\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\Program\eclipse31\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program\Java\jre1.5.0_04\lib\rt.jar;C :\Program\Java\jre1.5.0_04\lib\i18n.jar;C:\Program\Java\jre1 .5.0_04\lib\sunrsasign.jar;C:\Program\Java\jre1.5.0_04\lib\j sse.jar;C:\Program\Java\jre1.5.0_04\lib\jce.jar;C:\Program\J ava\jre1.5.0_04\lib\charsets.jar;C:\Program\Java\jre1.5.0_04 \classes
sun.boot.library.path=C:\Program\Java\jre1.5.0_04\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=SE
user.dir=D:\Program\eclipse31\eclipse
user.home=C:\Documents and Settings\Ingemar Allkvist
user.language=sv
user.name=Ingemar Allkvist
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.emf (2.1.0.I200506160200) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.1.0.I200506160200) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.examples (2.0.1) "Examples for Eclipse Modeling Framework
(EMF)"
org.eclipse.gef (3.1.0) "Graphical Editing Framework"
org.eclipse.gef.examples (3.0.1) "GEF Examples"
org.eclipse.gef.sdk (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0) "Java EMF Model Source"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.0) "Eclipse RCP"
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.ve (1.1.0) "Visual Editor"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
net.sourceforge.jode (1.0.4) "Jode Plug-in" [Active]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis11 (1.1.0) "Apache Axis 1.1 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.6.2) "pluginName" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.compare (3.1.0) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.0.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.activities (2.0.0) "EMF Activities" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit
Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
(EMF)" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.java (2.0.1) "EMF Java" [Resolved]
org.eclipse.emf.java.edit (2.0.0) "EMF Java Edit" [Resolved]
org.eclipse.emf.java.editor (2.0.1) "EMF Java Editor" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping Model"
[Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.0.1) "Graphical Editing Framework Documentation"
[Resolved]
org.eclipse.gef.examples.flow (3.0.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.0.0) "GEF Logic Editor Example" [Resolved]
org.eclipse.gef.examples.source (3.0.1) "GEF Examples" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Active]
org.eclipse.help.base (3.1.0) "Help System Base" [Active]
org.eclipse.help.ui (3.1.0) "Help System UI" [Active]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support"
[Active]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime
support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support"
[Active]
[Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0) "Java EMF Model BeanInfo (Introspection)
Support" [Active]
org.eclipse.jem.proxy (1.1.0) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0) "Java EMF Model Utilities" [Resolved]
org.eclipse.jem.workbench (1.1.0) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.jst.common.annotations.controller (1.0.0) "Annotation Controller
Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.0.0) "Annotation Core Plug-in"
[Resolved]
org.eclipse.jst.common.annotations.ui (1.0.0) "Ui Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.0.0) "Integration Plug-in" [Installed]
org.eclipse.jst.common.frameworks.ui (1.0.0) "WTP JDT Integration UI
org.eclipse.jst.common.launcher.ant (1.0.0) "Ant Launcher Plug-in"
[Resolved]
org.eclipse.jst.common.navigator.java (1.0.0) "Navigator Plug-in" [Resolved]
org.eclipse.jst.doc.isv (1.0.0) "WST ISV Documentation" [Resolved]
org.eclipse.jst.ejb.ui (1.0.0) "WTP EJB UI Plug-in" [Installed]
org.eclipse.jst.j2ee (1.0.0) "J2EE Component" [Installed]
org.eclipse.jst.j2ee.core (1.0.0) "J2EE Core Component" [Installed]
org.eclipse.jst.j2ee.ejb (1.0.0) "EJB component Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotation.model (1.0.0) "EJB Annotation Model
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.0.0) "EJB Emitter Plug-in"
[Installed]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.0.0) "EJB Annotations Ui Plug-in"
[Installed]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.0.0) "Xdoclet Annotations
org.eclipse.jst.j2ee.jca (1.0.0) "JCA Plug-in" [Installed]
