Re: Hybrid jars [message #1234094 is a reply to message #1234085] |
Tue, 21 January 2014 08:18 |
Lior Giller Messages: 14 Registered: January 2014 |
Junior Member |
Hey Tom,
Thank you for the reply,
first i have changed the "Toolkit Type" == swing. it did not helped. the jar is still 300k, and i still get the
Process manager already initialized: can't fully enable headless mode.
java.lang.reflect.InvocationTargetException
for you second question, I'm not repackaging libs, I am exporting all the java sources and resources, than compress the jar.
exception when running. from Jar, when running from the e(fx)clipse all is still ok.
i wrote a new project just so i can find the issue since my project is very large,
i rewrote just the basics, something like a simple javafx project with a system tray app.
again, works well on the e(fx)clipse, but not as jar (except I don't get an error, the jar just doesn't do anything).
As I said before, my app is really big, and working well from the eclipse, so there must be something i'm doing wrong while packaging right?
I would hate to re do this whole thing just cause i cant get a proper jar
ill appreciate any idea at this moment!!!
Thanks!
Re: Hybrid jars [message #1234102 is a reply to message #1234094] |
Tue, 21 January 2014 08:38 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
IIRC the export is not packaging the libraries directly into the JAR but
adds a MANIFEST.MF-Entry pointing to them, not?
I'd need something to test to see what's broken. In the end all our
build is doing is to write the build.xml and execute it. You can take a
look at the build.xml and fix things manually?
Tom
On 21.01.14 09:18, Lior Giller wrote:
> Hey Tom,
> jar is still 300k, and i still get the Process manager already
> is still ok.
> very large, i rewrote just the basics, something like a simple javafx
> project with a system tray app. again, works well on the e(fx)clipse,
> anything).
> jar :(
> Thanks!
Re: Hybrid jars [message #1234173 is a reply to message #1234129] |
Tue, 21 January 2014 11:54 |
Junior Member |
I have some progress which might help understand the issue better.
i realised (and maybe it was obvious but i missed it( that fro running from e(fx)clipse, i use "main" method., but if i want my jar to work, i need to use "start" method.
i manages to get my simple system tray app working by copying my "main" code into the start, but from eclipse its stopped cause i have to have main.
thats why i fail running as javafx jars, as it searches for the start method.
also, on my mac, when i'm running from main all is ok, but same code running from start i get different result for
if (!SystemTray.isSupported()) {
System.out.println("SystemTray is not supported");
return;
running from eclipse- its supported, running from jar its not.
Does that make any sense to you?
Lior
Re: Hybrid jars [message #1234191 is a reply to message #1234173] |
Tue, 21 January 2014 12:41 |
If you look at the MANIFEST.MF generated? Does it hold the special
JavaFX-Launcher as the main-class?
If I remember correct JavaFX-Launcher does not call main but directly
bootstraps the application class and calls the start method.
What makes me wonder a bit because you said you have a Swing application!
Tom
> need to use "start" method. i manages to get my simple system tray app
> method. also, on my mac, when i'm running from main all is ok, but same
> code running from start i get different result for if
> return;
> Lior
FUDForum. Page generated in 0.04974 seconds
