Re: Programmatically do XML Catalog contributions in WST [message #204685 is a reply to message #204473] |
Mon, 19 November 2007 08:32 |
Anders Olsson Messages: 21 Registered: July 2009 |
Junior Member |
Thank you for your reply, Lawrence.
I've tried implementing this solution in my plug-in, but I've ran into
some problems.
What I've done is that I've added an extension:
<extension
point="org.eclipse.wst.common.uriresolver.resolverExtensions ">
<resolverExtension
class="schemaSetter.ResolverExtension1">
</resolverExtension>
</extension>
in my plug-in.
The schemaSetter.ResolverExtension1 class is very simple, and implements
org.eclipse.wst.common.uriresolver.internal.provisional.URIR esolver
in both the resolve and resolvePhysicalLocation methods I simply return a
URI string without checking the input arguments.
I would paste the code, but so far that's not where the problem lies. I
ran in debugging mode with break points in both the methods, and they were
never visited. What I tried to do is to validate an XML file, but all I
get is an error about <the original URI> not being found.
Is there something I've missed? Is there something more that needs to be
done to use this resource?
/Anders
lmandel@ca.ibm.com wrote:
> Hi Anders,
> If your contributed DTDs don't need to be viewable in the XML catalog you
> can create a custom URI resolver [1].
> [1]
http://help.eclipse.org/help31/topic/org.eclipse.wst.doc.isv /reference/extension-points/common/org_eclipse_wst_common_ur iresolver_resolverExtensions.html
> Lawrence
>>Hello!
>>I have a need for adding DTDs to the XML Catalog in WST. I cannot use the
>>org.eclipse.est.xml.core.catalogContributions Extension Point, since the
>>location of the DTDs might be different every startup (or on different
>>machines).
>>I've been looking at the internal classes in
>>org.eclipse.wst.xml.core.internal and .catalog to little avail. I've
>>managed to do:
>>XMLCorePlugin xmlPlug =
>> org.eclipse.wst.xml.core.internal.XMLCorePlugin.getDefault() ;
>>Catalog defaultXMLCatalog = (Catalog) xmlPlug.getDefaultXMLCatalog();
>>What I then should do is a bit unclear. I want to do is add entries one
> by
>>one. So I think the class I should instance and insert is CatalogEntry.
>>Problem is only it has it's constructor set as protected.
>>What I would of course want is a public API for XML Catalog
> contributions.
>>But for now I'm content with using the internals. Could someone tell me
> if
>>my approach makes sense, and where I've diverted from the correct path.
> It
>>cannot be the case that this is currently impossible.
>>Thanks in advance for any replies.
>>Best Regards,
>>Anders Olsson
FUDForum. Page generated in 0.03733 seconds