org.eclipse.jst.j2ee.jca.ui (1.0.0) "WTP JCA UI Plug-in" [Installed]
org.eclipse.jst.j2ee.navigator.ui (1.0.0) "J2EE Extensions to Common
Navigator" [Installed]
org.eclipse.jst.j2ee.ui (1.0.0) "WTP J2EE UI Plug-in" [Installed]
org.eclipse.jst.j2ee.web (1.0.0) "Web Plug-in" [Installed]
org.eclipse.jst.j2ee.webservice (1.0.0) "Web Service Plug-in" [Installed]
org.eclipse.jst.j2ee.webservices.ui (1.0.0) "WTP Webservice UI Plug-in"
[Installed]
org.eclipse.jst.jsp.core (1.0.0) "Structured Source JSP Model" [Resolved]
org.eclipse.jst.jsp.ui (1.0.0) "SSE JSP Source Editor" [Resolved]
org.eclipse.jst.server.core (1.0.0) "Java Server Support" [Resolved]
org.eclipse.jst.server.generic.core (1.0.0) "Generic Server Plugin"
[Resolved]
org.eclipse.jst.server.generic.serverdefinitions (1.0.0) "Generic server
example definitions" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.0) "Generic Server Plugin UI"
[Resolved]
org.eclipse.jst.server.tomcat.core (1.0.0) "Apache Tomcat Support"
[Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.0) "Apache Tomcat UI Support"
[Resolved]
org.eclipse.jst.server.ui (1.0.0) "Java Server UI Support" [Resolved]
org.eclipse.jst.servlet.ui (1.0.0) "WTP Servlet UI Plug-in" [Installed]
org.eclipse.jst.source (1.0.0) "pluginName" [Resolved]
org.eclipse.jst.ws (1.0.0) "Web Services" [Installed]
org.eclipse.jst.ws.axis.consumption.core (1.0.0) "Web service Axis
Consumption Core" [Installed]
org.eclipse.jst.ws.axis.consumption.ui (1.0.0) "Webservice Axis Consumption
UI" [Installed]
org.eclipse.jst.ws.axis.creation.ui (1.0.0) "Webservice Axis Creation UI"
[Installed]
org.eclipse.jst.ws.consumption (1.0.0) "Web Services Consumption"
[Installed]
org.eclipse.jst.ws.consumption.ui (1.0.0) "Web Services Consumption
Graphical User Interface" [Installed]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0) "Web Services Creation EJB
org.eclipse.jst.ws.creation.ui (1.0.0) "Web Services Creation Graphical User
org.eclipse.jst.ws.uddiregistry (1.0.0) "Web Services Universal Description
Discovery and Integration Registry" [Installed]
org.eclipse.jst.ws.ui (1.0.0) "Web Services Graphical User Interface"
[Installed]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.0) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Resolved]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Active]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Resolved]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Resolved]
org.eclipse.ve (1.0.1) "Visual Editor" [Resolved]
org.eclipse.ve.cde (11.0.0) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.1.0) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.swt (1.1.0) "Visual Editor for Standard Widget Toolkit"
[Active]
org.eclipse.wst.command.env (1.0.0) "Environment Command Framework
(headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.0) "PLUGIN_NAME" [Resolved]
org.eclipse.wst.command.env.ui (1.0.0) "PLUGIN_NAME" [Resolved]
org.eclipse.wst.common.dependencychecker (1.0.0) "PLUGIN_NAME" [Resolved]
org.eclipse.wst.common.emf (1.0.0) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (1.0.0) "EMF Workbench Edit
org.eclipse.wst.common.frameworks (1.0.0)
"org.eclipse.wst.common.frameworks" [Resolved]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.migration (1.0.0) "Tacit Migration Engine Plug-in"
[Installed]
org.eclipse.wst.common.migration.ui (1.0.0) "Compatibility Engine Startup
Hook" [Installed]
org.eclipse.wst.common.modulecore (1.0.0) "Modulecore Plug-in" [Installed]
org.eclipse.wst.common.navigator.views (1.0.0) "Plugin.name" [Resolved]
org.eclipse.wst.common.navigator.workbench (1.0.0) "Navigator Workbench
Components" [Resolved]
org.eclipse.wst.common.snippets (1.0.0) "Snippets View" [Resolved]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI"
[Resolved]
org.eclipse.wst.common.uriresolver (1.0.0)
"org.eclipse.wst.common.uriresolver" [Resolved]
org.eclipse.wst.css.core (1.0.0) "Structured Source CSS Model" [Resolved]
org.eclipse.wst.css.ui (1.0.0) "SSE CSS Source Editor" [Resolved]
org.eclipse.wst.doc.isv (1.0.0) "WST ISV Documentation" [Resolved]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.dtd.validation (1.0.0) "DTD Validator" [Resolved]
org.eclipse.wst.html.core (1.0.0) "Structured Source HTML Model" [Resolved]
org.eclipse.wst.html.ui (1.0.0) "SSE HTML Source Editor" [Resolved]
org.eclipse.wst.internet.cache (1.0.0) "Cache URI Resolver Plug-in"
[Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (1.0.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.internet.webbrowser (1.0.0) "Web Browser" [Resolved]
org.eclipse.wst.javascript.core (1.0.0) "Structured Source JavaScript Model"
[Resolved]
org.eclipse.wst.javascript.ui (1.0.0) "SSE JavaScript Source Editor"
[Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (1.0.0) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.0) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.cloudscape (1.0.0) "IBM Cloudscape
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (1.0.0) "IBM Cloudscape Database
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0) "DBDefinition Informix
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0) "DBDefinition Oracle
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.0) "DBDefinition SQLServer
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.0) "DBDefinition Sybase
Plug-in" [Resolved]
org.eclipse.wst.rdb.derby (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (1.0.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (1.0.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (1.0.0) "OutputView Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.0) "SQL Source Editor Plug-in" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.0) "Server Core" [Resolved]
org.eclipse.wst.server.ui (1.0.0) "Server UI" [Resolved]
org.eclipse.wst.server.util (1.0.0) "Server Utilities" [Resolved]
org.eclipse.wst.source (1.0.0) "pluginName" [Resolved]
org.eclipse.wst.sse.core (1.0.0) "Structured Text Model" [Resolved]
org.eclipse.wst.sse.ui (1.0.0) "Structured Source Editor" [Resolved]
org.eclipse.wst.validation (1.0.0) "Validation Framework" [Resolved]
org.eclipse.wst.validation.ui (1.0.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (1.0.0) "Simple Web Plug-in" [Installed]
org.eclipse.wst.web.ui (1.0.0) "Simple Web UI Plug-in" [Installed]
org.eclipse.wst.ws (1.0.0) "PLUGIN_NAME" [Installed]
org.eclipse.wst.ws.explorer (1.0.0) "Web Services Explorer" [Installed]
org.eclipse.wst.ws.parser (1.0.0) "PLUGIN_NAME" [Installed]
org.eclipse.wst.ws.ui (1.0.0) "Web Services UI" [Installed]
org.eclipse.wst.wsdl (1.0.0) "WSDL Model" [Installed]
org.eclipse.wst.wsdl.ui (1.0.0) "WSDL Editor" [Installed]
org.eclipse.wst.wsdl.validation (1.0.0) "WSDL Validator" [Resolved]
org.eclipse.wst.wsi (1.0.0) "WSI Conformance Tools" [Installed]
org.eclipse.wst.wsi.ui (1.0.0) "Soap Monitor" [Installed]
org.eclipse.wst.xml.core (1.0.0) "Structured Source XML Model" [Resolved]
org.eclipse.wst.xml.ui (1.0.0) "SSE XML Source Editor" [Resolved]
org.eclipse.wst.xml.uriresolver (1.0.0) "pluginName" [Resolved]
org.eclipse.wst.xml.uriresolver.ui (1.0.0) "XML Catalog UI" [Resolved]
org.eclipse.wst.xml.validation (1.0.0) "XML Validator" [Resolved]
org.eclipse.wst.xsd.contentmodel (1.0.0) "Content Model for XML Schema"
[Installed]
org.eclipse.wst.xsd.ui (1.0.0) "XML Schema Editor" [Installed]
org.eclipse.wst.xsd.validation (1.0.0) "XML Schema Validator" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (1.0.0) "UDDI4J 2.0.3" [Resolved]
org.wsdl4j (1.0.0) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue Jun 28 10:41:46 CEST 2005
@org.eclipse.debug.ui=3.1.0
/project/Litet15/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.problem.enumIdentifier=error
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.lin ktoeditor=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_04"
path\="C\:\\Program\\Java\\jre1.5.0_04"/>\r\n</vmType>\r\n </vmSettings>\r\n
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="jpage"
name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="genmodel" name\="*">\r\n<editor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "/>\r\n</info>\r\n<info
extension\="html" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="override" name\="*">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="flow" name\="*">\r\n<editor id\="GEF Flow
Editor"/>\r\n<defaultEditor id\="GEF Flow Editor"/>\r\n</info>\r\n<info
extension\="ecore" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info
extension\="properties" name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="logic" name\="*">\r\n<editor id\="Logic Graphical
Editor"/>\r\n<defaultEditor id\="Logic Graphical
Editor"/>\r\n</info>\r\n<info extension\="ecore2xml" name\="*">\r\n<editor
id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n</info>\r\n<info
extension\="htm" name\="*">\r\n<editor
extension\="datagraph" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n </info>\r\n<info
extension\="xmi" name\="*">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info
extension\="jardesc" name\="*">\r\n<editor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="ecore2ecore" name\="*">\r\n<editor
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info
extension\="shtml" name\="*">\r\n<editor
extension\="java" name\="*">\r\n<editor
id\="org.eclipse.emf.java.presentation.JavaEditorID"/>\r\n </info>\r\n<info
extension\="class" name\="*">\r\n<editor
id\="jode.JodeClassFileEditor"/>\r\n<defaultEditor
id\="jode.JodeClassFileEditor"/>\r\n</info>\r\n<info extension\="emof"
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n</editors>
@org.eclipse.pde.core=3.1.0
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.swt.cat-Composite-org.eclipse .swt.widgets.Composite
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.ui.workbench/perspectives=Visual_Java
@org.eclipse.ui.browser=3.1.0
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.1.0
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.1.0
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=5
/instance/org.eclipse.help.ui/browser.x=207
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/project/Widgets/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.source=1.5
/instance/org.eclipse.pde.core/platform_path=d\:\\Program\\e clipse31\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.ui.workbench/Visual_Java_persp=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<perspective editorAreaVisible\="1" fixed\="0"
version\="0.016">\r\n<descriptor
descriptor\="org.eclipse.jdt.ui.JavaPerspective" id\="Visual_Java"
label\="Visual Java"/>\r\n<window height\="1032" width\="1288" x\="-4"
y\="-4"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.search.searchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet
id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.SourceView"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<show_view_action
id\="org.eclipse.search.ui.views.SearchView"/>\r\n<show_view_action
id\="org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<show_view_action
id\="org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action
id\="org.eclipse.pde.runtime.LogView"/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\r\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.file"/>\r\n<new_wizard_action
id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\r\n<perspective_action
id\="org.eclipse.jdt.ui.JavaPerspective"/>\r\n<perspective_action
id\="org.eclipse.debug.ui.DebugPerspective"/>\r\n<perspective_action
id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\r\n<view
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<view
id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<view
id\="org.eclipse.ui.views.ProblemView"/>\r\n<view
id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<view
id\="org.eclipse.jdt.ui.SourceView"/>\r\n<view
id\="org.eclipse.ui.console.ConsoleView"/>\r\n<view
id\="org.eclipse.ve.internal.java.codegen.editorpart.BeansList "/>\r\n<view
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<view
id\="org.eclipse.ui.views.PropertySheet"/>\r\n<layout>\r\n <mainWindow>\r\n<info
folder\="true" part\="left">\r\n<folder
activePageID\="org.eclipse.jdt.ui.PackageExplorer" appearance\="2"
expanded\="2">\r\n<page content\="org.eclipse.jdt.ui.PackageExplorer"
label\="Package Explorer"/>\r\n<page
content\="org.eclipse.jdt.ui.TypeHierarchy" label\="Hierarchy"/>\r\n<page
content\="org.eclipse.ui.views.ResourceNavigator"
label\="LabelNotFound"/>\r\n<page
content\="org.eclipse.jdt.junit.ResultView"
label\="LabelNotFound"/>\r\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part
id\="0"/>\r\n<part
id\="1"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true"
part\="org.eclipse.ui.internal.ViewStack@1ca6954" ratio\="0.7496063"
ratioLeft\="952" ratioRight\="318" relationship\="2"
relative\="left">\r\n<folder appearance\="2" expanded\="2">\r\n<page
content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\r\n<page
content\="org.eclipse.ui.internal.introview"
content\="org.eclipse.ui.cheatsheets.views.CheatSheetView"
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory "/>\r\n</folder>\r\n</info>\r\n<info
part\="org.eclipse.ui.editorss" ratio\="0.16416733" ratioLeft\="208"
ratioRight\="1059" relationship\="2" relative\="left"/>\r\n<info
folder\="true" part\="bottom" ratio\="0.8059211" ratioLeft\="735"
ratioRight\="177" relationship\="4"
relative\="org.eclipse.ui.editorss">\r\n<folder
activePageID\="org.eclipse.ve.internal.java.codegen.editorpart.BeansList "
content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\r\n<page
content\="org.eclipse.jdt.ui.JavadocView" label\="Javadoc"/>\r\n<page
content\="org.eclipse.jdt.ui.SourceView" label\="Declaration"/>\r\n<page
content\="org.eclipse.search.ui.views.SearchView"
content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\r\n<page
content\="org.eclipse.ui.views.BookmarkView"
content\="org.eclipse.ui.views.ProgressView"
content\="org.eclipse.ve.internal.java.codegen.editorpart.BeansList "
label\="Java Beans"/>\r\n<presentation
id\="0"/>\r\n<part id\="1"/>\r\n<part id\="2"/>\r\n<part id\="3"/>\r\n<part
id\="4"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info
part\="org.eclipse.ant.ui.views.AntView" ratio\="0.5" ratioLeft\="531"
ratioRight\="531" relationship\="2" relative\="bottom"/>\r\n<info
folder\="true" part\="org.eclipse.ui.internal.ViewStack@802ed1" ratio\="0.5"
ratioLeft\="531" ratioRight\="531" relationship\="2"
relative\="bottom">\r\n<folder
activePageID\="org.eclipse.ui.views.PropertySheet" appearance\="2"
expanded\="2">\r\n<page content\="org.eclipse.ui.views.PropertySheet"
label\="Properties"/>\r\n<presentation
id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true"
part\="org.eclipse.ui.internal.ViewStack@1397663" ratio\="0.7495292"
ratioLeft\="796" ratioRight\="266" relationship\="2"
activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2"
expanded\="2">\r\n<page content\="org.eclipse.ui.views.ContentOutline"
label\="Outline"/>\r\n<presentation
id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n </mainWindow>\r\n</layout>\r\n</perspective>
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/project/Litet15/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.codegen.targetPlatform=1.5
@org.eclipse.ui.workbench=3.1.0
@org.eclipse.ve.java.core=1.1.0
file_export_version=3.0
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.help.ui/browser.h=969
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.wiz ards.buildpaths.NewSourceContainerPage.openSetting=false
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=169
@org.eclipse.wst.sse.ui=1.0.0
/instance/org.eclipse.ui.ide/platformState=396
/project/Widgets/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.compliance=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.SWT_WIN32=D\:/Program/eclipse31/eclipse/lib/win32_ x86
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.ve.java.core/PALETTE_STATE=4
@org.eclipse.ui.editors=3.1.0
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and
Settings\\Ingemar Allkvist\\workspace
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=d\:/Program/eclipse31/eclipse/plugins/o rg.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program/Java/jre1.5.0_04/lib/rt.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/project/Litet15/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.compliance=1.5
@org.eclipse.jdt.core=3.1.0
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/project/Widgets/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.problem.assertIdentifier=error
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_p erspective_on_suspend=always
/instance/org.eclipse.ui.ide/tipsAndTricks=true
@org.eclipse.jdt.debug.ui=3.1.0
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n</web-browsers>
/instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor
class\=" org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetE ditor "
image\="icons/full/obj16/jsbook_obj.gif" internal\="true" label\="Scrapbook"
openMode\="1" open_in_place\="false"
plugin\="org.eclipse.jdt.debug.ui"/>\r\n<descriptor
class\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor "
image\="icons/full/obj16/GenModelModelFile.gif" internal\="true" label\="EMF
Generator" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.emf.codegen.ecore.ui"/>\r\n<descriptor
image\="icons/obj16/internal_browser.gif" internal\="false" label\="Web
Browser" launcher\="org.eclipse.ui.internal.browser.BrowserLauncher"
openMode\="4" open_in_place\="false"
plugin\="org.eclipse.ui.browser"/>\r\n<descriptor
class\=" org.eclipse.ui.editors/org.eclipse.ui.editors.text.TextEdito r "
image\="icons/full/obj16/file_obj.gif" internal\="true" label\="Override
Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.jem.ui"/>\r\n<descriptor
class\="org.eclipse.gef.examples.flow.ui.FlowEditor" id\="GEF Flow Editor"
image\="view.gif" internal\="true" label\="GEF Flow Example" openMode\="1"
plugin\="org.eclipse.gef.examples.flow"/>\r\n<descriptor
class\="org.eclipse.emf.ecore.presentation.EcoreEditor"
image\="icons/full/obj16/EcoreModelFile.gif" internal\="true" label\="Sample
Ecore Model Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.emf.ecore.editor"/>\r\n<descriptor
class\="org.eclipse.pde.ui.internal.samples.SampleEditor"
id\="org.eclipse.pde.ui.sampleEditor" image\="icons/obj16/build_exec.gif"
internal\="true" label\="Code Sample Editor" openMode\="1"
open_in_place\="false" plugin\="org.eclipse.pde.ui"/>\r\n<descriptor
class\="org.eclipse.gef.examples.logicdesigner.LogicEditor" id\="Logic
Graphical Editor" image\="logic.gif" internal\="true" label\="Logic
Graphical Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.gef.examples.logic"/>\r\n<descriptor
class\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit or "
image\="icons/full/obj16/Ecore2XMLModelFile.gif" internal\="true"
label\="Ecore2XML Model Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.emf.mapping.ecore2xml.ui"/>\r\n<descriptor
class\="org.eclipse.emf.ecore.sdo.presentation.SDOEditor"
image\="icons/full/obj16/SDOModelFile.gif" internal\="true" label\="Data
Graph Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.emf.ecore.sdo.editor"/>\r\n<descriptor
image\=" platform\:/plugin/org.eclipse.emf.edit/icons/full/obj16/Mode lFile.gif "
internal\="true" label\="Sample Reflective Ecore Model Editor" openMode\="1"
class\="org.eclipse.ui.editors.text.TextEditor"
image\="icons/full/obj16/jar_desc_obj.gif" internal\="true" label\="JAR
Description Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.jdt.ui"/>\r\n<descriptor
class\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore Editor "
image\="icons/full/obj16/Ecore2EcoreModelFile.gif" internal\="true"
label\="Ecore to Ecore Mapping Editor" openMode\="1" open_in_place\="false"
plugin\="org.eclipse.emf.mapping.ecore2ecore.editor"/>\r\n <descriptor
class\="org.eclipse.emf.java.presentation.JavaEditor"
image\="icons/full/obj16/JavaModelFile.gif" internal\="true" label\="Java
plugin\="org.eclipse.emf.java.editor"/>\r\n<descriptor
class\="net.sourceforge.jode.JodeClassFileEditor"
id\="jode.JodeClassFileEditor" image\="icons/jcu_obj.gif" internal\="true"
label\="Jode Class File Viewer" openMode\="1" open_in_place\="false"
plugin\="net.sourceforge.jode"/>\r\n</editors>
/project/Widgets/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.problem.enumIdentifier=error
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_ TAB=1
/instance/org.eclipse.jdt.ui/LexicalSortingAction.isChecked= true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_C REATION=always
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/project/Litet15/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.problem.assertIdentifier=error
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
/project/Litet15/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.source=1.5
@org.eclipse.help.ui=3.1.0
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/project/Widgets/org.eclipse.jdt.core/org.eclipse.jdt.core.c ompiler.codegen.targetPlatform=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=d\:/Program/eclipse31/eclipse
@org.eclipse.ui=3.1.0
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates><template autoinsert\="false"
context\="constructorcomment_context" deleted\="false" description\="Comment
for created constructors" enabled\="true"
id\="org.eclipse.jdt.ui.text.codetemplates.constructorcomment "
name\="constructorcomment">/**\r\n * Constructor\r\n * ${tags}\r\n
*/</template><template autoinsert\="false" context\="methodcomment_context"
deleted\="false" description\="Comment for non-overriding methods"
enabled\="true" id\="org.eclipse.jdt.ui.text.codetemplates.methodcomment"
name\="methodcomment">/**\r\n * Method ${enclosing_method}\r\n * ${tags}\r\n
*/</template></templates>
*** Current Install Configuration:
Install configuration:
Last changed on 2005-jun-27
file:/d:/
Current Time: Fri Apr 26 21:16:09 GMT 2024
Powered by FUDForum. Page generated in 0.02853 seconds
